Infineon ICE5ASAG 60W开关电源解决方案详解
电子工程师 作者:工程师陈翠 2018-06-16 19:39 次阅读
infineon公司ICE5ASAG是第五代固定频率PWM控制器,采用软栅极驱动和频率抖动操作使得在轻负载和50%间有更低的EMI和更好的效率。器件工作电压(10.0~25.5 V),待机时的功耗小于10mW,内置了数字软起动,集成的误差放大器支持非隔离反激的直接反馈,主要用在家用电器,白色家电,TV,PC和服务器的辅助电源,蓝光播放器,机顶盒以及LCD/LED监视器。本文介绍了ICE5ASAG产品亮点和主要特性,框图和应用电路,以及采用ICE5ASAG和IPA80R600P7的60 W 12 V 5 V SMPS演示板DEMO_5ASAG_60W1主要特性,电路图,材料清单和PCB设计图。
The ICE5xSAG is the 5th generation of fixed frequency PWM controller optimized for off-line switch mode power supply in cascode configuration. The cascode configuration helps achieve fast startup. The frequency reduction with soft gate driving and frequency jitter operation offers lower EMI and better efficiency between light load and 50% load. The selectable entry and exit standby power ABM enables flexibility and ultra-low power consumption at standby mode with small and controllable output voltage ripple. The product has a wide operating range (10.0 ~ 25.5 V) of IC power supply and lower power consumption. The numerous protection functions with adjustable line over voltage protection support the power supply system in failure situations. All these make the 5th generation ICE5xSAG series an outstanding PWM controller for fixed frequency flyback converter in the market.
ICE5ASAG产品亮点:
Enhanced Active Burst Mode with selectable entry and exit standby power to reach the lowest standby power 《100 mW
Digital frequency reduction for better overall system efficiency
Fast startup achieved with cascode configuration
Frequency jitter and soft gate driving for low EMI
Integrated error amplifier
Comprehensive protection with input line over voltage protection
Pb-free lead plating, halogen-free mold compound, RoHS compliant
ICE5ASAG主要特性:
DCM and CCM operation with slope compensation
Built-in digital soft start
Integrated error amplifier to support direct feedback in non-isolated flyback
Comprehensive protection with input line over voltage protection, VCC over voltage, VCC under voltage, overload/open loop, over temperature and Current Sense (CS) short to GND
All protections are in auto restart mode
Limited charging current for VCC short to GND
ICE5ASAG应用:
Auxiliary power supply for home appliances/white goods, TV, PC & server
Blu-ray player, set-top box & LCD/LED monitor
图1.ICE5ASAG框图
图2.ICE5ASAG和TL431与光耦在隔离反激的应用电路
图3.ICE5ASAG采用集成误差放大器的非隔离反激应用电路
This document is an engineering report that describes a universal-input 60 W 12 V 5 V off-line isolated Flyback converter using the latest fifth-generation Infineon Fixed Frequency Controller (FFC) ICE5ASAG and CoolMOSTM IPA80R600P7, which offers high-efficiency, low standby power with selectable entry and exit standby power options, wide VCC operating range with fast start-up, robust line protection with input Over Voltage Protection (OVP) and various protection modes for a highly reliable system. This demo board is designed for users who wish to evaluate the performance of ICE5ASAG and IPA80R600P7 in terms of optimized efficiency, thermal performance and EMI.
This document is intended for power supply design/application engineers, students, etc. who wish to design low-cost and highly reliable systems for off-line SMPS; either auxiliary power supplies for white goods, PCs, servers and TVs, or enclosed adapters for Blu-ray players, set-top boxes, games consoles, etc.
This document is an engineering report for a 60 W 12 V 5 V demo board designed in an FF isolated Flyback converter topology using the fifth-generation FFC ICE5ASAG and a P7 series of HV CoolMOSTM IPA80R600P7. The demo board is operated in Discontinuous Conduction Mode (DCM) and is running at 100 kHz fixed switching frequency. The frequency reduction with soft gate driving and frequency jittering offers lower EMI and better efficiency between light load and 50% load. The selectable Active Burst Mode (ABM) power enables ultra-low power consumption. In addition, numerous adjustable protection functions have been implemented in ICE5ASAG to protect the system and customize the IC for the chosen application. In case of failures like line Over Voltage (OV), VCC OV/Under Voltage (UV), open control-loop or over-load, over-temperature, VCC short-to- GND and CS short-to-GND, the device enters protection mode. By means of the cycle-by-cycle Peak Current Limitation (PCL), the dimensions of the transformer and current rating of the secondary diode can both be optimized. In this way, a cost-effective solution can easily be achieved. The target applications of ICE5ASAG are either auxiliary power supplies for white goods, PCs, servers and TVs, or enclosed adapters for Blu-ray players, set-top boxes, games consoles, etc.
