TI AM6548 Sitara MCU多协议吉比特工业4.0解决方案
电子工程师 来源:陈翠 2019-04-05 00:11 次阅读
TI公司的AM6548是具有TSN使能的用于工业4.0 工业级Sitara处理器,提供先进工业通信,增强安全性,高度可靠性和安全特性。处理器组合两个四个或两个ARM Cortex-A53和和两个Cortex-R5F MCU子系统, 四核Arm® Cortex®-A53 MCU工作频率高达1.1GHz,双核Arm Cortex-R5F MCU工作频率高达400MHz,具有三个吉比特工业通信子系统(PRU_ICSSG),两个10/100/1000以太网端口per PRU_ICSSG,支持两个SGMII端口,和10/100Mb PRU-ICSS兼容,有24x PWM per PRU_ICSSG,可以逐个周期控制,主要用在工业可编控制器PLC),带安全功能的工厂自动化,多协议现场总线通信,工业PC,工业机器人,人机接口,电网基础设备保护继电器和机器人马达驱动器。本文介绍了AM654x和AM652x主要特性,功能框图,以及TMDX654GPEVM AM65x 评估模块(EVM)系统外形图和处理器板电路图,材料清单和PCB设计图。
AM654x and AM652x Sitara Arm applications processors are built to meet the complex processing needs of modern industrial embedded products.
The AM654x and AM652x devices combine four or two Arm Cortex-A53 cores with a dual Cortex-R5F MCU subsystem which includes features intended to help customers achieve their functional safety goals for their end products and three Gigabit industrial communications subsystems (PRU_ICSSG) to create a SoC capable of high-performance industrial controls with industrial connectivity and processing for functional safety applications. AM65xx is currently undergoing assessment to be certified by TÜV SÜD
according to IEC 61508.
The four A53 cores are arranged in two dual-core clusters with shared L2 memory to create two processing channels. Extensive ECC is included on on-chip memory, peripherals, and interconnect for reliability. The SoC as a whole includes features intended to help customers design systems that can achieve their functional safety goals (assessment pending with TÜV SÜD)。 Cryptographic acceleration and secure boot are available on AM654x and AM652x devices in addition to granular firewalls managed by the DMSC.
Programmability is provided by the quad-core Arm Cortex-A53 RISC CPUs with Neon extension, and the dual Cortex-R5F MCU subsystem is available for general purpose use as two cores or it can be used in lockstep to help meet the needs of functional safety applications. The PRU_ICSSG subsystems can be used to provide up to six ports of industrial Ethernet such as Profinet IRT, TSN, or EtherCAT™ (among many others), or they can be used for standard Gigabit Ethernet connectivity.
TI provides a complete set of software and development tools for the Arm cores including Processor SDK Linux-RT, RTOS, and Android as well as C compilers and a debugging interface for visibility into source code execution. Applicable safety documentation will be made available to assist customers in developing their functional safety related systems.
