基于低压照明的可调光LED驱动器的设计
电子工程师 来源:网络整理 作者:工程师d 2018-05-17 16:16 次阅读
Cirrus公司的CS1680是低压照明的可调光LED驱动器,具有最好的变压器兼容性,调光特性以及高达83%的效率,最低调光量5%,输出电压12V/15V,主要用在MR16灯和所有的12VAC/DC低压照明应用.本文介绍了CS1680主要特性,框图和应用电路,以及CRD1680-7W 7 W参考设计主要特性,电路图,材料清单和PCB设计图.
The CS1680 is a cascade boost-buck dimmable LEDdriver for the 12V halogen lamp-replacement market.
The CS1680 uses a Cirrus Logic proprietary intelligentdigital control that provides exceptional single-lamp andmulti-lamp transformer compatibility for non-dimmer systemsand dimmer systems paired with electronic andmagnetic low-voltage transformers.
The CS1680 integrates a continuous conduction mode(CCM) boost converter that provides transformer compatibilityand dimmer compatibility. An adaptive digitalalgorithm controls the boost stage and dimmer compatibilityoperation mode to enable flicker-free operationdown to 5% output current with leading-edge and trailing-edge dimmers.
CS1680主要特性:
• Best-in-class Transformer Compatibility
- Magnetic Transformers
- Electronic Transformers
• Best-in-class Dimmer Compatibility
- Leading-edge (TRIAC) Dimmers
- Trailing-edge Dimmers
• High Efficiency
- Up to 80% for CS1680-00 Applications
- Up to 83% for CS1680-02 Applications
• Flicker-free Dimming
• 5% Minimum Dimming Level
• Cascade Boost-buck Topology with Constant-currentOutput
- CS1680-00 Output Voltage 15V
- CS1680-02 Output Voltage 21V
• Fast Startup
• Tight LED Current Regulation: Better than ±10%
• >0.9 Power Factor on Magnetic Transformers
• Soft Start
• Protections:
-Output Open/Short
- Boost Overvoltage
-Overcurrent Detection
- External Overtemperature Using NTC
CS1680应用:
• MR16 Lamps
• All 12VAC/VDC Low-voltage Lighting Applications
图1.CS1680框图
图2.CS1680应用电路图
CRD1680-7W 7 W参考设计
The CRD1680-7W reference design demonstrates theperformance of the CS1680 dimmable LED driver forlow-voltage lighting with a target output of 430mA driving4LEDs in series. It provides exceptional single-lampand multi-lamp transformer compatibility for non-dimmersystems and dimmer systems paired with electronic andmagnetic low-voltage transformers. The form factor istargeted to fit into MR16 LED lamp applications.
The CRD1680-7W board is optimized to deliver low system cost in a high-efficiency, flicker-free, phase-dimmable,solid-state lighting (SSL) solution for incandescent lamp replacement applications. The feedback loop is closedthrough an integrated digital control system within the IC. Protection algorithms such as output open/short, overcurrentdetection, boost overvoltage, and overtemperature thermistors protect the system during abnormal conditions.
Details of these features are provided in the CS1680 Dimmable LED Driver IC for Low-voltage Lighting data sheet.
The CRD1680-7W board demonstrates the performance of the CS1680. This reference board has been designedfor an output load of 4LEDs in series at a target output current of 430mA (12.0V typical).
This document provides the schematic for the board. It includes oscilloscope screen shots that indicate various operatingwaveforms. Graphs are also provided that document the performance of the board in terms of Efficiency vs.Line Voltage, Output Current vs. Line Voltage, and Output Current vs. Dim Angle for the CS1680 dimmable LEDcontroller IC.
