24C02读写操作程序设计实例,24C02 read / write process
关键字:24C02读写操作程序设计实例
24C02读写操作程序设计实例
#define uchar unsigned char
#define uint unsigned int
#i nclude
#i nclude
#i nclude
sbit scl=P3^5; //24c02 SCL
sbit sda=P3^4; //24c02 SDA
sbit DOG=P1^7; //狗
uchar x24c02_read(uchar address); //从24c02的地址address中读取一个字节数据
void x24c02_write(uchar address,uchar info); //向24c02的address地址中写入一字节数据info
void x24c02_init(); //24c02初始化子程序
void delay1(uchar x);
void flash();
void x24c01_init();
void start();
void stop();
void writex(uchar j);
uchar readx();
void clock();
uint i;
for(i=0;i DOG=~DOG;
void flash()
uchar u;
DOG=~DOG;
void x24c02_init()
scl=1; flash(); sda=1; flash();
void start()
sda=1; flash(); scl=1; flash(); sda=0; flash(); scl=0; flash();
void stop()
sda=0; flash(); scl=1; flash(); sda=1; flash();
uchar i,temp;
temp=j;
for (i=0;i<8;i++){
temp=temp<<1; scl=0; flash(); sda=CY; flash(); scl=1; flash();
scl=0; flash(); sda=1; flash();
uchar readx()
uchar i,j,k=0;
for (i=0;i<8;i++){
if (sda==1) j=1;
else j=0;
k=(k<<1)|j; scl=0;
flash(); return(k);
void clock()
uchar i=0;
scl=1; flash();
while ((sda==1)&&(i<255))i++;
scl=0; flash();
uchar i;
start(); writex(0xa0);
clock(); writex(address);
clock(); start();
writex(0xa1); clock();
i=readx(); stop();
delay1(10);
return(i);
EA=0;
clock(); writex(info);
clock(); stop();
EA=1;
delay1(50);
#i nclude
#i nclude
#i nclude
sbit DOG=P1^7; //狗
void flash();
void x24c01_init();
void start();
void stop();
uchar readx();
void clock();
uint i;
for(i=0;i
void flash()
uchar u;
DOG=~DOG;
void x24c02_init()
void start()
void stop()
uchar i,temp;
temp=j;
for (i=0;i<8;i++){
uchar readx()
uchar i,j,k=0;
for (i=0;i<8;i++){
if (sda==1) j=1;
else j=0;
k=(k<<1)|j; scl=0;
flash(); return(k);
void clock()
uchar i=0;
scl=1; flash();
scl=0; flash();
uchar i;
clock(); start();
i=readx(); stop();
delay1(10);
return(i);
EA=0;
clock(); stop();
EA=1;
delay1(50);
举报投诉
热点推荐
深入剖析 CAT24C02/04/08/16:I²C 串行 EEPROM 的卓越之选
深入剖析 CAT24C02/04/08/16:I²C 串行 EEPROM 的卓越之选 在电子设计领域,EEPROM(电可擦可编程只读存储器)扮演着至关重要的角色,它能够在断电后保留数据,为各种
Z86C02/E02/L02微控制器:高性价比的512字节ROM CMOS解决方案
Z86C02/E02/L02微控制器:高性价比的512字节ROM CMOS解决方案 在电子设计领域,寻找一款既经济实惠又功能强大的微控制器是许多工程师的追求。Zilog的Z86C02/
深入剖析 CAT24AA01/02 EEPROM:特性、功能与应用详解
: CAT24AA02TDI-GT3.pdf 产品概述 CAT24AA01 和 CAT24AA02 是两款基于 I²C 总线协议的串行 EEPROM 设备,分别提供 1Kb 和 2Kb
M24SR02-Y:动态NFC/RFID标签IC的技术解析与应用指南
的一员,是一款极具特色的动态NFC/RFID标签IC,下面我们就来深入了解一下它。 文件下载: M24SR02-YMN6T 2.pdf 一、M24SR02-Y的核心特性 接口特性 I²C接口 :采用两
FM24V02A:高性能串行F - RAM的卓越之选
——FM24V02A,看看它在众多应用场景中是如何脱颖而出的。 文件下载: FM24V02A-G.pdf 产品概述 FM24V02A是一款256 - Kbit(32K × 8)的串行(I²C
深入剖析M24SR02-Y:动态NFC/RFID标签IC的卓越之选
深入剖析M24SR02-Y:动态NFC/RFID标签IC的卓越之选 在当今的电子技术领域,NFC/RFID技术的应用日益广泛,为各种智能设备和系统带来了便捷与高效的通信方式。M24SR02-Y作为
探秘AQ24COME - 02HTG:高性能双向TVS二极管的卓越表现
探秘AQ24COME - 02HTG:高性能双向TVS二极管的卓越表现 作为电子工程师,在设计过程中选择合适的静电放电(ESD)保护元件至关重要。今天,我们就来深入了解一下Littelfuse
深入解析 N24C02/04/08/16:高性能CMOS串行EEPROM
推出的 N24C02/04/08/16 系列 $I^{2}C$ CMOS 串行 EEPROM,看看它们在设计中能为我们带来哪些便利和优势。
Onsemi N24C02/04/08/16:高性能I²C EEPROM的卓越之选
在电子设计领域,EEPROM是一种至关重要的存储元件,而Onsemi的N24C02、N24C04、N24C08和N24C16系列I²C EE
芯伯乐24C02/24C04/24CXX:百万次擦写非易失性存储器的解决方案
的首选方案。无论是消费电子、工业控制还是物联网设备,都能见到它的身影。一产品概述24C02/24C04/24Cxx系列是基于IIC总线协议的串行电可擦除存储器(E
STMicroelectronics M24M02E-U 2Mbit I²C EEPROM技术解析与应用指南
STMicroelectronics M24M02E-U 2Mbit I^2^C兼容电子擦除可编程只读存储器内部组织为256K x 8位。其工作电源电压为1.6V至5.5V、时钟频率最高可达1MHz
【沁恒CH585开发板免费试用体验】I2C 读写EEPROM (三)
是对AT24C02的读写操作。
5.2 实验现象
下载程序,连接串口打印信息如下。
Figure 5‑1 软件I2C实现现象
发表于 08-05 22:25
【沁恒CH585开发板免费试用体验】I2C 读写EEPROM (二)
_GetFlagStatus(I2C_FLAG_BUSY) != RESET);
主要配置I2C模式、低电平占空比、I2C寻址模式以及通信速率,最后使能I2C设备。
初始化完成后
发表于 08-05 22:13
【RA-Eco-RA4M2开发板评测】I2C读取EEPROM(二)
的读写操作,严格按照相应的时序操作就行。
6.2.1 字节写
在字节写模式下,向AT24C02中写数据时序如下:
Figure 6‑4 字节写操作
发表于 04-28 23:14