AM654x和AM652x主要特性:
1Processor Cores:
• Quad-Core Arm® Cortex®-A53 Microprocessor Subsystem at up to 1.1 GHz
– Two Dual-Core Cortex-A53 Clusters with 512KB L2 Cache Including SECDED
– Each A53 Core has 32KB L1 ICache and 32K L1 DCache
• Dual-Core Arm Cortex-R5F at up to 400 MHz
– Supports Lockstep Mode
– 16KB ICache, 16KB DCache, and 64KB RAM per R5F Core
Industrial Subsystem:
• Three Gigabit Industrial Communication Subsystems (PRU_ICSSG)
– Two 10/100/1000 Ethernet Ports per PRU_ICSSG
– Supports Two SGMII Ports (2)
– Compatibility with 10/100Mb PRU-ICSS
– 24× PWMs per PRU_ICSSG
– Cycle-by-Cycle Control
– Enhanced Trip Control
– 18× Sigma-Delta Filters per PRU_ICSSG
– Short Circuit Logic
– Over-Current Logic
– 6× Multi-protocol Position Encoder Interfaces per PRU_ICSSG
Memory Subsystem:
• Up to 2MB of On-Chip L3 RAM with SECDED
• Multi-Core Shared Memory Controller (MSMC)
– Up to 2MB (2 banks × 1MB) SRAM with SECDED
– Shared Coherent Level 2 or Level 3 Memory-Mapped SRAM
– Shared Coherent Level 3 Cache
– 256-Bit Processor Port Bus and 40-Bit Physical Address Bus
– Coherent Unified Bi-Directional Interfaces to Connect to Processors or Device Masters
– L2, L3 Cache Pre-Warming and Post Flushing
– Bandwidth Management with Starvation Bound
– One Infrastructure Master Interface
– Single External Memory Master Interface
– Supports Distributed Virtual System
– Supports Internal DMA Engine – DRU (Data Routing Unit)
– ECC Error Protection
DDR Subsystem (DDRSS)
– Supports DDR3L/DDR4 Memory Types up to DDR-1600
– Supports LPDDR4 Memory Type up to DDR-1333
– 32-Bit Data Bus and 7-Bit SECDED Bus
– 32GB of Total Addressable Space
• General-Purpose Memory Controller (GPMC)
Safety:
• AM65xx Helps System Designers Address Safety Requirements
– The Dual Cortex-R5F System is Undergoing Assessment to be Certified at TÜV SÜD
According to IEC 61508, Targeting SIL-3
– The A53 Cores and Entire System on Chip (SoC) is Undergoing Assessment to be Certified at TÜV SÜD According to IEC 61508, Targeting SIL-2
– ECC or Parity on Calculation-Critical Memories
– ECC and Parity on Internal Bus Interconnect
– Firewalls to Help Provide Freedom From Interference (FFI)
– Built-In Self-Test (BIST) for CPU, High-End Timers, and On-Chip RAM
– Hardware Error Injection Support for Test-for- Diagnostics
– Error Signaling Modules (ESM) for Capture of Safety Related Errors
– Voltage, Temperature, and Clock Monitoring
– Windowed and Non-Windowed Watchdog Timers in Multiple Clock Domains
• MCU Island
– Isolation of the Dual-Core Arm Cortex-R5F Microprocessor Subsystem to Help Provide
– Separate Voltage, Clocks, Resets, and Dedicated Peripherals
– Internal MCSPI Connection to the Rest of SoC
Security:
• Secure Boot Supported
– Hardware-Enforced Root-of-Trust
– Support to Switch Root-of-Trust via Backup Key
– Support for Takeover Protection, IP Protection, and Anti-Roll Back Protection
• Cryptographic Acceleration Supported
– Session-Aware Cryptographic Engine with Ability to Auto-Switch Key-Material Based on
Incoming Data Stream
– Supports Cryptographic Cores
– AES – 128/192/256 Bits Key Sizes
– 3DES – 56/112/168 Bits Key Sizes
– MD5, SHA1
– SHA2 – 224/256/384/512
– DRBG with True Random Number Generator
– PKA (Public Key Accelerator) to Assist in RSA/ECC Processing
– DMA Support
• Debugging Security
– Secure Software Controlled Debug Access
– Security Aware Debugging
• Trusted Execution Environment (TEE) Supported
– Arm TrustZone® Based TEE
– Extensive Firewall Support for Isolation
– Secure DMA Path and Interconnect
– Secure Watchdog/Timer/IPC
• Secure Storage Support
• On-the-Fly Encryption and Authentication Support for OSPI Interface
• Networking Security Support for Data (Payload) Encryption/Authentication via Packet Based Hardware Cryptographic Engine
• Security Co-Processor (DMSC) for Key and Security Management, with Dedicated Device Level Interconnect for Security
SoC Services:
• Device Management Security Controller (DMSC)
– Centralized SoC System Controller
– Manages System Services Including Initial Boot, Security, Safety and Clock/Reset/Power Management
– Power Management Controller for Active and Low Power Modes
– Communication with Various Processing Units over Message Manager
Simplified Interface for Optimizing Unused Peripherals
