植物缺水告警器,water alarm for plant
454398 2018-09-20 18:44 次阅读
关键字:缺水告警电路
Parts:
R1___________470K1/4W Resistor
R2_____________3K3 1/4W Resistor
R3___________100K 1/2W Trimmer Cermet
C1_____________1nF 63V Polyester Capacitor
C2____________47µF 25V Electrolytic Capacitor
D1__________1N4148 75V 150mA Diode
D2_____________5mm. Red LED
IC1___________4093 Quad 2 input Schmitt NAND Gate IC
P1,P2_______Probes (See text)
SW1___________SPST Slider Switch
B1______________3V Battery (2 AA 1.5V Cells in series)
Device purpose:
This circuit is intended to signal when a plant is needing water. A LED illuminates at maximum brightness when the ground in the flower-pot is too dry: it dims gradually as the water's content in the pot grows, turning off when the optimum moisture's level is reached. This condition is obtained trimming R3.
Circuit operation:
IC1D forms a square wave oscillator with approx. 10/90 mark-space ratio. It feeds the output probe P1 and its signal, inverted by IC1A is compared with that picked-up by P2 in the NAND gates IC1B & IC1C in parallel, driving the LED. When a low resistance exists between the probes, due to an high water's content in the flower-pot, the LED is off, turning gradually on as the resistance between the probes increases.
Notes:
  • A square wave is used to avoid probes' oxidization.
  • Probes can be long nails, carbon rods obtained from disassembled exhausted 1.5V batteries, or even a couple of screwdrivers.
  • The probes must be driven in the pot's ground a few inches apart.
  • Due to 3V supply, the LED needs not a limiting resistor.
  • Power consumption: LED off = 50µA; LED full on = 1mA.
  • To switch-off the circuit, you can short the probes. In this case SW1 can be omitted.
  • Using an high-efficiency LED, brightness variations are better emphasized. In this case a limiting resistor could be necessary.
    dac3171 config5的alarm_dataclk_ gone有告警是什么原因?
    使用的是DAC 31717bit模式。FPGA有数据输出,也有随路时钟216M。但3171的config5 的alarm_dataclk_ gone有告警。用示波器测试有时钟216M输入到DAC里面,DAC无输出,请问还需要配置其它寄存
    发表于 12-20 07:02
    DAC3484只要对寄存进行写操作都会触发alarm,在此期间txenable保持为0,没有数据传输怎么解决?
    触发alarm,在此期间txenable保持为0,没有数据传输。始终alarm清不掉. 设计中使用DAC3484芯片输出信号,上电后,对其的配置过程如下: 序号寄存配置值说明 100089c16倍
    发表于 12-13 08:08
    请问ADS8661寄存如何配置可使alarm输出报警?
    我们现在使用ADS8661数模转换,采样数据读取正常,我们打算使用ads8661的input alarm功能在电压超门限的时候产生报警信号,我配置了下面的寄存: 1.地址14寄存
    发表于 11-27 07:40
    AFE7689 TX JESD Alarm调试
    电子发烧友网站提供《AFE7689 TX JESD Alarm调试.pdf》资料免费下载
    发表于 09-27 09:46 0次下载
    AFE7689 TX JESD <b class='flag-5'>Alarm</b>调试
    电极式传感告警的原因有哪些
    电极式传感告警的原因可能涉及多个方面,以下是一些常见的原因及其解释: 电极污染或损坏 : 传感电极可能因长期使用而污染,如被污垢、沉积物或其他杂质覆盖,导致电极间的电导率降低,无法准确检测液位
    的头像 发表于 09-19 17:31 304次阅读
    LITESTAR 4D应用:温室植物照明案例
    设计意义 现如今,越来越多的人工光源改变照明模式,使得植物照明的发展趋势越来越迅速。这种设计的意义是:提升光能利用率,照明促进植物高效高质量成长;植物照明发展迅速,市场规模不断增长,其中应用的LED
    发表于 08-13 17:57
    请问如何定位SMU中alarm的报警源?
    对于开发人员来说,SMU 检测到 Alarm 后,如何发现和定位导致 alarm 的原因和位置才是最具有挑战性的。以看门狗超时为例,在出现看门狗复位后,我有以下问题希望得到解答: 1. 1.通过那些
    发表于 08-01 06:18
    IR615配置流量告警方法
    1.登录路由,服务流量管理中设置流量使用阀值. 2.添加告警设置,在服务&gt;告警设置中勾选告警输入和告警输出. 3.登
    发表于 07-25 07:59
    蓝牙连接失败,打印alarm_set failed to start timer, err 0x103如何解决?
    蓝牙偶尔连接失败,似乎是启动alarm定时的问题,打印信息如下:alarm_set failed to start timer, err 0x103 请问如何解决?谢谢!
    发表于 06-25 08:22
    “铁卫”级防水防腐:LP20系列连接解决植物生长灯连接难点
    植物生长灯在科技农业领域有着非常重要的应用,它有助于植物增产增量,提升品质。由于存在水液、农药等环境因素的影响,因而植物生长灯系统采用的连接多为更耐环境考验的高性能、高可靠工业级连接
    的头像 发表于 06-19 08:13 272次阅读
    “铁卫”级防水防腐:LP20系列连接<b class='flag-5'>器</b>解决<b class='flag-5'>植物</b>生长灯连接难点
    STM32F103正点RTC RTC_Alarm_Set不能作用是为什么?
    STM32F103正点RTC RTC_Alarm_Set根本不能作用
    发表于 04-08 07:28
    AWTK 开源串口屏开发(10) - 告警信息的高级用法
    告警信息是串口屏常用的功能,之前我们介绍了告警信息的基本用法,实现了告警信息的显示和管理。本文介绍一下实现查询告警信息和查看告警信息详情的方
    的头像 发表于 02-24 08:23 307次阅读
    AWTK 开源串口屏开发(10) - <b class='flag-5'>告警</b>信息的高级用法
    TC277 watchdog超时后无法触发SMU Alarm怎么解决?
    不了watchdog timeout alarm,如果在不解锁的情况下,强制修改SCU_WDTSCON0寄存的 lck位,ALM3[17]可以报出Alarm watchdog配置寄存
    发表于 01-30 07:06
    水箱如何实现自动检测缺水及时补水
    水箱的自动检测缺水及时补水功能是现代生活中非常实用的一个功能,尤其在家庭和商业场合中。这种功能的实现,主要依赖于水位传感和补水。 水位传感是一种检测水位的设备,通过感应水位的变动
    的头像 发表于 12-29 15:02 956次阅读
    水箱如何实现自动检测<b class='flag-5'>缺水</b>及时补水
    鱼缸如何实现自动检测缺水补水
    自动停止。 在实际的鱼缸应用中,长时间的户外活动会导致水箱中的水位随着时间的推移而降低,无人补水会导致鱼类因缺水而死亡。因此,这种补水可以用于自动向鱼缸补水。 鱼缸补水 实际功能是将补水
    的头像 发表于 12-27 14:17 491次阅读
    鱼缸如何实现自动检测<b class='flag-5'>缺水</b>补水
