ADI公司的AD4111是具有±10V和0 mA至20 mA输入和明线检测功能的低功耗 24 位 Σ-Δ ADC,集成了模拟前端(AFE),还集成主要模拟和数字的信号调理区快,为每个模拟输入通路配置成八种单独建立图,最大通路扫描速率6.2 kSPS(161 μs),嵌入的2.5V低漂移(5 ppm/℃)能隙基准电压降低了外接元件数量,单电源5V或3.3V工作,工作温度−40℃ 到 +105℃,主要用在过程控制PLC和DCS模块。本文介绍了AD4111主要特性,功能框图以及评估板EVAL-AD4111SDZ主要特性,框图,电路图,材料清单和PCB设计图。
The AD4111 is a low power, low noise, 24-bit, sigma-delta (Σ-Δ) analog-to-digital converter (ADC) that integrates an analog front end (AFE) for fully differential or single-ended, high impedance(≥1 MΩ) bipolar,±10 V voltage inputs, and 0 mA to 20 mA current inputs. The AD4111 also integrates key analog and digital signalconditioning blocks to configure eight individual setups for each analog input channel in use. The AD4111 features amaximum channel scan rate of 6.2 kSPS (161 μs) for fullysettled data.
The embedded 2.5 V, low drift (5 ppm/℃), band gap internal reference (with output reference buffer) reduces the external component count. The digital filter allows flexible settings, including simultaneous50 Hz and 60 Hz rejection at a 27.27 SPS output data rate. The user can select between the different filter settings depending on the demands of each channel in the application. The automatic channel sequencer enables the ADC to switch through eachenabled channel.
The precision performance of the AD4111 is achieved by integrating the proprietary iPassives™ technology from Analog Devices, Inc. The AD4111 is factory calibrated to achieve a high degree of specified accuracy.
The AD4111 also has the unique feature of open wire detection on the voltage inputs (patent pending) for system level diagnosticsusing a single 5 V or 3.3 V power supply. The AD4111 operates with a single power supply, making it easy to use in galvanically isolated applications. The specified operating temperature range is −40℃ to +105℃。 The AD4111 is housedin a 40-lead, 6 mm × 6 mm LFCSP package.
AD4111主要特性:
24-bit ADC with integrated analog front end
Up to 6.2 kSPS per channel (161 μs per channel)
16 noise free bits at 1 kSPS per channel
85 dB rejection of 50 Hz and 60 Hz at 20 SPS per channel
±10 V inputs, 4 differential or 8 single-ended Overrange up to ±20 V ≥1 MΩ impedance
±0.06% accuracy at 25℃ Open wire detection 0 mA to 20 mA inputs,4 single-ended Overrange from −0.5 mA to +24 mA
60 Ω impedance
±0.08% accuracy at 25℃ On-chip 2.5 V reference ±0.12% accuracy at 25℃
, ±5 ppm/℃ (typical) drift Internal or external clock
Power supplies
AVDD = 3.0 V to 5.5 V
IOVDD = 2 V to 5.5 V
Total IDD = 3.9 mA
Temperature range: −40℃ to +105℃ 3-wire or 4-wire serial digital interface (Schmitt trigger on SCLK)
SPI, QSPI, MICROWIRE, and DSP compatible
AD4111应用:
Process control PLC and DCS modules
图1.AD4111功能框图
评估板EVAL-AD4111SDZ
Evaluating the AD4111 ±10 V and 0 mA to 20 mA, Analog Front End forIndustrial Automation Systems
The EVAL-AD4111SDZ evaluation kit features the AD4111,a 24-bit, 31.25 kSPS analog-to-digital converter (ADC) with a±10 V input voltage range (4 single-ended or 8 differentialchannels) with open wire detection and 4 current channelsoperating from 0 mA to 20 mA. All channels have on-board overvoltage and overcurrent protection. The EVAL-AD4111SDZ board includes voltage reference, power, and data insulation and can be connected to the Analog Devices, Inc., SDP-B system demonstration platform (EVAL-
SDP-CB1Z)。 The SDP-B board provides connection to a PC viaUSB port and can provide power for the EVAL-AD4111SDZboard from the PC USB port.
The AD411X Eval+ evaluation software configures the AD4111device functionality and provides open wire detection, dc timedomain analysis in the form of waveform graphs, histograms,and associated noise analysis for ADC performance evaluation.
Full specifications for the AD4111 are available in the productdata sheet, which must be consulted in conjunction with thisuser guide when working with this evaluation board.
评估板EVAL-AD4111SDZ主要特性:
Fully featured evaluation board for the AD4111
PC control in conjunction with Analog Devices, Inc., SDP-B
system demonstration platform (EVAL-SDP-CB1Z)
PC software for control and data analysis (time domain)
评估板EVAL-AD4111SDZ包括:
EVAL-AD4111SDZ evaluation board
Required software: AD411X Eval+
图2.评估板EVAL-AD4111SDZ外形图
图3. 评估板EVAL-AD4111SDZ框图
图4. 评估板EVAL-AD4111SDZ硬件配置图
图5.评估板EVAL-AD4111SDZ电路图:AD4111
图6.评估板EVAL-AD4111SDZ电路图:电压输入前端
图7.评估板EVAL-AD4111SDZ电路图:电流输入前端
图8.评估板EVAL-AD4111SDZ电路图:SDP连接器
图9.评估板EVAL-AD4111SDZ电路图:隔离和电源
评估板EVAL-AD4111SDZ材料清单:
图10.评估板EVAL-AD4111SDZ PCB设计图:顶层
图11.评估板EVAL-AD4111SDZ PCB设计图:元件丝印(顶层)
图12.评估板EVAL-AD4111SDZ PCB设计图:元件边(层1)
图13.评估板EVAL-AD4111SDZ PCB设计图:焊接边(层2)
详情请见:
和
AD4111.pdf
EVAL-AD4111SDZ-UG-1124.pdf
电源
185文章
17896浏览量
252401 -
adc
99文章
6548浏览量
546240
【案例分享】去繁从简,教你简化模拟输入模块设计
PLC与DCS模块中如何设计模拟输入模块
低功耗超低噪音放大器MAX2641电子资料
如何设计一款14位,24G, 28nm的ADC产品?
低功耗24位 Δ-ΣADC MAX11410的特性及应用分析
AD4111:单电源,24位,Sigma-Delta ADC,±10 V和0 mA至20 mA输入,开线检测数据表
UG-761:AD7714-3 24位低功耗Sigma-Delta ADC评估板
AD7796/AD7797:低功耗,16/24位Sigma-Delta ADC,用于电桥传感器低功耗,16/24位数据表
