FPGA Verilog实现基本的图像滤波处理仿真
FPGA学习交流 2018-10-19 13:39 次阅读
1、用matlab代码,准备好把图片转化成Vivado Simulator识别的格式,即每行一个数据:
img = imread('E:\matlab\Images\2016-09-05-211710.jpg');
if size(img,3)==3
img = rgb2gray(img);
end
height = size(img, 1);
width = size(img, 2);
s = fopen('image2mem.txt','wb'); %opens the output file
cnt = 0;
for r=1:height
for c=1:width
cnt = cnt + 1;
grey=img(r,c);
greyb = dec2bin(grey,8);
Outbyte =greyb(1:8);
if (Outbyte(1:4) == '0000')fprintf(s,'0%X',bin2dec(Outbyte));
else fprintf(s,'%X',bin2dec(Outbyte)); end
if (mod(cnt,1) == 0)fprintf(s,'\r\n'); end
end
end
figure,imshow(img);
fclose(s);
2、EdgeSobel的Verilog源代码:
`timescale 1ns / 1ps
module EdgeSobel
input clk,
input [7:0] inData,
input [11:0]x,
input [11:0]y,
output [7:0] outData
parameter pixel_depth=8;
parameter frame_width=640;
parameter block_width=3;
parameter block_height=3;
parameter shiftRegSize=pixel_depth*((block_height-1)*frame_width+block_width);
reg[shiftRegSize-1:0] shiftReg;
wire [block_width*block_height*pixel_depth-1:0] Window;
initial begin shiftReg=10264'b0;end
always@(posedge clk)if((x<640)&&(y<480))shiftReg<={shiftReg,inData};
genvar i,j;
generate
for(i = 0; i < block_height; i = i + 1) begin : array
for(j = 0; j < block_width; j = j + 1) begin : vector
assign Window[pixel_depth*(i * block_width + j)+:pixel_depth] =shiftReg[pixel_depth*(i*frame_width+j)+:pixel_depth];
end
end
endgenerate
wire [7:0] average;
assign average =
(Window[7:0]+Window[15:8]+Window[23:16]+
//Window[31:24]+Window[39:32]+Window[47:40]+
Window[55:48]+Window[63:56]+Window[71:64])/9 ;
wire signed [pixel_depth+1:0] Gx;
wire signed [pixel_depth+1:0] Gy;
wire [pixel_depth+1:0] Gxabs;
wire [pixel_depth+1:0] Gyabs;
wire [pixel_depth+1:0] G;
assign Gx = shiftReg[pixel_depth*(0*frame_width+2)+:pixel_depth]
+2*shiftReg[pixel_depth*(1*frame_width+2)+:pixel_depth]
+ shiftReg[pixel_depth*(2*frame_width+2)+:pixel_depth]
- shiftReg[pixel_depth*(0*frame_width+0)+:pixel_depth]
-2*shiftReg[pixel_depth*(1*frame_width+0)+:pixel_depth]
- shiftReg[pixel_depth*(2*frame_width+0)+:pixel_depth];
assign Gy = shiftReg[pixel_depth*(2*frame_width+0)+:pixel_depth]
+2*shiftReg[pixel_depth*(2*frame_width+1)+:pixel_depth]
-2*shiftReg[pixel_depth*(0*frame_width+1)+:pixel_depth]
- shiftReg[pixel_depth*(0*frame_width+2)+:pixel_depth];
assign Gxabs = (Gx>0)?Gx-Gx);
assign Gyabs = (Gy>0)?Gy-Gy);
assign G = Gxabs+Gyabs;
//assign outData = average; //平滑
assign outData = G[9:2]; //边缘检测
endmodule
3、仿真文件:tb_EdgeSobel.v
module tb_edgesobel;
reg clk;
reg [7:0] inData;
reg [19:0] cnt;
reg [9:0] row;
wire [7:0] outData;
reg [7:0] image [307199:0];
integer file_id;
reg [4:0] frame_cnt;
initial
begin
$readmemh("E:/matlab/Vivado/image2mem.txt", image);
file_id = $fopen("E:/matlab/Vivado/mem2image.txt","w");
clk = 0;
cnt = 0;
row = 0;
frame_cnt = 0;
end
EdgeSobel u_2
.clk(clk),
.x(1),