– Tracing and Debugging Capability
• Sixteen 32-Bit General-Purpose Timers
• Two Data Movement and Control Navigator Subsystems (NAVSS)
– Ring Accelerator (RA)
– Unified DMA (UDMA)
– Up to 2 Timer Managers (TM) (1024 Timers Each)
Multimedia:
• Display Subsystem
– Two Fully Input-Mapped Overlay Managers Associated with Two Display Outputs
– One Port MIPI® DPI Parallel Interface
– One Port OLDI
• Graphics Processing Unit (GPU
• One Camera Serial Interface-2 (MIPI CSI-2)
• One Port Video Capture: BT.656/1120 (No Embedded Sync)
High-Speed Interfaces:
• One Gigabit Ethernet (CPSW) Interface Supporting
– RMII (10/100) or RGMII (10/100/1000)
– IEEE1588 (2008 Annex D, Annex E, Annex F) with 802.1AS PTP
– Audio/Video Bridging (P802.1Qav/D6.0)
– Energy-Efficient Ethernet (802.3az)
– Jumbo Frames (2024 bytes)
– Clause 45 MDIO PHY Management
• Two PCI-Express® Revision 3.1 Subsystems (2)
– Supports Gen3 (8.0GT/s) Operation
– Two Independent 1-lane, or a Single 2-lane Port
– Support for Concurrent Root-Complex and/or End-Point Operation
USB 3.1 Dual-Role Device Subsystem (2)
– One Enhanced SuperSpeed Gen1 Port
– One USB 2.0 Port
– Each Port Independently Configurable as USB Host, USB Peripheral, or USB Dual-Role Device
General Connectivity:
• 6× Inter-Integrated Circuit (I2C) Ports
• 5× Configurable UART/IrDA/CIR Modules
• Two Simultaneous Flash Interfaces Configured
– Two OSPI™ Flash Interfaces
– or Hyperbus™ and OSPI1 Flash Interface
• 2× 12-Bit Analog-to-Digital Converters (ADC
– Up to 4 Msamples/s
– Eight Multiplexed Analog Inputs
• 8× Multichannel Serial Peripheral Interfaces (MCSPI) Controllers
– Two with Internal Connections
– Six with External Interfaces
• General-Purpose I/O (GPIO) Pins
Control Interfaces:
• 6× Enhanced High Resolution Pulse-Width Modulator (EHRPWM) Modules
• One Enhanced Capture (eCAP) Module
• 3× Enhanced Quadrature Encoder Pulse (eQEP) Modules
Automotive Interfaces:
• 2× Modular Controller Area Network (MCAN) Modules with Full CAN-FD Support
Audio Interfaces:
• 3× Multichannel Audio Serial Port (MCASP) Modules
Media and Data Storage:
• 2× MultiMedia Card/Secure Digital (MMC/SD) Interfaces
Simplified Power Management:
• Simplified Power Sequence with Full Support for Dual Voltage I/O
• Integrated LDOs Reduces Power Solution Complexity
• Integrated SDIO LDO for Handling Automatic Voltage Transition for SD Interface
• Integrated POR (Power on Reset) Generation Reducing Power Solution Complexity
• Integrated Voltage Supervisor for Safety Monitoring
• Integrated Power Supply Glitch Detector for Detecting Fast Power Supply Transients
Analog/System Integration:
• Integrated USB VBUS Detection
• Fail Safe I/O for DDR RESET
• All I/O Pins Drivers Disabled During Reset to Avoid Bus Conflicts
• Default I/O Pulls Disabled During Reset to Avoid System Conflicts
• Support Dynamic I/O Pinmux Configuration Change
System on Chip (SoC) Architecture:
• Supports Primary Boot from UART, I2C, MCSPI, HyperBus, Parallel NOR Flash, SD or eMMC, USB, PCIe, and Ethernet Interfaces
• 28-nm CMOS Technology
• 23 mm × 23 mm, 0.8-mm Pitch, 784-Pin S-PBGA (ACD)
AM654x和AM652x应用:
• Industrial Programmable Controllers (PLC)
• Factory Automation with Safety Functions
• Multi-Protocol Fieldbus Communications
• Industrial PC
• Industrial Robots
• Human Machine Interface (HMI)
• Grid Infrastructure Protection Relays
• Robotic Motor Drives
图1. AM654x和AM652x功能框图
The AM65x GP EVM is a standalone test, development, and evaluation module (EVM) system that lets developers write software and develop hardware for industrial communication-type applications. The GP EVM is equipped with AM6548 processor from TI and a defined set of features to let the user experience industrial communication solutions using serial, Ethernet-based, PCIe, and many other interfaces. Using standard interfaces, the GP EVM can communicate with other processors or systems, and act as a
communication gateway. In addition, the GP EVM can directly operate as a standard remote I/O system or simple sensor connected to an industrial communication network. The embedded emulation logic allows for emulation and debugging using standard development tools such as Code Composer Studio™, from TI, by using the supplied USB cable.
