如何在Oracle数据库中找出损坏索引?
电子工程师 来源:未知 作者:胡薇 2018-10-18 14:24 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
在Oracle数据库中如何找出损坏索引呢? 下面我们人为构造一个案例,将索引块损坏。如下案例所示:
SQL> create tablespace test_data
2 datafile '/u01/app/oracle/oradata/gsp/test_data_01.dbf'
3 size 200M autoextend off
4 logging
5 segment space management auto
6 extent management local;
Tablespace created.
SQL> create tablespace test_index
2 datafile '/u01/app/oracle/oradata/gsp/test_idx_01.dbf'
4 logging
Tablespace created.
SQL> create user kerry
2 identified by 123456
3 default tablespace test_data;
User created.
SQL> grant connect to kerry;
SQL> grant resource to kerry;
上述脚本是创建表空间,创建用户kerry并授权,然后使用kerry账号登录数据库,构造测试数据,在TEST表上创建索引IX_TEST
SQL> show user;
USER is "KERRY"
SQL>
SQL> CREATE TABLE TEST(ID NUMBER(10), NAME VARCHAR2(64));
Table created.
SQL> DECLARE I NUMBER;
2 BEGIN
3 FOR I IN 1..1000 LOOP
4 INSERT INTO TEST VALUES(I, LPAD('T', 60));
5 END LOOP;
6 COMMIT;
7 END;
8 /
PL/SQL procedure successfully completed.
SQL> CREATE INDEX IX_TEST ON KERRY.TEST(NAME) TABLESPACE TEST_INDEX;
Index created.
然后使用下面脚本找到索引段数据库文件ID,以及索引段的第一个块的块号。
SQL> show user;
USER is "SYS"
SQL> col segment_name for a32;
SQL> col header_file for 9999;
SQL> col header_block for 9999;
SQL> select segment_name
2 ,header_file
3 ,header_block
4 ,blocks
5 from dba_segments ds
6 where ds.owner='KERRY' and ds.segment_name='IX_TEST';
SEGMENT_NAME HEADER_FILE HEADER_BLOCK BLOCKS
IX_TEST 8 130 16
SQL>
构造坏块的方法有不少(例如BBED等),这里我们使用RMAN下面的命令clear,可以标记数据块为corrupt,标记数据文件8中130号数据块为坏块。
[oracle@DB-Server ~]$ rman target /
Recovery Manager: Release 11.2.0.1.0 - Production on Thu Sep 13 17:41:05 2018
Copyright (c) 1982, 2009, Oracle and/or its affiliates. All rights reserved.
connected to target database: GSP (DBID=644393201)
RMAN> recover datafile 8 block 130 clear;
Starting recover at 13-SEP-18
using target database control file instead of recovery catalog
allocated channel: ORA_DISK_1
channel ORA_DISK_1: SID=12 device type=DISK
Finished recover at 13-SEP-18
RMAN>
那么我们先来看看使用那些方法验证索引损坏了,测试验证一下看看是否可行。
1:使用ANALYZE分析验证索引结构
[oracle@DB-Server ~]$ sqlplus / as sysdba
SQL*Plus: Release 11.2.0.1.0 Production on Thu Sep 13 17:42:03 2018
Copyright (c) 1982, 2009, Oracle. All rights reserved.
