如何实现 Tomcat 服务双机热备?
马哥Linux运维 来源:未知 作者:工程师李察 2018-07-28 08:36 次阅读
1. 规划
1.1服务器环境规划
负载服务器master及WEB服务器1真实IP:10.10.195.53
负载服务器backup及WEB服务器2真实IP:10.10.195.190
负载服务器虚拟ip:10.10.195.212
1.2 软件环境规划
操作系统:Red Hat Enterprise Linux Server release 5.6 (Tikanga)
keepalived:keepalived-1.2.19
Java:jdk-1.7.0_79
Tomcat:apache-tomcat-7.0.64
2. 负载服务器配置
这里只叙述如何安装配置keepalived,至于java以及tomcat的安装及配置,这里不赘述。
2.1 安装keepalived
[~]tar -zxvf keepalived-1.2.19.tar.gz
[~] cd keepalived-1.2.19
[keepalived-1.2.19] ./configure --prefix=/usr/local/keepalived --disable-fwmark
#(如果直接输入./configure有可能报错:configure:error: No SO_MARK declaration in headers)
[keepalived-1.2.19] make
[keepalived-1.2.19] make install
2.2 配置keepalived服务
[keepalived-1.2.19] cp /usr/local/keepalived/sbin/keepalived /usr/sbin/
[keepalived-1.2.19] cp /usr/local/keepalived/etc/sysconfig/keepalived /etc/sysconfig/
[keepalived-1.2.19] cp /usr/local/keepalived/etc/rc.d/init.d/keepalived /etc/init.d/
[keepalived-1.2.19] mkdir /etc/keepalived
[keepalived-1.2.19] cp /usr/local/keepalived/etc/keepalived/keepalived.conf/etc/keepalived/
[keepalived-1.2.19] chkconfig --add keepalived
[keepalived-1.2.19] chkconfig keepalived on
重启\启动\关闭\查看状态keepalived
service keepalived restart
service keepalived start
service keepalived stop
service keepalived status
2.3 配置keepalived.conf文件
[~]mv /etc/keepalived/keepalived.conf/etc/keepalived/keepalived.conf.bak
[~]vi /etc/keepalived//keepalived.conf
主备机的keepalived.conf文件大致相同,只是注意红色标注的地方。
主机配置:
global_defs {
router_id NodeA
vrrp_script chk_http_port {
script "/opt/tomcat.pid"
interval 5
weight 2
vrrp_instance VI_1 {
state MASTER
interface eth0
virtual_router_id 52
priority 150
advert_int 1
authentication {
auth_type PASS
auth_pass 1111
track_script {
chk_http_port
virtual_ipaddress {
10.10.195.212
备机配置:
global_defs {
router_id NodeB
interval 5
weight 2
state BACKUP
interface eth0
priority 100
advert_int 1
authentication {
auth_type PASS
auth_pass 1111
track_script {
chk_http_port
virtual_ipaddress {
10.10.195.212
2.4配置/opt/tomcat.pid
#!/bin/bash
#description: check tomcat service anddecide whether stop the keepalived or not
#edited by zzh: 2015-10-14
CATALINA_HOME=/users/shr/apache-tomcat-7.0.64
JAVA_HOME=/users/shr/util/JavaDir/jdk
export CATALINA_HOME
export JAVA_HOME
ps ax --width=1000 | grep"org.apache.catalina.startup.Bootstrap start" | grep -v"grep" | awk '{printf $1 " "}' | wc | awk '{print $2}' >tomcat_process_count.txt
read line < tomcat_process_count.txt
start_tomcat=$CATALINA_HOME/bin/startup.sh
if [ ${line} -lt 1 ]
then
echo -n "===Starting tomcat===:"
${start_tomcat}
# :sudo service tomcat start
echo "===tomcat start ok.==="
sleep 3
# check the tomcat status.
ps ax --width=1000 | grep "org.apache.catalina.startup.Bootstrapstart" | grep -v "grep" | awk '{printf $1 " "}' | wc |awk '{print $2}' > tomcat_process_count.txt
read line2 < tomcat_process_count.txt
if [ ${line2} -lt 1 ]
then
sudo service keepalived stop
fi
fi
rm tomcat_process_count.txt
#shell end.