The AM65x GP EVM is a high performance, standalone development platform that enables users to evaluate and develop industrial applications for the Texas Instrument’s K3 System-on-Chip (SoC)。 The AM65x GP EVM supports the following key features:
• Based on the K3 architecture with Arm
• 4-GB DDR4 supporting data rate up to 1600 MT/s
• 16-GB eMMC Flash
• Full size SD card, up to 64-GB density with UHS-1 support (8-GB UHS-1 card supplied with the kit)
• 128-Mbit SPI EEPROM
• 512-Mbit OSPI EEPROM
• 256-Kbit I2C Boot EEPROM
• 3× PRU-ICSSG, supporting multi-protocol industrial Gigabit Ethernet on 2 ports
• Expansion Connectors with two full PRU-ICSSG ports
• 1x MCU Gigabit Ethernet port
• One USB2.0 interface port with Micro AB connector
• CSI-2 connector to interface camera card
• I-PEX EVAFLEX5-VS connector to interface with the LCD adapter card
• GPMC/DSS interface expansion connector
• Application board expansion connector
• SERDES expansion connector to interface two lane PCIe Personality card
• XDS110 on-board emulator
• Quad port UART to USB circuit over microB USB connector
• Expansion headers:
– Two UART
– One SPI
– One I2C
– Four timer signals
• Boot mode selection using DIP switches
• Two push buttons to generate interrupts
• Industrial Ethernet LEDs
• DC Input: 11 V to 28 V
• Status output: LEDs to indicate power status
• INA devices for current monitoring
• Over- and under-voltage protection circuit
• RoHS-compliant design
AM654x系列评估模块
The AM65x Evaluation Module provides a platform to quickly start evaluation of Sitara™ Arm® Cortex®-A53 AM65x Processors (AM6548, AM6546, AM6528, AM6527, AM6526) and accelerate development for HMI, networking, patient monitoring, and other industrial applications. It is a development platform based on the quad core Cortex-A53, dual Cortex-R5F processor that is integrated with ample connectivity such as PCIe, USB 3.0/2.0, Gigabit Ethernet, and more.
