电池欠压告警器(英文),Battery Low Voltage Alarm
454398 2018-09-20 18:30 次阅读
关键字:电池欠压告警器
Here is another equally cool low voltage alarm circuit for your glider receiver battery that I've shamelessly stolen from George Steiner's book "A to Z--Radio Control Electronic Journal" (see below). I've modified it to use with small battery packs in R/C gliders. This design has a trigger voltage at about 4.3 volts, and it draws 1mA or less when quiet and about 4mA when buzzing. This can be constructed from parts fromt Radio Shack, though you may need to order a few through them.
The voltage of a receiver system is punctuated by low-voltage spikes every time the servo motors spin up, since the servos draw more than the battery can deliver. With large receiver battery packs, this is not as much of an issue, and it may not be noticeable. However with 270mA and smaller battery packs, particularly with more than two servos, low voltage alarms can chirp constantly, every time a servo moves. The challenge is to design in a little slack or delay, just enough so that you are not annoyed by constant chirping, but not too much so that the chirps can give you a warning before the battery is completely exhausted. Here, this "hysteresis" is adjusted with the capacitor. For large packs (600mA and above), no capacitor is probably needed, although I've been using a 1uF capacitor on my open class ship with 6 servos and a 600mA battery. For 270 mA and two servos, I'd suggest trying a 1uF capacitor. For 150mA or less, a 2.2uF capacitor works well. If you want to know only when the battery has finally reached the trigger voltage, try a 5uF (or 4.7uF) capacitor. The actual type of capacitor is not critical, but tantalum capacitors are physically smaller. If you want to worry about the polarity of the capacitor, the negative side should be directed toward the negative pole of the battery, but at these relatively low voltages compared to the capacitor rating, the polarity probably does not matter.
This circuit is set up for a four cell receiver battery pack at a trigger voltage of about 4.3 volts (about 1.1volts/cell). You can adjust R1 (here a 3.3k resistor) to change the trigger voltage of the circuit. For example, for a 5 cell pack, to change the trigger voltage to 5.5 volts, change R1 to 2.2k. For a three cell pack, to change the trigger voltage to 3.3 volts, change R1 to 6.8 k (or use two 3.3k resistors in parallel by soldering a resistor in each hole and twisting together the top leads). Because of slight variability in tolerances of the componants, you should check this little device with a variable power source and a voltmeter to confirm its trigger point. Alternately, use your digital voltmeter or expanded scale voltmeter to calibrate its chirp pattern by measuring the voltage of the onboard battery pack intermittently as you fly.
Make sure the band on the Zener diode is toward the "+" side (toward R1). Solder a battery connector or servo connector to the board with positive and negative as shown, and plug the connector into an unused slot in your receiver.
Circuit diagram
Radio Shack parts: Here again, you can use smaller rated resistors if you can get them--1/8 watt or less is fine. Tantalum capacitors are physically smaller, but any composition will work.
273-074 Miniature Piezo Buzzer, 12v, PC board mount
271-312 1/4 watt 5% carbon film resistors, 500 pieces (Take the plunge!)
276-1604 Package of 15 PNP small signal 2N3906-type transistors. Could use instead 276-2016 $0.59 2N3904 PNP transistors
RSU 11673505 3.3v Zener diode (not on shelf--need to order 1-800-THE-SHACK)
272-1434 1uf tantalum capacitor (see above for choice of capacitor)
RSU 11295888 2.2uF tantalum capacitor (not on shelf--need to order)
272-1024 4.7uF radial-lead electrolytic capacitor
Digikey (1-800-344-4539) part numbers: Digikey does sell the peizo buzzers, but they are much more expensive than those at Radio Shack and are larger as well.
2N3906-ND PNP general purpose amp/switch transistor
1N5226BMSCT-ND 3.3v Zener diode 500mA
3.3KEBK-ND 1/8 watt resistors
4.7KEBK-ND 1/8 watt resistors
10KEBK-ND 1/8 watt resistors
P2105-ND 1.0uF Tantalum capacitor 16volt
P2022-ND 2.2uF Tantalum capacitor 10volt
P2024-ND 4.7uF Tantalum capacitor 10 volt
FP012C-5-ND 3M clear 0.5" heat shrink tubing, 5 feet
George Steiner's book, crammed with cool R/C radio info, can be had for $19.95 postage paid from the following:
GSP AZ Journal
2238 Rogue River Drive
Sacramento CA 95826
phone: 916-362-1962
Author: Rob Crockett 10/99
    dac3171 config5的alarm_dataclk_ gone有告警是什么原因?
