一文解析TPS657051的特性_功能_应用电路
电子工程师 作者:工程师a 2018-05-12 09:05 次阅读
TI 公司的TPS657051/52是小型(2-mm x 2-mm WCSP)封装的3路电源管理单元,主要用于嵌入照相机模块或其它手提低功耗消费类终端设备。 TPS657051/52包括两个效率高达92%的400mA降压转换器,输入电压从3.3V到6V,固定工作频率2.25MH ,此外还有一个200mA LDO,其工作电压从1.7V到6.0V.本文介绍了TPS657051/52主要特性, 功能方框图, 应用电路和TPS657051/2EVM-522 评估模块主要特性,性能指标以及电路图和材料清单(BOM)。
PMU for Embedded Camera Module
TPS657051/52 are small power management units targeted for embedded camera module or other portable low power consumer end equipments. It contains two high efficient step down converters, a low dropout linear regulator and additional supporting functions. The 2.25MHz step-down converter enters a low power mode at light load for maximum efficiency across the widest possible range of load currents. For low noise applications the devices can be forced into fixed frequency PWM mode using the MODE pin. The device allows the use of small inductors and capacitors to achieve a small sized solution. TPS657051/52 provides an output current of up to 400mA on both DCDC converters and integrates one 200mA LDO with different output settings.
TPS657051/52主要特性:
Two 400mA Step-Down Converters
Up to 92% Efficiency
VIN Range for DCDC Converter From 3.3V to 6V
2.25 MHz Fixed Frequency Operation
Power Save Mode at Light Load Current
Output Voltage Accuracy in PWM Mode ±1.5%
100% Duty Cycle for Lowest Dropout
180°Out of Phase Operation
1 General Purpose 200mA LDO
VIN Range for LDO From 1.7V to 6.0V
Available in a 16 Ball WCSP With 0.5mm Pitch
TPS657051/52应用:
Digital Cameras
Portable Media Players
Handheld Equipment
图1.TPS657051/52功能方框图
图2.TPS657051/52应用电路
The TPS657051/2EVM evaluation module (EVM) is designed to help the user easily evaluate and test the operation and functionality of the TPS657051/2. This user’s guide includes setup instructions for the hardware, a schematic diagram, a bill of materials, and printed-circuit board layout drawings for the evaluation module.
TPS657051/2EVM-522 评估模块主要特性:
• Input voltage rating
• 2 × 200-mA Step-down converter for TPS657051/2
• 2.25-MHz switching frequency
• 1 General-purpose 200-mA LDO
PS657051/2EVM-522 评估模块电和性能指标:
图3.TPS657051/2EVM-522 评估模块电路图
TPS657051/2EVM-522 评估模块材料清单(BOM):
  • 转换器
  • 电源管理
    解析工业互联网
    电子发烧友网站提供《解析工业互联网.pptx》资料免费下载
    发表于 02-20 16:42 0次下载
    TPS65950和TPS65951之间的功能差异
    电子发烧友网站提供《TPS65950和TPS65951之间的功能差异.pdf》资料免费下载
    发表于 10-29 10:03 0次下载
    <b class='flag-5'>TPS</b>65950和<b class='flag-5'>TPS</b>65951之间的<b class='flag-5'>功能</b>差异
