自制MP3播放器,mp3 player
关键字:MP3电路图
简述:此款名为yampp-7型MP3播放器,用了一片Nokia3310手机的LCD显示屏来显示操作,使用一片FT8U245USB芯片!能使用多种小型Flash卡和多媒体卡作为歌曲文件存储器!
yampp7 is a new portable MP3 player that uses ComPACt Flash or MultiMedia cards for storage of songs. You'll get about 1 minute of playing time per MB on the memory card, if your songs are 128 kbps.
The player is pretty small and the PCB has been designed to fit into a Teko "Soap" box.
It features a 84*48 pixel graphICal LCD display, similar to the displays used on Nokia 3310 cell phones.
It's designed to operate from rechargable battery cells, either from a single 3.6V Li-Ion cell (recommended), or from 3*1.2V Ni-Mh cells. With a 600 mA Li-Ion cell, the playing time is about 12 hours, but you CAN find Li-Ion cells up to 1200 mAh that will fit in the player, extending the playing time to about 24 hours
It's intended to be used with replacement Li-Ion cells for Mobile Phones, making it easy (and relatively cheap) to find a suitable cell. (I use mine with a cell for a Motorola V3688 Phone).
It also features a USB interface for fast downloading of songs to the memory card, and for firmware updates
The player uses a special filesystem calLED YADL (Yampp Advanced Disk Layout), which maximizes the capacoty of the memory card.
It is playlist based and give the player a powerful but easy to use user interface
Processor
The central part of the yampp-7 player is the Atmel mega161 CPU. It's like a big-brother to the classic 8515 CPU that was used on the original yampp-3.
It has 16 kB Flash and 1024 bytes internal SRAM, both double as much as on the 8515.
It also features a bootloader option. This is been used in yampp-7, where it is now possible to download new firmware over the USB link
USB
The USB link is controlled by a FT8U245BM Chip from FTDI. This is a VERY easy to use USB chip, which basically looks like a simple 8-bit buffer (hence the name). There's no need for implementing any specific USB code in the player, to communicate over the USB link, you just read and write data directly to the chip.
Two status PINs inDICate if there's any data in the receive buffer, and if the transmitter queue is empty.
The USB chip is memorymapped and oCCupies a single address in the CPU address space.
Some discrete circuitry is added to the USB chip to enable it to startup in the correct mode, and to handle the power on reset and SOFt-Connect feature.
Li-Ion charger
A Maxim MAX1811 chip is added for handling the charging of the Li-Ion cell.(Ni-Mh cells can also be used in the player, in this case, the MAX1811 is replaced by a diode and a resistor).
The MAX chip is a special USB to Li-Ion charger, and it controls the relatively complicated charge sequence to the Li-Ion cell.
The Li-Ion cell (or Ni-Mh cells), supply 3.6V to the other components.
Memory Card Interface
The player can be used with either a Compact Flash card or a MultiMedia Card.
The Compact Flash (CF) interface is pretty similar to a standard ATA interface. The nice thing about it, is that it can run in 8-bit mode, making it very simple to interface to a microprocessor.
In the yampp-7, the CF interface is mapped directly into the memorymap of the processor. To control the CF card and to read/write data, the standard ATA register bank of is used, and address bits A8-A11 is used to select the register.
The MultiMedia Interface is a serial interface with an SPI bus. As the mega161 already has such a bus, the MultiMedia card is simply hooked onto this bus, with a single address line used as chip select.
Address decoding
To simplify the addressing of the CF card and USB interface, a 74HC00 is used to gate the RD and WR signals to the USB chip depending on the state of address line A15. With this, the USB chip will be LOCated at address 0x8000, and the CF card's registers are located at 0x1000 to 0x1F00.
MP3 Decoder
The MP3 decoder is, as on other yampp's the VS1001K chip from VLSI. It's an easy to use decoder with a built in DAC. It's clocked from a 12.288 MHz Crystal, enabling bitrates up to 256k bps.
It also has a built in headphone amplifier.
Player control
The player is controlled with 4 pushbuttons. One of these is connected to the ICP input of the CPU, which can generate an interrupt to the CPU. When the player is stopped, it enters power-down mode after 1 minute. The interrupt from the button can then be used to wakeup the CPU from the low-power sleep mode.
