关键字:89C51编程器
#include "at89x52.h" sbit rdy=P3^2; void init_serial() void init_pro() void sendbyte(unsigned char da) /*send a byte*/ unsigned int getadr() /*get 5 diti DEC adr*/ unsigned char getdata() /*get 2 diti HEX data*/ unsigned int test(unsigned int nn) unsigned char erase(unsigned int nn,unsigned int p) prog=1; if(test(nn)==0) return 's'; unsigned char write() unsigned char lock(unsigned char level) void main()
#include "stdio.h"
#include "intrins.h"
#include "ctype.h"
sbit vpp=P3^3;
sbit p26=P3^4;
sbit p27=P3^5;
sbit p36=P3^6;
sbit p37=P3^7;
sbit prog=P2^7;
SCON=0x50; /*mode 1*/
TMOD=0x20;
TH1=0xfd;
PCON=0x80; /*38400bps*/
TR1=1; /*load tmr1*/
TI=1;
ES=1;}
p26=0;
p27=0;
p36=0;
p37=0;
vpp=1;
prog=1;
while(!TI);
TI=0;
SBUF=da;}
unsigned char IntToAscii(unsigned char a) /*change DEC to ASCII HEX code*/
if(a<10) return a+48;
if(a>9) return a+55;}
unsigned char i,a[5];
for(i=0;i<5;i++)
while(!RI);
RI=0;
a[i]=SBUF-48;
return a[0]*10000+a[1]*1000+a[2]*100+a[3]*10+a[4];}
unsigned char d1,d2;
while(!RI);
RI=0;
d1=toint(SBUF);
while(!RI);
RI=0;
d2=toint(SBUF);
return d1*16+d2;}
unsigned int detchip(int adr)
P0=0xff;
P1=adr%256;P2=adr/256;
init_pro();
_nop_();_nop_();_nop_();_nop_();_nop_(); /*delay 10 us*/
return P0;}
void read()
unsigned int adr,maxadr;
unsigned char h,l;
P0=0xff;
maxadr=getadr();
for(adr=0;adr
p26=0;
p27=0;
p36=1;
p37=1;
vpp=1;
prog=1;
h=IntToAscii(P0/16);
sendbyte(h);
l=IntToAscii(P0%16);
sendbyte(l);}
init_pro();}
unsigned int adr,counter=0;
P0=0xff;
for(adr=0;adr
p26=0;
p27=0;
p36=1;
p37=1;
vpp=1;
prog=1;
if(P0!=0xff) counter++;}
init_pro();
return counter;}
unsigned int i;
P0=0xff;
p26=1;
p27=0;
p36=0;
p37=0;
vpp=0;
prog=1;
for(i=0;i<50000;i++) _nop_();
switch(p)
case 0 : prog=0;
prog=1;
break;
case 1 : prog=0;
_nop_();
prog=1;
break;
case 2 : prog=0;
_nop_();_nop_();
prog=1;
break;
case 3 : prog=0;
prog=1;
break;
case 4 : prog=0;
prog=1;
break;
case 5 : prog=0;
prog=1;
break;
case 6 : prog=0;
_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
prog=1;
break;
case 7 : prog=0;
_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
prog=1;
break;
case 8 : prog=0;
_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
prog=1;
break;
default: prog=0;
for(i=0;i
break;}
vpp=1;
for(i=0;i
else return 'f';}
unsigned int adr,d,i;
p26=0;
p27=1;
p36=1;
p37=1;
vpp=0;
prog=1;
for(i=0;i<4000;i++) _nop_();
adr=getadr();
d=getdata();
while(1)
if(adr>50000) break;
P1=adr%256;P2=(adr/256)|0x80;
P0=d;
TI=0;
SBUF='s';
prog=0;
prog=1;
adr=getadr();
d=getdata();
while(!rdy);}
init_pro();
return 'f';}
unsigned int i;
vpp=0;
if(level==1) {p26=1;p27=1;p36=1;p37=1;}
if(level==2) {p26=1;p27=1;p36=0;p37=0;}
if(level==3) {p26=1;p27=0;p36=1;p37=0;}
prog=1;
prog=0;
prog=1;
while(!rdy);
init_pro();
return 'o';}
unsigned char data c;
unsigned int data adr,l,dx;
init_pro();
init_serial();
while(1)
init_pro();
scanf("%c",&c);
switch(c)
case 'c' : printf("%c",'o');
break;
case 'd' : scanf("%x",&adr);
printf("%x",detchip(adr));
break;
case 't' : scanf("%u",&dx);
printf("%u",test(dx));
break;
case 'r' : read();
break;
case 'e' : scanf("%u,%u",&adr,&dx);
printf("%c",erase(adr,dx));
break;
case 'w' : printf("%c",write());
break;
case 'l' : scanf("%u",&l);
printf("%c",lock(l));
break;
case 'h' : printf("**********Er6y Programmer Help Window***********\n");
break;
default : break;}
89C51编程器,89c51 programmer
