Silabs Si3406x系列以太网供电(PoE)管理解决方案
电子工程师 作者:工程师陈翠 2018-06-16 00:22 次阅读
Silabs公司的Si3406x系列是符合IEEE 802.3要求的全集成式PoE+ PD 接口和带晶体管旁路以及睡眠,唤醒和 LED 驱动器的高效率开关稳压器,集成了以太网供电+(PoE+)型供电设备(PD) 应用中所需的所有电源管理和控制功能,完全支持 IEEE 802.3at 规范,能够进行单个或两个事件分类。主要用在 IP 语音电话,无线接入点,安保和监察 IP 摄像机,照明设备,销售点终端机,以太网设备和网络设备。本文介绍了Si3406x系列主要特性,框图,应用电路以及评估板Si34061ISOC4-KIT主要特性,电路图,材料清单和PCB设计图。
The Si3406x family integrates all power management and control functions required ina Power-over-Ethernet Plus (PoE+) powered device (PD) application. These devicesconvert the high voltage supplied over the 10/100/1000BASE-T Ethernet connection toa regulated, low-voltage output supply. The optimized architecture of this device familyminimizes the solution footprint and external BOM cost and enables the use of low-cost
external components while maintaining high performance. The Si3406x family integrates the required diode bridges and transient surge suppressor, thus enabling directconnection of the IC to the Ethernet RJ-45 connector. The switching power FET and all associated functions are also integrated. The integrated, current mode controlledswitching regulator supports isolated or non-isolated flyback and buck converter topologies.
The switching frequency for the regulator is tunable with a simple external resistorvalue to help avoid unwanted harmonics for better emissions control. A synchronousdriver is provided to optionally drive a secondary side FET to improve efficiency of powerconversion. Connection to the PSE switch is maintained during sleep by an optional automated maintain-power-signature (MPS) signal.
These devices fully support the IEEE 802.3at specification for the cases of single ortwo event classification. Standard external resistors provide the proper IEEE 802.3 signatures for the detection function and programming of the classification mode, and internalstartup circuits ensure well-controlled soft-start initial operation of both the hotswapswitch and the voltage regulator.
The Si34061 and Si34062 add main transformer bias winding support for ultra-high-efficiencyoperation.
The Si34061 includes support for external augmentation or full bypass of the internalhotswap and/or switching FET for best power handling and thermal management at the high end of Class 4, plus offers a further boost in power conversion efficiency whenneeded.
The Si34062 includes support for sleep modes with wake function, as well as LED drive capability. These features can be utilized to minimize standby current, control sleepand wake states, and provide application status information using a solid or blinkingLED.
The Si3406 is available in a low-profile, 20-pin, 5 x 5 mm QFN package, and theSi34061 and Si34062 are available in low-profile, 24-pin, 5 x 5 mm QFN packages.
Si3406x系列主要特性:
• Type 1 (PoE) or Type 2 (PoE+) power
• Full IEEE 802.3at compliance
• Synchronous secondary FET driver
• Current mode dc-dc converter
• Tunable switching frequency
• Auxiliary transformer winding support
• Auxiliary adapter support
• Internal hotswap and switching FET bypasssupport
• Automated maintain-power-signature (MPS)support
• Sleep mode augmented with wake pin,mode control, and LED driver
• 120 V Absolute Max voltage performance
• Extended –40 to +85 ℃ temperature
• Compact ROHS-compliant 5 mm x 5 mmQFN Package
Si3406x系列应用:
• Voice over IP telephones
• Wireless access points
• Security and surveillance IP cameras
• Lighting luminaires
• Point-of-sale terminals
• Internet appliances
• Network devices
图1. Si3406框图
图2. Si34061框图
图3. Si34062框图
图4. Si3406x DC/DC转换器
图5. Si3406 Non-ISO反激应用框图
图6. Si34061 ISO反激应用框图
图7. Si34062 ISO反激应用框图
评估板Si34061ISOC4-KIT
This Si34061-ISO-FB EVB maximum output level is Class 4 power (η x 30 W).The Si34061-ISO-FB EVB is shown below. The Si34061 IC integrates an IEEE 802.03at compatiblePoE+ interface as well as a current control based dc/dc converter.
The Si34061 PD integrates two diode bridges, which can be used up to 200 mA input current, detection circuit, classification circuit, dc/dc switch, hot-swap switch, TVS overvoltageprotection, dynamic soft-start circuit, cycle-by-cycle current limit, synchronous gate driver, bias winding option, maintain power signature (MPS), thermal shutdown and inrush current protection.
Beyond this, to improve thermal and power performance Si34061 integrates a driver foran external hot swap switch, as well as a driver for a primary dc/dc switch.
To improve efficiency, the Si34061 can be driven from an auxiliary bias winding. Besides a PoE input, the Si34061 is capable of running from an external wall adapterwith a minimum voltage of 12 V.
The switching frequency of the converter is tunable by an external resistor.
