Diodes AP3302AQC4/4+ 27W Class A充电器解决方案详解
电子工程师 作者:工程师陈翠 2018-06-24 08:23 次阅读
Diodes公司的AP3302A是峰值电流控制准谐振(QR)PWM控制器,具有非常低的起动电流,起动过程软起动,准谐振控制不会产生可听见噪音,频率折返可得到高的平均效率,是高性能低待机功率和成本效率的离线反激转换器,主要用在开关AC/DC适配器/充电器,ATX/BTX辅助电源,机顶盒(STB)电源以及开架开关电源。本文介绍了AP3302A主要特性,框图,应用电路以及QC4/4+ 27W Class A充电器EV1板主要特性和测试结果,电路图,材料清单和PCB设计图。
The AP3302 is a Peak-Current control, Quasi-Resonant (QR) PWM controller which is optimized for high performance, low standby power and cost effective offline flyback converters.
At no load or light load, the IC will enter the burst mode to minimize standby power consumption. The minimum switching frequency (about 22kHz) is set to avoid the audible noise. When the load increases, the IC will enter valley lock QR mode with frequency foldback to improve system efficiency and EMI performance. The maximum switching frequency (about 120kHz) is set to clamp the QR frequency to reduce switching power loss. Furthermore, the frequency dithering function is built in to reduce EMI emission. Internal piecewise linear line compensation ensures constant output power limit over entire universal line voltage range.
Comprehensive protection features are included, such as brown out protection, cycle-by-cycle current limit (OCP), VCC Over Voltage Protection (VOVP), Secondary-side Output OVP (SOVP) and UVP (SUVP), internal OTP, Over Load Protection (OLP) and pins’ fault protection.
AP3302A主要特性:
 Very Low Start-Up Current
 Quasi-Resonant Operation with Valley Lock under All Line and Load Condition
 Non-Audible-Noise Quasi-Resonant Control
 Soft Start During Startup Process
 Frequency Fold Back for High Average Efficiency
 Constant Over Current Protection
 Secondary Winding Short Protection with FOCP
 Frequency Dithering for Reducing EMI
 VCC Maintain Mode
 Useful Pin Fault Protection:
SENSE Pin Floating
FB/Opto-Coupler Open/Short
 Comprehensive System Protection Feature:
 Brown Out Protection (BNO)
 Secondary Side OVP (SOVP) and UVP (SUVP)
 Mini Size Package of SOT26
 Totally Lead-Free & Fully RoHS Compliant (Notes 1 & 2)
 Halogen and Antimony Free. “Green” Device (Note 3)
AP3302A应用:
 Switching AC-DC Adapter/Charger
 ATX/BTX Auxiliary Power
 Set -Top Box (STB) Power Supply
 Open Frame Switching Power Supply
图1.AP3302A框图
图2. AP3302A应用电路图
The 27W QC4/4+ Class A charger Evaluation Board EV1 is composed of three main parts, AP3302A offers the QR PWM switching control & working under the DCM mode with peak current controlling, APR345 is a Synchronous Rectification Controller, and the WT6615F is USB PD and Qualcomm Quick Charge 4/4+ Controller for implementing quick charger decoder functions. Based on monitoring D+ & D- and CC1 & CC2 signals, WT6615F will interprets desired voltage and current setting, and then feedback information to primary side AP3302A controller for providing well regulated voltage and current as well as related power protections.
QC4/4+ 27W Class A充电器EV1板主要特性:
1)。系统主要特性:
 SSR Topology Implementation with an Opto-coupler for Accurate Step Voltage Controlling
 QC4+ Offers QC3.0/QC2.0 Backward Compliance
 Supports the USB PD3.0 Function and PPS (3V-11V@20mV)
 Meet DOE6 and CoC Tier 2 Efficiency Requirements
 《75mW No-Load Standby Power
2)。 AP3302A主要特性:
 Quasi-Resonant Operation with Valley Lock under all Lines and Load Conditions
 Switching Frequency: 22kHz-120kHz
 Non-audible-noise QR Controlling
