一、C51读写AT24C04源代码
/*;起动24C01时序*/
void Start()
SCL=1;
SDA=1;
SDA=0;
SCL=0;
/*;停止24C01时序*/
void Stop()
SDA=0;
SCL=1;
SDA=1;
/*;检测24C01的响应信号*/
bit ACK()
bit c;
SDA=1;
SCL=1;
c=SDA;
SCL=0;
return c;
/*;往24C01发一8位数据*/
void SendChar(unsigned char ch)
unsigned char i;
i=8;
do
SDA=(ch&0x80);
SCL=1;
SCL=0;
ch《《=1;
}while(--i!=0);
/*;从24C01接收一8位数据*/
unsigned char RecChar()
unsigned char i,j;
i=8;
do
SCL=1;
j=(j《《1)|SDA;
SCL=0;
}while(--i!=0);
return j;
/*;往24C01写一字节*/
void WriteChar(unsigned int addr,unsigned char ch)
unsigned char c;
c=((*((unsigned char *)&addr))《《1)&0x02;
Start();
SendChar(0xa0|c);
ACK();
SendChar(addr);
ACK();
SendChar(ch);
ACK();
Stop();
// for(addr=4;addr!=0;addr--)
for(ch=0xff;ch!=0;ch--) ;
/*;往24C01写多字节*/
void WriteBuf(unsigned int addr,unsigned char idata *buf,unsigned char count)
unsigned char c;
Start();
SendChar(0xa0|c);
ACK();
SendChar(addr);
ACK();
do
SendChar(*buf++);
ACK();
if(count!=1)
{if(((++addr)&0x7)==0)
Stop();
for(c=0xff;c!=0;c--) ;
Start();
SendChar(0xa0|c);
ACK();
SendChar(addr);
ACK();
else
Stop();
}while(--count!=0);
/*;从24C01读一字节*/
/*;入口:R0中为要读出内容的地址*/
/*;出口:A中为读到的内容*/
unsigned char ReadChar(unsigned int addr)
unsigned char ch;
ch=((*((unsigned char *)&addr))《《1)&0x02;
Start();
SendChar(0xa0|ch);
ACK();
SendChar(addr);
ACK();
Start();
SendChar(0xa1|ch);
ACK();
ch=RecChar();
Stop();
return ch;
/*至少读2字节*/
void ReadBuf(unsigned int addr,unsigned char idata *buf,unsigned char count)
unsigned char ch;
Start();
SendChar(0xa0|ch);
ACK();
SendChar(addr);
ACK();
Start();
SendChar(0xa1|ch);
ACK();
count--;
do
*buf++=RecChar();
SDA=0;
SCL=1;
SCL=0;
SDA=1;
}while(--count!=0);
*buf=RecChar();
Stop();
二、AT24C04测试程序
主芯片 : STC12C5A60S2 (1T)
工作频率: 12.000MHz
#include “REG51.H”
#include “INTRINS.H”
typedef unsigned char BYTE;
typedef unsigned short WORD;
sbit SCL = P3^4; //AT24C04的时钟
sbit SDA = P3^5; //AT24C04的数据
BYTE BUF[16]; //数据缓存区
BYTE code TESTDATA[] =
0x00,0x11,0x22,0x33,0x44,0x55,0x66,0x77,
0x88,0x99,0xAA,0xBB,0xCC,0xDD,0xEE,0xFF
void Delay5us();
void Delay5ms();
void AT24C04_Start();
void AT24C04_Stop();
void AT24C04_SendACK(bit ack);
bit AT24C04_RecvACK();
void AT24C04_SendByte(BYTE dat);
BYTE AT24C04_RecvByte();
void AT24C04_ReadPage();
void AT24C04_WritePage();
void main()
Delay5ms();
AT24C04_ReadPage();
while (1);
向AT24C04写1页(16字节)数据
将TESTDATA开始的16个测试数据写如设备的00~0F地址中
BYTE i;
AT24C04_Start(); //起始信号
AT24C04_SendByte(0xa0); //发送设备地址+写信号
AT24C04_SendByte(0x00); //发送存储单元地址
for (i=0; i《16; i++)
AT24C04_SendByte(TESTDATA[i]);
AT24C04_Stop(); //停止信号
从AT24C04读取1页(16字节)数据
将设备的00~0F地址中的数据读出存放在DATA区的BUF中
BYTE i;
AT24C04_SendByte(0xa1); //发送设备地址+读信号
BUF[i] = AT24C04_RecvByte();
if (i == 15)
AT24C04_SendACK(1); //最后一个数据需要会NAK
else
AT24C04_SendACK(0); //回应ACK
延时5微秒(STC12C5A60S2@12M)
不同的工作环境,需要调整此函数
此延时函数是使用1T的指令周期进行计算,与传统的12T的MCU不同
void Delay5us()
BYTE n = 4;
while (n--)
_nop_();
_nop_();
延时5毫秒(STC12C5A60S2@12M)
不同的工作环境,需要调整此函数
void Delay5ms()
WORD n = 2500;
while (n--)
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
起始信号
SDA = 1; //拉高数据线
SCL = 1; //拉高时钟线
Delay5us(); //延时
SDA = 0; //产生下降沿
Delay5us(); //延时
SCL = 0; //拉低时钟线
停止信号
void AT24C04_Stop()
SDA = 0; //拉低数据线
SCL = 1; //拉高时钟线
Delay5us(); //延时
SDA = 1; //产生上升沿
Delay5us(); //延时
发送应答信号
入口参数:ack (0:ACK 1:NAK)
SDA = ack; //写应答信号
SCL = 1; //拉高时钟线
Delay5us(); //延时
SCL = 0; //拉低时钟线
Delay5us(); //延时
接收应答信号
SCL = 1; //拉高时钟线
Delay5us(); //延时
CY = SDA; //读应答信号
SCL = 0; //拉低时钟线
Delay5us(); //延时
return CY;
向IIC总线发送一个字节数据
BYTE i;
for (i=0; i《8; i++) //8位计数器
dat 《《= 1; //移出数据的最高位
SDA = CY; //送数据口
SCL = 1; //拉高时钟线
Delay5us(); //延时
SCL = 0; //拉低时钟线
Delay5us(); //延时
AT24C04_RecvACK();
从IIC总线接收一个字节数据
BYTE i;
BYTE dat = 0;
SDA = 1; //使能内部上拉,准备读取数据
dat 《《= 1;
SCL = 1; //拉高时钟线
Delay5us(); //延时
dat |= SDA; //读数据
SCL = 0; //拉低时钟线
Delay5us(); //延时
return dat;
STC12C5A60S2
36文章
219浏览量
70912 -
AT24C04
9浏览量
4534
stc12c5a60s2 AT24C04 I2C
凔海笔记之FPGA(八):AT24c04单字节读写的IIC协议
电可檫编程只读存储器AT24C04电子资料
AT24C02/AT24C04/AT24C08/AT24C1
24c04读写程序详解
单片机STC12C5A60S2控制AT24C04的程序(C语言)
at24c04中文资料汇总(at24c04引脚图及功能_工作原理及电路图)
AT89S52单片机并行端口模拟I2C总线协议读写AT24C04的设计
使用AT24C04和1602LCD设计的电子密码锁仿真和代码资料合集
