Gadgets 3D 推出Zortrax 新型桌面3D打印机和设计组件
454398 来源:网络整理 2018-05-08 07:44 次阅读
No matter if you’re a student, a designer or an engineer, at some point you’ve stumbled upon the need to make an idea real. The Zortrax M200 allows you to do just that. You can create high-precision durable models of any shapes and colors. And since it’s inexpensive, you can print a model, after model, after model, seeing your project in reality even during design.
Here are the specifications:
•Slick, aluminum design that just works. It really ties your office space together. It just fits the room
• Solid, stable aluminum printer frame, guaranteeing high-precision printing
• Printer head specially designed for ABS, PC-ABS and Nylon material – Innovative, state-of-the-art high-precision material dosing mechanism
• Just unbox it! Plug & Print!
• Gantry system is based on idea comes from MIT:
The slicing engine included in the Zortrax Suite is a ready solution designed and programmed by Gadgets 3D with no 3rd party software included! Everything, from the engine to a handsome GUI was created by the team from scratch.
Why is the Zortrax Suite awesome?
•Built-in slicing engine fixes the majority of possible errors that can occur in .stl models and does it automatically during the slicing process!
•Slices really big and complex models in a very short time
•You can set the layer thickness to a variety of options: 0.1mm, 0.14mm, 0.2mm, 0.3mm
•The engine created focuses on maintaining the geometry of your model as close as possible to your project
•Three different printing speed modes
•Automatic support generation, so you can print those really complicated models
•No USB connection is required – just use the included SD card reader!
•Supports Windows XP, Windows Vista, Windows 7 and Windows 8, including virtual machines!
自动翻译仅供参考
不管你是学生、设计师还是工程师,在某个时候你都会无意中发现一个想法的真实性。ZORTRAX M200可以让你做到这一点。您可以创建任何形状和颜色的高精度耐用模型。而且因为它便宜,你可以打印模型,模型后,模型后,看到你的项目在现实中,甚至在设计过程中。
这里有规格
•油滑,铝的设计,只是工作。这真的绑您的办公空间在一起。它只是适合房间
•牢固,稳定的铝框架打印机,确保高精度打印
•打印机头专为ABS,PC,ABS和尼龙材料 - 创新,高精度计量的材料机理国家的最先进的
•刚拆箱吧!即插即打印!
•基于想法龙门系统来自麻省理工学院:
列入Zortrax套房切片引擎是一个现成的解决方案,并通过小工具3D编程包括任何第三方软件!一切,从发动机到一个英俊的图形用户界面是由小组从头开始创建。
为什么Zortrax套房真棒?
•内置切片引擎修复大部分可能发生的可能存在的错误.STL模型和在切片过程自动完成!
•片真正的大和复杂的模型在极短的时间
•您可以设置层厚度有多种选择:0.1mm时,0.14毫米,0.2毫米,0.3毫米
•创建的引擎专注于保持模型的几何形状尽可能接近到项目
•三种不同的打印速度模式
•自动生成的支持,这样你就可以打印那些真正复杂的模型
•无需USB连接 - 只需使用附带的SD读卡器!
•支持Windows XP,Windows Vista中,Windows 7和Windows 8,包括虚拟机!