Connected to:
Oracle Database 11g Enterprise Edition Release 11.2.0.1.0 - 64bit Production
With the Partitioning, OLAP, Data Mining and Real Application Testing options
SQL> analyze index kerry.ix_test validate structure;
ERROR at line 1:
ORA-01578: ORACLE data block corrupted (file # 8, block # 130)
ORA-01110: data file 8: '/u01/app/oracle/oradata/gsp/test_idx_01.dbf'
如上截图所示,如果索引损坏(Corrupt Index),那么使用analyze index validate structure就会报错。要检查整个数据库所有的损坏索引(Corrupt Indexes)的话,就可以借助下面脚本:
spool analy_index.sql
SET PAGESIZE 50000;
SELECT
'ANALYZE INDEX ' || OWNER || '.' || INDEX_NAME|| ' VALIDATE STRUCTURE;' FROM DBA_INDEXES;
spool off;
@analy_index.sql
2:使用系统视图v$database_block_corruption查看损坏索引
如下所示,我们使用这个脚本来查看出现坏块的索引,发现这个脚本无法找出坏块索引。
set pagesize 50 linesize 170
col segment_name format a30
col partition_name format a30
SELECT DISTINCT file#,
segment_name,
segment_type,
tablespace_name,
partition_name
FROM dba_extents a,
v$database_block_corruption b
WHERE a.file_id = b.file#
AND a.block_id <= b.block#
AND a.block_id + a.blocks >= b.block#;
原因分析如下,视图v$database_block_corruption中有坏块记录,但是我们将索引段的第一个块标记为坏块后,在dba_extents中没有该索引段的记录了。所以这种情况下的索引损坏,这个SQL语句根本无法找出坏块索引。
SQL> SELECT file_id,
2 segment_name,
3 segment_type
4 FROM dba_extents
5 WHERE file_id = 8 ;
no rows selected
2 segment_name,
3 segment_type
4 FROM dba_extents
5 WHERE owner = 'KERRY';
FILE_ID SEGMENT_NAME SEGMENT_TYPE
7 TEST TABLE
7 TEST TABLE
SQL>
因为一个段的第一个区的第一个块是FIRST LEVEL BITMAP BLOCK,第二个块是SECOND LEVEL BITMAP BLOCK,这两个块是用来管理free block的,第三个块是PAGETABLE SEGMENT HEADER,这个块才是segment里的HEADER_BLOCK,再后面的块就是用来记录数据的。关于这些知识,可以参考我博客ORACLE关于段的HEADER_BLOCK的一点浅析。而我们最上面的例子,是将第一个块构造为坏块,所以导致上面SQL无法查出。 我们重新构造案例,如我们将索引段的数据块构造为坏块,例如下面,将块号148人为构造坏块。那么此时这个脚本就能找出坏块索引了。所以综上述实验可以看出,这个脚本查找坏块索引是有条件的,要看索引段损坏的块是什么类型
SQL> SELECT FILE_ID,
2 BLOCK_ID,
3 BLOCKS
FROM DBA_EXTENTS
4 5 WHERE OWNER ='&OWNER'
6 AND SEGMENT_NAME = '&TABLE_NAME';
Enter value for owner: KERRY
old 5: WHERE OWNER ='&OWNER'
new 5: WHERE OWNER ='KERRY'
Enter value for table_name: IX_TEST
old 6: AND SEGMENT_NAME = '&TABLE_NAME'
new 6: AND SEGMENT_NAME = 'IX_TEST'
FILE_ID BLOCK_ID BLOCKS
8 144 8
8 152 8
SQL> SELECT HEADER_FILE
2 , HEADER_BLOCK
3 , BYTES
4 , BLOCKS
5 , EXTENTS
FROM DBA_SEGMENTS
6 7 WHERE OWNER='&OWNER' AND SEGMENT_NAME='&SEGMENT_NAME';
Enter value for segment_name: IX_TEST
old 7: WHERE OWNER='&OWNER' AND SEGMENT_NAME='&SEGMENT_NAME'
new 7: WHERE OWNER='KERRY' AND SEGMENT_NAME='IX_TEST'
HEADER_FILE HEADER_BLOCK BYTES BLOCKS EXTENTS
8 146 131072 16 2
SQL>
RMAN> recover datafile 8 block 148 clear;
  • Oracle
  • 索引
原文标题:ORACLE 如何检查找出损坏索引
文章出处:【微信号:DBDevs,微信公众号:数据分析与开发】欢迎添加关注!文章转载请注明出处。
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    数据库索引技术应用
