Microsemi LX7730耐辐射遥测系统控制器解决方案
电子工程师 作者:工程师陈翠 2018-07-14 11:03 次阅读
Microsemi公司的LX7730是耐辐射遥测系统控制器,作为FPGA的姐妹器件,包括了64个通用输入复接器,可以配置差分或单端传感器输入端,集成了13kSPS 12位ADC和10位DAC,可调电流源精度3%,1%精度的5.00V电压源,具有阈值监测,支持并行或两个SPI接口,耐辐射容差为100krad TID,50kad ELDRS,主要用在数字通信,有效载荷设备遥控,遥测系统跟踪和控制,透明射频应答器,航天器健康监测和姿态控制系统。本文介绍了LX7730主要特性,框图,传感器扩展器框图,典型应用电路图以及LX7730 MKT评估板主要特性和电路图。
The LX7730 is a spacecraft telemetry manager IC that functions as a companion to the FPGA. The LX7730 contains a 64 universal input multiplexer that can be configured as a mix of differential or single ended sensor inputs. There is a programmable current source that can be directed to any of the 64 universal inputs. The universal inputs can be sampled with a 12 bit analog-to-digital converter at a sample rate up to 13kHz. The universal inputs can also function as variable bi-level inputs with the threshold set by an internal 8 bit digital-to-analog converter. There is an additional 10 bit digital-to- analog current DAC with complementary outputs. Finally there are 8 fixed threshold bi-level inputs.
The LX7730 is register programmable with 17 addressable eight bit registers. Two options are available for communication with the host FPGA. First there is an eight bit parallel bus with 5 address bits and a read/write bit that can communicate at a speed of up to 25MHz. The second option is a pair of 12.5Mbps SPI interfaces that can support redundant (alternating not simultaneous) communication to two different hosts.
The LX7730 offers 1 kV ESD pin protection on FPGA interface pins and 500V ESD protection to all CH# and BLI# pins. The dielectric isolated process is failsafe. The LX7730 has enable registers that allow most of the device to be shut down to reduce power consumption and supports cold sparing on its signal pins.
The controller is designed for use in rugged environments. It is packaged in a 132 pin ceramic quad flat pack and operates over a -55℃ to 125℃ temperature range. It is radiation tolerant to 100krad TID and 50krad ELDRs as well as single event effects.
LX7730主要特性:
64 channel MUX
Break-before-make switching
13kSPS 12 bit ADC
3% Precision Adjustable Current Source
1% Precision 5.00V Source
Threshold Monitoring
8 x Bi-level Logic
10 bit DAC
Supports Parallel or Dual SPI Interface
Radiation Tolerant: 100krad TID, 50kad ELDRS
LX7730应用:
Spacecraft Health Monitoring
Attitude Control
Payload Equipment
图1. LX7730应用框图
图2.LX7730顶级框图
图3.LX7730传感器扩展器框图
图4.LX7730典型应用电路图
LX7730 MKT评估板
The LX7730 Evaluation board is basically a ‘breakout box’ that allows the user when it’s coupled with the included USB to serial interface and application software to exercise the controller’s features. The included USB to serial interface is the Future Technologies Device International (FTDI) C232HM-DDHSL-0 cable assembly. USB device drivers must be loaded on host computer along with the LX7730 application software to utilize the LX7730 evaluation board as shipped.
图5.LX7730 MKT评估板外形图
图6.传感器复接器框图
图7.LX7730 MKT评估板电路图
The LX7730 daughter board is designed to allow the user to exercise the controller’s feature throughRTG4 evaluation board and the provided application interface. The included granddaughter board isused to provide LX7730 input sensor data.
