infineon公司的IDP2303是集成了浮点高边驱动器和600V起动单元的多模式PFC和LLC控制器,数字引擎为多模式工作提供先进算法,在整个负载范围内支持最高的效率,主要用在75W到300W的LCD-TV以及通用的开关电源(SMPS)。本文介绍了IDP2303产品亮点和主要特性,典型应用电路图以及采用IDP2303的120 W 24 V 3.5 A 12 V 3 A SMPS演示板主要特性与指标,电路图,材料清单和PCB设计图。
The IDP2303 is a multi-mode PFC and LLC controller combined with a floating high side driver and a startup cell. Adigital engine provides advanced algorithms for multi-mode operation to support highest efficiency over the whole loadrange. A comprehensive and configurable protection feature set is implemented. Only a minimum of externalcomponents are required with the low pin count DSO-16 package. The integrated HV startup cell and advanced burstmode enable to achieve low stand-by power. In addition a one-time-programming (OTP) unit is integrated to provide awide set of configurable parameters that help to ease the design in phase.
IDP2303产品亮点:
• Integrated 600V startup cell
• Integrated floating driver based on coreless transformer technology
• Digital multi-mode operation for higher efficiency curve
• Supports low stand-by power by means of direct X-cap discharge function andadvanced burst mode control
• Eliminates the auxiliary power supply by means of integrated startup cell andburst mode
• UART interface for communication and in-circuit configuration
• Flexible design-in by means of one time programming capability for a widerange of parameters
IDP2303主要特性:
• Multi-mode PFC
• Configurable PFC gate driver
• Synchronous PFC and LLC burst mode control
• Configurable non-linear LLC VCO curve
• Configurable soft-start
• VAC input voltage sensing and X cap discharge via HVPin
IDP2303应用:
• LCD-TV 75W~ 300W
• Generarl SMPS
图1.IDP2303框图
图2.IDP2303典型应用电路图
The demo board described in this document is a 120 W SMPS using a digital PFC-LLC combi controller (the IDP2303), which is the second generation of digital combi controller with a 16pin package developed by Infineon Technologies. The IDP2303 is specially designed for switch mode power supplies used in TV power system applications.
The IDP2303 is a highly integrated multi-mode power factor correction (PFC) and half-bridge LLC (HB LLC) controller. Multi-mode operation of the PFC controller and zero voltage switching of the LLC MOSFETs can significantly increase the power conversion efficiency, especially light load efficiency, while the system costs are minimized by the integrated high-voltage start-up cell, regulator for the PFC converter, MOSFET drivers and internal communication between the PFC and LLC controllers. The auxiliary power supply can be eliminated by the integrated high-voltage start-up cell and advanced burst mode control. With an active X-CAP discharge function, low stand-by power consumption during burst mode is supported. A comprehensive set of built-in protection features can greatly enhance the system operation and safety. Up to 40 different parameters ensure flexibility during system design and achieve optimal performance. All of these features make the IDP2303 a very competitive AC-DC controller for PFC-HB LLC resonant converter.
DPAK power MOSFETs are used in this reference design. For LED TVs, a slim SMPS board is a desire and also a challenge due to the limitations of active and passive components. Compared to FullPAK MOSFETs which are used in conventional TV SMPS design, DPAK MOSFETs have the advantage of being thinner and also easier to assemble. In this reference design, two IPD60R400CE are used in parallel for the PFC stage, and two IPD60R1K5CE are used in the LLC stage.
图3.DEMO-IDP2303-120W PFC+LLC转换器外形图(正面)
图4.DEMO-IDP2303-120W PFC+LLC转换器外形图(背面)
DEMO-IDP2303-120W主要指标:
图5.DEMO-IDP2303-120W PFC+LLC转换器电路图
DEMO-IDP2303-120W PFC+LLC转换器材料清单:
图6.LLC谐振变压器电路图
图7.DEMO-IDP2303-120W PFC+LLC转换器 PCB元件分布图(正面)
图8.DEMO-IDP2303-120W PFC+LLC转换器 PCB元件分布图(背面)
PFC
47文章
979浏览量
106515 -
LLC控制器
13浏览量
3858
![](https://file.elecfans.com/web2/M00/66/CB/poYBAGMS9p2AIdGbAAOBT-liMTo397.jpg)
请问有人能根据我的描述意图画出大致的电路图或者PCB设计图吗?
Infineon IDP2303120W PFC+LLC转换器参考设计手册
![Infineon <b class='flag-5'>IDP</b>2303120W PFC+LLC转换器参考设计手册](https://file1.elecfans.com//web2/M00/A7/32/wKgZomUMQvKASMIbAABI3F4i9GQ094.png)
LM3434主要特性 DLP投映仪RGB LED驱动器介绍
![LM3434<b class='flag-5'>主要</b><b class='flag-5'>特性</b> DLP投映仪RGB LED驱动器介绍](https://file1.elecfans.com//web2/M00/A7/40/wKgZomUMQ1WAEfruAAAbCl5ZHsM631.gif)
MAX14483优势和特性/应用电路_评估板MAX14483 EVK电路图及PCB设计图
![MAX14483优势和<b class='flag-5'>特性</b>/应<b class='flag-5'>用电路</b>_评估板MAX14483 EVK<b class='flag-5'>电路图</b>及<b class='flag-5'>PCB设计图</b>](https://file1.elecfans.com//web2/M00/A7/4A/wKgZomUMQ5WAat4KAAAzpbpnXfY203.png)
CC1352P主要特性以及pcb电路图
NCP51705主要特性_内部框图以及应用电路
![NCP51705<b class='flag-5'>主要</b><b class='flag-5'>特性</b>_内部框图以及应<b class='flag-5'>用电路</b>](https://file1.elecfans.com//web2/M00/A7/4F/wKgZomUMQ8KAHa2UAAA2ZGvA53o841.png)
ATSAME70Q21的主要特性以及电路图
![ATSAME70Q21的<b class='flag-5'>主要</b><b class='flag-5'>特性</b>以及<b class='flag-5'>电路图</b>](https://file1.elecfans.com//web2/M00/A7/55/wKgZomUMQ_WAGLkIAABK6UCk5Js092.png)
MAX86150的优势特性以及典型应用电路图
![MAX86150的优势<b class='flag-5'>特性</b>以及典型应<b class='flag-5'>用电路图</b>](https://file1.elecfans.com//web2/M00/A7/56/wKgZomUMQ_qAFurrAAAfTXEziAE128.png)