3. 日志查看
3.1 正常启动
输入tail -f /var/log/messages查看启动keepalived日志:
(MASTER:10.10.195.53)
Sep 29 15:49:16 shr Keepalived[5536]:Starting Keepalived v1.2.19 (09/21,2015)
Sep 29 15:49:16 shrKeepalived_healthcheckers[5538]: Netlink reflector reports IP 10.10.195.53added
Sep 29 15:49:16 shrKeepalived_healthcheckers[5538]: Registering Kernel netlink reflector
Sep 29 15:49:16 shrKeepalived_healthcheckers[5538]: Registering Kernel netlink command channel
Sep 29 15:49:16 shrKeepalived_healthcheckers[5538]: Opening file'/etc/keepalived/keepalived.conf'.
Sep 29 15:49:16 shrKeepalived_healthcheckers[5538]: Configuration is using : 6572 Bytes
Sep 29 15:49:16 shr Keepalived[5537]:Starting Healthcheck child process, pid=5538
Sep 29 15:49:16 shr Keepalived_healthcheckers[5538]:Using LinkWatch kernel netlink reflector...
Sep 29 15:49:16 shr Keepalived_vrrp[5539]:Netlink reflector reports IP 10.10.195.53 added
Sep 29 15:49:16 shr Keepalived[5537]:Starting VRRP child process, pid=5539
Sep 29 15:49:16 shr Keepalived_vrrp[5539]:Registering Kernel netlink reflector
Sep 29 15:49:16 shr Keepalived_vrrp[5539]:Registering Kernel netlink command channel
Sep 29 15:49:16 shr Keepalived_vrrp[5539]:Registering gratuitous ARP shared channel
Sep 29 15:49:16 shr Keepalived_vrrp[5539]:Opening file '/etc/keepalived/keepalived.conf'.
Sep 29 15:49:16 shr Keepalived_vrrp[5539]:Configuration is using : 36541 Bytes
Sep 29 15:49:16 shr Keepalived_vrrp[5539]:Using LinkWatch kernel netlink reflector...
Sep 29 15:49:16 shr Keepalived_vrrp[5539]:VRRP sockpool: [ifindex(2), proto(112), unicast(0), fd(10,11)]
Sep 29 15:49:17 shr Keepalived_vrrp[5539]:VRRP_Instance(VI_1) Transition to MASTER STATE
Sep 29 15:49:17 shr Keepalived_vrrp[5539]:VRRP_Instance(VI_1) Received lower prio advert, forcing new election
Sep 29 15:49:18 shr Keepalived_vrrp[5539]:VRRP_Instance(VI_1) Entering MASTER STATE
Sep 29 15:49:18 shr Keepalived_vrrp[5539]:VRRP_Instance(VI_1) setting protocol VIPs.
Sep 29 15:49:18 shr Keepalived_vrrp[5539]:VRRP_Instance(VI_1) Sending gratuitous ARPs on eth0 for 10.10.195.212
Sep 29 15:49:18 shr Keepalived_vrrp[5539]:Netlink reflector reports IP 10.10.195.212 added
Sep 29 15:49:18 shrKeepalived_healthcheckers[5538]: Netlink reflector reports IP 10.10.195.212added
Sep 29 15:49:23 shr Keepalived_vrrp[5539]:VRRP_Instance(VI_1) Sending gratuitous ARPs on eth0 for 10.10.195.212
(BACKUP:10.10.195.190)
Sep 29 15:46:25 server1 Keepalived[18218]:Starting Keepalived v1.2.19 (09/25,2015)
Sep 29 15:46:25 server1Keepalived_healthcheckers[18220]: Netlink reflector reports IP 10.10.195.190added
Sep 29 15:46:25 server1Keepalived_healthcheckers[18220]: Registering Kernel netlink reflector
Sep 29 15:46:25 server1Keepalived_healthcheckers[18220]: Registering Kernel netlink command channel
Sep 29 15:46:25 server1 Keepalived_healthcheckers[18220]:Opening file '/etc/keepalived/keepalived.conf'.
