常用高频发射三级管资料,RF transistor datasheet
关键字:常用高频发射三级管资料
下面列出的一些常用高频发射三级管资料,或许可以给大家参考
型号 s 功率 增益 电压 频率 工作状态 封装 123脚2N3375 10W5dB28V400MHz FM/AM/SSBTO-60
2N3553 2,5W10dB28V175MHzFM/AMTO-39 C B E
2N3632 20W7dB 28V 175MHz FM TO-60
2N3866 5W 10dB28V 400MHz WINTransceiverTO-39 C B E
2N3924 4W 6dB 13,6V 175MHz WINTransceiverTO-39
2N4427 2W 10dB12V 175MHz WINTransceiverTO-39
2N5108 1W 5dB24V 1200MHz WINTransceiverTO-39
2N5109 3,5W11dB 15V 200MHz WINTransceiverTO-39
2N5421 3W 9dB13,5V 175MHz WINTransceiverTO-39
2N5913 2W 7dB12,5V 175MHz WINTransceiverTO-39
2N5943 1W 8dB15V 400MHz FM TO-39
2SC730 0,8W 10dB 13,5V 175MHz FM TO-39 C B E
2SC1096 10W 60MHz FM TO-220
2SC1173 10W 100MHz FM/AM/SSB TO-220
2SC1306 16W 30MHz FM/AM/SSB TO-220 B C E
2SC1307 16W 12dB 12V 30MHz FM/AM/SSB TO-220 B C E
2SC1590 5W 10dB 12,5V 136-174MHz FM TO-220 B E C
2SC1591 14W 7,5dB12,5V 136-174MHz FM TO-220 B E C
2SC1678 5W 30MHz WINTransceiver TO-220 B C E
2SC1728 8W 80MHz WINTransceiver TO-202 E B C
2SC1729 14W 10dB 13,5V 175MHz FM T-31E
2SC1909 10W 14,5dB13,5V 50MHz FM/AM/SSB TO-220 B C E
2SC1944 13W 11,1dB 12V 30MHz WINTransceiver TO-220 B C E
2SC1945 16W 14,5dB 12V 30MHz FM/AM/SSB TO-220 B E C
2SC1946 25W 6,7dB 13,5V 175MHz FM T-31E
2SC1946A 30W 10dB 13,5V 175MHz FM T-31E
2SC1947 3W 10dB 13,5V 175MHz FM TO-39 C B E
2SC1957 1,8W 17dB 12V 30MHzWINTransceiver TO-126 E C B
2SC1966 3W 7,8dB 13,5V 470MHz FM T-31E
2SC1967 7W 6,7dB 13,5V 470MHz FM T-31E
2SC1968 14W 3,7dB 13,5V 470MHz FM T-31E
2SC1968A 14W 5,4dB 13,5V 470MHz FM T-31E
2SC1969 18W 12dB 12V 30MHz FM/AM/SSB TO-220 B C E
2SC1970 1,5W 10dB 13,5V 175MHz WINTransceiver TO-220 B E C
2SC1971 7W 10dB 13,5V 175MHz WINTransceiver TO-220 B E C
2SC1972 14W 10dB 13,5V 175MHz WINTransceiver TO-220 B E C
2SC1973 1W 50MHz WINTransceiver TO-92L B C E
2SC1974 13W 10dB 13,5V 30MHz WINTransceiver TO-220 B C E
2SC1975 4W 10dB 13,5V 30MHz WINTransceiver TO-220 B C E
2SC2028 1,8W 30MHz WINTransceiver TO-126 E C B
2SC2029 6W 30MHz WINTransceiver TO-220 B C E
2SC2036A 1,4W WINTransceiver TO-202 B C E