评估板Si34061ISOC4-KIT主要特性:
• IEEE 802.03at Compatible
• High Efficiency
• High Integration
• Optional MPS Function
• External Primary Switch Driver
• External HSSW Driver
• Auxiliary Bias Winding Support
• Wall Adapter Support from 12 V
• Synchronous Gate Driver
• High Flexibility
• Transient Overvoltage Protection
• Thermal Shutdown Protection
• 5x5 mm 24-pin QFN
图8.评估板Si34061ISOC4-KIT外形图
图8.评估板Si34061ISOC4-KIT电路图:5V, Class 4 PD
评估板Si34061ISOC4-KIT材料清单:
图9.评估板Si34061ISOC4-KIT PCB设计图:顶层丝印
图10.评估板Si34061ISOC4-KIT PCB设计图:顶层
图11.评估板Si34061ISOC4-KIT PCB设计图:内1(层2)
图12.评估板Si34061ISOC4-KIT PCB设计图:内2(层3)
图13.评估板Si34061ISOC4-KIT PCB设计图:底层
  • 开关稳压器
    如何优化以太网供电 (PoE) PD 设计
    如何优化以太网供电 (PoE) PD 设计 什么是以太网供电 (PoE)?
    的头像 发表于 08-24 16:51 1409次阅读
    如何优化<b class='flag-5'>以太网</b><b class='flag-5'>供电</b> (<b class='flag-5'>PoE</b>) PD 设计
    以太网供电 (PoE)/LAN 防护解决方案概述
    PoE 是一项成熟且不断发展的技术,用于便捷地通过以太网电缆向负载传输电力,而不必额外增加电源线。浪拓可提供电缆两端的防护解决方案
    发表于 09-12 13:21
    什么是以太网供电PoE
    通常,嵌入式系统部署在难以或昂贵地为连接的设备添加电源插座的环境中。以太网供电(通常称为PoE(IEEE 802.3))使组织能够通过以太网端口为设备(例如传感器,摄像机和其他设备)
    发表于 12-17 06:40
    以太网供电技术(PoE)标准
    以太网供电技术(PoE)标准综述:IEEE 802.3af 规范定义了一种允许通过以太网线缆输送DC 电源的方法。首先简要介绍以太网
    发表于 10-11 18:28 71次下载
    以太网供电(POE)接口供电保护电路
    以太网供电(POE)接口供电保护电路
    发表于 11-20 09:12 4094次阅读
    <b class='flag-5'>以太网</b><b class='flag-5'>供电</b>(<b class='flag-5'>POE</b>)接口<b class='flag-5'>供电</b>保护电路
    Silicon发表Si348x系列电源管理IC
      Silicon Laboratories (芯科实验室有限公司)发表Si348x系列电源管理IC,可降低以太网供电(
    发表于 11-08 08:52 1072次阅读
    美高森美将在iic china展示LED背光及以太网供电(PoE)解决方案
    美高森美的技术专家与销售团队将现场展示LED背光、电机控制,以及以太网供电(PoE)解决方案
    发表于 02-23 18:36 755次阅读
    Silicon Labs推出满足物联网增长需求的新型高集成度PoE IC
    Silicon Labs日前发布了两款全新的以太网供电PoE)受电设备(PD)系列产品,为各种物联网(IoT)应用提供一流的集成度和效率。Silicon Labs的
    的头像 发表于 03-06 12:38 6153次阅读
    贸泽备货Silicon Labs Si3406x POE+受电设备产品 可支持多功能物联网产品
    商贸泽电子(Mouser Electronics)即日起备货Silicon Labs的Si3406x以太网供电+ (POE+)受电设备 (PD)系列
    的头像 发表于 09-07 14:48 6629次阅读
    高功率以太网供电不再困难,POE
    高功率以太网供电不再困难,POE 关键字:高功率以太网供电不再困难
    的头像 发表于 09-20 19:49 1340次阅读
    浅谈关于Silabs Si3471 90W完全自主以太网供电(PoE)解决方案
    Silabs公司的Si3471是完全自主以太网供电(PoE)的供电设备(PSE)器件.完全和IE
    发表于 03-25 08:46 3036次阅读
    浅谈关于<b class='flag-5'>Silabs</b> <b class='flag-5'>Si</b>3471 90W完全自主<b class='flag-5'>以太网</b><b class='flag-5'>供电</b>(<b class='flag-5'>PoE</b>)<b class='flag-5'>解决方案</b>
    以太网供电解决方案
    以太网供电解决方案
    发表于 05-18 13:45 15次下载
    <b class='flag-5'>以太网</b><b class='flag-5'>供电解决方案</b>
    POE以太网供电浪涌保护方案
    内的数据、视频传输、流量控制、以及通过总线实现供电。但由于工业以太网工作环境的严苛,对于POE以太网供电端口的浪涌及静电防护必不可少,接下来
    的头像 发表于 05-09 11:08 2144次阅读
    <b class='flag-5'>POE</b><b class='flag-5'>以太网</b><b class='flag-5'>供电</b>浪涌保护<b class='flag-5'>方案</b>
    智嵌物联ZQWL工业以太网交换机POE供电介绍
    智嵌物联ZQWL的工业以太网交换机POE的系统构成:poe供电一个完整的POE系统包括供电端设备
    的头像 发表于 05-27 15:02 1525次阅读
    智嵌物联ZQWL工业<b class='flag-5'>以太网</b>交换机<b class='flag-5'>POE</b><b class='flag-5'>供电</b>介绍
    设计以太网供电(PoE)解决方案
    以太网供电PoE供电是一种利用网线来传输功率的供电方案,由
    的头像 发表于 08-02 11:20 1577次阅读
    设计<b class='flag-5'>以太网</b><b class='flag-5'>供电</b>(<b class='flag-5'>PoE</b>)<b class='flag-5'>解决方案</b>
