+50V 3A 可调稳压电源(英文),Regulated power supply
关键字:+50V 3A 可调稳压电源制作
+50V 3A 可调稳压电源制作
Many times we needed a stabilized, together regulated power supply and high relatively output voltage. These specifICations him it cover our circuit. It ’s a circuit that can give in his exit + 40V until + 60V 3A, with simultaneous stabilization. The materials that use is very simple and will not exist difficulties in the manufacture, is enough you are careful certain points. 1 ] For output voltages smaller of + 50V until + 40V, the Q1 is hot enough, so that it needs one big heatsink. 2]For output voltages bigger of + 50V up to + 70V, the stabilization is not Satisfactory. Conclusion: ideal output voltage is + 45V until + 60V. In the circuit pontesometer RV1, is used in order to we change the output voltage between + 40V until + 70V, we can however and perhaps it should, him we replace with two constant resistors, when finishe the regulation, in the desirable price. The reason is, that with time is presented change of output voltage, up to 3V, with connected pontesometer. ATTENTION!!! The positive exit correspond in point [ A ] and the exit of 0V in point [ B ], which should not be connected in the ground.
Part List
R1=10KohmR8=1.8Kohm 0.5W
Q3=BC303 or BC461
R2=1 ohm 5W
R9=3.3Kohm 0.5W
D1....4=Bridge 15A
R3=3.9 ohms 1W
RV1=470 ohms pot.
D5=LED RED 5mm
R4=6.8Kohm 1W
C1-2-4=4700uF 100V
D6-7=10V 1W Zener
R5=390 ohms 1W
C3-5=100nF 250V MKT
D8-9-10=1N4007
R6=100Kohm 0.5W
Q1=2N3055 on heatsink
T1=230Vac / 55V 3A
R7=1.2Kohm 1W
Q2=BD162 or BD243 or BD543
直流稳压电源使用方法 直流稳压电源由什么组成?
大功率可调直流稳压电源的工作原理
直流稳压电源的定义和分类 直流稳压电源的应用
lm317可调稳压电源电路怎么实现用上位机控制其输出电压呢?
lm317可调稳压电源板怎么连?
可调稳压电源怎么使用 大电流可调稳压电源电路图
![<b class='flag-5'>可调</b><b class='flag-5'>稳压电源</b>怎么使用 大电流<b class='flag-5'>可调</b><b class='flag-5'>稳压电源</b>电路图](https://file1.elecfans.com/web2/M00/A0/04/wKgZomToVDuAaQdLAADVzVX9uWs608.png)
3-30V/2.5A可调稳压电源电路图
![<b class='flag-5'>3-30V</b>/2.5<b class='flag-5'>A</b><b class='flag-5'>可调</b><b class='flag-5'>稳压电源</b>电路图](https://file1.elecfans.com/web2/M00/94/7A/wKgZomTlxGuAQX_HAAAj1O00AXM133.jpg)
双12v稳压电源原理详解
lm317可调稳压电源电路方法
![lm317<b class='flag-5'>可调</b><b class='flag-5'>稳压电源</b>电路方法](https://file1.elecfans.com/web2/M00/91/3C/wKgZomTe4xWAL_taAACb2DDlxqs666.jpg)
