MAX22191寄生电源数字输入解决方案
电子工程师 来源:xx 2019-05-01 16:31 次阅读
Maxim公司的MAX22191是IEC 61131-2兼容的工业数字输入(DI),能把24V数字工业输入转换成2.4mA电流,用来驱动光隔离器。电压阈值和电流值和Type 1和Type 3输入,采用额外外接电阻还和48V输入兼容,工作温度-40℃ - +125℃,主要用在过程自动化,工业自动化,马达控制,单个隔离输入以及电流源输入。本文介绍了MAX22191主要优势和特性,框图和应用框图,以及评估板MAX22191PMB# EVK主要特性,电路图,材料清单和PCB设计图。
The MAX22191 is an IEC 61131-2 compliant, industrial digital input (DI) device that translates a 24V digital industrial input to a 2.4mA (typ) current for driving optical isolators. Voltage thresholds and current levels in the MAX22191 are compliant with Type 1 and Type 3 inputs, while minimizing power dissipation. The MAX22191 is also compliant with 48V inputs, with the addition of external resistors.
Operating power is derived from the input signal, eliminating the need for an external field-side power supply. A 250ns (max) fast response time is ideal for high-speed inputs. Additionally, a CMOS-compatible test input is available for safety diagnostics.
The MAX22191 features robust functionality for harsh industrial systems and is capable of normal operation with input signals ranging from -60V to +60V. Integrated thermal shutdown further protects the device when VCC is present.
The MAX22191 is available in a small, 6-lead SOT23 package and operates over the -40℃ to +125℃ ambient temperature range.
MAX22191主要优势和特性:
High Integration for Flexible Circuit Designs 250ns (max) Response Time
Parasitically Powered from the Field Input
Current Sourcing Input with Optical Isolators
Current Sinking Input with Optical Isolators
Current Sinking Input with Logic Devices
Test Pulse Input
Reduced Power and Heat Dissipation Current Limited Input
Robust Design Operates from -60V to +60V Input Voltage
-40℃ to +125℃ Ambient Operating Temperature
MAX22191应用:
Process Automation
Industrial Automation
Motor Controls
Individually Isolated Inputs
Current Sourcing Inputs
[原创] Maxim MAX22191寄生电源数字输入解决方案
图1.MAX22191简化框图
图2.MAX22191典型工作电路图
图3.MAX22191工作电路图(1)
图4.MAX22191工作电路图(2)
图5.MAX22191工作电路图(3)
评估板MAX22191PMB#
The MAX22191PMB# peripheral module provides the hardware to evaluate the MAX22191 parasitically powered digital input. Refer to the MAX22191 IC data sheet for detailed information regarding operation of the IC. The PMB features two circuits: one for isolated parasitically powered circuit (using an optoisolator) and one for a 24V input signal with the circuit powered from a low-voltage logic supply.
The module can be used in various ways. Maxim sells low-cost USB2PMB1#, USB2PMB2#, and USB2GPIO# adapter boards that use the Munich GUI software for communication through a USB cable. This is not included with this board. Alternatively, any microcontroller or FPGA with a 12-pin Pmod™-compatible connector can be used. Another option for the user is to wire-wrap a temporary connection from their system to the pins on connector X1. For these later two options the user needs to write their own control software.
The Pmod PCB dimension is just 42mm long x 20mm wide, with the width determined by the size of the X1 connector.
评估板MAX22191PMB#主要特性:
Easy Evaluation of the MAX22191
Isolated, Paristically Powered and Logic-Powered Circuits for Easy Evaluation
Proven PCB Layout