  • 3D打印
    360万像素3D打印机参考设计
    电子发烧友网站提供《360万像素3D打印机参考设计.pdf》资料免费下载
    发表于 10-31 09:47 0次下载
    360万像素<b class='flag-5'>3D</b><b class='flag-5'>打印机</b>参考设计
    3D打印机优化:ARMxy嵌入式计算机的作用
    3D打印机3D Printers),又称三维打印机,是快速成型的一种工艺设备。其工作原理类似于传统打印机,只不过传统
    的头像 发表于 10-10 15:22 255次阅读
    <b class='flag-5'>3D</b><b class='flag-5'>打印机</b>优化:ARMxy嵌入式计算机的作用
    领麦微红外测温传感器在小型光敏3D打印机中的创新应用
    在小型3D打印技术持续革新的背景下,领麦微红外测温传感器,以其出色的性能和独特优势,在光敏3D打印领域展现出非凡的创新价值与应用潜力。这款传感器专为提升
    的头像 发表于 09-25 14:45 537次阅读
    领麦微红外测温传感器在小型光敏<b class='flag-5'>3D</b><b class='flag-5'>打印机</b>中的创新应用
    应用在3D打印机的BD系列金属连接器
    能入3D打印机法眼,BD系列工业级连接器究竟有哪些独特之处? 3D打印是近些年非常热门的加工方式,它相较于传统加工方式,无需复杂的工艺流程和生产线,就能实现高效快速的加工。
    的头像 发表于 09-09 16:02 236次阅读
    2024年含直线电机3D打印机在内共出口182.9万台
    亿元(不含零部件),比2023年上半年出口的总金额24.1亿元增长了77.2%。 按出口的3D打印机的品类来划分,依然是打印塑料的桌面3D
    的头像 发表于 08-05 08:15 372次阅读
    2024年含直线电机<b class='flag-5'>3D</b><b class='flag-5'>打印机</b>在内共出口182.9万台
    3D打印汽车零部件建模设计3D打印服务
    传统的汽车零件制造过程需要经过多个环节,包括设计、制造、装配等,耗时且复杂。而采用3D打印技术制造汽车零件可以大幅度缩短生产周期。设计人员可以通过CAD软件直接进行零件设计,并将设计文件转化为3D
    的头像 发表于 07-21 15:01 551次阅读
    <b class='flag-5'>3D</b><b class='flag-5'>打印</b>汽车零部件建模设计<b class='flag-5'>3D</b><b class='flag-5'>打印</b>服务
    我用香橙派做了一个Klipper 3D打印控制器
    一个好用的Klipper 3D打印机,一定离不开一个可以稳定进行无线通信,而且性能足够,最重要是价格亲民的上位机。 所谓Klipper,简单来说就是一套可以通过联动上、下位机来有效提升3D
    发表于 06-11 09:45
    纯硅振荡器替代SiTime助力3D打印机精确的时钟信号
    的头像 发表于 05-23 10:10 393次阅读
    纯硅振荡器替代SiTime助力<b class='flag-5'>3D</b><b class='flag-5'>打印机</b>精确的时钟信号
    UltiMaker正式推出了工业级3D打印机—UltiMaker Factor 4
    与之前的UltiMaker S系列桌面3D打印机不同,全球3D打印领域的领导者UltiMaker正式推出
    的头像 发表于 05-09 16:58 541次阅读
    雷卯电子3D打印机防静电保护方案
    3D打印机的广泛应用离不开3D打印机的稳定性和安全性,3D打印机常用的接口包括USB接口、SD卡
    的头像 发表于 04-26 17:17 774次阅读
    雷卯电子<b class='flag-5'>3D</b><b class='flag-5'>打印机</b>防静电保护方案
    3D打印机防静电保护
    工艺和材料不同,设备主要分为桌面3D打印机、工业级3D打印机、生物3D
    的头像 发表于 04-19 20:17 314次阅读
    3D打印机防静电保护方案
    3D打印机防静电保护方案
    的头像 发表于 04-17 08:02 373次阅读
    YXC晶振 32.768KHz石英振荡器,封装3225,应用于3D打印机
    3D打印过程中,需要进行大量的数据处理,包括模型的切片、打印路径的规划等。晶振提供稳定的时钟信号,有助于加快数据处理速度,提高3D打印的效率
    的头像 发表于 03-27 16:26 712次阅读
    YXC晶振 32.768KHz石英振荡器,封装3225,应用于<b class='flag-5'>3D</b><b class='flag-5'>打印机</b>
    用于3D打印机电源连接3D打印机,基本都是一次打印成型,中途经常停机停打,会导致最终成型的产品存在质量瑕疵与问题。因而
    的头像 发表于 03-05 08:16 507次阅读
    能入<b class='flag-5'>3D</b><b class='flag-5'>打印机</b>法眼,BD系列工业级连接器究竟有哪些独特之处?
    并联式3D打印机的设计与计算
    从机械结构、电控部分和上位机软件三方面讲述了并联式3D打印机的组成,采用SolidWorks三维建模软件设计了一款并联式3D打印机,通过运动算法计算和步进电机算法对其进行控制。结果表明
    的头像 发表于 12-25 14:08 1271次阅读
    并联式<b class='flag-5'>3D</b><b class='flag-5'>打印机</b>的设计与计算
