Maxim MAX32650超低功耗高性能MCU穿戴应用开发方案
电子工程师 作者:工程师陈翠 2018-06-16 11:44 次阅读
Maxim公司的MAX32650–MAX32652是超低功耗存储器可升级的微控制器MCU),集成了具有浮点单元(FPU)的Arm® Cortex®-M4核和3MB以及1MB SRAM,存储器升级有多个存储器扩展接口包括HyperBus™/Xccela™ DDR接口和两个SPIX接口,安全数字接口支持外接高速存储器卡包括SDSDIO,MMC,SDHC和microSD™。器件具有120MHz高速和40MHz低功耗振荡器,7.3728MHz低功耗振荡器,32.768kHz和RTC时钟,主要用在运动手表,健美监视器,可穿戴医疗贴片,手持医疗设备,工业传感器物联网IoT)。本文介绍了MAX32650主要优势和特性,框图,以及评估板MAX32650 EVK优势和特性以及电路图,材料清单。
The MAX32650–MAX32652 are ultra-low power memory-scalable microcontrollers designed specifically for high-performance, battery-powered applications. It is based on an Arm® Cortex®-M4 with a floating point unit (FPU) with 3MB flash and 1MB SRAM. Memory scalability is supported with multiple memory-expansion interfaces, including a HyperBus™/Xccela™ DDR interface and two SPI execute in place (SPIX) interfaces. A secure digital interface supports external high-speed memory cards including SD, SDIO, MMC, SDHC, and microSD™。
Extensive power management features provide fine-grained clock and voltage controls. The system clock can be selected from one of four on-chip oscillators from 8kHz to 120MHz as well as the external 32kHz crystal oscillator.Five low power modes provide configurable clocks, peripheral, and power management schemes. Individual SRAM banks of 32KB, 96KB, or 1024KB (full retention) can be placed in a mode to reduce power consumption while retaining SRAM contents.
A SmartDMA performs complex background processing on data being transferred, from simple arithmetic to multiply/accumulate, while the CPU is off. This dramatically reduces overall power consumption compared to conven­tional DMA solutions.
Multiple serial interfaces, each with dedicated FIFOs, allow communication to external sensors. A 4-input, 10-bit ADC monitors system power supplies. An I2S port supportsbidirectional audio streaming.
The MAX32651 includes a trust protection unit (TPU) to provide advanced security features such as a modular arith­metic accelerator (MAA) for fast ECDSA, an AES engine, TRNG, SHA-256 hash, and secure bootloader. A memory decryption integrity unit (MDIU) provides on-the-fly data decryption (plain or executable) stored in external flash.
The MAX32652 is a high-density, 0.35mm pitch, 140-bump WLP package targeted for tiny form factor products that require high I/O counts.
MAX32650主要优势和特性:
Ultra-Efficient Microcontroller for Battery-Powered Applications120MHz Arm Cortex-M4 with FPU
SmartDMA Provides Background Memory Trans­fers with Programmable Data Processing
120MHz High-Speed and 40MHz Low-Power Oscillators
7.3728MHz Low-Power Oscillators
32.768kHz and RTC Clock (Requires External Crystal)
8kHz Always-On Ultra-Low Power Oscillator
3MB Internal Flash
1MB Internal SRAM
104μW/MHz Executing from Cache at 1.1V
Five Low Power Modes: Active, Sleep, Background,Deep-sleep, and Backup
1.8V and 3.3V I/O with No Level Translators
Scalable Cached External Memory Interfaces:120MB/s HyperBus/Xccela DDR Interface
SPIXF/SPIXR for External Flash/RAM Expansion
240Mbps SDHC/eMMC/SDIO/microSD Interface
Optimal Peripheral Mix Provides Platform Scalability16-Channel DMA
Three SPI Master (60MHz)/Slave (48MHz)
One QuadSPI Master (60MHz)/Slave (48MHz)
Up to Three 4Mbaud UARTs with Flow Control
Two 1MHz I2C Master/Slave
I2S Slave
Four-Channel 7.8ksps 10-Bit Delta-Sigma ADC
USB 2.0 Hi-Speed Device Interface with PHY
16 Pulse Train Generators
Six 32-Bit Timers with 8mA High Drive
1-Wire Master
Trust Protection Unit (TPU) for IP/Data SecurityModular Arithmetic Accelerator (MAA),True Random Number Generator (TRNG)
Secure Nonvolatile Key Storage, SHA-256,AES-128/192/256
Memory Decryption Integrity Unit, Secure Boot ROM
MAX32650应用:
Sports Watches, Fitness Monitors
Wearable Medical Patches, Portable Medical Devices
Industrial Sensors, IoT
图1.MAX32650简化框图
评估板MAX32650 EVK
The MAX32650 EV kit provides a platform for evaluating the capabilities of the MAX32650 ultra-low power memory-scalable microcontroller designed specifically for high per­formance battery powered applications.
