手头上攒了一些手机电池不知道干嘛就寻思着做一些小玩意,于是就有了一个主意就是摇摇棒即简单又好玩,本人喜欢小而巧的东西所以就把这个东西做的很小。
上图是摇摇棒的原理利用人的视觉暂留结合单片机控制LED的亮灭就可以在空中显示字符或者图标。
上图是电路图为了把东西做小我选择了STC15F104单片机它有8个引脚去除VCC和GND还有6个I/O口可以显示一些简单的字母和数字单片机内部自带了EEPROM所以利用它可以存储每一次显示的状态(每一次的开关电源就可以切换到下一个显示的字符)
程序在最后面。
代码在下面:
#include
#define uchar unsigned char
#define EN_EPROM 0x83; //使能EEPROM
#define S_MODE 0x00; //待机模式
#define R_MODE 0x01; //读模式
#define W_MODE 0x02; //写模式
#define F_MODE 0x03; //擦除模式
sfr IAP_DATA = 0xC2;
sfr IAP_ADDRH = 0xC3;
sfr IAP_ADDRL = 0xC4;
sfr IAP_CMD = 0xC5;
sfr IAP_TRIG = 0xC6;
sfr IAP_CONTR = 0xC7;
void init();
uchar num=0,m=0;
uchar read_dat(uchar addr_h,uchar addr_l);
void erase_dat(uchar addr_h,uchar addr_l);
void write_dat(uchar addr_h,uchar addr_l,uchar w_dat);
unsigned char code tab[10][32]={
0xe7,0xc3,0xc1,0xe0,0xc1,0xc3,0xe7,0xff,
0xff,0xff,0xff,0xe7,0xc3,0xc1,0xe0,0xc1,
0xc3,0xe7,0xff,0xff,0xff,0xff,0xe7,0xc3,
0xc1,0xe0,0xc1,0xc3,0xe7,0xff,0xff,0xff
0xff,0xff,0xde,0xc0,0xde,0xff,0xff,0xff,
0xc3,0xe7,0xff,0xff,0xff,0xff,0xff,0xc1,
0xfe,0xfe,0xfe,0xfe,0xc1,0xff,0xff,0xff
0xde,0xed,0xf3,0xf3,0xed,0xde,0xff,0xff,
0xff,0xff,0xff,0xde,0xed,0xf3,0xf3,0xed,
0xde,0xff,0xff,0xff,0xff,0xff,0xff,0xde,
0xed,0xf3,0xf3,0xed,0xde,0xff,0xff,0xff
0xfb,0xfd,0xd6,0xe8,0xd6,0xfd,0xfb,0xff,
0xff,0xff,0xff,0xfb,0xfd,0xd6,0xe8,0xd6,
0xfd,0xfb,0xff,0xff,0xff,0xff,0xfb,0xfd,
0xd6,0xe8,0xd6,0xfd,0xfb,0xff,0xff,0xff
0xea,0xd5,0xea,0xd5,0xea,0xd5,0xea,0xd5,
0xfa,0xfd,0xfa,0xff,0xef,0xd7,0xef,0xff,
0xf0,0xed,0xdd,0xed,0xf0,0xff,0xff,0xdf,
0xdf,0xc0,0xdf,0xdf,0xff,0xff,0xc1,0xfe,
0xfe,0xfe,0xc1,0xff,0xff,0xc1,0xfe,0xf1,
0xfe,0xc1,0xff,0xff,0xe1,0xde,0xde,0xe1
0xc0,0xfb,0xfb,0xfb,0xc0,0xff,0xff,0xff,
0xff,0xff,0xde,0xed,0xf3,0xf3,0xed,0xde,
0xff,0xff,0xff,0xff,0xff,0xff,0xcf,0xf7,
0xf8,0xf7,0xcf,0xff,0xff,0xff,0xff,0xff
0xc0,0xde,0xd2,0xda,0xda,0xc2,0xfe,0xc0,
0xdf,0xd0,0xd6,0xd6,0xd2,0xde,0xc0,0xff,
0xdf,0xef,0xf7,0xfb,0xfd,0xfe,0xfd,0xfb,
0xf7,0xef,0xdf,0xef,0xf7,0xfb,0xfd,0xfe,
0xfd,0xfb,0xf7,0xef,0xdf,0xef,0xf7,0xfb,
0xfd,0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xff
void delay(uchar xms)
char i,j;
for(i=0;i for(j=0;j《50;j++);
void main()
init();
num=read_dat(0x00,0x01);
++num;
if(num》=11)
num=1;
erase_dat(0x00,0x01);
write_dat(0x00,0x01,num);
while(1)
uchar i=0;
for(i=0;i《32;i++)
P3=tab[num-1][i];
delay(100);
void init()
IAP_CONTR = EN_EPROM; //把第7位置1允许EEPROM可以读写
IAP_CMD = S_MODE; //待机模式无ISP操作
IAP_ADDRH = 0x00;
IAP_ADDRL = 0x00;
uchar E_dat = 0x00;
IAP_CMD = R_MODE; //模式选择为读EEPROM
IAP_ADDRH = addr_h;
IAP_ADDRL = addr_l;
IAP_TRIG = 0x5A; //使命令有效
IAP_TRIG = 0xA5; //使命令有效
E_dat = IAP_DATA;
return E_dat;
IAP_CMD = W_MODE; //模式选择为写EEPROM
IAP_ADDRH = addr_h;
IAP_ADDRL = addr_l;
IAP_DATA = w_dat;
IAP_CMD = F_MODE; //模式选择为擦除EEPROM
IAP_ADDRH = addr_h;
IAP_ADDRL = addr_l;
单片机
6037文章
44562浏览量
635819 -
摇摇棒
10文章
61浏览量
30906
