Apache Flink 是一个分布式大数据计算引擎,专为处理无界和有界数据流上的有状态计算而设计,以其高吞吐量、低延迟和高性能在实时流处理和批量计算领域脱颖而出,Flink 支持批流一体化,即能够同时处理实时数据流和静态数据集,使得数据处理更加灵活高效
华为云端口放行
•服务器放行对应端口 8082
Docker 安装并配置镜像加速
1、购买华为云 Flexus X 实例
Flexus云服务器X实例-华为云 (huaweicloud.com)
2、docker 安装
yuminstall -ydocker-ce
3、验证 Docker 是否安装成功,启动 docker 服务并设置开机自启动,且查看 docker 状态
docker --versionsystemctl enable dockersystemctl start dockersystemctl status docker
4、docker-ce 下载
wget-O/etc/yum.repos.d/docker-ce.repo https://mirrors.huaweicloud.com/docker-ce/linux/centos/docker-ce.repo
5、路径/etc/yum.repos.d 修改配置文件
[docker-ce-stable]name=Docker CEStable -$basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/$basearch/stableenabled=1gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-stable-debuginfo]name=Docker CEStable -Debuginfo $basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/debug-$basearch/stableenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-stable-source]name=Docker CEStable -Sourcesbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/source/stableenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-test]name=Docker CETest -$basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/$basearch/testenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-test-debuginfo]name=Docker CETest -Debuginfo $basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/debug-$basearch/testenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-test-source]name=Docker CETest -Sourcesbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/source/testenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-nightly]name=Docker CENightly -$basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/$basearch/nightlyenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-nightly-debuginfo]name=Docker CENightly -Debuginfo $basearchbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/debug-$basearch/nightlyenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg[docker-ce-nightly-source]name=Docker CENightly -Sourcesbaseurl=https://repo.huaweicloud.com/docker-ce/linux/centos/9.9/source/nightlyenabled=0gpgcheck=1gpgkey=https://repo.huaweicloud.com/docker-ce/linux/centos/gpg
6、清除和构建缓存
yumclean allyummakecache
7、docker 配置镜像加速(在华为云镜像中心可获取自己的镜像加速配置)
8、创建镜像加速配置文件
vim/etc/docker/daemon.json
{"registry-mirrors":[ "https://fd0cfec0ac0d446db7fd9d27e92d4a8e.mirror.swr.myhuaweicloud.com"]}
9、重新加载配置文件,重新启动 docker,查看是否配置成功
systemctldaemon-reloadsystemctlrestart docker.service
10、docker info 查看配置信息,是否配置成功镜像加速
dockerinfo
搭建 Flink
1、创建文件夹
mkdir /flink
2、编写 docker-compose.yml 文件
vim docker-compose.yml
version:"2.2"services:jobmanager:image:flink:1.14.4-scala_2.11ports:-"8082:8082"command:jobmanagerenvironment:-|FLINK_PROPERTIES=jobmanager.rpc.address:jobmanager taskmanager:image:flink:1.14.4-scala_2.11depends_on:-jobmanagercommand:taskmanagerscale:1environment:-|FLINK_PROPERTIES=jobmanager.rpc.address:jobmanagertaskmanager.numberOfTaskSlots:2
3、运行 docker-compose.yml 文件
docker-composeup -d
4、关闭服务器防火墙
systemctlstop firewalldsystemctlstatus firewalld
5、浏览器地址访问公网 IP:8082
总结
华为云服务器 Flexus X 实例,Docker 集成搭建搭建 Flink,Flink 能够同时处理实时数据流和静态数据集,使得数据处理更加灵活高效,欢迎搭建一起购买华为云服务器搭建,目前服务器正在大力促销优惠,有需要的小伙伴可以购买!
华为云828 Flexus X实例
云服务器
770浏览量
13531 -
Docker
498浏览量
12306 -
华为云
3文章
2746浏览量
17863
华为云 Flexus 云服务器 X 实例之 openEuler 系统下搭建 MaxKB 开源知识库问答系统
云服务器 Flexus X 实例,Docker 集成搭建 Grafana 开源数据可视化平台
华为云 Flexus X 实例下的场景体验——小企业必备——禅道服务搭建
Flexus 云服务器 X 实例:在 Docker 环境下搭建 java 开发环境
基于华为云 Flexus 云服务器 X 实例部搭建 Halo 博客平台
基于华为云 Flexus 云服务器 X 实例搭建 Linux 学习环境