 Soft Start Process during the Start-up Turn-on Moment
 During the burst mode operation and Low start-up operating quiescent currents, 75mW standby power can be achieved
 Built-in Jittering Frequency Function which is the EMI emission can be improved
 Internal Auto Recovery OCP, OVP, OLP, OTP Power Protection, cycle by cycle current limit, also with DC polarity & transformer short and Brown out Protection
3)。 APR345主要特性:
 Synchronous Rectification Working at DCM, CCM and QR Flyback
 Eliminate Resonant Ringing Interference
 Fewest External Components used
4)。 WT6615F主要特性:
Type-C Source
 USB PD 3.0 v1.1 (PPS)
 BC1.2 DCP
 Qualcomm Quick Charge 4/4+
 Built in Shunt Regulator for Constant Voltage and Constant Current
 Programmable OVP/UVP/OCP/OTP
 Internal Discharge MOS
 Internal Vbus Load Switch Driver
 3V- 30V Operation Voltage without External Regulator
QC4/4+ 27W Class A充电器EV1板应用:
 QC4/4+ Wall Chargers
主要电源指标(CV和CC模式)
图3.QC4/4+ 27W Class A充电器EV1板外形图(背视图)
图4.QC4/4+ 27W Class A充电器EV1板外形图(正视图)
电源指标和测试结果:
图5.QC4/4+ 27W Class A充电器EV1板电路图
QC4/4+ 27W Class A充电器EV1板材料清单:
图6.QC4/4+ 27W Class A充电器EV1板PCB设计图:左:顶层;右:底层
  • Diodes
  • PWM控制器
    大联大友尚集团推出基于Diodes产品的65W ACF Type-C PD3.0充电器方案
    大联大控股宣布,其旗下友尚推出基于达尔科技(DiodesAP3306+APR347+AP43771的65W ACF Type-C PD3.0充电器
    发表于 06-17 14:20 2452次阅读
    大联大友尚集团推出基于<b class='flag-5'>Diodes</b>产品的65<b class='flag-5'>W</b> ACF Type-C PD3.0<b class='flag-5'>充电器</b><b class='flag-5'>方案</b>
    5V1A充电器设计方案
    ` 本帖最后由 maskmyself 于 2016-1-5 13:15 编辑 FMD现推出了FT838MBD、FT839NB、FT839MB三种充电器方案FT838NB是适用于5V1A
    发表于 07-15 10:49
    USB充电器解决方案及限流保护方案
    供应泰德芯片:新型4口USB充电器解决方案:TD1741+TD1742新型6口USB充电器60W快充版
    发表于 07-05 16:07
    详解线性充电器和开关充电器的区别
    的功能。图1:线性充电器图图2:开关充电器图线性充电器开关充电器功耗大,充电电流大更高的效率和更低的功耗简单设计;小
    发表于 04-01 06:30
    Iphone 12充电器PD 20W方案
    快速充电器方案充电功率可达18W, 20W ,27W, 36
    发表于 10-28 09:55
    STSAFE-V110面向车载Qi V1.3无线充电器的身份验证解决方案
    是面向汽车Qi充电器的整体式安全解决方案,符合Qi WPC 1.3规范。它内嵌在Qi充电器中,鉴别真正获得Qi认证的充电器,从而确保用户安全并保护设备免受任何由非认证无线
    发表于 09-08 07:01
    手机充电器解决方案
    本文涉及 TH102 手机充电器解决方案设计技术细节,以及与两款手机充电器竞争方案(POWER INTEGRATIONS INC 的TNY264,ST 的PIVer12
    发表于 08-07 16:38 411次下载
    Diodes公司与伟诠电子推出合作开发的 27W Class A 充电器参考设计
    Diodes 公司与伟诠电子 (Weltrend Semiconductor Inc.) 推出合作开发的 27W Class A 充电器参考
    发表于 05-22 10:28 1135次阅读
    小米9首次加入了有线27W快充和无线20W快充功能
    小米9支持27W有线快充,原配的充电头型号为MDY-10-EH,可以提供四挡电压档位,分别为5V/3A、9V/3A、12V/2.25A、20
    的头像 发表于 04-03 14:45 1.9w次阅读
    联想手机官方回应联想Z6Pro为什么配备27W充电器只支持18W快充
    4月25日消息,有博主发微博表示,联想Z6 Pro配备27W充电器,但是手机本身只支持18W快充。
    的头像 发表于 04-26 11:40 8862次阅读
    方案精选】移动充电快人一步!大联大推出基于DIODES的18W Type-c PD3.0充电器解决方案
    的头像 发表于 06-27 19:39 4729次阅读
    英飞凌15W超薄充电器解决方案
    英飞凌15W超薄充电器解决方案免费下载。
    发表于 04-16 14:24 20次下载
    基于QC4/4+ 27W AP3302A+APR345+WT6615F交流到直流多输出电源的参考设计
    View the reference design for QC4/4+ 27W AP3302A+APR345+WT6615F. http://www.elecfans.com/sof
    发表于 07-01 21:46 6次下载
    基于QC<b class='flag-5'>4</b>/<b class='flag-5'>4+</b> <b class='flag-5'>27W</b> <b class='flag-5'>AP3302A</b>+APR345+WT6615F交流到直流多输出电源的参考设计
    有了这组强大的芯片,轻松Get√ 27W电源适配器解决方案
    是基于一个能适用于宽输入电压范围,输出功率27W方案,输出9V3A的工程样机,控制IC采用了思睿达主推的CR5159TN和CR85V25RS。CR5159TN+CR85
    的头像 发表于 01-07 14:02 1214次阅读
    有了这组强大的芯片,轻松Get√ <b class='flag-5'>27W</b>电源适配器<b class='flag-5'>解决方案</b>
    CR5159 9V3A_27W充电器电源适配器方案
    骊微电子提供CR5159高性能CCM+PFM绿色节能PWM控制芯片,提供CR51599V3A_27W充电器电源适配器方案,是启辰微代理商可提供样品申请及技术支持。>>
    发表于 03-02 10:42 6次下载