AM654x系列评估模块主要特性:
3 gigabit Ethernet ports
4GB DDR4 with ECC
On-board 16GB eMMC
On-board 512Mb OSPI Flash
1-lane PCIe Gen3.1, USB 3.1, USB 2.0 and CSI-2 interfaces
AM654x系列评估模块包括:
Assembled EVM
SD card
USB cable
Ethernet cable
Documentation
图2. TMDX654GPEVM AM65x 评估模块(EVM)系统外形图
图3. TMDX654GPEVM AM65x 评估模块(EVM)系统架构接口
图4.处理器板外形图(顶视图)
图5.处理器板外形图(底视图)
处理器板主要特性:
SoC:
• Based on the K3 architecture with Quad-Core Arm® Cortex®-A53 Microprocessor and Dual-Core Arm
Cortex-R5F Arm
• Heatsink and support for 12-V fan
Memory:
• 16-GB eMMC Flash which can support HS400 speed of operation
• 256-Kbit I2C EEPROM for Boot
I/O Interface:
• One MCU Gigabit Ethernet port and two Industrial Ethernet ports based on the Gigabit Industrial Communication Subsystem (PRU-ICSS-Gb) paired with Texas Instruments Gigabit Ethernet PHYs
• One USB2.0 interface with Micro AB connector
Expansion Bus:
• GPMC/DSS interface expansion connector for secondary display
• Application connector to expansion application cards
• SERDES expansion connector to support various SERDES modules
Debug:
• Supports 20-pin JTAG connection from external emulator
• Automatic selection between on-board and external emulator (higher priority)
• Two UART, one SPI, and I2C ports connected to test header for slave testing of the AM65x device
• Four timer signals from Maxwell connected to test header
• Two push buttons to generate Interrupts
Power Supply:
• Wide range DC input: 11 V to 28 V
Compliance:
• RoHS-compliant
• REACH-compliant
图6.处理器板功能框图
图7.处理器板电路图(1)
图8.处理器板电路图(2)
图9.处理器板电路图(3)
图10.处理器板电路图(4)
图11.处理器板电路图(5)
图12.处理器板电路图(6)
图13.处理器板电路图(7)
图14.处理器板电路图(8)
图15.处理器板电路图(9)
图16.处理器板电路图(10)
图17.处理器板电路图(11)
图18.处理器板电路图(12)
图19.处理器板电路图(13)
图20.处理器板电路图(14)
图21.处理器板电路图(15)
图22.处理器板电路图(16)
图23.处理器板电路图(17)
图24.处理器板电路图(18)
图25.处理器板电路图(19)
图26.处理器板电路图(20)
图27.处理器板电路图(21)
图28.处理器板电路图(22)
图29.处理器板电路图(23)
图30.处理器板电路图(24)
图31.处理器板电路图(25)
图32.处理器板电路图(26)
图33.处理器板电路图(27)
图34.处理器板电路图(28)
图35.处理器板电路图(29)
图36.处理器板电路图(30)
图37.处理器板电路图(31)
图38.处理器板电路图(32)
图39.处理器板电路图(33)
图40.处理器板电路图(34)
图41.处理器板电路图(35)
图42.处理器板电路图(36)
图43.处理器板电路图(37)
图44.处理器板电路图(38)
图45.处理器板电路图(39)
图46.处理器板电路图(40)
图47.处理器板电路图(41)
图48.处理器板电路图(42)
图49.处理器板PCB设计图(1)
图50.处理器板PCB设计图(2)
图51.处理器板PCB设计图(3)
图52.处理器板PCB设计图(4)
图53.处理器板PCB设计图(5)
图54.处理器板PCB设计图(6)
图55.处理器板PCB设计图(7)
图56.处理器板PCB设计图(8)
图57.处理器板PCB设计图(9)
图58.处理器板PCB设计图(10)
图59.处理器板PCB设计图(11)
图60.处理器板PCB设计图(12)
图61.处理器板PCB设计图(13)
图62.处理器板PCB设计图(14)