Sep 29 15:46:25 server1Keepalived_healthcheckers[18220]: Configuration is using : 6682 Bytes
Sep 29 15:46:25 server1 Keepalived[18219]:Starting Healthcheck child process, pid=18220
Sep 29 15:46:25 server1 Keepalived[18219]:Starting VRRP child process, pid=18221
Sep 29 15:46:25 server1Keepalived_vrrp[18221]: Netlink reflector reports IP 10.10.195.190 added
Sep 29 15:46:25 server1Keepalived_healthcheckers[18220]: Using LinkWatch kernel netlink reflector...
Sep 29 15:46:25 server1Keepalived_vrrp[18221]: Registering Kernel netlink reflector
Sep 29 15:46:25 server1Keepalived_vrrp[18221]: Registering Kernel netlink command channel
Sep 29 15:46:25 server1Keepalived_vrrp[18221]: Registering gratuitous ARP shared channel
Sep 29 15:46:25 server1Keepalived_vrrp[18221]: Opening file '/etc/keepalived/keepalived.conf'.
Sep 29 15:46:25 server1 Keepalived_vrrp[18221]:Configuration is using : 36651 Bytes
Sep 29 15:46:25 server1Keepalived_vrrp[18221]: Using LinkWatch kernel netlink reflector...
Sep 29 15:46:25 server1Keepalived_vrrp[18221]: VRRP_Instance(VI_1) Entering BACKUP STATE
Sep 29 15:46:25 server1 Keepalived_vrrp[18221]:VRRP sockpool: [ifindex(2), proto(112), unicast(0), fd(10,11)]
3.2 主备切换
l 当在主机(MASTER:10.10.195.53)中输入 sudoservice keepalived stop,此时就会进行主备切换,主机切换成备机。
主机(MASTER:10.10.195.53)输出如下
Oct 14 13:25:09 shr Keepalived_vrrp[26683]:VRRP_Instance(VI_1) sending 0 priority
Oct 14 13:25:09 shr Keepalived_vrrp[26683]:VRRP_Instance(VI_1) removing protocol VIPs.
Oct 14 13:25:09 shrKeepalived_healthcheckers[26682]: Netlink reflector reports IP 10.10.195.212removed
Oct 14 13:25:09 shr Keepalived[26681]:Stopping Keepalived v1.2.19 (09/21,2015)
备机(BACKUP:10.10.195.190)输出如下
Oct 14 13:19:58 server1Keepalived_vrrp[30890]: VRRP_Instance(VI_1) Transition to MASTER STATE
Oct 14 13:19:59 server1Keepalived_vrrp[30890]: VRRP_Instance(VI_1) Entering MASTER STATE
Oct 14 13:19:59 server1Keepalived_vrrp[30890]: VRRP_Instance(VI_1) setting protocol VIPs.
Oct 14 13:19:59 server1Keepalived_vrrp[30890]: VRRP_Instance(VI_1) Sending gratuitous ARPs on eth0 for10.10.195.212
Oct 14 13:19:59 server1 Keepalived_healthcheckers[30889]:Netlink reflector reports IP 10.10.195.212 added
Oct 14 13:19:59 server1Keepalived_vrrp[30890]: Netlink reflector reports IP 10.10.195.212 added
Oct 14 13:20:04 server1Keepalived_vrrp[30890]: VRRP_Instance(VI_1) Sending gratuitous ARPs on eth0 for10.10.195.212
l 当在主机(MASTER:10.10.195.53)中输入sudoservice keepalived start,此时就会切换成主机。备机(BACKUP:10.10.195.190)输出如下信息
Oct 14 13:25:11 server1Keepalived_vrrp[30890]: VRRP_Instance(VI_1) Received higher prio advert
Oct 14 13:25:11 server1Keepalived_vrrp[30890]: VRRP_Instance(VI_1) Entering BACKUP STATE
Oct 14 13:25:11 server1Keepalived_vrrp[30890]: VRRP_Instance(VI_1) removing protocol VIPs.