    使用的是DAC 31717bit模式。FPGA有数据输出,也有随路时钟216M。但3171的config5 的alarm_dataclk_ gone有告警。用示波器测试有时钟216M输入到DAC里面,DAC无输出,请问还需要配置其它寄存
    发表于 12-20 07:02
    电动车控制保护怎样调整
    电动车控制保护功能是为了保护电池和延长电池寿命而设计的。当电池电压下降到某一设定值时,控
    的头像 发表于 10-15 10:34 4085次阅读
    封锁电路有什么作用
    电子设备和系统中,如电源管理系统、电池管理系统、电机控制系统等。 1. 封锁电路的基本原理 封锁电路的核心是检测电源电压,并在电压低
    的头像 发表于 09-20 14:42 469次阅读
    脱扣怎么判断好坏
    脱扣是一种用于保护电气设备在电压过低时自动断开电源的装置。它的主要作用是在电网电压下降到设定的阈值以下时,自动切断电路,以保护设备不受损坏。判断
    的头像 发表于 09-19 10:40 998次阅读
    脱扣合不上闸的原因
    脱扣合不上闸的原因可能涉及多个方面,主要包括电气故障和机械故障两大类。以下是对这些原因的具体分析: 一、电气故障 脱扣
    的头像 发表于 09-19 10:26 1315次阅读
    脱扣线圈怎么连接在电路中
    脱扣线圈在电路中的连接方式主要取决于电源的类型(交流或直流)以及脱扣的具体规格。以下
    的头像 发表于 09-19 10:22 1180次阅读
    宽VIN过监控的常见应用
    电子发烧友网站提供《宽VIN过监控的常见应用.pdf》资料免费下载
    发表于 09-02 10:13 0次下载
    宽VIN过<b class='flag-5'>压</b>和<b class='flag-5'>欠</b><b class='flag-5'>压</b>监控<b class='flag-5'>器</b>的常见应用
    馈电开关保护动作怎么解决
    馈电开关保护动作是指当电网电压低于设定值时,馈电开关会自动断开,以保护用电设备不受电压过低的影响。解决馈电开关保护动作的问题,需要从多个方面进行分析和处理。 一、馈电开关
    的头像 发表于 07-22 10:50 1246次阅读
    保护可以防雷电吗?
    保护(Over-Under Voltage Protector)是一种用于保护电子设备免受过高或过低电压影响的装置。它通常用于电源系统中,以防止电压波动对设备造成损害。然而,过
    的头像 发表于 07-13 15:27 2644次阅读
    家里过保护频繁跳闸怎么解决
    问题 过保护是一种保护电器设备不受电压波动影响的装置,当电压超过或低于设定值时,保护会自动跳闸,切断电源。如果电力系统出现问题,如供电不稳定、电压波动大等,都可能导致过
    的头像 发表于 07-09 11:31 1.1w次阅读
    软启动显示故障怎么办
    软启动显示故障是电气系统中常见的问题之一。本文将详细介绍软启动故障的原因、诊断方法、
    的头像 发表于 06-18 16:49 2627次阅读
    脱扣脱扣的区别
    脱扣脱扣的区别  失脱扣
    的头像 发表于 04-08 15:55 6410次阅读
    保护怎么测量是不是坏的
    保护是一种保护电器设备的重要装置,它用于监测电路中的电压,当电压低于设定值时,保护
    的头像 发表于 02-26 10:59 3049次阅读
    怎样判断保护坏了怎么办
    判断保护坏了怎么办 保护是一种用于保护电气设备免受
    的头像 发表于 02-26 10:55 4503次阅读
    自动切断电路分析
    自动切断电路”项目旨在保护电气和电子设备免受过的影响,从而确保该设备的长寿命。
    的头像 发表于 02-25 16:28 1688次阅读
    过<b class='flag-5'>压</b>和<b class='flag-5'>欠</b><b class='flag-5'>压</b>自动切断电路分析