图63.处理器板PCB设计图(15)
图64.处理器板PCB设计图(16)
图65.处理器板PCB设计图(17)
图66.处理器板PCB设计图(18)
图67.处理器板PCB设计图(19)
图68.处理器板PCB设计图(20)
图69.处理器板PCB设计图(21)
图70.处理器板PCB设计图(22)
  • mcu
    mcu
  • ti
    ti
    AM1810 Sitara ARM 微处理器
    型认证解决方案,进一步印证了其对工业市场的一贯承诺。与当前市面上的芯片解决方案相比,AM1810 Si
    发表于 01-24 10:41
    带你了解TIAMIC11x工业以太网从站解决方案
    开发可用于多个不同网络的解决方案更具挑战性。一个解决方案是拥有一个可针对不同协议进行再编程的单个设备。AMIC11x概述:用于工业以太网和现场总线从属设备的
    发表于 05-23 14:09
    创龙基于TI AM5728高端数控系统方案
    能力,可满足工业协议支持、大数据计算、实时控制等应用需求。 广州创龙基于TI AM5728浮点双DSPC66x+双ARMCortex-A15处理器设计的开发板,广泛应用于机器视觉、电力
    发表于 07-26 09:35
    基于Sitara处理器工业以太网应用的快速启动系统解决方案
    描述TI 提供用于在 Sitara 处理器上进行集成式协议工业以太网通信的系统解决方案。各种
    发表于 08-28 10:34
    面向工业自动化的协议工业以太网协议检测固件设计方案
    或 ASIC。PRU-ICSS 中的固件可用于检测工业以太网协议的类型并在运行时期间将相应的工业应用加载到 Sitara 处理器中。此 TI
    发表于 08-30 08:48
    协议解决方案工业以太网像标准以太网一样简单
    领先的自动化系统进行通信。.具有支持快速应用开发流程的协议TI工业处理器具有PRU-ICSS(工业通信子系统)的
    发表于 09-10 11:47
    如何选择合适的工业以太网
    Sitara™ARM处理器。这些应用处理器具有一个集成可编程实时单元和工业通信子系统(PRU-ICSS),其能够读懂协议工业以太网。让我
    发表于 07-18 04:45
    TI Sitara系列AM3352/AM3354/AM3359 ARM Cortex-A8方案分享
    、eQEP等额外资源,且具有与FPGA进行高速通信的并行接口GPMC,也就是可通过FPGA拓展更多DI/DO、UART、CAN、网口、光口等接口。SOM-TL335x-S基于TI Sitara系列AM
    发表于 06-30 10:26
    工业设计更智能:通过Sitara AM437x工业用单芯片实现连接、控制与通信
    控制工业系统设计的差异化和优化,同时还有助于评估基于ARM® Cortex®-A9内核的高集成度Sitara AM4379与AM4377处理器的
    发表于 03-20 13:46 1860次阅读
    TI推出用于工业4.0的首款支持协议千兆位TSN的AM6x处理器
    工业SitaraAM6x处理器可强化安全,实现先进的工业通信、高可靠性和功能安全性。
    的头像 发表于 10-31 18:44 5400次阅读
    AM6548 Sitara 处理器:四核 Arm Cortex-A53 和双核 Arm Cortex-R5F,千兆位 PRU-ICSS,3D 图形
    电子发烧友网为你提供TI(ti)AM6548相关产品参数、数据手册,更有AM6548的引脚图、接线图、封装手册、中文资料、英文资料,AM6548
    发表于 01-08 17:49
    工业通信总线设计的TI SITARA产品概述
    基于AMIC产品的工业通信总线设计方案-1.6 TI Sitara Product Overview
    的头像 发表于 05-08 06:19 3110次阅读
    <b class='flag-5'>工业</b>通信总线设计的<b class='flag-5'>TI</b> <b class='flag-5'>SITARA</b>产品概述
    TI Sitara™︎ AM2x系列重新定义MCU
    Other Parts Discussed in Post: AM2431, AM2432, AM2434TI Sitara  AM2x
    的头像 发表于 01-12 14:01 1447次阅读
    TI全新Sitara™︎ AM2x系列重新定义MCU,处理能力相比现有器件提高10倍
    发表于 10-28 12:00 0次下载
    <b class='flag-5'>TI</b>全新<b class='flag-5'>Sitara</b>™︎ <b class='flag-5'>AM</b>2x系列重新定义<b class='flag-5'>MCU</b>,处理能力相比现有器件提高10倍
    AM64x/AM243x协议Demo搭建与详解
    AM243x是TI的高性能Sitara MCU产品,具有两个PRU_ICSSG(可编程实时Unit_Industrial通信子系统Gb)模块,能够用于
    的头像 发表于 03-16 10:32 2750次阅读
    <b class='flag-5'>AM</b>64x/<b class='flag-5'>AM</b>243x<b class='flag-5'>多</b><b class='flag-5'>协议</b>Demo搭建与详解