Works with USB2PMB2# or USB2GPIO# Adapter and Munich GUI Software
图6.评估板MAX22191PM#外形图
图7.评估板MAX22191PM#和USB2PMB2#适配器连接图
图8.评估板MAX22191PM# EVK电路图
评估板MAX22191PM# EVK材料清单:
图9.评估板MAX22191PM# EVK PCB设计图:左:顶层丝印;右:顶层布局
图10.评估板MAX22191PM# EVK PCB设计图:底层布局
详情请见:
https://datasheets.maximintegrated.com/en/ds/MAX22191.pdf
和https://datasheets.maximintegrated.com/en/ds/MAX22191EVKIT.pdf
MAX22191.pdf
  • 电源
  • 隔离器
    支持多种输入电压的电源解决方案
    基于LTC3115-1 降压-升压型 DC/DC 转换器,能支持多种输入电压的电源解决方案,这些输入电压是由汽车输入电压瞬态、阻性电路压降和
    发表于 06-04 11:10 4646次阅读
    如何选择合适的FPGA电源解决方案
    `作者:Frederik Dostal为FPGA应用设计优秀电源管理解决方案不是一项简单的任务,相关技术讨论有很多。本文一方面旨在找到正确解决方案并选择最合适的电源管理产品,另一方面则
    发表于 08-13 09:29
    用于拆分数字电源的高效线性和开关解决方案
    DN172- 用于拆分数字电源的高效线性和开关解决方案
    发表于 09-30 10:47
    基于MAX17014的低成本LCD TV电源解决方案
    基于MAX17014的低成本LCD TV电源解决方案 Maxim 公司的MAX17014是低成本多输出的LCD TV电源控制器,能
    发表于 03-24 17:53 994次阅读
    基于<b class='flag-5'>MAX</b>17014的低成本LCD TV<b class='flag-5'>电源</b><b class='flag-5'>解决方案</b>
    典型隔离式数字电源解决方案
    典型隔离式数字电源解决方案如图所示:
    发表于 07-18 16:29 1291次阅读
    典型隔离式<b class='flag-5'>数字</b><b class='flag-5'>电源</b><b class='flag-5'>解决方案</b>
    数字电源解决方案,基站电源设计
    基站电源的设计必须使规模,效率和性能之间权衡。新的电源解决方案,基于数字遥测是简单,灵活和可扩展性。周围的MAX15301的负载点(POL)
    发表于 08-07 15:05 1057次阅读
    <b class='flag-5'>数字</b><b class='flag-5'>电源</b><b class='flag-5'>解决方案</b>,基站<b class='flag-5'>电源</b>设计
    MAX5986A,MAX5986B,MAX5987A完整的电源解决方案
    MAX5986A/MAX5986B/MAX5987A提供一个完整的电源解决方案,因为IEEE 802.3af标准的,兼容的类1/Class的
    发表于 01-11 11:35 1762次阅读
    <b class='flag-5'>MAX</b>5986A,<b class='flag-5'>MAX</b>5986B,<b class='flag-5'>MAX</b>5987A完整的<b class='flag-5'>电源</b><b class='flag-5'>解决方案</b>
    c2000数字电源解决方案数字控制led照明系统(英文版)
    发表于 04-09 11:07 0次下载
    c2000<b class='flag-5'>数字</b><b class='flag-5'>电源</b><b class='flag-5'>解决方案</b>和<b class='flag-5'>数字</b>控制led照明系统(英文版)
    MAX22191 的工业数字输入
    发表于 11-16 19:47 0次下载
    <b class='flag-5'>MAX22191</b> 的工业<b class='flag-5'>数字</b><b class='flag-5'>输入</b>
    MAX22191AUT+T MAX22191AUT+T - (Maxim Integrated) - 专用 IC
    电子发烧友网为你提供()MAX22191AUT+T相关产品参数、数据手册,更有MAX22191AUT+T的引脚图、接线图、封装手册、中文资料、英文资料,MAX22191AUT+T真值表,MAX
    发表于 11-16 20:18
    <b class='flag-5'>MAX22191</b>AUT+T <b class='flag-5'>MAX22191</b>AUT+T - (Maxim Integrated) - 专用 IC
    关于 MAX22191 寄生供电、工业数字输入的常见问题 (FAQ)
    发表于 11-16 23:25 0次下载
    关于 <b class='flag-5'>MAX22191</b> <b class='flag-5'>寄生</b>供电、工业<b class='flag-5'>数字</b><b class='flag-5'>输入</b>的常见问题 (FAQ)
    MAX22191AUT+ 专用 IC
    电子发烧友网为你提供Maxim(Maxim)MAX22191AUT+相关产品参数、数据手册,更有MAX22191AUT+的引脚图、接线图、封装手册、中文资料、英文资料,MAX22191AUT+真值表,
    发表于 11-18 19:18
    <b class='flag-5'>MAX22191</b>AUT+ 专用 IC
    双向数字电源解决方案
    以 Renesas 高性能 RA6T2 Arm® 内核MCU 为基础,该解决方案可实现双向电源转换。 它可为用户提供双向数字电源转换系统,打破 DSP 应用在
    发表于 12-05 16:48 16次下载
    采用MAX22191的工业数字输入
    MAX22191寄生供电DI电路可以监测1型和3型灌电流,并为PLC和工业电路提供二进制输入信号源。本应用笔记给出了使用MAX22191的吸电流、电流源、高压和交流检测
    的头像 发表于 01-12 10:05 1558次阅读
    采用<b class='flag-5'>MAX22191</b>的工业<b class='flag-5'>数字</b><b class='flag-5'>输入</b>
    MAX22191PMB# 评估板 - 扩展板,子卡
    电子发烧友网为你提供Maxim(Maxim)MAX22191PMB#相关产品参数、数据手册,更有MAX22191PMB#的引脚图、接线图、封装手册、中文资料、英文资料,MAX22191PMB#真值表,
    发表于 02-06 19:32
    <b class='flag-5'>MAX22191</b>PMB# 评估板 - 扩展板,子卡
