12V电池升压器(英文),multi output power converter
关键字:12V电池升压器制作
12V电池升压器制作
Many times we needed a variety of voltages, from a battery 12V. With the circuit, we CAN take voltages smaller or bigger, positive or negative, from a battery 12V. The idea is based in oscillator roughly 7KHz, round the R1, C28, that lead the remainder gates of IC1, that are connected at the parallel, (so that they provide the essential current of drive), that drive with the line their transistors Q1 until Q4. Then exist two circuits of "cascade" constituted from diodes and caPACitors, D1 until D4, C14 until C17 for the negative and D5 until D9, C19 until C23 for the positive voltage, that drive the corresponding stabilizers. In the outputs of stabilizers exist inductors, which they remove and the last remains of oscillation. The current that we can take from the outputs are order the 100 until 200 mA. The total time that will capacity of battery it gives the current that we want, it’s up to from her capacity on Ah, as long as more so much more time. All the transistors and the stabilizers, good it is they are placed in a heatsink, in order to it remove the produced heat.
举报投诉
发布评论请先 登录 相关推荐 DCDC低电压2V输入升压12V、18、24V/2A升压恒压电源供电IC SLB628电压配置,成为了低电压输入升压应用的理想选择。
产品概述SLB628是一款专为低电压输入设计的升压电源模块,能够轻松将2V的输入电压升压至12V
发表于 12-18 17:16
蓝牙音响/吸奶器3.3V升压5V芯片 3.7V升压12Vic 5V升压12V2.5A 电路同步升压恒压芯片-H6392 低功耗 高效率:H6392支持2.6-5V的输入电压,适用于单节锂电池供电的设备,满足多种低压电源的应用场景。
· 高效升压功能:芯片能将输入电压升压至12
发表于 11-28 14:53
锂电池输入3.7-7V 输出12V 5A 发热片 SL4010升压恒压芯片SL4010 高性能升压转换模块:为您的发热片提供稳定强劲的12V 5A动力源在追求高效能与可靠性的今天,SL4010升压转换模块以其卓越的性能和广泛的应用适应性,成为驱动各类发热元件的理想选择
发表于 11-13 14:24
直流电5v变12v怎么升压直流电5V变12V的升压方法有很多种,本文将介绍其中一种方法——使用DC-DC升压模块。DC-DC升压模块是一种将低电压直流电转换为高电压直
5v升12v的直流升压电路工作原理是什么5V升12V的直流升压电路是一种将输入电压从5V提高到12V的电路。这种电路广泛应用于各种电子设备中,如手机充电器、便携式电源、太阳能
PMP21867.1-适用于功率放大器的12V/100A负转正同步降压/升压转换器PCB layout 设计电子发烧友网站提供《PMP21867.1-适用于功率放大器的12V/100A负转正同步降压/升压转换器PCB layout 设计.pdf》资料免费下载
发表于 05-15 11:16
•1次下载
5v转12v升压线8.4v/9v小米华为路由器电源线圆头充电线芯片方案IC小米、华为等知名品牌路由器供电时,其使用频率更是相当高。本文将对5V转12V升压线的工作原理、性能特点以及在小米、华为路由器中的应用进行深入
H6392升压恒压DC3.7V升5V 3.7V升9V 3.7V升12V电源芯片H6392 是一款升压恒压电源管理芯片,能够将低电压升高到所需的更高电压(如 5V 或 12V)。这类芯片通常用于电池供电的应用,其中电池电
发表于 03-12 10:04
ACM5618 超大电流能力DC-DC升压,可实现单节电池升压12V。ACM5618全集成方案,外部无需MOS和肖特基,外围简单,最高效率96%,即使在单节电池升压到12V的应用下,效率也可以达到91%。可以应用于音响系统,电子烟,便携打印机,便携电机类产品等。 ACM5618高效率大电流的特点
12v电源和12v充电器有什么区别?。它通常由电源适配器、电路板、转换器等部分组成。这种电源可以通过直插插座或带有插头的电线与电网接通,然后通过转换器将电网上的交流电转换为直流电输出。12V电源在一定范围内提供稳定的电压输出,常用于供电电子设备,如笔记本电脑、电视
12v继电器的作用和原理介绍12V继电器可以实现电路的开关控制、信号传递等功能。在实际应用中,12V继电器的作用和原理是非常重要的。本文将对12V继电器的作用和原理进行详细介绍。 首先,我们需要了解12V继电器的
用LTC7149将+12V转-12V,正负12V给运放供电,变换器不能正常启动怎么解决?您好!用LTC7149将+12V转-12V,正负12V给运放供电,发现+12V转-12V变换器不
发表于 01-05 13:22
大功率12v三端稳压有哪些大功率12V三端稳压器是一种常用的电子电路,用于稳定输入电压为12V,并输出稳定的12V电压。在许多电子设备中,这种稳压器被广泛应用,例如电