图8.LX7730子板和孙子板外形图
图9.LX7730子板和孙子板连接建立图
图10.RTG4板连接器建立图
图11.LX7730插座连接器电路
图12.FMC连接器LPC电路图
图13.降压升压稳压器电路图
图14.子板电路图
  • Microsemi
    基于Microsemi FPGA的TFT控制的四大解决方案
    目前,TFT控制器主要用专用芯片、自带控制器的MCU以及FPGA来实现,基于FPGA的方案以其实现灵活性、低成本以及高可靠性的特点,越来越被大家所接受,并且广泛的应用。本文为您介绍四种基于Mi
    发表于 05-07 11:14 1889次阅读
    Microsemi可探测亮度最低的光传感LX1973B
    LX1973B(tm)的特点是采用创新的穹顶形透镜封装,以及暗电流消除技术对最低亮度等级进行优化,是汽车显示、自动调光镜和头灯亮度自动控制的理想解决方案;也可用于笔记本电脑、LCD监
    发表于 10-29 15:44
    Microsemi可见光传感LX1973B可探测极低亮度
    优化,是汽车显示、自动调光镜和头灯亮度自动控制的理想解决方案;也可用于笔记本电脑、LCD监视、TV、手持显示、便携式电话、数码相机、公
    发表于 11-16 16:02
    高价回收发那科O系统 回收FANUC OI系 回收基恩士康视视觉系统控制器模块
    高价回收发那科O系统 回收FANUC OI系 回收基恩士康视视觉系统控制器模块高价回收发那科O系统 回收FANUC OI系 回收基恩士康
    发表于 12-07 13:25
    变速变桨距风力发电系统的逆系统控制器性能评估
    基于风机模拟实验平台,本文验证了作者提出的用于风力发电系统桨距角控制的逆系统控制器的性能。由于系统动态呈典型的非仿射非线性特性,该控制器根据
    发表于 04-08 15:38 46次下载
    调整系统控制量的模糊PID 控制器的计算机设计与仿真
    该文提出调整系统控制量的模糊 PID 控制器的计算机设计与仿真。以碱回收炉的水位控制为例具体论述调整系统控制量的模糊PID 控制器的设计、2
    发表于 06-09 16:41 20次下载
    LX1752(tm) 双PWM控制器,,提高功率变换效率
    Microsemi近日宣布已制作出它的LX1752(tm) 双PWM 控制器新产品,该控制器能够对机顶盒、宽带调制解调、数字电视和数据中心
    发表于 10-31 07:40 875次阅读
    Microsemi推出液晶电视的CCFL背光逆变器的控制器L
    Microsemi推出液晶电视的CCFL背光逆变器的控制器LX6523A Microsemi公司宣布推出用于26~37英寸LCD TV的冷阴极荧光灯(CCFL)背光逆变器的
    发表于 02-26 08:44 1525次阅读
    Microsemi宣布全系列背光-驱动IC方案中添加LX24
    Microsemi宣布全系列背光-驱动IC方案中添加LX24132和LX23108L Microsemi公司,日前宣布在它所有的全系列背光
    发表于 03-02 08:34 873次阅读
    光电跟踪系统控制器硬件设计
    为了提高光电跟踪系统控制器的性能,文中对光电跟踪系统控制器的硬件部分进行了设计。首先给出光电跟踪系统控制器硬件电路框图。接着介绍最小系统的设计方案
    发表于 09-12 17:02 81次下载
    实车碰撞车速控制系统控制器的设计与实现
    实车碰撞车速控制系统控制器的设计与实现
    发表于 01-24 15:45 8次下载
    负压系统控制器的功能作用
    负压系统控制器分为高低限报警、消毒指示灯、电源开关、负压控制器;高低限报警是指设定额定最高控制负压数值及最低负压数值;该负压控制器在负压救护车正常工作中可实时监测箱体内的气压状况。 三
    发表于 03-20 11:25 2148次阅读
    AD7730L-微控制器无操作系统驱动程序
    发表于 04-22 14:42 10次下载
    AD<b class='flag-5'>7730</b>L-微<b class='flag-5'>控制器</b>无操作<b class='flag-5'>系统</b>驱动程序
    辐射V类高速PWM控制器UC1825PWM数据表
    电子发烧友网站提供《辐射V类高速PWM控制器UC1825PWM数据表.pdf》资料免费下载
    发表于 04-08 09:16 0次下载
    <b class='flag-5'>耐</b><b class='flag-5'>辐射</b>V类高速PWM<b class='flag-5'>控制器</b>UC1825PWM数据表
    辐射V类精密模拟控制器UC19432数据表
    电子发烧友网站提供《辐射V类精密模拟控制器UC19432数据表 .pdf》资料免费下载
    发表于 04-08 11:23 0次下载
    <b class='flag-5'>耐</b><b class='flag-5'>辐射</b>V类精密模拟<b class='flag-5'>控制器</b>UC19432数据表