评估板MAX32650 EVK优势和特性:
3.5in 320 x 240 Color TFT Display
64MB HyperRAM
64MB XIP Flash
1MB XIP RAM
USB 2.0 Micro B Interface
USB 2.0 Micro B to Serial UARTs Selection with Jumpers Between UART0 and UART2
Micro SD Card Interface
Select GPIOs Accessed through 0.1in Header
Access to the Four Analog Input Through 0.1in Header
Arm® or SWD JTAG 20-Pin Header
On-Board PMIC to Source Power for the MAX32650
Board Power Provided by Either USB Port
Individual Power Measurement on All IC Rails Through Jumpers
On-Board 1.8V and 3.3V Regulators for Peripherals
Two General-Purpose LEDs and Two General- Purpose Pushbutton Switches
评估板MAX32650 EVK包括:
MAX32650 EV kit containing a MAX32650 with a preprogrammed demo
JTAG debugger with ribbon cable
Two standard A to Micro B USB cables
图2.评估板MAX32650 EVK外形图
图3.评估板MAX32650 EVK电路图(1)
图4.评估板MAX32650 EVK电路图(2)
图5.评估板MAX32650 EVK电路图(3)
图6.评估板MAX32650 EVK电路图(4)
图7.评估板MAX32650 EVK电路图(5)
图8.评估板MAX32650 EVK电路图(6)
图9.评估板MAX32650 EVK电路图(7)
评估板MAX32650 EVK材料清单:
  • mcu
    mcu
  • 存储器
    浅谈CC2640超低功耗无线MCU
    浅谈CC2640超低功耗无线MCUSimpleLink超低功耗无线MCU平台的首批成员是用于Bluetooth Smart的CC2640,以及针对6LoWPAN和ZigBee的CC2630。如需获得
    发表于 03-08 14:32
    小尺寸、超低功耗的智能穿戴定位解决方案
    解决方案也是必不可少的。本篇SKYLAB君将以小尺寸、超低功耗GPS模块SKG08A/SKG09A为切入点,详细介绍体积小、功耗低的智能穿戴定位解决
    发表于 09-28 16:13
    MAX32660试用申请】Maxim MAX32660 低功耗Arm Cortex-M4 FPU SOC开发板试用
    项目名称:Maxim MAX32660 低功耗Arm Cortex-M4 FPU SOC开发板试用试用计划:1.可穿戴医疗设备,主要用于研究
    发表于 01-25 11:47
    超低功耗MCU选型与设计
      循序渐进式的功耗优化已经不再是超低功耗mcu的游戏规则,而是“突飞猛进”模式,与功耗相关的很多指标都不断刷新记录。我们在选择合适的超低功耗
    发表于 07-29 07:27
    如何选择超低功耗MCU
    在物联网的推动下,业界对各种电池供电设备产生了巨大需求。这反过来又使业界对微控制器和其他系统级器件的能源效率要求不断提高。因此超低功耗MCU功耗相关的很多指标都不断得刷新记录。在选择合适的
    发表于 12-28 07:12
    如何选择超低功耗MCU
    发表于 11-04 07:07
    超低功耗MCU在物联网方案中的应用
    随着物联网技术的不断发展,超低功耗MCU已经成为了物联网方案中主要的芯片处理技术。超低功耗MCU具有众多的优点,其中一大所用就是能够大大提高
    发表于 06-13 18:18
    基于STM8L15xxx设计的超低功耗8位MCU开发方案
    基于STM8L15xxx设计的超低功耗8位MCU开发方案 ST公司的STM8L15xxx是超低功耗8位
