Avnet公司的MiniZed是Xilinx公司的单核Zynq 7Z007S器件的开发板,目标在具有低成本原型平台的入门级Zynq开发设计师,可使设计者开发或评估Zynq处理器子系统(PS)和可编逻辑(PL)架构.开发板具有通过USB, Wi-Fi和蓝牙进行板上连接,外设能插入两个Pmod兼容的连接器, Arduino兼容的屏蔽接口或USB 2.0主接口, JTAG电路使用一根电缆通过 USB口连接笔记本电脑,就可以使开发板运行起来.主要应用在入门级/低成本Zynq开发环境,采Wi-Fi和蓝牙的无线设计和演示,采用麦克风输入的音频信号处理,板上和外设传感器的IoT/云连接.本文介绍了MiniZed开发板主要特性和所支持特性,框图和拓扑图,电路图,材料清单和PCB设计图.
MiniZed™ is a single-core Zynq 7Z007S development board.With the advent of the latest cost-optimized portfolio fromXilinx, this board targets entry-level Zynq developers witha low-cost prototyping platform.
This compact design features on-board connectivity through USB, Wi-Fi andBluetooth. Peripherals can be plugged into dual Pmod-compatible connectors,the Arduino-compatible shield interface or the USB 2.0 host interface. JTAGcircuitry is incorporated onto the MiniZed base board, so with a single micro-USB cable to your laptop you are already up and running. User LED’s, a buttonand a switch allow for a physical board interface.
Micron memory solutions are presented for QSPI flash, DDR3L memory andon-board eMMC instead of an external SD card. The Murata Type 1DX wirelesssolution incorporates 802.11b/g/n Wi-Fi as well as Bluetooth 4.1, whichprovides both Bluetooth Classic and Low Energy (BLE). The integrated powersupply from Dialog generates all on-board voltages, while an auxiliary supplyinput can be used to power designs that require additional current. From STMicro there is an on-board motion and temperature sensor, as well as a digitalmicrophone.
MiniZed provides for an efficient hardware reference design, while it is alsoan inexpensive board that can be used to run workshops and tutorials. Theboard aims to showcase the power of Zynq, where the Cortex A9 processorcore integrates seamlessly with the programmable fabric to provide signalprocessing and control solutions. The on-board digital microphone serves asan input for a variety of illustrations of how to implement FIR filters, FFT’s anddirect memory access.
图1.MiniZed开发板外形图
MiniZed开发板主要特性:
Xilinx Zynq XC7Z007S SoC
Memory
o Micron 512 MB DDR3L
o Micron 128 MB QSPI flash
o Micron 8GB eMMC mass storage
Configuration and Debug
o On-board USB to JTAG and debug UART circuit
Communications
o Murata "Type 1DX" wireless module with 802.11b/g/n Wi-Fi and Bluetooth 4.1 plus EDR and BLE (Bluetooth Low Energy)
o USB 2.0 host interface
Power
o Dialog Semiconductor DA9062 PMIC (Power Management IC)
Expansion connectors
o Arduino-compatible shield interface
o 2 x Pmod-compatible interfaces
Sensors
o ST Micro LIS2DS12 Accelerometer and Temperature sensor
o ST Micro MP34DT05 digital MEMS microphone
General Purpose I/O
o Reset button
o User button
o User switch
o Two user bi-element LEDs
MiniZed开发板支持下面特性:
̶ Zynq single-core System-on-Chip (SoC) device : XC7Z007S-1CLG225C
̶ Storage ̶ Micron 512 MB DDR3L
̶ Micron 128 Mb Quad SPI NOR flash
̶ Micron 8GB eMMC
̶ Micro USB connector for on-board JTAG and UART via FTDI device
̶ Micro USB connector for external power in high power mode
̶ USB Type A host connector for a USB slave device connection
̶ Arduino Shield connectors for Arduino-compatible peripherals
̶ Pmod sockets x 2
̶ Murata wireless “Type 1DX” module: LBEE5KL1DX ̶ based on the Cypress BCM4343W
̶ 2.4 GHz Wi-Fi complies with 802.11b/g/n
̶ Bluetooth ̶ Bluetooth Version 4.1 plus EDR (Enhanced Data Rate)
̶ Power Class 1 (10dBm max) and BLE (Bluetooth Low Energy)
̶ Leverages certification of reference design that uses PCB antenna
̶ Dialog PMIC (power-management IC) with I2C interface : DA9062
̶ Bi-element user LEDs x 2
̶ Single-color LEDs for Power, Config Done, Wifi, and Bluetooth
̶ Reset pushbutton & user PS pushbutton x 1
̶ User PL switch x 1
̶ ST Micro Accelerometer and Temperature sensor : LIS2DS12
̶ ST Micro MEMS microphone sensor : MP34DT05
MiniZed开发板目标应用:
--Entry level/Low-cost Zynqdevelopment environment
--Training, prototyping andproof-of-concept demo platform
--Wireless design and demonstrationsusing Wi-Fi and Bluetooth
--Audio signal processing examplesusing the microphone input
--IoT/Cloud connectivity for on-boardand peripheral sensors
图2.MiniZed开发板框图
图3.MiniZed开发板拓扑图
图4.MiniZed开发板电路图(1)
图5.MiniZed开发板电路图(2)
图6.MiniZed开发板电路图(3)
图7.MiniZed开发板电路图(4)
图8.MiniZed开发板电路图(5)
图9.MiniZed开发板电路图(6)
图10.MiniZed开发板电路图(7)
图11.MiniZed开发板电路图(8)
MiniZed开发板材料清单:
图12.MiniZed开发板PCB设计图(1)
图13.MiniZed开发板PCB设计图(2)
图14.MiniZed开发板PCB设计图(3)
图15.MiniZed开发板PCB设计图(4)
图16.MiniZed开发板PCB设计图(5)
图17.MiniZed开发板PCB设计图(6)
图18.MiniZed开发板PCB设计图(7)
图19.MiniZed开发板PCB设计图(8)
图20.MiniZed开发板PCB设计图(9)
图21.MiniZed开发板PCB设计图(10)
图22.MiniZed开发板PCB设计图(11)
图23.MiniZed开发板PCB设计图(12)
Zynq-7000
3文章
144浏览量
38153 -
Avnet
17浏览量
15194
打造Zynq平台性价比标杆,米尔强势推出MYC-Y7Z010/007S核心板
打造Zynq平台性价比标杆,MYIR强势推出MYC-Y7Z010/007S核心板
MYD-Y7Z010/007S开发板产品概
用于工业物联网应用的Cora Z7S成本优化单核SoC平台
ZYNQ的GPIO相关资料推荐
低成本 MiniZed Zynq SoC 开发板
一文详解Avnet Zynq 7Z007SMiniZed开发方案
基于单核Zynq 7Z007S的MiniZed™ 开发套件
基于FPGA的图像差分处理
全新Xilinx Zynq Z-7007S器件产品介绍
米尔科技MYD-Y7Z010/007S IO Cape简介
ZYNQ的GPIO简介
Avnet MiniZed单核Zynq 7Z007S入门开发方案
