AT24C02的读写程序,24C02 read / write process
关键字:AT24C02的读写程序
AT24C02的读写程序
#include
#include
#include "INTRINS.H"
#define uchar unsigned char
#define _NOP_() _nop_()
#define WriteDeviceAddress 0xa0 /*24c02的写地址*/
#define ReadDviceAddress 0xa1 /*24c02的读地址*/
sbit SCL=P1^6;
sbit SDA=P1^7;
sbit P1_5=P1^5;
sbit P1_4=P1^4;
sbit P1_3=P1^3;
sbit P1_2=P1^2;
unsigned char code table[]={0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01};
unsigned char table1[8];
/*********************延时程序*******************************************/
void DelayMs(unsigned int number) {
unsigned char temp;
for(;number!=0;number--)
for(temp=112;temp!=0;temp--);
#include
sbit SCL=P1^6;
sbit SDA=P1^7;
sbit P1_5=P1^5;
sbit P1_4=P1^4;
sbit P1_3=P1^3;
sbit P1_2=P1^2;
unsigned char temp;
***************************24c02开始程序************************************
void Start()
SDA=1;
SCL=1;
SDA=0;
SCL=0;
***************************24c02停止程序************************************
void Stop()
SCL=0;
SDA=0;
SCL=1;
SDA=1;
void Start()
SDA=1;
SCL=1;
SDA=0;
SCL=0;
void Stop()
SCL=0;
SDA=0;
SCL=1;
SDA=1;
void Ack()
SDA=0;
SCL=1;
SCL=0;
SDA=1;
void Ack()
SDA=0;
SCL=1;
SCL=0;
SDA=1;
void NoAck()
SDA=1;
SCL=1;
SCL=0;
*返回错误标志,ErrorBit=SDA,为1错误,0正确*********************************
bit TestAck()
bit ErrorBit;
SDA=1;
SCL=1;
ErrorBit=SDA;
SCL=0;
return(ErrorBit);
***************************24c02写一个字节程序******************************
void Write8Bit(unsigned char input)
unsigned char temp;
for(temp=8;temp!=0;temp--)
SDA=(bit)(input&0x80);/*从高位依次取input的各位*/
SCL=1;
SCL=0;
input=input<<1; /*相等与RLC,取了CY位*/
***************************24c02写程序**************************************
void Write24c02(unsigned char *Wdata,unsigned char RomAddress,unsigned char number)
{ /*Wdata对准要写的数据的首地址 RomAddress单元地址 number几个Byte*/
Start();/*IIC开始*/
Write8Bit(WriteDeviceAddress);/*写入器件地址0xa0*/
TestAck();/*测试ACK位*/
Write8Bit(RomAddress);/*写入器件控制单元地址*/
Write8Bit(*Wdata);
TestAck();
Wdata++;
Stop();/*IIC停止*/
DelayMs(10);/*延长10MS,保证数据写入*/
***************************24c02读一个字节程序******************************
unsigned char Read8Bit()
unsigned char temp,rbyte=0;
SCL=1;
rbyte=rbyte<<1;
rbyte=rbyte|((unsigned char)(SDA));
SCL=0;
/* for(temp=8;temp!=0;temp--)
SCL=1;
rbyte=rbyte<<1;
if(SDA==1)
rbyte=rbyte|0x01;
SCL=0;
return(rbyte); /*把数据返回*/