    MLCC直流偏压特性解析
    在电子电路设计中,多层陶瓷电容器(MLCC)因其体积小、电性能优良而被广泛应用。然而,MLCC在直流电压下的容量会出现降低的现象,即直流偏压特性。这特性对于
    的头像 发表于 10-20 12:04 886次阅读
    TPS6521815工业应用电源管理集成电路(PMIC)
    电子发烧友网站提供《TPS6521815工业应用电源管理集成电路(PMIC).pdf》资料免费下载
    发表于 10-08 14:46 0次下载
    <b class='flag-5'>TPS</b>6521815工业应<b class='flag-5'>用电</b>源管理集成<b class='flag-5'>电路</b>(PMIC)
    电源常用ic脚位解析方法 7脚电源芯片怎么看型号
    有详细的数据手册,其中包含了引脚功能、电气特性、应用电路等关键信息。这是解析IC脚位最直接、最准确的方法。 识别引脚编号 : 大多数IC都会在其封装上标注引脚编号,这些编号通常按照
    的头像 发表于 10-07 17:10 3144次阅读
    软启动:TPS2373X特性说明
    电子发烧友网站提供《软启动:TPS2373X特性说明.pdf》资料免费下载
    发表于 09-25 11:20 0次下载
    软启动:<b class='flag-5'>TPS</b>2373X<b class='flag-5'>特性</b>说明
    在自动模式下使用TPS23861和TPS23882B的功能和优势
    电子发烧友网站提供《在自动模式下使用TPS23861和TPS23882B的功能和优势.pdf》资料免费下载
    发表于 09-24 10:35 0次下载
    在自动模式下使用<b class='flag-5'>TPS</b>23861和<b class='flag-5'>TPS</b>23882B的<b class='flag-5'>功能</b>和优势
    读懂新能源汽车的功能安全
    电子发烧友网站提供《读懂新能源汽车的功能安全.pdf》资料免费下载
    发表于 09-04 09:22 3次下载
    TPS621和TPS821系列的时序控制和跟踪功能
    电子发烧友网站提供《TPS621和TPS821系列的时序控制和跟踪功能.pdf》资料免费下载
    发表于 08-26 14:38 0次下载
    <b class='flag-5'>TPS</b>621和<b class='flag-5'>TPS</b>821系列的时序控制和跟踪<b class='flag-5'>功能</b>
    详解运放七大应用电路设计
    ** 在运放的使用中,电压跟随器是种常见的应用,该电路的好处是:是减小负载对信号源的影响;二是提高信号带负载的能力。 上图是运用运放实现了电阻分压的功能,首先
    发表于 06-13 10:06
    具有电源故障检测功能的处理器监控电路TPS370x-xx数据表
    电子发烧友网站提供《具有电源故障检测功能的处理器监控电路TPS370x-xx数据表.pdf》资料免费下载
    发表于 03-22 10:37 0次下载
    具有电源故障检测<b class='flag-5'>功能</b>的处理器监控<b class='flag-5'>电路</b><b class='flag-5'>TPS</b>370x-xx数据表
    纳米功率监控电路TPS3836、TPS3837和TPS3838系列数据表
    电子发烧友网站提供《纳米功率监控电路TPS3836、TPS3837和TPS3838系列数据表.pdf》资料免费下载
    发表于 03-14 11:10 0次下载
    纳米功率监控<b class='flag-5'>电路</b><b class='flag-5'>TPS</b>3836、<b class='flag-5'>TPS</b>3837和<b class='flag-5'>TPS</b>3838系列数据表
    用于RAM保持的备用电池监控器TPS3619和TPS3620系列数据表
    电子发烧友网站提供《用于RAM保持的备用电池监控器TPS3619和TPS3620系列数据表.pdf》资料免费下载
    发表于 03-14 10:40 0次下载
    用于RAM保持的备<b class='flag-5'>用电</b>池监控器<b class='flag-5'>TPS</b>3619和<b class='flag-5'>TPS</b>3620系列数据表
    用于RAM保持的备用电池监控器TPS3619-33-EP TPS3619-50-EP TPS3620-33-EP TPS3620-50-EP数据表
    电子发烧友网站提供《用于RAM保持的备用电池监控器TPS3619-33-EP TPS3619-50-EP TPS3620-33-EP TPS
    发表于 03-14 10:27 0次下载
    用于RAM保持的备<b class='flag-5'>用电</b>池监控器<b class='flag-5'>TPS</b>3619-33-EP <b class='flag-5'>TPS</b>3619-50-EP <b class='flag-5'>TPS</b>3620-33-EP <b class='flag-5'>TPS</b>3620-50-EP数据表
    设计干货!详解运放七大应用电路设计
    发表于 03-13 09:57
