先查看当前内核版本
~]#uname -a
Linux localhost.localdomain 3.10.0-1160.el7.x86_64 #1 SMP Mon Oct 19 1659 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
查看系统grub内核启动列表
~]# awk -F' '$1=="menuentry " {print i++ " : " $2}' /etc/grub2.cfg
0 : CentOS Linux (3.10.0-1160.el7.x86_64) 7 (Core)
1 : CentOS Linux (0-rescue-9c44fe6cef3746b2b96d834164eb6b07) 7 (Core)
安装epel源
~]#rpm --import https://www.elrepo.org/RPM-GPG-KEY-elrepo.org
~]#yum install -y https://www.elrepo.org/elrepo-release-7.el7.elrepo.noarch.rpm
查看可安装的内核版本列表
~]# yum --disablerepo="*" --enablerepo="elrepo-kernel" list available
已加载插件:fastestmirror
Loading mirror speeds from cached hostfile
* elrepo-kernel: ftp.yz.yamagata-u.ac.jp
elrepo-kernel | 3.0 kB 0000
elrepo-kernel/primary_db | 2.1 MB 0002
可安装的软件包
kernel-lt.x86_64 5.4.270-1.el7.elrepo elrepo-kernel
kernel-lt-devel.x86_64 5.4.270-1.el7.elrepo elrepo-kernel
kernel-lt-doc.noarch 5.4.270-1.el7.elrepo elrepo-kernel
kernel-lt-headers.x86_64 5.4.270-1.el7.elrepo elrepo-kernel
kernel-lt-tools.x86_64 5.4.270-1.el7.elrepo elrepo-kernel
kernel-lt-tools-libs.x86_64 5.4.270-1.el7.elrepo elrepo-kernel
kernel-lt-tools-libs-devel.x86_64 5.4.270-1.el7.elrepo elrepo-kernel
kernel-ml.x86_64 6.7.8-1.el7.elrepo elrepo-kernel
kernel-ml-devel.x86_64 6.7.8-1.el7.elrepo elrepo-kernel
kernel-ml-doc.noarch 6.7.8-1.el7.elrepo elrepo-kernel
kernel-ml-headers.x86_64 6.7.8-1.el7.elrepo elrepo-kernel
kernel-ml-tools.x86_64 6.7.8-1.el7.elrepo elrepo-kernel
kernel-ml-tools-libs.x86_64 6.7.8-1.el7.elrepo elrepo-kernel
kernel-ml-tools-libs-devel.x86_64 6.7.8-1.el7.elrepo elrepo-kernel
perf.x86_64 5.4.270-1.el7.elrepo elrepo-kernel
python-perf.x86_64 5.4.270-1.el7.elrepo elrepo-kernel
安装最新的lt稳定版内核
~]#yum --disablerepo='*' --enablerepo=elrepo-kernel install kernel-lt -y
查看系统grub内核启动列表,5.4版本使我们最新安装的
0 : CentOS Linux (5.4.270-1.el7.elrepo.x86_64) 7 (Core)
1 : CentOS Linux (3.10.0-1160.el7.x86_64) 7 (Core)
2 : CentOS Linux (0-rescue-9c44fe6cef3746b2b96d834164eb6b07) 7 (Core)
指定以新安装的编号0的内核版本为默认启动内核
~]# grub2-set-default 0
卸载旧内核版本
~]# yum remove kernel -y
已加载插件:fastestmirror
跳过正在运行的内核:kernel-3.10.0-1160.el7.x86_64s
不删除任何软件包
重启机器,以新内核版本加载启动
~]#reboot
重启完成后再次查看内核版本,已经升级为最新的5.4版本
~]# uname -a
Linux localhost.localdomain 5.4.270-1.el7.elrepo.x86_64 #1 SMP Fri Mar 1 1736 EST 2024 x86_64 x86_64 x86_64 GNU/Linux
举报投诉
内核
4文章
1479浏览量
43141 -
CentOS
85浏览量
14853
原文标题:升级centos7内核版本
文章出处:【微信号:magedu-Linux,微信公众号:马哥Linux运维】欢迎添加关注!文章转载请注明出处。
热点推荐
ATT7026C:ATT7026A升级版本的技术解析
ATT7026C:ATT7026A升级版本的技术解析 在电子设计领域,芯片的性能和功能升级对于提高产品的质量和竞争力至关重要。今天我们要探讨的ATT7026C,就是钜泉光电科技(上海)有限公司推出
迅为电子RK系列开发板SDK内核正式升级至6.1 LTS版本
迅为RK3568、RK3588、RK3576、RK3562系列开发板,SDK内核从5.10版本正式升级至6.1 LTS版本。
开源鸿蒙6.1 Release版本正式发布,在鸿OS 6.1率先完成升级适配!
