手机来电指示器(英文),Cellular Phone calling Detector
关键字:手机来电指示器
Circuit diagram
Parts:
R1 100K 1/4W Resistor
R2 3K9 1/4W Resistor
R3 1M 1/4W Resistor
C1,C2 100nF 63V Polyester Capacitors
C3 220µF 25V Electrolytic Capacitor
D1 LED Red 10mm. Ultra-bright (see Notes)
D2 1N5819 40V 1A Schottky-barrier Diode (see Notes)
Q1 BC547 45V 100mA NPN Transistor
IC1 7555 or TS555CN CMos Timer IC
L1 Sensor coil (see Notes)
B1 1.5V Battery (AA or AAA cell etc.)
R3 1M 1/4W Resistor
Device purpose:
This circuit was designed to detect when a call is incoming in a cellular phone (even when the calling tone of the device is switched-off) by means of a flashing LED.
The device must be placed a few centimeters from the cellular phone, so its sensor coil L1 can detect the field emitted by the phone receiver during an incoming call.
Circuit operation:
The signal detected by the sensor coil is amplified by transistor Q1 and drives the monostable input pin of IC1. The IC's output voltage is doubled by C2 & D2 in order to drive the high-efficiency ultra-bright LED at a suitable peak-voltage.
Notes:
Stand-by current drawing is less than 200µA, therefore a power on/off switch is unnecessary.
Sensitivity of this circuit depends on the sensor coil type.
L1 can be made by winding 130 to 150 turns of 0.2 mm. enameled wire on a 5 cm. diameter former (e.g. a can). Remove the coil from the former and wind it with insulating tape, thus obtaining a stand-alone coil.
A commercial 10mH miniature inductor, usually sold in the form of a tiny rectangular plastic box, can be used satisfactorily but with lower sensitivity.
IC1 must be a CMos type: only these devices can safely operate at 1.5V supply or less.
Any Schottky-barrier type diode can be used in place of the 1N5819: the BAT46 type is a very good choice.
举报投诉
热点推荐
架空就地型故障指示器(暂态特征型)|翻牌/闪光/无线传
用电,造成不良社会影响与直接经济损失。 目前这类城区线路原有传统故障指示器存在明显功能短板,不具备接地故障判断能力,而10kV配电线路接地故障属于高发故障类型,传统设备无法有效识别判定,导致故障发生后只能依赖人工逐段巡
线路暂态特征型远传型故障指示器:“技术+管理”双轮驱动
。本文从故障类型解析入手,结合鼎信智慧科技的线路暂态特征型远传型故障指示器JYZ-DX,为运维人员提供一套高效、精准的故障定位方法。 一、配电线路常见故障类型及诱因 1、短路故障 :导体间或导体与地间异常导通,电流激增
STM32H5开发VL53L8CX(4)----运动指示器
VL53L8CX传感器内置了一个固件功能,可以检测场景中的运动。这个运动指示器是基于连续帧之间来计算的。使用插件vl53l8cx_plugin_motion_indicator可以使用这个选项
VL53L8CX小板开发(4)----运动指示器
VL53L8CX设备的引用。
配置运动指示器:
○ 使用4x4的分辨率初始化运动指示器。如果失败,则打印错误信息并返回状态。
○ 可选地更改用于检测运动的最小和最大距离。这些距离有一些限制,如果超出
光纤收发器6个指示灯含义
在工业通信、安防监控、企业组网等场景中, 光纤收发器 作为光电转换的关键设备,广泛应用于千兆/百兆以太网的远距离传输。然而,当网络出现中断或不稳定时,很多用户面对设备上闪烁的指示灯却一头雾水。其实
荣耀官宣明年推出机器人手机 Robot Phone!手机+摄像机+机器人三合一
荣耀C官宣明年将推出革命性的机器人手机Robot Phone,把AI手机、具身智能和高清摄像融成了“智能生命体”。Robot Phone融合了三大核心能力:具备AI的“超强大脑”,能随
基于ST EVLIOL4LSV1 IO-Link执行器的工业物联网技术解析
STMicroelectronics EVLIOL4LSV1 IO-Link执行器设计用于工厂自动化和系统报警指示器应用中使用的传统塔式灯:它是一套完整的解决方案,可用作工业化的参考设计。通过IO-Link,EVLIOL4LSV1成为智能塔式灯的执行
TPS563212同步降压转换器技术解析与应用指南
的电源正常状态指示器或外部软启动。通过正确配置使能引脚、电源正常状态指示器或外部软启动可以实现电源时序控制。4.2V至18V的宽输入电压范围支持12V和15V等各种常见的输入电压轨。其输出电压为0.6V至7V,支持高达3A的持续输出电流。
TPS562212同步降压转换器技术解析与应用指南
TPS562212 是一款具有成本效益且高度灵活的同步降压转化器,可在可选的Eco-mode或强制连续导通模式 (FCCM) 下工作。另外还可以通过MODE引脚配置可选的电源正常状态指示器或外部
TPS563212 具有节能模式和可选 FCCM 的 4.2V 至 18V、3A、1.2MHz 同步降压转换器数据手册
TPS563212 是一款经济高效且高度灵活的同步降压转换器,可提供可选的 Eco 模式作或 FCCM(强制连续导通模式)作。可选的电源正常指示器或外部软启动也可以通过 MODE 引脚进行配置。通过
华为AI Calling同声传译如何改变游客体验
近期,作为泰国领先的数字服务提供商,AIS(Advanced Info Service)在华为MATE XT发布会期间推出全球首个AI Calling英泰同声传译业务,为全球游客带来跨语言通话
HarmonyOS5云服务技术分享--手机号登录教程
一、为什么选择手机号认证?
在开始代码之前,先说说它的优势:
用户友好:不需要记忆复杂用户名
安全性强:双重验证机制(短信+密码)
快速接入:HarmonyOS Auth
发表于 05-22 15:37
Profinet转Ethernet IP主站网关:点燃氢醌生产线的智慧之光!
案例分享:转角指示器和Profinet转EthernetIP网关的应用
在现代工业自动化中,设备和系统之间的高效通信至关重要。最近,我们在某大型化工企业的生产线上实施了一个项目,旨在通过先进的设备
超级电容在故障指示器中的作用有哪些?
超级电容在故障指示器中的作用有哪些?安装在输配电线路、电力电缆及开关柜进出线上的故障指示器在电流流通的线路中起着非常重要的作用,一旦线路发生故障,巡线人员可以利用指示灯的报警显示快速的确定故障出现
