ST公司的STGIF10CH60TS-L是小型低损耗智能模塑模块(SLLIMM)第二代IPM,包括了ST专有的控制IC(一个LS和一个HS驱动器)和15A/600V抗短路的IGBT, 3.3V, 5 V TTL/CMOS输入,主要用在3相马达驱动逆变器,以及家用电器如洗衣机,空调,冰箱和缝纫机等。本文介绍了STGIF10CH60TS-L主要特性,框图和应用电路,以及1000W马达控制电源板STEVAL-IPM10F主要特性,电路图和材料清单与PCB设计。
This second series of SLLIMM (small low-loss intelligent molded module) provides a compact, high performance AC motor drive in a simple, rugged design. It combines new ST proprietary control ICs (one LS and one HS driver) with an improved short-circuit rugged trench gate field-stop (TFS) IGBT, making it ideal for 3-phase inverter systems such as home appliances and air conditioners. SLLIMM™ is a trademark of STMicroelectronics.
STGIF10CH60TS-L主要特性:
IPM 15 A, 600 V 3-phase IGBT inverter bridge including 2 control ICs for gate driving and freewheeling diodes
3.3 V, 5 V TTL/CMOS inputs with hysteresis
Internal bootstrap diode
Undervoltage lockout of gate drivers
Smart shutdown function
Short-circuit protection
Shutdown input/fault output
Separate open emitter outputs
Built-in temperature sensor
Comparator for fault protection
Short-circuit rugged TFS IGBTs
Very fast, soft recovery diodes
85 kΩ NTC UL 1434 CA 4 recognized
Fully isolated package
Isolation rating of 1500 Vrms/min
STGIF10CH60TS-L应用:
3-phase inverters for motor drives
Home appliances such as washing machines, refrigerators, air conditioners and sewing machine
图1. STGIF10CH60TS-L框图和引脚配置图
图2. STGIF10CH60TS-L应用电路图
The STEVAL-IPM10F is a compact motor drive power board based on SLLIMM™ (small low-loss intelligent molded module) 2nd series (STGIF10CH60TS-L)。 It provides an affordable and easy-to-use solution for driving high power motors for a wide range of applications such as power white goods, air conditioning, compressors, power fans, high-end power tools and 3-phase inverters for motor drives in general. The IPM itself consists of short-circuit rugged IGBTs and a wide range of features like undervoltage lockout, smart shutdown, embedded temperature sensor and NTC, and overcurrent protection.
The main characteristics of this evaluation board are small size, minimal BOM and high efficiency. It consists of an interface circuit (BUS and VCC connectors), bootstrap capacitors, snubber capacitor, hardware short-circuit protection, fault event and temperature monitoring. In order to increase the flexibility, it is designed to work in single- or three-shunt configuration and with double current sensing options such as using three dedicated onboard op-amps, or op-amps embedded in the MCU. The Hall/Encoder part completes the circuit. Thanks to these advanced characteristics, the system has been specifically designed to achieve fast and accurate current feedback conditioning, satisfying the typical requirements for field-oriented control (FOC)。
The STEVAL-IPM10F is compatible with ST ’s STM32-based control board, enabling designers to build a complete platform for motor control.
图3. 1000W马达控制电源板STEVAL-IPM10F外形图(正面)
图4. 1000W马达控制电源板STEVAL-IPM10F外形图(背面)
图5. 1000W马达控制电源板STEVAL-IPM10F架构图
1000W马达控制电源板STEVAL-IPM10F主要特性:
• Input voltage: 125 - 400 VDC
• Nominal power: up to 1000 W
• Nominal current: up to 6 A
• Input auxiliary voltage: up to 20 V DC
• Motor control connector (32 pins) interfacing with ST MCU boards
• Single- or three-shunt resistors for current sensing (with sensing network)
• Two options for current sensing: dedicated op-amps or through MCU
• Overcurrent hardware protection
• IPM temperature monitoring and protection
• Hall sensors (3.3 / 5 V)/encoder inputs (3.3 / 5 V)
• IGBT intelligent power module:
– SLLIMM™ 2nd series IPM (STGIF10CH60TS-L - Full molded package)
• Universal conception for further evaluation with bread board and testing pins
• Very compact size
图6. 1000W马达控制电源板STEVAL-IPM10F电路图(1)
图7. 1000W马达控制电源板STEVAL-IPM10F电路图(2)
图8. 1000W马达控制电源板STEVAL-IPM10F电路图(3)
图9. 1000W马达控制电源板STEVAL-IPM10F电路图(4)
图10. 1000W马达控制电源板STEVAL-IPM10F电路图(5)
图11. 1000W马达控制电源板STEVAL-IPM10F电路图(6)
1000W马达控制电源板STEVAL-IPM10F材料清单:
图12. 1000W马达控制电源板STEVAL-IPM10F PCB设计图(1):顶层
图13. 1000W马达控制电源板STEVAL-IPM10F PCB设计图(2):底层
马达
1文章
885浏览量
65493 -
ST公司
1文章
45浏览量
32622
基于STGIF10CH60TS-L的马达控制电源板解决方案详解