3月8日,开源鸿蒙6.1Release版本正式发布!作为新一代版本,6.1在应用开发能力、系统体验、多媒体与安全等领域带来全面升级,为生态商用落地注入全新动能。作为开放原子开源基金会黄金捐赠人、开源
如何在 S32G3 上的 M7 和 A53 内核之间建立 IPCF 通信?
我正在使用内核版本 6.6.52 的 Yocto。以下是我为 IPCF 集成计划的步骤:
- 从 IPCF 构建站点构建 IPCF_m7_0 示例程序,将其加载到 M7 的 SRA
发表于 03-05 07:28
【工具升级】 I OrCAD X 全版本新功能汇总,高效搞定电路协同设计
在电子电路设计领域,一款功能强大、适配协同工作的工具,能大幅提升设计效率与精准度。OrCADX系列版本更新,围绕协作、易用性、仿真分析三大核心,为个人及小型设计团队带来全方位的功能升级。以下
软件更新 | TSMaster 7-8月新功能来了!你升级了吗?
为持续赋能汽车电子研发,TSMaster在2025年夏季再度升级。TSMaster软件7-8月版本重磅推出了安全管理功能增强、IOAPI优化,并正式释放了RPC/IP与EthernetPDURBS
解决博途新旧版本项目兼容问题:升级操作与风险提示
升级(转换)。 TIA Portal 项目通常支持向上兼容,例如 V15 能打开 V13 SP1 创建的项目。但需注意版本跨度带来的限制。 当你尝试在 V17 中打开一个 V15 或更早版本(如
CentOS 7下MySQL 8双主热备高可用架构全解
Centos7部署MySQL8+keepalived双主热备(含Keepalived配置与GTID同步优化方案) 架构拓扑原理 GTID同步 VIP 192.168.1.100 MySQL主节点1
涂鸦OmniAI Foundation 2.2版本正式发布:AI智能体全面升级,响应速度迅猛提高40%
7月17日,涂鸦OmniAIFoundation正式升级至2.2版本!本次迭代的核心亮点,在于我们对AI智能体技能进行了全面升级,显著提升了系统在内容理解、多技能协同以及泛化沟通方面的
VA One 2024版本的关键升级
自 2005 年发布以来,VA One 已广泛应用于汽车、航空航天、船舶等多个行业领域。VA One 开发团队每年都会对软件进行功能迭代与优化,目前最新版本为 VA One 2024。与以往版本
详解蓝牙空中升级(OTA)原理与步骤
://pan.baidu.com/s/1FKTfY3Q_zBVvviO7KC7Gyg#list/path=%2Fblog 密码: y8fb 脚本是按照SDK版本进行分类的,建议大家把自己SDK版本对应的脚本下载下
Centos7分用户记录历史命令至日志文件教程
在企业级Linux运维中,实时记录用户操作历史是审计排查的关键步骤。本文华纳云针对CentOS7系统,提供三种高效方案实现分用户日志记录+防篡改管理。所有步骤均经过实际验证,代码段内含执行逻辑剖析。
升级centos7内核版本