Oct 14 13:25:11 server1Keepalived_healthcheckers[30889]: Netlink reflector reports IP 10.10.195.212removed
Oct 14 13:25:11 server1Keepalived_vrrp[30890]: Netlink reflector reports IP 10.10.195.212 removed
4. 查看虚拟ip
可以通过ip add show命令查看添加的虚拟ip:
[shr@shr bin]$ip add show
1: lo: mtu16436 qdisc noqueue
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
2: eth0: mtu 1500 qdisc pfifo_fast qlen 1000
link/ether 00:0c:29:6b:f2:a8 brd ff:ff:ff:ff:ff:ff
inet 10.10.195.53/24 brd 10.10.195.255 scope global eth0
inet 10.10.195.212/32scope global eth0
5. 常见错误
5. 1常见错误一:
/var/log/messages has thousands of errorslike this:
Jun 28 09:18:32 rust Keepalived_vrrp:receive an invalid ip number count
associated with VRID!
Jun 28 09:18:32 rust Keepalived_vrrp: bogusVRRP packet received on eth0 !!!
Jun 28 09:18:32 rust Keepalived_vrrp:VRRP_Instance(VI_1) Dropping received
VRRP packet...
The backup director starts up, but doesn'tlisten on the virtual addresses
at all. Its /var/log/messages has thousands of errors like this:
Jun 28 06:25:05 stye Keepalived_vrrp:receive an invalid ip number count
Jun 28 06:25:05 stye Keepalived_vrrp: bogusVRRP packet received on eth0 !!!
Jun 28 06:25:05 stye Keepalived_vrrp:VRRP_Instance(VI_1) ignoring received
advertisment...
解决方法:
改变配置文件/etc/keepalived/keepalived.conf中virtual_router_id为另一个值即可。
(changed the vrid to another number and it worked fine).
5.2 常见错误二:
主机执行到VRRP_Instance(VI_1) Entering BACKUP STATE之后没有执行VRRP_Instance(VI_1)setting protocol VIPs。
解决方法:
可能是配置文件keepalived.conf中{左边没有空格。
linux添加tomcat服务
在/etc/init.d中输入 sudo vim tomcat
脚本具体内容如下:
#!/bin/bash
#chkconfig: 2345 10 90
#description: Starts and Stops the tomcatdaemon
#edited by ZZH: 2015-10-14
export JAVA_HOME
stop_tomcat=$CATALINA_HOME/bin/shutdown.sh
if [ ! -f $CATALINA_HOME/bin/catalina.sh ]
then
echo"===Tomcat is not available.==="
exit
fi
start()
echo-n "===Starting tomcat===:"
${start_tomcat}
echo"===tomcat start ok.==="
stop()
echo-n "===Shutting down tomcat===:"
${stop_tomcat}
echo"===tomcat stop ok.==="
status()
ps ax --width=1000 | grep"org.apache.catalina.startup.Bootstrap start" | grep -v"grep" | awk '{printf $1 " "}' | wc | awk '{print $2}'> tomcat_process_count.txt
readline < tomcat_process_count.txt
rmtomcat_process_count.txt
if[ $line -gt 0 ]
then
echo-n "tomcat ( pid = "
ps ax --width=1000 | grep"org.apache.catalina.startup.Bootstrap start" | grep -v"grep" | awk '{printf $1 " "}' | awk '{print $1}'> tomcat_process_pid.txt
readpid < tomcat_process_pid.txt
rmtomcat_process_pid.txt
echo-n $pid
echo-n ") is running..."
echo
else
echo"tomcat is stopped"
fi
case "$1" in
start)
start
stop)
stop
restart)
stop
sleep1
start
status)
status
echo"Usage:$0 {start|stop|restart}"