.y(1),
.inData(inData),
.outData(outData)
always #1 clk = ~clk;
begin
if(cnt == 307200)
begin
cnt = 0;
row = 0;
frame_cnt = frame_cnt + 1;
end
else
inData = image[cnt];
cnt = cnt+1;
if(frame_cnt==1)
begin
$fwrite(file_id, "%d ", outData);
if(((cnt % 640)==0) &&(cnt>0))
begin
$fwrite(file_id,"\r\n");
row = row + 1;
end;
end
end
endmodule
4、把输出的txt文件转化成图片Matlab程序:
A=importdata('E:\matlab\Vivado\mem2image.txt');
A=A./255;
imshow(A);
注意这里的A是double类型的,直接进行imshow会全白,要转化到0-1:A=A./255,或者把double类型转化为整形。
  • FPGA
    FPGA上的图像处理算法集成与优化
    、Tophat形态学滤波、RAW8转RGB888、彩色图像均值滤波、Alpha背景叠加、直方图灰度拉伸算法以及自动白平衡算法。每种算法都提供了实现方法和相关公式,涵盖了
    的头像 发表于 02-14 13:46 162次阅读
    <b class='flag-5'>FPGA</b>上的<b class='flag-5'>图像</b><b class='flag-5'>处理</b>算法集成与优化
    FPGA图像处理基础----实现缓存卷积窗口
    像素行与像素窗口 一幅图像是由一个个像素点构成的,对于一幅480*272大小的图片来说,其宽度是480,高度是272。在使用FPGA进行图像处理时,最关键的就是使用
    的头像 发表于 02-07 10:43 266次阅读
    <b class='flag-5'>FPGA</b><b class='flag-5'>图像</b><b class='flag-5'>处理</b>基础----<b class='flag-5'>实现</b>缓存卷积窗口
    基于FPGA实现图像直方图设计
    简单,单采用FPGA实现直方图的统计就稍显麻烦。若使用Xilinx和Altera的FPGA芯片,可以使用HLS来进行图像的加速处理。但这暂
    的头像 发表于 12-24 10:24 347次阅读
    基于<b class='flag-5'>FPGA</b><b class='flag-5'>实现</b><b class='flag-5'>图像</b>直方图设计
    Verilog 测试平台设计方法 Verilog FPGA开发指南
    Verilog测试平台设计方法是Verilog FPGA开发中的重要环节,它用于验证Verilog设计的正确性和性能。以下是一个详细的Verilog
    的头像 发表于 12-17 09:50 571次阅读
    图像高斯滤波的原理及FPGA实现思路
    1.概念 高斯分布 图像滤波之高斯滤波介绍 图像处理算法|高斯滤波 高斯
    的头像 发表于 12-07 09:12 884次阅读
    <b class='flag-5'>图像</b>高斯<b class='flag-5'>滤波</b>的原理及<b class='flag-5'>FPGA</b><b class='flag-5'>实现</b>思路
    FPGA 实时信号处理应用 FPGA图像处理中的优势
    优势之一是其并行处理能力。与传统的CPU或GPU相比,FPGA可以同时执行多个操作,这在图像处理中尤为重要,因为图像
    的头像 发表于 12-02 10:01 1118次阅读
    Verilog vhdl fpga
    编程语言,熟悉时序约束、时序分析方法; 4.熟悉FPGA开发环境及仿真调试工具。 5.熟悉FPGA外部存储控制器及数据传输接口,如E2PROM、FLASH、DDR等。有FPGA高速数据
    发表于 11-12 16:40
    FPGA图像处理领域的优势有哪些?
    单元和可编程互联线,可以实现高度并行的数据处理。在图像处理任务中,如图像处理、特征提取和
    发表于 10-09 14:36
    【招聘】verilog vhdl FPGA
    1.熟悉FPGA架构及应用,熟悉图像算法的FPGA实现。 2.熟悉verilog vhdl,熟悉Xilinx或Intel等开发工具。 3.有
    发表于 09-02 15:50
    FPGA verilog HDL实现中值滤波
    今天给大侠简单带来FPGA verilog HDL实现中值滤波,话不多说,上货。一、实现步骤: 1、查看了中值
    发表于 06-18 18:50
    FPGA设计经验之图像处理
    系列:基于 FPGA图像边缘检测系统设计(sobel算法) FPGA设计中 Verilog HDL实现基本的
    发表于 06-12 16:26
    matlab与FPGA数字信号处理系列 Verilog 实现并行 FIR 滤波
    FPGA 实现 FIR 滤波器时,最常用的是直接型结构,简单方便,在实现直接型结构时,可以选择串行结构/并行结构/分布式结构。 并行结构即并行
    发表于 05-24 07:48
    基于FPGA的实时边缘检测系统设计,Sobel图像边缘检测,FPGA图像处理
    计算机软件实现方式有更快的处理速度。 经验证,系统工作稳定,满足实时性要求 。 MATLAB 与 FPGA无线通信、图像处理、数字信号
    发表于 05-24 07:45
    FPGA设计中 Verilog HDL实现基本的图像滤波处理仿真
    今天给大侠带来FPGA设计中用Verilog HDL实现基本的图像滤波处理
    发表于 05-20 16:44
    基于Verilog HDL的FPGA图像滤波处理仿真实现
    发表于 04-26 11:37 665次阅读
    基于<b class='flag-5'>Verilog</b> HDL的<b class='flag-5'>FPGA</b><b class='flag-5'>图像</b><b class='flag-5'>滤波</b><b class='flag-5'>处理</b><b class='flag-5'>仿真实现</b>
