Whistle Responder,口哨响应电路
454398 2018-09-20 20:35 次阅读
关键字:Whistle Responder
Beeps when hears your whistle
A gadget suitable for key-holders, games etc.
Circuit diagram:
Parts:
R1 22K 1/4W Resistor
R2 10K 1/4W Resistor
R3 4M7 1/4W Resistor
R4,R8 100K 1/4W Resistors
R5 220R 1/4W Resistor
R6 330K 1/4W Resistor
R7 47K 1/4W Resistor
R9 2M2 1/4W Resistor
R10 1M5 1/4W Resistor
C1,C5 47nF 63V Polyester or Ceramic Capacitors
C2,C3 10nF 63V Polyester Capacitors
C4,C6 1µF 63V Electrolytic Capacitors
D1,D2 1N4148 75V 150mA Diodes
IC1 4049 Hex Inverter IC
Q1 BC337 45V 800mA NPN Transistor
MIC1 Miniature electret microphone
BZ1 Piezo sounder (incorporating 3KHz oscillator)
B1 2.8 or 3V Battery (see notes)
Device purpose:
Some 15 years ago it was common to see small key-holders emitting an intermittent beep for a couple of seconds after its owner whistled. These devices contained a special purpose IC and therefore were not suited to home construction. The present circuit is designed around a general purpose hex-inverter CMos IC and, using miniature components and button clock-type batteries can be enclosed in a matchbox. It is primarily a gadget, but everyone will be able to find suitable applications.
Circuit operation:
This device beeps intermittently for approx. two seconds when a person in a range of about 10 meters emits a whistle.
The first two inverters contained in IC1 are used as audio amplifiers. IC1A amplifies consistently the signal picked-up by the small electret-microphone and IC1B acts as a band-pass filter, its frequency being centered at about 1.8KHz. The filter is required in order to select a specific frequency, the whistle's one, stopping other frequencies that would cause undesired beeper's operation. IC1C is wired as a Schmitt trigger, squaring the incoming audio signal. IC1D is a 2 second (approx.) monostable driving the astable formed by IC1E & IC1F. This oscillator generates a 3 to 5Hz square wave feeding Q1 and BZ1, thus providing intermittent beeper's operation.
Notes:
Power supply range: 2.6 to 3.6 Volts.
Standing current: 150µA.
Depending on dimensions of your box, you can choose from a wide variety of battery types:
2 x 1.5 V batteries type: AA, AAA, AAAA, button clock-type, photo-camera type & others.
2 x 1.4 V mercury batteries, button clock-type.
1 x 3 V or 1 x 3.6 V Lithium cells.
    瞬态响应的定义和重要性
    描述的是系统对输入信号变化的快速响应能力。在电子电路中,瞬态响应通常指的是电路在输入信号突然变化时,输出电压或电流随时间变化的特性。
    的头像 发表于 10-10 15:24 872次阅读
    OPA695 TINA-TI对于相同电路的幅频响应结果不同是怎么回事?
    图1图2 图1是我搭建的电路,图2是同学搭建的电路,两个电路的参数和元件位置都相同,但是幅频响应的频带和增益却相差很大,具体如下: 图3图4 图3是图1
    发表于 07-30 06:48
    瞬态响应的性能指标包括哪些
    瞬态响应性能指标是衡量电子系统、电路或信号处理系统在响应瞬态输入信号时的性能指标。这些指标对于确保系统在实际应用中的稳定性、可靠性和性能至关重要。 瞬态响应的定义 瞬态
    的头像 发表于 07-29 11:11 824次阅读
    请问OPA350峰值检测电路如何响应信号峰值变化?
    在器件手册中看到的一个推荐电路。但是这个电路是不是有点问题,电容C1只能充电不能放电,信号峰值变大可以响应,信号峰值变小的时候输出不会响应的,怎么才能实现第二图中的输出跟随信
    发表于 07-26 07:32
    使用示波器测量共射极放大电路的频率响应
    共射极放大电路作为电子电路中常用的放大结构,其频率响应是衡量其性能的重要指标之一。频率响应描述了电路在不同频率输入信号下的增益变化情况,通过
    的头像 发表于 05-27 15:49 740次阅读
    影响放大电路低频响应和高频响应的分别是什么?
    影响放大电路低频响应和高频响应的分别是什么? 影响放大电路低频响应和高频响应的因素是多方面的。
    的头像 发表于 02-04 10:25 2730次阅读
    使用RS示波器和频率响应分析选件进行电源控制环路响应测量
    和动态响应。海洋仪器解决方案使用RTx-K36频率响应分析(波特图)选件,在示波器上轻松快速地分析低频响应:表征多种电子设备的频率响应,包括无源滤波器和放大器
    的头像 发表于 01-20 08:30 568次阅读
    使用RS示波器和频率<b class='flag-5'>响应</b>分析选件进行电源控制环路<b class='flag-5'>响应</b>测量
    用示波器观测RC一阶电路零输入响应为什么激励必须是方波信号?
    用示波器观测RC一阶电路零输入响应为什么激励必须是方波信号? RC电路是一种常见的一阶电路,它由一个电阻R和一个电容C组成。当RC电路受到一
    的头像 发表于 11-21 16:00 3752次阅读
    请问关于全相应电路中的零状态响应和零输入响应分别怎么求呀?
    请问关于全相应电路中的零状态响应和零输入响应分别怎么求呀? 全相应电路是指由线性常系数微分方程描述的电路。零状态
    的头像 发表于 11-21 15:22 2422次阅读
    动态元件的初始储能在电路中产生的零输入响应中有什么分量?
    动态元件的初始储能在电路中产生的零输入响应中有什么分量? 动态元件指的是具有存储能量的元件,如电感和电容。在电路中,当输入信号突变或变化时,动态元件可以储存一部分能量,并在信号稳定后释放出来。而在
    的头像 发表于 11-21 15:22 1740次阅读
    动态电路中,零输入响应是仅由动态元件的初始贮能产生的响应对吗?
    动态电路中,零输入响应是仅由动态元件的初始贮能产生的响应对吗? 在动态电路中,零输入响应指的是由于初始条件引起的
    的头像 发表于 11-21 15:22 913次阅读
    什么样的电信号可以作为RC一阶电路零输入响应的激励信号呢?
    什么样的电信号可以作为RC一阶电路零输入响应、零状态响应和完全响应的激励信号呢? RC一阶电路是由一个电阻(R)和一个电容(C)组成的简单
    的头像 发表于 11-21 15:22 4366次阅读
    什么是二阶电路的零状态响应和零输入响应?零输入响应的步骤有哪些?
    什么是二阶电路的零状态响应和零输入响应?二阶电路的零输入响应的步骤有哪些? 二阶电路是指由电容、
    的头像 发表于 11-21 15:18 3014次阅读
    什么是动态电路的零状态响应呢?
    若输入的激励信号为零,仅有储能元件的初始储能所激发的响应,称为零输入响应
    的头像 发表于 11-20 17:44 2377次阅读
    什么是动态<b class='flag-5'>电路</b>的零状态<b class='flag-5'>响应</b>呢?
    一阶RC和RL电路的0状态响应的区别在哪?
    一阶RC电路的零状态响应,指的是RC串联电路,在初始时刻(即t=0)电容电压为零
    的头像 发表于 11-20 17:42 2017次阅读
    一阶RC和RL<b class='flag-5'>电路</b>的0状态<b class='flag-5'>响应</b>的区别在哪?