exit1
esac
exit 0
# shell end.
在终端输入:
sudo chmod 755 tomcat
sudo chkconfig --add tomcat
tomcat 启动 service tomcatstart
tomcat 关闭 service tomcatstop
tomcat 重启 service tomcatrestart
tomcat状态查看 service tomcatstatus
  • 负载
  • 服务器
  • JAVA
原文标题:keepalived 实现 Tomcat 服务双机热备
文章出处:【微信号:magedu-Linux,微信公众号:马哥Linux运维】欢迎添加关注!文章转载请注明出处。
    防火墙双机命令行配置方案
    部署防火墙双机,避免防火墙出现单点故障而导致的网络瘫痪
    的头像 发表于 01-02 09:45 1150次阅读
    防火墙<b class='flag-5'>双机</b><b class='flag-5'>热</b><b class='flag-5'>备</b>命令行配置方案
    浅析Tomcat服务
    Tomcat服务器是一个免费的开放源代码的Web应用服务器。因为Tomcat技术先进、性能稳定且免费,所以深受Java爱好者的喜爱并得到了部分软件开发商的认可,成为目前比较流行的Web
    发表于 07-16 06:23
    Tomcat服务器简介
    简介简介Tomcat服务器是一个开放源码的轻量级Web应用服务器,非常适合搭建微服务应用。Embedded Tomcat嵌入式
    发表于 12-16 08:24
    双机单片机系统内部通信接口的简化设计
    双机单片机系统内部通信接口的简化设计 分析了工业测控系统中双机单片机系统内部通信的特点
    发表于 10-01 22:02 13次下载
    双机与负载均衡的设计与实现
    针对OpenFlow SDN系统中的策略管理模块提出了一种新型的双机和负载均衡方案,采用了服务器集群的方式,通过Keepalived和Heartbeat
    发表于 12-24 17:57 10次下载
    基于EHW和双机技术的故障自修复电路系统设计
    基于EHW和双机技术的故障自修复电路系统设计_张峻宾
    发表于 01-07 18:39 0次下载
    双机和冷的区别
    双机特指基于高可用系统中的两台服务器的(或高可用),因两机高可用在国内使用较多,故得名
    发表于 11-21 15:15 4.3w次阅读
    <b class='flag-5'>双机</b><b class='flag-5'>热</b><b class='flag-5'>备</b>和冷<b class='flag-5'>备</b>的区别
    双机和集群的区别
    所谓双机,就是将中心服务器安装成互为备份的两台服务器,并且在同一时间内只有一台服务器运行。当
    发表于 11-21 15:37 1.3w次阅读
    VMWare7.0虚拟机双机图列教程资料免费下载
    本文档的主要内容详细介绍的是VMWare7.0虚拟机双机图列教程资料免费下载。
    发表于 06-12 15:59 8次下载
    推荐几款服务器的Windows与Linux双机软件
    服务商。今天小编就给大家推荐几款服务器的Windows与Linux双机软件! 众所周知,双机
    发表于 11-12 14:16 3141次阅读
    你知道国产双机双机的意思吗
    机的应用系统切换到另一台主机上继续运行,及时地进行错误隔绝、恢复,以最低成本实现用户几乎不停顿的业务应用。 但高可用软件也分为双机和冷
    的头像 发表于 06-29 10:46 2671次阅读
    你知道国产<b class='flag-5'>双机</b><b class='flag-5'>热</b><b class='flag-5'>备</b>与<b class='flag-5'>双机</b>冷<b class='flag-5'>备</b>的意思吗
    双机原理很神秘?看完这文,让你秒懂
    络,一旦该设备或该设备所在链路出现故障,就会极大地影响了用户的网络体验。网络可靠性技术中的双机功能就能很好的解决这个问题。新支点双机
    的头像 发表于 07-07 15:55 2480次阅读
    <b class='flag-5'>双机</b><b class='flag-5'>热</b><b class='flag-5'>备</b>原理很神秘?看完这文,让你秒懂
    企业实施服务双机方案存在重要意义
    随着网络信息不断的发展,现在很多企业对于服务器的要求比较苛刻,需要保证服务器无休止的运转服务,这对于服务器来说无疑会出现故障,给企业带来影响,那么怎么保证
    的头像 发表于 07-12 15:20 1852次阅读
    防火墙双机组网环境中的IPSecVPN实验步骤及配置
    FW1/FW2部署双机,采用主方式,FW1为主设备,FW2为设备;
    的头像 发表于 11-08 09:41 3479次阅读
    路由器功能介绍-双机备份机制
    我们以东用科技的ORB305系列工业级路由器为例,来为大家简单介绍一下。所谓的双机无非就是以7X24小时不中断的为企业提供服务为目的,各种双机
    的头像 发表于 10-08 09:16 1445次阅读
    路由器功能介绍-<b class='flag-5'>双机</b><b class='flag-5'>热</b>备份机制
