300W逆变器,300W Power Inverter
关键字:逆变电路及图
Here is a schematic 300W power inverter with 12 volt batteries as a source. This inverter is controlled by 555 timer and CD4017 decade counter. You should try to build this inverter, because it can be used to power load 300W. With the power was sufficient to illuminate a few light bulbs at night for your camping needs.
This 300W power inverter is quite simple but powerful, efficient, and stable. The inverter is built using a 10V center tap transformer. A 555 Timer IC and a 4017 decade counter IC used to produce a modified sine wave of 50 Hz.
300W Power Inverter Circuit Diagram(点击图片放大)
Timer 555 will produce a frequency of 200 Hz (see the schematic for more info) by adjusting the potentiometer value of 500K. CD4017 produces the pulse trains on pin 2 and pin 7 of CD4017 is connected to the gates of the MOSFET STP36NF06L. It then directed to the transformer primary side. There will be 220V AC at the transformer secondary side of the 300W power inverter.
In order for the inverter system can run to efficiently use the cooling fan, even though the heatsink is still needed. Be careful you are working with AC power at the output of the 300W power inverter.
300W大功率智能调光IC-H6912 3.3V3.7V5V升压150V10A大电流芯片 PWM+模拟无频闪调光方案
UCC28063EVM-723 300W交错式PFC预调节器手册
UCC28060EVM 300W交错式PFC预调节器手册
Vox Power Ltd - 最新发布EIRE300系列开放式AC-DC电源,高功率密度,300W输出功率,占地4”x 2”,1”纤薄设计,30
TP3255 RCA input输入单端信号幅值范围是多少?输入差分信号幅值范围是多少?
ATA-8126射频功率放大器
大联大推出基于Innoscience产品的300W电源适配器方案
大联大诠鼎集团推出基于Innoscience产品的300W电源适配器方案
PMP31052.1-汽车类四开关、大于 300W 降压/升压 PCB layout 设计
PMP21697.1-适用于汽车级音频放大器的可变电压电源转换器(5-35V,300W 峰值) PCB layout 设计
100-300W功放应用电路-APA320
基于Hi8000恒压升压芯片的100-300W功放应用电路
