使用变容管的优质调频话筒(英文),3V FM Transmitter for Short Distance - 88MHz to 108MHz
454398 2018-09-20 19:25 次阅读
关键字:使用变容管的优质调频话筒(英文)
Description
Features of the transmitter:
Supply Voltage:+3V DC
Current: 21mA
Output Frequency: 88MHz - 108MHz
Modulation: FM
Frequency Shift: ±30KHz
Input: Electret microphone or other input audio source
The important part of the circuit is formed of the Colpitts type oscillator. C3,C4,C5,C6,CD1-CD2 and L1 determines the frequency. BF982 and dual gate MOSFET are active parts in the oscillator. When the input impedance of the MOSFET gate inputs are high, LC tank is not affected. However transistors force the LC tank and cause phase shift.
Two driver stages are added to isolate the antenna from oscillator. First stage (BF199) amplifies the low signal of the oscillator and works as a constant load. The second stage (BFR90) amplifies the signal going through the antenna some more. A short copper wire can be used as an antenna here. Attaching a large antenna to this circuit is unnecessary because the output power is low.
Notes
Coil 1: Winding wire must be 1 mm thick and isolated. Number of turns: 3.5 . 5mm core must be used and the distance between each turn must be 1mm.
You can use BF199 instead of BFR90.
If you can't find the varicap diode, you can use two BB405 instead.
注意:下面两张图合并起来才是个完整电路哦
    TPA6139A2内部电源是否用开关升压电路?这样是否对88MHz--239.2MHz会产生干扰?
    TPA6139A2这颗IC 内部电源是否用开关升压电路, 这样是否对88MHz--239.2MHz 会产生干扰
    发表于 10-23 06:45
    舒尔SLX4无线话筒接收机原理图:二次变频超外差部分
    舒尔SLX4无线话筒接收机110MHz10.7MHz二次变频超外差部分实测原理图
    发表于 09-29 11:18 25次下载
    OPA847频率特性曲线中为什么会有多条曲线?
    本人刚学这个软件请问我想将20mA100Mhz正弦波放大10被并且在75MHz108MHz频率范围内增益波动不大于2dB 应该怎么办? 频率特性曲线中为什么会有多条曲线? 是杂波吗
    发表于 08-30 08:49
    用LMV551和mos做恒流源,同相端输入0的时候,运放输出为什么是3v
    用LMV551和mos做恒流源,同相端输入0的时候,运放输出为什么是3v? mos拆掉也一样。
    发表于 08-28 07:11
    TLV3501迟滞比较器,1v正弦波在3Mhz后出现较大失真的原因?怎么解决?
    TLV3501,而且小幅值输入的情况下(100mv)比较效果也很差 我只搭建了这么小的模块,输入信号是信号发送器给的,范围从30mv ~3v频率从1k~10mhz。电源是电源箱提供的3.3v另外一端
    发表于 08-26 07:42
    想用ths3001id将频率为25Mhz,峰峰值为3v的正弦波放大到15v峰峰值,请问可以实现吗?
    我想用ths3001id将频率为25Mhz,峰峰值为3v的正弦波放大到15v峰峰值,请问可以实现吗
    发表于 08-23 06:42
    窄带调频和宽带调频的区别特点和应用
    窄带调频(Narrowband FM)和宽带调频(Wideband FM)是两种不同的调频技术,它们在通信领域有着广泛的应用。 一、窄带
    的头像 发表于 08-14 11:22 3984次阅读
    全波段和调频收音机怎么选择
    调频等波段。全波段收音机可以接收来自世界各地的广播信号,包括新闻、音乐、体育赛事等。 调频收音机 调频收音机是一种专门接收调频FM)信号
    的头像 发表于 08-06 10:09 3987次阅读
    调频中波段收音机接收频率范围
    领域得到了广泛应用。 一、调频中波段收音机的接收频率范围 调频广播的频率范围 调频广播的频率范围通常在87MHz108MHz之间,这个频率
    的头像 发表于 08-06 10:07 2246次阅读
    1.6 MHz3-V至6-V输入,3-A同步降压SWIFT™转换器TPS54317数据表
    电子发烧友网站提供《1.6 MHz3-V至6-V输入,3-A同步降压SWIFT™转换器TPS54317数据表.pdf》资料免费下载
    发表于 04-16 10:54 0次下载
    1.6 <b class='flag-5'>MHz</b>,<b class='flag-5'>3-V</b>至6-<b class='flag-5'>V</b>输入,<b class='flag-5'>3</b>-A同步降压SWIFT™转换器TPS54317数据表
    2.95V至6V输入、3A输出、2MHz、同步降压SWIFT™转换器TPS54318数据表
    电子发烧友网站提供《2.95V至6V输入、3A输出、2MHz、同步降压SWIFT™转换器TPS54318数据表.pdf》资料免费下载
    发表于 04-15 09:23 0次下载
    2.95<b class='flag-5'>V</b>至6<b class='flag-5'>V</b>输入、<b class='flag-5'>3</b>A输出、2<b class='flag-5'>MHz</b>、同步降压SWIFT™转换器TPS54318数据表
    用于驱动背对背 NFET的 3V 至 65V理想二极控制器LM7480数据表
    电子发烧友网站提供《用于驱动背对背 NFET的 3V 至 65V理想二极控制器LM7480数据表.pdf》资料免费下载
    发表于 03-22 16:03 0次下载
    用于驱动背对背 NFET的 <b class='flag-5'>3V</b> 至 65<b class='flag-5'>V</b>理想二极<b class='flag-5'>管</b>控制器LM7480数据表
    用于驱动背对背NFET的3V至65V理想二极控制器LM7481数据表
    电子发烧友网站提供《用于驱动背对背NFET的3V至65V理想二极控制器LM7481数据表.pdf》资料免费下载
    发表于 03-22 15:55 0次下载
    用于驱动背对背NFET的<b class='flag-5'>3V</b>至65<b class='flag-5'>V</b>理想二极<b class='flag-5'>管</b>控制器LM7481数据表
    调频广播副信道RDS智能寻址编码器技术参数
    1、RDS简介 按照标准(GB4311.3-84)规定,我国调频广播的频率范围为87.5~108MHz,为防止调频台间的相互干扰,规定各电台之间的频道间隔为200kHz,最大频偏为75kHz,最高
    的头像 发表于 03-19 11:38 834次阅读
    <b class='flag-5'>调频</b>广播副信道RDS智能寻址编码器技术参数
    20MHz~700MHz抗阻塞放大器
    BR8122AFF是一款采用SMT工艺,PCB基板作为载体,通过金属外壳来实现硬件防护的抗阻塞放大器。该产品覆盖20MHz~700MHz的频率范围,在400MHz 频率下,Vdd=+5V
    的头像 发表于 03-13 14:40 700次阅读
    20<b class='flag-5'>MHz</b>~700<b class='flag-5'>MHz</b>抗阻塞放大器