All buttons have two functions, one is reached by a short press on the button, and the other by holding down the button. Depending on player state, the buttons control various functio
Partslist
PartvaluePackage
R1,R610k R0805
R2,R3100RR0805 *
R4 1MR0805
R5,R8,R114k7 R0805
R71k5R0805
R102k2R0805
R12470R0805
R1333kR0805
R14,R1527 R0805
R1651kR0805
C1,C6,C7 100nFC0805
C9-C11 100nFC0805
C2-C533pFC0805
C8 10uF/16ELNA_RV2_4
C14 10uF/16 Tantal ! C6032
C15 1uF/16 Tantal C3528
C12,C13100uF/10ELNA_RV2_63
D1 BAS32 SOD80 *
T2 BC817 SOT23
IC1ATmega161LTQFP44
IC2VS1001K SOIC-28
IC474HC00D SO14
IC5MAX1811 SO8 **
IC6FT8U245BM QFP32
Q1 4.000MHzHC49U-V Crystal
Q2 12.288MHz HC49U-V Crystal
Q3 6.00MHz Ceramic Resonator
J1 Compact Flash Connector
J2 LCD/Programming Angled Connector 2*5 2mm
SH1 MultiMedia Card Connector
X1 Headphones3.5mm Jack
X2 USB Connector Type787780
SW1-SW4ALPS Type SKHHLQ pushbutton
* = only used with Ni-Mh cells
** = only used with Li-Ion cells
点击图片可放大
相关下载:
自制MP3播放器制作资料
自制MP3播放器制作资料
chengxu.rar
举报投诉
热点推荐
探秘SCF5249集成ColdFire®微处理器:性能与应用的深度剖析
MP3音乐播放器,尤其是便携式MP3 CD播放器,作为系统控制器/解码器。它采用32位ColdF
AT8xC51SND1C:集成MP3解码与丰富外设的单芯片解决方案
微控制器,它集成了MP3解码器和丰富的人机接口功能,为各类音频及多媒体应用提供了理想的解决方案。 文件下载: AT80C51SND1C-ROTIL.pdf 一、芯片概述 AT8xC51SND1C系列
芯知识|MP3语音芯片如何成为现代智能设备的“声音心脏”?
在智能化浪潮席卷全球的今天,从智能家居的温声细语到车载导航的清晰指引,背后都离不开一个核心元器件的驱动——MP3语音芯片。这种高度集成的MP3音频解码芯片,凭借其卓越的性能,已成为现代电子产品实现
广州唯创电子WT2003H MP3语音芯片方案:强大、灵活且易于集成的高性能音频解决方案
配置和简便的集成方式,为各行业提供了一套完善的高品质声音播报芯片解决方案。强大音频处理能力,满足多元应用场景WT2003H语音芯片支持MP3和WAV两种主流音频格式
多封装长录音:WT2003H系列MP3录音芯片满足全场景音频需求
系列MP3录音芯片在8K采样率下支持最长达70秒的连续录音,这一时长指标在同类产品中表现优异。通过优化的存储架构和高效的压缩算法,芯片在保证语音清晰度的同时,实现了
广州唯创WT2003H录音芯片-高精度ADC/DAC+64mA驱动MP3音频芯片
一、产品概述:WT2003H系列MP3录音芯片的技术优势1.1芯片定位与市场价值广州唯创电子作为国内领先的语音IC厂家,推出的WT2003H系列MP3音频芯片集高精度信号处理和强大驱动能力于一体。该
广州唯创电子WT2003Hx高品质MP3语音芯片:重塑智能设备音频体验
32位处理器与工业级品质的完美结合,为智能设备注入卓越音频性能在智能化浪潮席卷各行各业的今天,音频体验已成为衡量智能设备品质的重要标准。广州唯创电子推出的高品质MP3音频解码语音芯片WT2003Hx
Waytronic广州唯创电子 MP3语音芯片:现代智能设备的音频解决方案
高品质音频与低功耗设计的完美结合,为智能设备注入声音灵魂在智能化浪潮席卷全球的今天,语音交互已成为人机互动的重要方式。MP3语音芯片作为高度集成的音频处理解决方案,正以其出色的性能和创新技术,推动着
广州唯创电子WT2003HX高品质MP3音频语音芯片在早教故事机中的智能化应用
体验与内容品质,广州唯创电子推出的WT2003HX高品质MP3音频语音芯片,为早教故事机提供了高音质、高灵活性的语音解决方案。一、清晰语音引导,提升人机交互体验WT200
广州唯创电子WT2003H高品质MP3语音芯片:赋能儿童早教故事机新体验
当前儿童早教故事机市场产品品质参差不齐,音质粗糙、功能单一、内容安全无保障等问题,困扰着众多家长。广州唯创电子推出的WT2003H高品质MP3语音芯片应用方案,凭借其卓越的音质表现、创新的内容保护
新品|Unit AudioPlayer,支持 MP3/WAV 播放的音频播放单元
UnitAudioPlayer是一款自带MP3解码功能的音频播放单元,内置高性能音频解码芯片N9301,自带microSD卡座。该产品采用UART通信接口,用户可通过配置指令实现音频播放功能,音频
芯知识|广州唯创电子WT2003HX系列MP3语音芯片声道特性解析与应用指南
集成度:单芯片集成MP3解码、存储控制、功放驱动低功耗设计:D类功放效率>85%,适配电池供电设备简化电路:省去外置功放电路,降低BOM成本注:单声道输出对智能家居提
芯资讯|广州唯创电子语音芯片U盘MP3播放IC技术解析与应用指南
,在语音芯片领域积累了深厚的技术实力。唯创电子的核心创新之一是其支持U盘直读的MP3语音芯片系列,这些芯片解决了传统语音芯片需要专用工具更新语音内容的痛点,为用户提
芯资讯|广州唯创电子MP3语音芯片IC的音频解码方式解析
支持、技术特性及应用场景三方面,解析其解码方案的设计逻辑与优势。一、音频解码格式的支持MP3播放类芯片的主流解码能力唯创电子的MP3语音芯片(如WT2003H系列)
自制MP3播放器,mp3 player
