第一步:新建一个qt C++项目
在此需要注意,名称和路径不能有中文。
第二步:添加控件完成UI布局
IC读写器读写IC卡数据块
第三步:开始写代码
使设备发出滴滴响声
#define BLOCK0_EN 0x01 #define BLOCK1_EN 0x02 #define BLOCK2_EN 0x04 #define NEEDSERIAL 0x08 #define EXTERNKEY 0x10 #define NEEDHALT 0x20 //#define NEEDSERIAL 0x08 #define EXTERNKEY 0x10 //让读写器发出声音 typedef unsigned char (*pcdbeep)(unsigned long xms); //返回本读写器独一无二的设备编号 typedef unsigned char (*pcdgetdevicenumber)(unsigned long devicenumber); //轻松读卡 typedef unsigned char (*piccreadex)(unsigned char ctrlword,unsigned char *serial,unsigned char area,unsigned char keyA1B0,unsigned char *picckey,unsigned char *piccdata0_2); //轻松写卡 typedef unsigned char (*piccwriteex)(unsigned char ctrlword,unsigned char *serial,unsigned char area, unsigned char keyA1B0,unsigned char *picckey,unsigned char *piccdata0_2); //改单区密码 typedef unsigned char (*piccchangesinglekeyex)(unsigned char ctrlword,unsigned char *serial,unsigned char area,unsigned char keyA1B0,unsigned char *piccoldkey,unsigned char *piccdata); //读出一块的数据,也就是16个字节 typedef unsigned char (*piccread)(unsigned char block,unsigned char *piccdata); //检测输入数据是否为16进制数 static bool checkinput(QString inputstr){ QString inputyes="0123456789abcdefABCDEF"; for(int i=0;i< inputstr.length();i++){ if(inputyes.contains(inputstr.mid(i,1),Qt::CaseSensitive)){ }else{return false;} } return true; } MainWindow::MainWindow(QWidget *parent) : QMainWindow(parent) , ui(new Ui::MainWindow) { ui- >setupUi(this); } MainWindow::~MainWindow() { delete ui; } void MainWindow::on_pushButton_4_clicked()//让设备发出声响 { unsigned char result; QLibrary mylib("OUR_MIFARE.dll"); if (!mylib.load()) //判断是否正确加载 { QMessageBox::information(NULL, "提示", "动态库没装载!原因是动态库OUR_MIFARE.dll没放在生成exe文件相同目录下!"); return; } pcdbeep mypcdbeep = (pcdbeep)mylib.resolve("pcdbeep"); if (mypcdbeep == NULL) //是否成功连接上 idr_beep()函数 { mylib.unload(); QMessageBox::information(NULL, "提示", "请检查函数名是否正确!"); return; } result = mypcdbeep(30); //这里函数指针调用dll中的idr_beep() 函数 mylib.unload(); if(result > 0) { if(result == 23) { QMessageBox::information(NULL, "提示", "机器没连上或者驱动没下载"); } else { QMessageBox::information(NULL, "提示", "错误代码:" + QString::number(result)); }; } //qDebug()<
读卡功能
void MainWindow::on_pushButton_3_clicked()//轻松读卡 { unsigned char ctrlword;//控制字 unsigned char serial[4];//可写数组 unsigned char area;//读出的区号 unsigned char keyA1B0;//AB密码认证 unsigned char picckey[6];//存放卡密码的数组 unsigned char piccdata0_2[48];//下标0~15存放作为读出的块0的数据,下标16~31存放作为读出的块1的数据,下标32~47存放作为读出的块2的数据 unsigned char status;//返回 unsigned char status1; unsigned char result; QString piccdata[16]; //卡数据缓冲 //unsigned char myareano = ui->lineEdit_5 ; '指定为第8区 //以下控制字含义:读块0、块1、块2,仅读指定序列号的卡,需要每次指定密码 if (ui->radioButton->isChecked()) { ctrlword = BLOCK0_EN + BLOCK1_EN + BLOCK2_EN + EXTERNKEY; } else {//内部密码 ctrlword = BLOCK0_EN + BLOCK1_EN + BLOCK2_EN; } area = ui->comboBox->currentText().toUShort(); keyA1B0 = 1;//用A密码 //qDebug()< lineEdit- >text().mid(0,2); //qDebug()< lineEdit- >text().mid(2,2); // qDebug()< lineEdit- >text().mid(2,2); // qDebug()< lineEdit- >text().mid(2,2); QString Key_str = ui->lineEdit->text().trimmed(); if(Key_str.length() < 12) { QMessageBox::information(NULL, "提示", "密码长度不够12位!"); ui- >lineEdit->setFocus(); return; } char c; for (int var = 0; var < 12; ++var) { c = Key_str.at(var).toLatin1(); if(!((('0' <= c) && (c <= '9')) || (('A' <= c) && (c <= 'F')) || (('a' <= c) && (c <= 'f')))) { QMessageBox::information(NULL, "提示", "密码输入字符不正确!"); //ui- >lineEdit->setSelection(var,1); ui->lineEdit->setSelection(var,1); ui->lineEdit->setFocus(); return; } } bool ok; // picckey[0]=(unsigned char)(Key_str.mid(0,2).toUShort(nullptr,16)); // picckey[1] = Key_str.mid(2,2).toShort(); // picckey[2] = Key_str.mid(4,2).toShort(); // picckey[3] = Key_str.mid(6,2).toShort(); // picckey[4] = Key_str.mid(8,2).toShort(); // picckey[5] = Key_str.mid(10,2).toShort(); for(int i = 0; i < 6; i++) { picckey[i]=QString(Key_str.mid(i*2,2)).toInt(&ok,16); } QLibrary mylib("OUR_MIFARE.dll"); if (!mylib.load()) //判断是否正确加载 { QMessageBox::information(NULL, "提示", "动态库没装载!原因是动态库OUR_MIFARE.dll没放在生成exe文件相同目录下!"); return; } piccreadex mypiccreadex = (piccreadex)mylib.resolve("piccreadex"); status = mypiccreadex(ctrlword,serial,area,keyA1B0,picckey,piccdata0_2); if(status == 0) { //qDebug()< lineEdit_5- >setText(QString::asprintf("%02X %02X %02X %02X %02X %02X %02X %02X %02X %02X",picckey[0],picckey[1],picckey[2],picckey[3],picckey[4],picckey[5],picckey[6],serial[1],serial[2],serial[3])); ui->lineEdit_2->setText(QString::asprintf("%02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X ",piccdata0_2[0],piccdata0_2[1],piccdata0_2[2],piccdata0_2[3],piccdata0_2[4],piccdata0_2[5],piccdata0_2[6],piccdata0_2[7],piccdata0_2[8],piccdata0_2[9],piccdata0_2[10],piccdata0_2[11],piccdata0_2[12],piccdata0_2[13],piccdata0_2[14],piccdata0_2[15])); ui->lineEdit_3->setText(QString::asprintf("%02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X ",piccdata0_2[16],piccdata0_2[17],piccdata0_2[18],piccdata0_2[19],piccdata0_2[20],piccdata0_2[21],piccdata0_2[22],piccdata0_2[23],piccdata0_2[24],piccdata0_2[25],piccdata0_2[26],piccdata0_2[27],piccdata0_2[28],piccdata0_2[29],piccdata0_2[30],piccdata0_2[31])); ui->lineEdit_4->setText(QString::asprintf("%02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X %02X ",piccdata0_2[32],piccdata0_2[33],piccdata0_2[34],piccdata0_2[35],piccdata0_2[36],piccdata0_2[37],piccdata0_2[38],piccdata0_2[39],piccdata0_2[40],piccdata0_2[41],piccdata0_2[42],piccdata0_2[43],piccdata0_2[44],piccdata0_2[45],piccdata0_2[46],piccdata0_2[47])); piccread mypiccread = (piccread)mylib.resolve("piccread"); //typedef unsigned char (*piccread)(unsigned char block,unsigned char *piccdata); status1 = piccread(area * 4 + 3,piccdata); pcdbeep mypcdbeep = (pcdbeep)mylib.resolve("pcdbeep"); if (mypcdbeep == NULL) //是否成功连接上 idr_beep()函数 { mylib.unload(); QMessageBox::information(NULL, "提示", "请检查函数名是否正确!"); return; } result = mypcdbeep(30); //这里函数指针调用dll中的idr_beep() 函数 mylib.unload(); } else if(status == 8) { ui->lineEdit_2->clear(); ui->lineEdit_3->clear(); ui->lineEdit_4->clear(); QMessageBox::information(NULL, "提示", "寻卡错误,根本就没有卡在感应区"); } else if(status == 12) { ui->lineEdit_2->clear(); ui->lineEdit_3->clear(); ui->lineEdit_4->clear(); QMessageBox::information(NULL, "提示", "密码认证失败"); } //qDebug()< 审核编辑 黄宇
举报投诉
IC
36文章
6012浏览量
176905 -
读写器
3文章
678浏览量
39080 -
C++
22文章
2114浏览量
74125
RFID读写器哪种性价比高?RFID读写器哪家做的比较好
在探讨RFID读写器性价比及品牌优劣时,我们不得不将目光聚焦于行业内的佼佼者,远望谷与远景达无疑是两颗璀璨的明星。这两家企业不仅在国内RFID及物联网领域享有盛誉,更以其卓越的技术实力、丰富的产品线
制鞋线体去毛刺工艺段现场RFID读写器进行数据传输应用
在制鞋厂的去毛刺工艺段,RFID标签被固定在鞋子上,读写器则安装在生产线上。当鞋子经过读写器时,读写器会迅速读取标签中的信息,并将数据传输给管理系统。
基于QT开发国产主板终端桌面程序 高效、稳定、跨平台的解决方案
了开发者们面临的一个重要挑战。本文将介绍如何基于QT框架,开发适用于国产主板的终端桌面程序,并探讨其优势和应用场景。 QT是一个跨平台的
USB免驱全协议IC卡读写器 QT程序开发
读取15693卡,IC读卡器如下入所示: 15693卡片,通常指的是符合ISO/IEC 15693标准的非接触式智能卡或RFID卡。以下是对15693卡片的详细介绍: 一、基本概述 15693
手持式RFID读写器可以当pda手持终端用吗
随着科技的不断进步,手持式RFID读写器作为一种新兴的便携式读写器,逐渐在各行各业中发挥着重要作用。而在很多场景下,手持式RFID读写器是否能替代传统的PDA(数据采集终端)手持终端也成为了一个备受
超高频读写器究竟是什么,能做什么?一文读懂!
在物联网技术日新月异的今天,超高频读写器作为射频识别(RFID)技术的重要组成部分,正逐渐渗透到我们生活的各个领域。那么,超高频读写器究竟是什么?它又能做些什么呢?本文将带您一探究竟。一、超高频
巴鲁夫rfid读头国产平替版——高频RFID读写器
随着RFID技术的不断发展,国内RFID企业的数量也在不断地变多,国产RFID读写器的质量也越来越高。具有着价格实惠、质量可靠等特点,成为了可平替国外RFID产品的首要选择。健永科技的高频RFID读写器JY-H830,是一款可平替巴鲁夫rfid读头的国产RFID
RFID读写器选择指南:专家解答您的疑惑
一芯未来在这些普通的RFID读写器基础上,自主研发、生产、销售的超高频 RFID国军标读写器,外观小巧,结构坚固可靠,采用防水、防震及宽温度适应范围设计。在军事领域具有更广泛的应用前景和潜力,为部队提供了高效、可靠的物资和人员管理解决方案。
在嵌入式系统中集成Rust和Qt的实践
Rust 拥有丰富的库生态系统,用于序列化和反序列化、异步操作、解析不安全输入、线程、静态分析等,而 Qt 是一个 C++ 工具包,支持跨各种平台的丰富的、基于 GUI 的应用程序,从 iOS 到嵌入式Linux。
发表于 05-03 10:26
•1975次阅读
超高频桌面读写器功能介绍,为什么要用超高频RFID读写器?
超高频桌面读写器是一种无线射频识别(RFID)设备。作为一种高效、准确的自动识别技术,它可以实现对远距离范围内的RFID标签进行高效读写,无需接触或靠近标签,这种超高频RFID读写器广泛应用于物流