2SC2050 10W 12dB 13,5V 30MHz FM/AM/SSB TO-220 B C E
2SC2053 0,2W 15,7dB 12V 175MHz FM/AM TO-92L B C E
2SC2055 0,25W 15,3dB 12V 175MHz FM/AM TO-92L B C E
2SC2056 1,5W 9dB 12V 175MHz FM TO-39 C B E
2SC2075 4W 13,5V 27MHz WINTransceiver TO-220 B C E
2SC2078 4W 13dB 12V 100MHz FM/AM TO-220 B C E
2SC2086 0,45W 13dB 12V 175MHz FM/AM TO-92L B C E
2SC2092 4W 13dB 12V100MHz FM/AM/SSB TO-220 B C E
2SC2094 15W 8,8dB 13,5V175MHz FM/AM/SSB T-31E
2SC2166 6W 13,8dB 12V 30MHz FM/AM/SSB TO-220 B C E
2SC2207 16W WINTransceiver TO-220 B C E
2SC2237 6W 13,8dB 13,5V 175MHz FM T-31E
2SC2312 18,5W 27MHz FM/AM/SSB TO-220 B C E
2SC2314 1,8W 17dB 12V 180MHz FM/AM TO-126 E C B
2SC2509 13W 14dB 30MHz WINTransceiver TO-220 B C E
2SC2527 60W WINTransceiver TO-220
2SC2538 0,6W 10dB 12V 175MHz FM/AM TO-92L B C E
2SC2539 14W 14,5dB 13,5V 175MHz FM T-31E
2SC2660 30W 30MHz WINTransceiver TO-220
2SC2695 23W 1,9dB 13,5V 520MHz FM T-31E
2SC3001 6W 13dB7,2V 175MHz FM T-31E
2SC3017 1W 11dB 13,5V 175MHz FM TO-39 C B E
2SC3018 3W 13dB 7,2V 175MHz FM T-31E
2SC3020 3W 10dB 12,5V520MHz FM T-31E
2SC3021 7W 7,7dB 12,5V 520MHz FM T-31E
2SC3022 18W 4,8dB 12,5V 520MHz FM T-31E
2SC3103 2,8W 6,7dB 7,2V 520MHz FM T-31E
2SC3104 6W 4,8dB 7,2V 520MHz FM T-31E
2SC3133 13W 14dB 12V 1,5-30MHz FM/AM/SSB TO-220 B E C
2SC3297 15W 100MHz WINTransceiver TO-220
2SC3299 20W WINTransceiver TO-220
2SC3668 1W 100MHz WINTransceiver
2SC3807 15W 260MHz WINTransceiver TO-126
2SC4137 4W 400MHz WINTransceiver TO-126
2SC4693 FM/AM TO-92L B C E
KTC1006 1W 100MHz FM/AM TO-92L E C B
KTC1969 16W 12dB 12V 100MHz FM/AM TO-220 B C E
KTC2078 4W 11dB 12V 100MHz FM/AM TO-220 B C E
MRF161 5W 13,5dB 12,5V 225-500MHz FM/AM TO-220 B E C
MRF162 15W 13,5dB 12,5V 225-500MHz FM/AM TO-220 B E C
MRF163 25W 12dB 12,5V 225-500MHz FM/AM TO-220 B E C
MRF237 4W 12dB 18V 175MHz WINTransceiver TO-39
MRF260 5W 10dB 12,5V 136-174MHz FM TO-220 B E C
MRF261 10W 5,2dB 12,5V 136-174MHz FM TO-220 B E C
MRF262 14W 7,5dB 12,5V 136-174MHz FM TO-220 B E C
MRF264 30W 5,2dB 12,5V 136-174MHz WINTransceiver TO-220 B E C
MRF340 8W 13dB 28V 70MHz WINTransceiver TO-220 B E C
