Lightning Detector,打雷告警器
关键字:Lightning Detector
Egor! Come quick! A storm approaches!
Here is a VLF receiver tuned to 300 kHz designed to detect the crackle of approaching lightning. A bright lamp flashes in sychrony with the lightning bolts indicating the proximity and intensity of the storm. Figure 1 shows the simple receiver which consists of a tuned amplifier driving a modified flasher circuit. The flasher is biased to not flash until a burst of RF energy, amplified by the 2N3904, is applied to the base of the 2N4403. The receiver standby current is about 350 microamps which is nothing at all to a couple of D cells, hardly denting the shelf life. Of course, the stormier it gets, the shorter the battery life.
Circuit diagram
For best effect, mount the lamp in an old-fashioned holder with an extra-large colored glass lense. Or construct your own fixture with a plate of textured colored glass behind a panel painted with black-crackle paint. Watch a few old science fiction movies for other ideas.
A totally different approach is to mount the circuit in an empty glass jar with the antenna and bulb protruding through the top. (A malted-milk jar has a nice, red plastic lid which is easy to work and looks good.) Use a pin jack for the antenna. The gadget looks quite home-made but fascinating.
Boat owners may wish to replace the lamp with a 3-volt beeper to provide an early warning of approaching bad weather. Choose one of those unbreakable clear plastic jars like the large jars of coffee creamer. A little silicone rubber will seal the antenna hole in the lid of the jar. Use a longer antenna for increased sensitivity since there are few electrical noise sources on the lake.
Tune-up is simple: adjust the potentiometer until the regular flashing just stops. (Use a multi-turn trimmer.) When properly adjusted, the lamp will occasionally flash when large motors or appliances switch on and off and an approaching storm will give quite a show. Obviously, tune-up is a bit more difficult during stormy weather. Adjust the pot with no antenna if lightning is nearby. Tune an AM radio to the bottom of the dial to monitor the pulses that the lightning detector is receiving.
This lightning detector is not so sensitive that it will flash with every crackle heard on the radio but will only flash when storms are nearby. Increased sensitivity may be achieved by increasing the antenna length. The experienced experimenter may wish to add another gain stage after the first by duplicating the 2N3904 circuitry including capacitor coupling with the addition of a 47 ohm emitter resistor to reduce the gain somewhat. This additional gain can cause stability problems if the layout is poor so novices are advised to use a longer antenna or adjust the sensitivity potentiometer more delicately instead! (When operating properly, the additional gain makes the pot adjustment much less critical.)
举报投诉
华为云 X 实例监控与告警管理详解
前言 随着云计算的飞速发展,越来越多的企业将业务部署在云平台上,云服务器实例的管理变得尤为重要。云实例的稳定性、性能及安全性,直接影响着业务的连续性与用户体验。为了确保这些目标的实现,监控与告警
工业智能网关可以采集什么设备数据并实现自动告警
随着工业物联网与数字化转型的全面发展,工业智能网关在各行各业的应用越来越广泛。它能够实现PLC、仪器仪表、传感器、数控机床、工业机器人、注塑机等设备数据采集,实现5G/4G/WIFI/以太网等方式
dac3171 config5的alarm_dataclk_ gone有告警是什么原因?
使用的是DAC 31717bit模式。FPGA有数据输出,也有随路时钟216M。但3171的config5 的alarm_dataclk_ gone有告警。用示波器测试有时钟216M输入到DAC里面,DAC无输出,请问还需要配置其它寄存器不?或者有肯是什么问题,多谢!!
发表于 12-20 07:02
电极式传感器不告警的原因有哪些
电极式传感器不告警的原因可能涉及多个方面,以下是一些常见的原因及其解释: 电极污染或损坏 : 传感器电极可能因长期使用而污染,如被污垢、沉积物或其他杂质覆盖,导致电极间的电导率降低,无法准确检测液位
CPS8849B Lightning转USB资料分享
1.为什么需要C口型接收器到闪电适配器2.USB-C到Lightning的MFi要求3.成都易冲USB-C到Lightning解决方案4.USB-C转照明 MFi 认证我们来看一下为什么需要
发表于 08-19 11:47
•1次下载
EM储能网关 ZWS智慧储能云应用(4) — 告警介绍(下)
ZWS智慧储能云平台,作为一个开放式第三方平台,是如何自定义创建告警规则的?本文将介绍储能系统如何创建告警规则、后续如何维护。储能系统的告警功能至关重要,它能够确保系统的稳定与安全。云端告警
EM储能网关 ZWS智慧储能云应用(4) — 告警介绍(上)
ZWS智慧储能云平台,支持储能系统快速完成数据对接,自定义配置告警规则,快速实现上云服务,实现云端告警智能化管理。储能系统的告警功能至关重要,它能够确保系统的稳定与安全。云端告警通过实
Hi-Fi 无损音质 Lightning 转耳机中的 EVASH Ultra EEPROM 实践应用
lightning接口和typec有啥区别 Type-C接口的特点
: Lightning接口是由苹果公司开发的,最早用于iPhone 5发布时代,以取代30针的Dock连接器。以下是Lightning接口的特点: 1.1 小巧便携:Lightning
微机消谐装置接地故障告警原因
微机消谐装置是一种用于消除电力系统中谐波的装置,其主要功能是检测电网谐波,并通过发出告警信号提醒运维人员进行处理。然而,在实际应用中,微机消谐装置也会出现接地故障告警的情况。本文将详细分析微机消谐
随着智能设备的不断发展,各种接口技术也日益增多。在移动设备领域,Lightning接口和Type-C接口是两种常见的接口技术,它们各自具有一定的特点和优势。本文将介绍比较分析Lightning接口
苹果 Lightning 数据线芯片IC(高耐压防倒流)APS0217数据手册
电子发烧友网站提供《苹果 Lightning 数据线芯片IC(高耐压防倒流)APS0217数据手册.pdf》资料免费下载
发表于 01-15 15:04
•8次下载