CRD1680-7W 7 W参考设计特性:
• Constant-current Output
• Line Voltage 12VAC/VDC, ±10%
• Rated Input Power: 7.0W
• Rated Output Power: 5.6W
• Output Voltage: <15V
• High Efficiency with Magnetic and ElectronicTransformers
• Low Component Count
• Supports Cirrus Logic Product CS1680
图3.CRD1680-7W 7 W参考设计外形图
图4.CRD1680-7W 7 W参考设计电路图
CRD1680-7W 7 W参考设计材料清单:
图5.CRD1680-7W 7 W参考设计PCB尺寸
图6.CRD1680-7W 7 W参考设计PCB顶层丝印图
图7.CRD1680-7W 7 W参考设计PCB底层丝印图
图8.CRD1680-7W 7 W参考设计PCB走线图(层1)
图9.CRD1680-7W 7 W参考设计PCB走线图(层2)
图10.CRD1680-7W 7 W参考设计PCB走线图(层3)
图11.CRD1680-7W 7 W参考设计PCB走线图(层4)
  • led
    led
  • 变压器
  • pcb
    pcb
    可调光LED照明原理图
    下图是可调光LED照明原理图,如图所示:TPS92210是一款面向LED照明应用的驱动器控制
    发表于 07-18 15:17 6846次阅读
    <b class='flag-5'>可调光</b><b class='flag-5'>LED</b><b class='flag-5'>照明</b>原理图
    9.5W TRIAC可调光,功率因数校正的隔离式LED驱动器
    该工程报告描述了一种TRIAC可调光隔离反激式LED驱动器,设计用于在输入电压范围为90 VAC至132 VAC时,以350 mA的电流驱动27 V的标称
    的头像 发表于 03-29 16:51 3.1w次阅读
    德州仪器推出可调光LED照明驱动器LM3448与TPS92070
    日前,德州仪器 (TI) 在欧洲照明技术策略大会 (the Strategies in Light Europe conference) 上宣布推出两款高度集成的相位可调光 AC/DC LED
    发表于 10-20 09:30 1335次阅读
    瞄准LED照明市场需求 可调光LED驱动IC厂竞推高整合方案
    和高压电解电容,该高压LED驱动芯片极少的外围元件,可节省电子元器件所占的空间,可实现LED照明方案批量化作业。另外,由于可调光
    发表于 05-22 10:19
    可调光LED照明驱动器控制PMP6003技术参数及设计
    描述 PMP6003 参考设计是使用 TPS92210 的隔离(反向)可调光 LED 照明驱动器控制。此参考设计接受的输入电压范围为 18
    发表于 07-13 04:53
    开关式可调光LED驱动器解决方案
    开关式可调光LED驱动器具有显著的性能并可以精准控制LED电流,也具有调光功能,这使终端用户在降低功耗的同时制作很好的灯光效果。 8位微控制
    发表于 07-15 06:45
    可调光驱动器支持绿色照明
    可调光驱动器支持绿色照明  近年来环保节能的浪潮中,首当其冲的就是绿色照明技术。近日,NXP同时发布面向CFL应用和SSL应用的驱动器IC,以及针对SSL应用的在线设
    发表于 12-31 10:01 688次阅读
    安森美推出PFC可调光LED驱动器
    安森美推出PFC可调光LED驱动器 应用于绿色电子产品的首要高性能、高能效硅方案供货商安森美半导体(ON Semiconductor)推出新的功率因数校正(PFC)可调光发光二极管(
    发表于 02-26 10:32 717次阅读
    安森美发布照明应用的PFC可调光LED驱动器
    安森美发布照明应用的PFC可调光LED驱动器 安森美半导体(ON Semiconductor)推出新的功率因数校正(PFC)可调光发光二极
    发表于 03-03 09:55 938次阅读
    Diodes可调光降压LED驱动器 简化LED照明应用设计
    Diodes公司推出可调光降压LED驱动器AL8807B,有效减少12V与24V LED照明系统和MR16
    发表于 06-09 14:52 1167次阅读
    将降压调节转换为智能可调光LED驱动器
    将降压调节转换为智能可调光LED驱动器
    发表于 01-07 15:06 0次下载
    具有PFC的晶闸管可调光反激式LED驱动器详细讲解
    本文主要内容是TI的具有PFC的晶闸管可调光反激式LED驱动器详细讲解
    发表于 04-11 14:16 22次下载
    具有PFC的晶闸管<b class='flag-5'>可调光</b>反激式<b class='flag-5'>LED</b><b class='flag-5'>驱动器</b>详细讲解
    PFC可调光LED驱动器NCL30000的功能特点及适用范围
    ON Semi推出的功率因数校正(PFC)可调光发光二极管(LED驱动器– NCL30000,用于住宅及商业照明应用。
    发表于 11-16 11:48 1670次阅读
    11 W 可控硅可调光 PA​​R30 LED 驱动器
    发表于 11-15 20:24 7次下载
    11 W 可控硅<b class='flag-5'>可调光</b> PA​​R30 <b class='flag-5'>LED</b> <b class='flag-5'>驱动器</b>
    基于8位MCU的开关模式可调光LED驱动器解决方案
    开关模式可调光LED驱动器以其效率和精确控制LED电流而闻名。它们还可以提供调光功能,同时降低功耗。
    发表于 07-04 16:55 2206次阅读
    基于8位MCU的开关模式<b class='flag-5'>可调光</b><b class='flag-5'>LED</b><b class='flag-5'>驱动器</b>解决方案