MRF342 24W 11dB 28V 70MHz WINTransceiver TO-220 B E C
MRF344 60W 6dB 28V 70MHz WINTransceiver TO-220
MRF454 80W 12dB 12,5V 1,5-30MHz FM/AM/SSB
MRF455 60W 13dB 12,5V 1,5-30MHz FM/AM/SSB
MRF475 12W 10dB 13,5V 1,5-30MHz FM/AM/SSB TO-220 B C E
MRF476 3W 15dB 13,5V 1,5-30MHz FM/AM/SSB TO-220 B C E
MRF477 40W 15dB 13,5V 1,5-30MHz FM/AM/SSB TO-220 B E C
MRF479 15W 10dB 13,5V 1,5-30MHz FM/AM/SSB TO-220
MRF485 15W 10dB 28V 1,5-30MHz WINTransceiver TO-220
MRF486 40W 15dB 28V 1,5-30MHz WINTransceiver TO-220
MRF496 40W 15dB 13,5V 1,5-30MHz WINTransceiver TO-220
MRF497 60W 10dB 13,5V 27-50MHz WINTransceiver TO-220 B E C
MRF517 0,75W 10dB 20V 1000MHz WINTransceiver TO-39
MRF607 1,75W 11,5dB 16V 175MHz WINTransceiver TO-39
MRF660 7W 5,4dB 12,5V 400-512MHz WINTransceiver TO-220
MS1226 30W 18dB 28V 30MHz FM/AM/SSB
MS1227 20W 15dB 12,5V 30MHz FM/AM/SSB
举报投诉
艾为电子荣获ISO56005《创新与知识产权管理能力》三级证书
近日,艾为电子获得ISO56005《创新与知识产权管理能力》三级等级证书。艾为不仅是上海市首家荣获该标准三级等级证书的企业,同时也是集成电路行业内首家达成此成就的公司。
OPA657跨阻放大器电路图的疑问求解
各位TI专家,各位高手!附件电路图是一个OPA657跨阻放大器,有如下问题:
图中三级管在何时导通,三极管的作用具体是什么。
R1,R2,R3电阻的作用是什么?改变这三个电阻值会有什么影响。
另外请帮忙详细分析一下这个电路的具
发表于 09-24 07:58
用三极管2N2219A和2N2905A怎样搭一个三级放大电路?
用三极管2N2219A和2N2905A怎样搭一个三级放大电路,要求放大4倍信号,频率从10Hz到120MHz,信号从5V放大到20V,急用,谢谢
发表于 09-20 07:36
使用OPA2695搭建的三级运放,输出的幅频特性上面有出现周期性的上跳,为什么?
有三级放大电路,第一级同相输入,第二、第三级反相输入。三级输出的频响是这样的:
这个是从1MHz到100MHz的幅频响应曲线,看到在50MHz的时候出现了一个上跳的现象。不仅在5
发表于 09-13 06:59
企业能源管控平台,能源三级管控、单品均耗分析
安科瑞企业能源管控平台是一个自动化、信息化和集中管理模式的企业能源管理系统,主要应用于钢铁、石化、冶金、有色金属、采矿、医药、水泥、煤炭、等行业,可对能源流行、班组能耗进行分析
能耗监测三级计量物联网系统解决方案
在当今能源紧缺、节能要求日益提高的背景下,如何高效管理能耗成为了一个亟待解决的问题。能耗监测三级计量物联网系统是通过物联网技术实现对电能、水力和其他资源消耗的全面监控,并采用三级计量的方式确保数据
高频加热mos管的电压范围
高频加热MOS管,即高频感应加热用MOSFET(Metal-Oxide-Semiconductor Field-Effect Transistor),是一种在
三级管恒流电路的优缺点有哪些
(BJT),是一种由三个半导体层组成的器件,包括发射极(Emitter)、基极(Base)和集电极(Collector)。恒流电路则是利用三级管的电流控制特性,实现对电流的稳定控制。 二、三级
三级管恒流源电路可以开路吗
三级管恒流源电路是一种利用三级管(PNP或NPN)的放大特性,实现恒定电流输出的电路。它广泛应用于电子设备中,如LED驱动、电源管理、传感器接口等。在某些情况下,三级管恒流源电路可能会遇到开路
使用 AM263 的10kW三相三级(T 型)逆变器参考设计
电子发烧友网站提供《使用 AM263 的10kW三相三级(T 型)逆变器参考设计.pdf》资料免费下载
发表于 02-28 14:13
•4次下载
