0.7~24V连续可调限流电源,0.7 ~ 24V adjustable current-limiting power supply
454398 2018-09-20 20:36 次阅读
关键字:0.7~24V连续可调限流电源
0.7~24V连续可调限流电源
图中的电路可以实现输出电压0.7~24V连续可调,并且可以实现50mA~2A可调的最大输出电流限制。
P1用来设置输出电流最大限值,调整它可以在相应的输出电压时,给出50mA~2A的电流限制。P1设置输出电流最大限值的原理如下:从图中可以看出,输出电流主要来自Q4的发射极,这样,当输出电流增大,电路中a、b点间的电压也跟着增大,这时,a点(即Q3的e极)和Q3的b极间的电压也增大,而Q3的e、b极间电压不可能超过0.7V,当Q3的e、b极间电压增大时,Q3的e极会分流走流往Q4的b极的电流,这样,就限制了a、b点间电压的增大,从而实现最大输出电流限制的目的。
P2用做输出电压调节。当输出电压增大,Q1的e、b极间电压也增大,这导致Q1分流走流往Q2的b极的电流,Q2导通电流下降后,不难看出Q4的导通电流也下降,从而使输出电压下降。当输出电压减小时,原理类似。
P2建议用对数型的电位器,这样输出电压的可调性和线性会更好些。
电源变压器的输出电压和容量应根据你所需要的输出电压和电流来选区。最佳的方案是:变压器次级电压为36、40、48V或带中间抽头的50、75、80V,容量为100VA。
电容C1可以从2200~6800uF/35~50V之间选择。
电路中,BC182为50V/100mA/NPN三极管,BD139为80V/1.5A/NPN三极管,BC212为50v/100mA/PNP三极管,2N3055为60V/15A/NPN三极管。Q4必须使用散热器,另外它可以使用TIP3055代替。
google translate:
0.7 ~ 24V continuously adjustable current limiting power supply
The circuit diagram can be achieved output voltage 0.7 ~ 24V continuously adjustable, and can be adjusted to achieve 50mA ~ 2A maximum output current limit.
P1 is used to set the maximum output current limit, you can adjust the output voltage in the corresponding given 50mA ~ 2A current limit. P1 to set the maximum output current limit of the principle is as follows: As can be seen from the diagram, mainly from the Q4 output current emitter, so that when the output current increases, the circuit in a, b points, also followed the voltage between the increase Then, a point (that is Q3 of e pole) and Q3 of the b pole voltage between the increase and Q3 of the e, b can not exceed the voltage between 0.7V, when the Q3 of e, b the voltage between electrodes increased time, Q3 e-flow to the most would be diverted away most of the current Q4 of b, so that the limits a, b point between voltage increases, the maximum output current limit in order to achieve the purpose.
P2 used as the output voltage regulation. When the output voltage increases, Q1 of the e, b the voltage between electrodes is also increased, leading to the Q2 Q1 flow diversion away the b-polar current, Q2 conduction current decreases, not difficult to see Q4 current will also decrease so that the output voltage drops. When output voltage decreases, the principle of similar.
P2 suggested logarithmic potentiometers, so the output voltage is adjustable and linear will be better.
Power transformer output voltage and capacity you need should be based on the output voltage and current to constituency. The best option is: Transformer secondary voltage 36,40,48 V or with intermediate tap 50,75,80 V, capacity of 100VA.
Capacitor C1 can be 2200 ~ 6800uF/35 ~ 50V to choose between.
Circuit, BC182 transistor for the 50V/100mA/NPN, BD139 to 80V/1.5A/NPN transistor, BC212 to 50v/100mA/PNP transistor, 2N3055 transistor to 60V/15A/NPN. Q4 must use the radiator, while it can use TIP3055 replace.