    发表于 05-17 11:56 4301次阅读
    基于STM8L15xxx设计的<b class='flag-5'>超低功耗</b>8位<b class='flag-5'>MCU</b><b class='flag-5'>开发</b><b class='flag-5'>方案</b>
    Apollo2_超低功耗MCU
    超低功耗MCU
    发表于 08-18 11:11 107次下载
    ST STM32L4R9I高性能超低功耗ARM MCU开发方案
    ST STM32L4R9I高性能超低功耗ARM MCU开发方案 关键词:Arm Cortex-M4 MC
    发表于 11-30 17:22 35次下载
     ST STM32L4R9I<b class='flag-5'>高性能</b><b class='flag-5'>超低功耗</b>ARM <b class='flag-5'>MCU</b><b class='flag-5'>开发</b><b class='flag-5'>方案</b>
    MAX32650评估板的LCD面板上如何绘制图形
    在系列视频的第三部分,学习如何寻址屏幕存储器,在MAX32650评估板的LCD面板上绘制简单图形。在下节视频“开始移动”中,学习如何设置运动的对象。
    的头像 发表于 10-11 03:34 3475次阅读
    如何使用MAX32650评估板的控制台接口
    在系列视频的第四部分,学习通过只绘制图帧中发生变化的像素,设置运动对象。在下节视频“控制是件好事”中,您将学习如何使用MAX32650评估板的控制台接口。
    的头像 发表于 10-11 03:22 3407次阅读
    PSoC 6高性能超低功耗IoT应用方案
    cypress公司的PSoC® 6 MCU系列产品是用于物联网(IoT)的高性能超低功耗和安全MCU平台,组合了双核微控制器和低功耗闪存技术
    的头像 发表于 05-11 10:01 4373次阅读
    PSoC 6<b class='flag-5'>高性能</b><b class='flag-5'>超低功耗</b>IoT应用<b class='flag-5'>方案</b>
    MAX32650-EVKIT-MAX32651-EVKIT: Evaluation Kit for the MAX32650/MAX32651/MAX32652 Data Sheet MAX32650-EVKIT-MAX32651-EVKIT: Evaluation Kit fo
    电子发烧友网为你提供ADI(ADI)MAX32650-EVKIT-MAX32651-EVKIT: Evaluation Kit for the MAX32650/MAX32651/MAX
    发表于 10-17 19:00
    <b class='flag-5'>MAX32650-EVKIT-MAX</b>32651-EVKIT: Evaluation Kit for the <b class='flag-5'>MAX32650</b>/<b class='flag-5'>MAX</b>32651/<b class='flag-5'>MAX</b>32652 Data Sheet <b class='flag-5'>MAX32650-EVKIT-MAX</b>32651-EVKIT: Evaluation Kit fo
    MAX32650FTHR: Evaluation Kit for the MAX32650 Data Sheet MAX32650FTHR: Evaluation Kit for the MAX32650 Data Sheet
    电子发烧友网为你提供ADI(ADI)MAX32650FTHR: Evaluation Kit for the MAX32650 Data Sheet相关产品参数、数据手册,更有
    发表于 10-17 19:06
    <b class='flag-5'>MAX32650</b>FTHR: Evaluation Kit for the <b class='flag-5'>MAX32650</b> Data Sheet <b class='flag-5'>MAX32650</b>FTHR: Evaluation Kit for the <b class='flag-5'>MAX32650</b> Data Sheet
