高稳定100KHz时钟发生电路,100khz clock generator
454398 2018-09-20 19:18 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
关键字:高稳定100KHz时钟发生电路
Build A 100Khz Crystal Calibrator
By N1HFX
There is a great deal of old amateur gear which many amateurs have decided to restore and bring back to life. While much of the early amateur transceivers work just fine they usually lack a digital readout and must rely on analog dials for tuning. The problem of dial calibration is complicated by the non-linear effects of tuning capacitors. This month's circuit is a 100Khz crystal calibrator using an inexpensive microprocessor crystal and CMOS IC's which are readily available at Radio Shack.
The main problem with building a 100Khz oscillator is the unavailability of 100Khz crystals. Even if you find a vendor willing to cut such a crystal for you, plan on paying $20 or more not including shipping charges. The circuit in Figure 1 uses an inexpensive 8Mhz microprocessor crystal which can be easily obtained from most parts suppliers for about $1. Using a 74HCT393 binary counter IC, we can easily divide down the 8 MHz signal from our crystal into 100Khz or almost any frequency we need.
The circuit in Figure 1 uses a couple of NAND gates (74HCT00 IC) for our 8Mhz crystal oscillator. Capacitor C2 actually helps us tune the crystal to the exact frequency, Use any value of C2 from about 22pf to about 82pf to get the oscillator on frequency. In the prototype, 68pf worked fine for most of the crystals tested. For an exact frequency, replace C2 with a 22pf and add a 50pf trimmer capacitor in parallel. By adjusting the 50pf trimmer capacitor, we can easily get the crystal exactly on frequency. The first NAND gate is our oscillator while the second NAND gate acts as a buffer and conditions the signal. This signal is then fed into the clock pulse input of one of the 4 bit binary counters in IC2. By taking the output from the Q3 signal, we have now divided the signal by 16 giving us 500Khz. This signal is now fed into the clock pulse input of the second 4 bit binary counter. In the first counter we tied the MR (clock reset) line to ground. In the second counter, we need the count to reset when we reach a binary five, which will allow us to divide the 500Khz by 5. For this counter, we used the last 2 remaining NAND gates in IC1 to detect the desired value. When we reach the correct reset interval, the MR line goes high resetting the counter to zero and allowing us to effectively divide by 5. The 100Khz output is taken from the Q2 line and is coupled through capacitor C4.
If you prefer, this circuit can be easily changed to a 50Khz calibrator by wiring pins 13 & 14 of IC1 into pins 10 and 8 of IC2. See Figure 2 for details. This arrangement makes the second counter reset at binary 10 which divides the 500Khz by 10 giving us the desired 50Khz.
The HCT series CMOS logic IC's require a 5 volt power supply just like the old TTL logic series. In this circuit we used a 5 volt zener diode, D1, along with resistor R2 to get 12 volts down to 5 volts. Capacitor C3 is used primarily for bypassing the oscillator and must be used in this circuit. If you prefer to power this circuit from a 9 volt battery, then reduce resistor R2 to 220 ohms for best performance.
If you plan to install this circuit inside a transceiver, feed the output directly to the receiver front end. Make certain you have connected it after the TR relay so that the circuit doesn't get zapped by RF from the transmitter side. Also, you will want to install an ON/OFF switch which will interrupt the 12V line going to the circuit. As with all static sensitive CMOS IC's, use special handling precautions and do not leave out those IC sockets.
This circuit has been found to generate accurate birdies at every 100Khz and will be an excellent aid in getting that old rig right on frequency. The accuracy of the 100Khz birdies will depend on how close the 8Mhz oscillator is on frequency. With the difficulty in getting crystals for specific frequencies, this circuit gives new meaning to the words "Divide and Conquer".
要产生100千赫兹频率的电路,如果采用晶体管搭建的LC震荡电路,当要求频率很稳定时比较困难,而采用晶体震荡器则容易实现,而低频率的晶体震荡器又不容易获得,下面的电路就能够将频率较高的晶体震荡器通过适当的电路输出频率较低的信号
电路原理简单,通过IC1的门电路,晶体以及外围电路组成8M赫兹震荡器,通过IC2分频获得100千赫兹信号。
DE N1HFX
下图是产生50千赫兹的电路,13脚接上图的IC2的6脚就可以了。
元件清单
Parts List
C1
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    使用 公元9106 的SRAM生成任意波形的问题
    嗨,ADI专家 我计划 生成 3 任意 信号 of 100kHz 吨he 公元9106 has 4 渠道, can I 生成 3 独立 任意 波形 of 100kHz。 提前感谢!