***************************24c02读程序**************************************
void Read24c02(unsigned char *RamAddress,unsigned char RomAddress,unsigned char bytes)
/*unsigned char temp,rbyte;*/
Start(); /*IIC开始*/
Start();/*IIC再次发送开始*/
Write8Bit(ReadDviceAddress);
while(bytes!=1)
*RamAddress=Read8Bit();/*存一个读到的数据到RamAddress+I*/
Ack();/*发送IIC再读*/
RamAddress++;/*存取地址加一*/
bytes--;
NoAck();/*发送IIC停止读*/
Stop();/*IIC停止*/
void NoAck()
SDA=1;
SCL=1;
SCL=0;
bit TestAck()
bit ErrorBit;
SDA=1;
SCL=1;
ErrorBit=SDA;
SCL=0;
return(ErrorBit);
unsigned char temp;
SCL=1;
SCL=0;
Start();/*IIC开始*/
Write8Bit(*Wdata);
TestAck();
Wdata++;
Stop();/*IIC停止*/
SCL=1;
rbyte=rbyte<<1;
SCL=0;
SCL=1;
rbyte=rbyte<<1;
if(SDA==1)
rbyte=rbyte|0x01;
SCL=0;
Start(); /*IIC开始*/
while(bytes!=1)
Ack();/*发送IIC再读*/
bytes--;
Stop();/*IIC停止*/
举报投诉
【AG32开发板体验连载】智能蒸烤箱--AG32VF407I2C总线测试
TestI2cPROM() // Testing AT24C02等五个主要函数组成,通过I2C总线实现对24LC02B的读写过程。具体程序
发表于 11-20 23:15
SSS1700C1鑫创USB麦克风芯片/24BIT 192K声卡芯片方案
),并具有内置立体声16/24位ADC、立体声16/24位DAC、耳机驱动程序、五频段硬件EQ、,音频锁相环,USB时钟振荡器,和USB FS控制器加物理层。外部24C02~
发表于 11-14 10:06
数据保存100年!纳祥科技国产EEPROM芯片NX24C02A,兼容替代AT24C02
NAXIANGTECHNOLOGY纳祥科技NX24C02AEEPROMEEPROM(ElectricallyErasableProgrammablereadonlymemory),带电
英锐芯AD24C02_16-Byte(中性)
AD24C02是一款串行电可擦除编程只读存储器(EEPROM)。存储器可存储256个字节数据,分为16页 每页16字节,随机字寻址需要8位数据字地址,具有低功耗CMOS技术,自定时编程周期
发表于 09-09 15:08
•0次下载
ADS125H02 ±20V输入、双通道、40kSPS、24位 Δ-ΣADC数据表
电子发烧友网站提供《ADS125H02 ±20V输入、双通道、40kSPS、24位 Δ-ΣADC数据表.pdf》资料免费下载
发表于 07-23 11:34
•0次下载
ADS131M02 2通道、同步采样、24位 Δ-ΣADC数据表
电子发烧友网站提供《ADS131M02 2通道、同步采样、24位 Δ-ΣADC数据表.pdf》资料免费下载
发表于 07-15 11:38
•0次下载
STM8S103F3读24C02硬件I2C可以连续读,模拟I2C只能读一个,第二个是0x00为什么?
读24C02硬件I2C可以连续读,模拟I2C只能读一个。第二个是0x00,求助大神指点
发表于 05-06 07:22
stm8s103k与AT24C02的iic通信不稳定是什么原因导致的?
stm8s103k与AT24C02的iic通信不稳定,有时可以读取数据,有时读不出
是什么原因?
有人与ADS1110用iic通信过吗?
发表于 04-30 07:33
STM32F103用普通IO口驱动24C02,读写不正确的原因?
以下24C02的驱动好像不稳定,不更换24C02时,读写都正确,但是更换一个24C02,数据就读写不正确,在把之前的正常的
发表于 04-19 06:12
通过STM32F103的I2C读写24LC024,超过16个以后读回来的地址上的数不对是怎么回事?
的问题?
#defineADDR_24LC02_Write0xA0
#defineADDR_24LC02_Read0xA1
#defineBufferSize20
发表于 04-18 06:37
24LC024超过16字节读写就不正常怎么解决?
。主控制器用的STM32F103。读写控制代码如下:#defineADDR_24LC02_Write0xA0
#defineBufferSize
发表于 04-15 06:21
昂科烧录器支持Giantec聚辰半导体的电可擦可编程只读存储器GT24C02B-2UDLI
芯片烧录行业领导者-昂科技术近日发布最新的烧录软件更新及新增支持的芯片型号列表,其中Giantec聚辰半导体的电可擦可编程只读存储器GT24C02B-2UDLI已经被昂科的通用烧录平台AP8000所支持。