    在对数据库索引技术进行讨论和研究,论述如何准确有效的设置数据库索引,并结合具体的实例对数据库索引
    发表于 11-04 11:28 26次下载
    提高Oracle数据库性能
    Oracle数据库设计中长期受到设计人员重视的是如何更好更快地提高Oracle数据库性能的问题。其中对数据库表现有较大关联的是两个因素,一
    发表于 11-11 18:16 4次下载
    oracle数据库应用领域
    Oracle Database,又名Oracle RDBMS,或简称Oracle。是甲骨文公司的一款关系数据库管理系统。它是在数据库领域一直
    的头像 发表于 02-23 10:08 2.7w次阅读
    <b class='flag-5'>oracle</b><b class='flag-5'>数据库</b>应用领域
    Oracle数据库开发和管理的工具
    的路径。   数据库设计   可视化编辑器的设计表 精心设计的表设计器,可以直观地创建和编辑表、列、键、索引、关系和约束,而无需键入任何代码。 在数据库图中绘制对象 将
    的头像 发表于 06-19 09:54 1511次阅读
    数据库数据恢复-Oracle数据库文件出现坏块的数据恢复案例
    ,sysaux01.dbf文件损坏数据库无备份,不能通过备份去恢复数据库。用户提供了该Oracle数据库
    的头像 发表于 07-18 15:10 2187次阅读
    <b class='flag-5'>数据库</b><b class='flag-5'>数据</b>恢复-<b class='flag-5'>Oracle</b><b class='flag-5'>数据库</b>文件出现坏块的<b class='flag-5'>数据</b>恢复案例
    数据库数据恢复-oracle数据库常见故障及数据恢复分析
    作为存储和处理数据的系统,oracle数据库在使用过程不可避免会出现各种导致数据丢失和数据
    的头像 发表于 07-27 15:01 1389次阅读
    数据库数据恢复-Oracle数据库文件块损坏数据恢复案例
    打开Oracle数据库时报错,报错信息:“system01.dbf需要更多的恢复来保持一致性,数据库无法打开”。用户急需恢复zxfg用户下的数据
    的头像 发表于 08-03 15:10 1419次阅读
    <b class='flag-5'>数据库</b><b class='flag-5'>数据</b>恢复-<b class='flag-5'>Oracle</b><b class='flag-5'>数据库</b>文件块<b class='flag-5'>损坏</b>的<b class='flag-5'>数据</b>恢复案例
    数据库数据恢复-Oracle ASM故障数据恢复案例
    数据库数据恢复环境: Oracle数据库ASM磁盘组有4块成员盘。 数据库故障&分析: Ora
    的头像 发表于 08-11 15:27 2324次阅读
    <b class='flag-5'>数据库</b><b class='flag-5'>数据</b>恢复-<b class='flag-5'>Oracle</b> ASM故障<b class='flag-5'>数据</b>恢复案例
    oracle数据库如何连接
    oracle数据库如何连接  Oracle数据库是目前非常流行的关系型数据库管理系统,它可以在各种平台上运行,因此它是企业级应用程序的首选
    的头像 发表于 08-28 17:09 1.2w次阅读
    数据库数据恢复-oracle数据库报错无法打开的数据恢复案例
    oracle数据库数据恢复环境: 一台服务器,底层由12块硬盘组成一组磁盘阵列,上层操作系统上运行oracle数据库
    的头像 发表于 10-12 14:00 1714次阅读
    oracle数据库的使用方法
    Oracle数据库是一种关系型数据库管理系统,它由Oracle公司开发和维护。它提供了安全、可靠和高性能的数据库管理解决方案,被广泛应用于企
    的头像 发表于 12-06 10:10 2393次阅读
    oracle数据库的基本操作
    Oracle数据库是一种关系数据库管理系统(RDBMS),广泛应用于企业级应用。它具有强大的功能和灵活的配置选项,可以满足复杂的数据处理需
    的头像 发表于 12-06 10:14 1617次阅读
    数据库数据恢复—Oracle数据库文件system01.dbf损坏数据恢复案例
    打开oracle数据库报错“system01.dbf需要更多的恢复来保持一致性,数据库无法打开”。
    的头像 发表于 09-21 14:25 1589次阅读
    <b class='flag-5'>数据库</b><b class='flag-5'>数据</b>恢复—<b class='flag-5'>Oracle</b><b class='flag-5'>数据库</b>文件system01.dbf<b class='flag-5'>损坏</b>的<b class='flag-5'>数据</b>恢复案例
    Oracle数据恢复—异常断电后Oracle数据库报错的数据恢复案例
    Oracle数据库故障: 机房异常断电后,Oracle数据库报错:“system01.dbf需要更多的恢复来保持一致性,
    的头像 发表于 09-30 13:31 1444次阅读
    <b class='flag-5'>Oracle</b><b class='flag-5'>数据</b>恢复—异常断电后<b class='flag-5'>Oracle</b><b class='flag-5'>数据库</b>启<b class='flag-5'>库</b>报错的<b class='flag-5'>数据</b>恢复案例
    数据库数据恢复—ORACLE常见故障的数据恢复可行性分析
    Oracle数据库常见故障表现: 1、ORACLE数据库无法启动或无法正常工作。 2、ORACLE ASM存储破坏。 3、
    的头像 发表于 12-10 11:35 889次阅读