图4.演示板DEMO_5ASAG_60W1外形图
演示板DEMO_5ASAG_60W1主要指标:
图5.演示板DEMO_5ASAG_60W1电路图
演示板DEMO_5ASAG_60W1材料清单:
图6.变压器结构图
图7.演示板DEMO_5ASAG_60W1 PCB设计图(1)
图8.演示板DEMO_5ASAG_60W1 PCB设计图(2)
  • 开关电源
  • Infineon
    你的理想型60W电源适配器方案,内部的国产芯片是亮点
    给大家整理了一份基于思睿达主推的国产芯片CR6890H 60W电源适配器方案
    的头像 发表于 11-17 11:08 5736次阅读
    你的理想型<b class='flag-5'>60W</b><b class='flag-5'>电源</b>适配器<b class='flag-5'>方案</b>,内部的国产芯片是亮点
    60W USB PD AC/DC开关电源实现方案
    ,IR1161LTRPBF作为次级同步整流控制芯片,BSC035N10NS5作为次级同步整流MOSFET。本方案支持恒压,恒流,恒功率三种输出模式,最大输出功率为60W,最高转换效率可为91%以上。此
    发表于 08-14 11:34 7371次阅读
    <b class='flag-5'>60W</b> USB PD AC/DC<b class='flag-5'>开关电源</b>实现<b class='flag-5'>方案</b>
    SN03A高功率60w电源方案SN03A+AP4313开关电源
    SN03A高功率60w电源方案SN03A+AP4313开关电源SN03A高功率因素反激式脉宽调制控制 QQ2892715427电源设计
    发表于 03-08 11:29
    转换效率高达91%的60W USB PD 电源方案
    我中国工信部的泰尔实验室达成了共识,预计未来将作为手机充电的国标,实现统一。 本次介绍60W USB PD电源实现方案使用了英飞凌5V~20V宽输出电压范围AC-DC Controll
    发表于 04-12 18:43
    银联宝科技-60W系列的开关电源方案
    供应商。银联宝提供的60W开关电源方案,满足六大能效,它具有±5%恒压恒流精度,快速动态响应控制,待机功耗小于75mw,具有自动补偿输入电压,电感感量变化,超低启动电流。
    发表于 06-21 15:26
    求一个 60W的 12V 开关电源
    求一个12V 60W开关电源原理图和PCB图,
    发表于 01-07 10:52
    开关电源为什么要接假负载?
    900Ω)或50W/300Ω电阻,它比使用60W灯泡更为准确。  有些电源是可以直接接假负载的,有些电源则不可以,需要具体问题具体分析,下面按3类情况
    发表于 03-23 16:24
    T-60W开关电源技术参数
    T-60W开关电源技术参数
    发表于 10-01 18:55 30次下载
    60W吉他音箱 (60W Guitar Amplifier)
    60W吉他音箱 (60W Guitar Amplifier) Amplifier parts: R1___
    发表于 12-25 10:51 2921次阅读
    <b class='flag-5'>60W</b>吉他音箱 (<b class='flag-5'>60W</b> Guitar Amplifier)
    60W低音放大器 (60W Bass Amplifier)
    60W低音放大器 (60W Bass Amplifier) Amplifier parts: R1__
    发表于 12-25 10:59 1916次阅读
    <b class='flag-5'>60W</b>低音放大器 (<b class='flag-5'>60W</b> Bass Amplifier)
    开关电源各功能电路详解
    开关电源各功能电路详解开关电源各功能电路详解开关电源各功能电路详解
    发表于 12-14 18:00 184次下载
    60W隔离反激开关电源(SMPS)电路图详解
    ,机顶盒,水/空气净化器和TV主电源,空调,冰箱,服务器,PC电源和音频的辅助电源.本文介绍了ICE5QR0680AG主要特性和优势,60W
    发表于 02-11 05:17 9804次阅读
    <b class='flag-5'>60W</b>隔离反激<b class='flag-5'>开关电源</b>(SMPS)电路图<b class='flag-5'>详解</b>
    0-60V-5A (最大)可调开关电源方案
    0-60V-5A (最大)可调开关电源方案(四层板电源层和地层)-0-60V-5A (最大)可调开关电
    发表于 07-26 10:03 261次下载
    0-<b class='flag-5'>60V-5</b>A (最大)可调<b class='flag-5'>开关电源</b>的<b class='flag-5'>方案</b>
    开关电源详解
    开关电源详解(肇庆理士电源技术公司)-关于开关电源的各部分详解,大家可以去看看
    发表于 09-29 17:44 147次下载
    <b class='flag-5'>开关电源</b><b class='flag-5'>详解</b>
    恒流输出副边60W开关电源芯片U6201
    恒流输出副边60W开关电源芯片U6201U6201在充电器领域,直接对电池充电的应用,一般会对空载电压精度要求高,可以直接选择副边开关电源芯片+恒流芯片来做。副边60W
    的头像 发表于 08-25 08:12 3064次阅读
    恒流输出副边<b class='flag-5'>60W</b><b class='flag-5'>开关电源</b>芯片U6201