    12V/24V输入多通道解决方案
    之前我们介绍了MCU/SoC/FPGA等集成电路的3.3V和5V电源配置示例,这期我们将介绍12V/24V输入配置示例。
    的头像 发表于 12-06 10:54 367次阅读
    12<b class='flag-5'>V</b>/<b class='flag-5'>24V</b>输入多通道解决方案
    24v开关电源原理及电路分析
    24V开关电源是一种广泛应用于工业和商业领域的电源转换器,它能够将交流电转换为稳定的直流电,并通过内部开关电路控制输出电压、电流和功率。 一
    的头像 发表于 10-18 17:17 1146次阅读
    24V流电源在工业控制系统中的精密控制
    24V流电源是指输电压24V的直流电源24V流电源因高效率、高可靠性、低噪音等特点,广泛应
    的头像 发表于 10-15 16:51 421次阅读
    如何简化隔离型24V PLC数字输入模块设计
    电子发烧友网站提供《如何简化隔离型24V PLC数字输入模块设计.pdf》资料免费下载
    发表于 09-23 12:23 0次下载
    如何简化隔离型<b class='flag-5'>24V</b> PLC数字输入模块设计
    用SN6507优化PLC I/O模块的24V隔离电源设计应用说明
    电子发烧友网站提供《用SN6507优化PLC I/O模块的24V隔离电源设计应用说明.pdf》资料免费下载
    发表于 09-12 09:52 0次下载
    用SN6507优化PLC I/O模块的<b class='flag-5'>24V</b>隔离<b class='flag-5'>电源</b>设计应用说明
    如何使用24V继电器
    使用24V继电器涉及多个步骤,包括理解其工作原理、选择合适的继电器、正确接线、调试与测试以及日常维护。以下将详细阐述这些步骤,以帮助用户更好地使用24V继电器。
    的头像 发表于 09-10 11:02 1058次阅读
    24V交流接触器A1是正极还是负极
    的工作电压是24V流电。这意味着,无论是A1还是A2(这两个通常是线圈的两个接线端子),它们都不区分正极或负极,因为交流电的特点是电流的方向会周期性改变。因此,在接线时,只需将线圈的两端(即A1和A2)分别接入到
    的头像 发表于 07-24 09:50 2456次阅读
    24V流电源是什么及其工作原理
    24V流电源是稳定输出的直流电源,广泛应用于航空航天、工业控制等领域。其工作原理包括变压器降压、整流、滤波和稳压。具有稳定性高、安全性强、适应性强、节能环保等特点,并在各领域有广泛应用。
    的头像 发表于 06-17 12:05 4046次阅读
    PMP22301.1-4 类 PoE PD (24V/0.9A) 电源 PCB layout 设计
    电子发烧友网站提供《PMP22301.1-4 类 PoE PD (24V/0.9A) 电源 PCB layout 设计.pdf》资料免费下载
    发表于 05-19 10:43 0次下载
    PMP22301.1-4 类 PoE PD (<b class='flag-5'>24V</b>/0.9A) <b class='flag-5'>电源</b> PCB layout 设计
    找一款负-48V输入,24V输出的隔离电源
    电源是通讯上用的电源,设备上提供的电源是负电源,模块板上需要+24V电压,因此需要一款-48V
    发表于 04-19 08:41
    24v开关电源改12v最简单的方法
    开关电源是一种将交流电转换为所需直流电的装置。在实际应用中,可能会遇到将24V开关电源改为12V
    的头像 发表于 01-19 11:19 1.3w次阅读
    怎么实现直流24V两条线,无论正接还是反接都能输出正24V电压?
    怎么实现直流24V两条线,无论正接还是反接都能输出正24V电压? 实现直流24V两条线,无论正接还是反接都能输出正24V电压,需要使用特定的电路设计和元件。这种电路称为"无基准电压电路
    的头像 发表于 01-16 11:06 1738次阅读
    变频器输出的直流24V电源输出了故障,怎么办?
    变频器输出的直流24V电源输出了故障,怎么办? 变频器是工业生产中常用的电器设备,它通过改变电力的频率,控制电机的转速和运行。然而,变频器输出的直流24V电源故障可能会给生产过程带来严
    的头像 发表于 01-15 16:15 3535次阅读
    24v开关电源正极与零线有电压吗?
    24v开关电源正极与零线有电压吗? 24V开关电源是一种常见的电源,用于为电子设备提供稳定的直流电
    的头像 发表于 01-15 11:23 2570次阅读
    电源输出端标的+24v和-24v是什么意思?
    电源输出端标的+24v和-24v是什么意思? 电源输出端标的+24V和-24V是指
    的头像 发表于 01-15 11:19 1.4w次阅读