    发表于 05-14 08:04
    英飞凌功率校正芯片ICE3PCS03G
    时具有最低的内部参考微调和集成的数字控制电压环。它们还具有其他优点,如0.2V时的低峰值电流限制、21kHz100kHz的可调栅极开关频率范围以及能够与50kHz100kHz之间的
    发表于 04-30 17:09
    针对高频(100kHz)碳化硅NPC三电平UPS的不间断电源谐波抑制与控制算法
    针对高频(100kHz)碳化硅NPC三电平UPS的不间断电源谐波抑制与控制算法综合研究 1. 现代不间断电源系统的高频演进与三电平拓扑技术背景 在现代数据中心、精密医疗装备、工业自动化控制网络以及
    的头像 发表于 04-25 06:42 317次阅读
    针对高频(<b class='flag-5'>100kHz</b>)碳化硅NPC三电平UPS的不间断电源谐波抑制与控制算法
    LTC5507:100kHz 至 1GHz RF 功率检测器的技术剖析
    LTC5507:100kHz 至 1GHz RF 功率检测器的技术剖析 在当今的电子设备中,RF 功率检测是一项至关重要的技术,它广泛应用于无线通信、雷达等领域。LTC5507 作为一款出色的 RF
    的头像 发表于 04-24 15:45 181次阅读
    LT3023:双路100mA低噪声微功耗稳压器的卓越之选
    100mA低噪声微功耗稳压器——LT3023。 文件下载: LT3023.pdf 一、LT3023的核心特性 1. 低噪声与低静态电流 LT3023的输出噪声极低,在10Hz至100kHz带宽内仅为20μVRMS。这一特性使得它在对噪声敏感的应用中表现出色,如射频
    的头像 发表于 03-20 11:10 236次阅读
    为什么时钟都用32.768kHz晶振?优势、应用、选型要点
    工程师、采购必看:RTC走时不准、功耗超标、批量温漂大、选型反复踩坑,90%问题都出在32.768kHz晶振没选对。它是时钟、电表、蓝牙、手环、工控主板的标准时基,搞懂原理、参数、封装、避坑技巧,一次设计稳定量产,再也不用返工。
    的头像 发表于 03-06 16:47 1261次阅读
    为什么<b class='flag-5'>时钟</b>都用32.768<b class='flag-5'>kHz</b>晶振?优势、应用、选型要点
    MLX90109 125kHz RFID 收发器:特性、应用与设计要点
    MLX90109 是一款集成式 RFID 收发器,能够寻址 100kHz 至 150kHz 频率范围的应答器。它支持双相和曼彻斯特 ASK 以及 ON/OFF 键控调制,具有低功耗
    的头像 发表于 02-03 16:50 773次阅读
    SiLM6478低边MOSFET驱动器,支持3-60V输入与100kHz-2.2MHz调频
    高可靠性、集成度的解决方案。特性 宽输入电压范围:支持3V至60V输入。 可调开关频率:工作频率可通过外部配置在100kHz至2.2MHz范围内调节。 强大内置驱动:集成1.5A峰值电流的低边栅极驱动器
    发表于 01-30 08:22
    SCT2430QSTER 高效率同步DCDC降压变换器电路图资料
    控制,支持脉冲跳跃调制(PSM),典型静态电流低至 25μA,有助于转换器在轻载或待机条件下实现高效率。SCT2430Q 通过外部电阻可实现 100kHz 至 2.2MHz 的可编程开关频率,为优化效率或外部元件尺寸提供了灵活性。转换器支持 100kHz 至 2.2MHz
    发表于 01-27 16:29 0次下载
    MLX90109 125kHz RFID 收发器:设计与应用全解析
    收发器 :能够寻址 100kHz 至 150kHz 频率范围的应答器,支持双相和曼彻斯特 ASK 编码,以及 ON/OFF 键控调制。 低功耗高性能 :采用独特的
    的头像 发表于 01-22 11:25 403次阅读
    氮化硼软陶瓷片 | 三高一阻新材料
    电源控制板(如开关电源、UPS、工业电源模块等)的IGBT核心功能是实现电能的高效转换与稳定输出,其工作场景具有功率跨度大(10W~100kW)、开关频率(10kHz~
    的头像 发表于 01-14 07:24 341次阅读
    氮化硼软陶瓷片 | 三高一阻新材料
    倾佳电子基于SiC MOSFET 的 3kW 高频 (100kHz) CCM 图腾柱 PFC 设计、分析与效率建模
    倾佳电子基于SiC MOSFET 的 3kW 高频 (100kHz) CCM 图腾柱 PFC 设计、分析与效率建模 倾佳电子(Changer Tech)是一家专注于功率半导体和新能源汽车连
    的头像 发表于 11-09 11:19 3138次阅读
    倾佳电子基于SiC MOSFET 的 3kW 高频 (<b class='flag-5'>100kHz</b>) CCM 图腾柱 PFC 设计、分析与效率建模
    请问如何确定和配置 HRPWM 周期值?
    你好,我想控制PWM开关频率,精度为10MHz±1%(100KHz)。 PSoC™ Control C3 可以为 PWM 外设提供 240MHz 时钟。因此,通过设置 Period=24,PWM
    发表于 08-12 08:24
    XL4016是一个180 KHz的固定频率 PWM降压(降压)DC/DC转换器
    频率振荡器。PWM控制电路能够调节占空比线性从0到100%。一个在内置电流保护功能。当短路保护功能发生时操作频率将从180KHz到48KHz
    发表于 07-01 15:18 0次下载
    32.768kHz:现代科技的时间命脉
    在晶振行业中,32.768kHz频率的晶振是最常用的一种它是一款实时时钟晶振能够产生时序电路基准信号精确到一秒的计时因在频率元器件领域无处不在而出名在日常生活中,时钟随处可见闹钟、手表
    的头像 发表于 05-22 10:00 1143次阅读
    32.768<b class='flag-5'>kHz</b>:现代科技的时间命脉
