ADMV4420的K波段下变换器解决方案
电子工程师 来源:xx 2019-05-01 16:53 次阅读
ADI公司ADMV4420是集成了分数-N PLL和VCO的K波段下变换器,具有高度集成双平衡有源混频器和分数N合成器,其RF前端包括集成的平衡/不平衡变换器(balun)和低噪音放大器(LNA)(7dB单边带噪音),以及高动态范围IF输出放大器,其转换增益36dB.集成的低相位噪音分数N锁相环(PLL)和多核压控振荡器(VCO)和内部2x乘法器,输出P1dB为7 dBm,输出IP3为16 dBm,RF输入频率16.95 GHz 到 22.05 GHz, LO频率范围16.75 GHz to 21.15 GHz, IF频率范围900 MHz 到 2500 MHz ,5V工作电压,主要用在卫星通信和点对点微波通信。本文介绍了ADMV4420主要特性,功能框图以及评估板ADMV4420-EVALZ主要特性,配置图和实验室连接图,电路图,材料清单和PCB设计图。
The ADMV4420 is a highly integrated, double balanced, active mixer with an integrated fractional-N synthesizer, ideally suited for next generation K band satellite communications.
The RF front end consists of an integrated RF balun and low noise amplifier (LNA) for an optimal, 7 dB, single-sideband noise figure while minimizing external components. Additionally, the high dynamic range IF output amplifier provides a nominal conversion gain of 36 dB.
An integrated low phase noise, fractional-N, phase-locked loop (PLL) with a multicore voltage controlled oscillator (VCO) and internal 2× multiplier generate the necessary on-chip LO signal for the double balanced mixer, eliminating the need for external frequency synthesis. The multicore VCO uses an internal autocalibration routine that allows the PLL to select the necessary settings and lock in approximately 400 μs.
The reference input to the PLL employs a differentially excited 50 MHz crystal oscillator. Alternatively, the reference input can be driven by an external, singled-ended, 50 MHz source. The phase frequency detector (PFD) comparison frequency of the PLL operates up to 50 MHz.
The ADMV4420 is fabricated on a silicon germanium (SiGe), bipolar complementary metal-oxide semiconductor (BiCMOS) process, and is available in a 32-lead, RoHS compliant, 5 mm × 5 mm LFCSP package with an exposed pad. The device is specified over the −40°C to +85°C temperature range on a 5 V power supply.
ADMV4420主要特性:
RF front end with integrated RF balun and LNA
Double balanced, active mixer with high dynamic range IF amplifier
Fractional-N synthesizer with low phase noise, multicore VCO
5 V supply operation with integrated LDO regulators
Output P1dB: 7 dBm
Output IP3: 16 dBm
Conversion gain: 36 dB
Noise figure: 7 dB
RF input frequency range: 16.95 GHz to 22.05 GHz
Internal LO frequency range: 16.75 GHz to 21.15 GHz
IF frequency range: 900 MHz to 2500 MHz
Single-ended 50 Ω input impedance and 75 Ω IF output impedance
Programmable via 4-wire SPI
32-lead, 5 mm × 5 mm LFCSP
ADMV4420应用:
Satellite communication
Point to point microwave communication
[原创]ADI ADMV4420 K波段下变换器解决方案
图1. ADMV4420功能框图
评估板ADMV4420-EVALZ
The ADMV4420-EVALZ evaluation board can be used to evaluate the performance of the ADMV4420. The top and cross sectional layout views of the ADMV4420-EVALZ evaluation board are shown in Figure 126 and Figure 127, respectively. The RF transmission lines were designed using a coplanar waveguide (CPWG) model with a line width (W) of 16 mil and 13 mil of ground spacing for a characteristic impedance of 50Ω for the RF input (RFIN) and the external reference input (REF/XTAL1)。 The line width and ground spacing for the IF output (IFOUT) are 9 mil and 15 mil, respectively. The PCB is made with Rogers 4350B dielectric material, which offers low loss performance, and isola 370HR dielectric material, which achieves the required thickness of the PCB.
The ADMV4420-EVALZ comes with an ADMV4420 chip. Figure 4 shows the location of this chip on the evaluation board and the block diagram of the ADMV4420.
When evaluating the device, connect the RF input to an RF signal generator. The ADMV4420-EVALZ runs on a 5 V dc supply. Figure 2 shows the top side of the ADMV4420-EVALZ and is intended for evaluation purposes only.
Connect the 5 V dc to the VPOS1 test point and ground to the GND2 test point on the ADMV4420-EVALZ. Connect a 50 Ω SMA female to a 75 Ω Type F male adapter to J4 (IF output)。 Connect the output of the adapter to a spectrum analyzer. The ADMV4420-EVALZ has 50 MHz crystal on board. Optionally, the user can connect a reference signal from a low phase signal generator to the J2 SMA connector. If the user wants to use an external reference, depopulate Y1, C5, and C6 and then install a 0.01 μF capacitor at C21, a 1 nF capacitor at C6, and 50 Ω at R21. See Figure 5 for ADMV4420-EVALZ lab connections. Figure 3 shows the block diagram of the ADMV4420 lab bench setup.
评估板ADMV4420-EVALZ主要特性:
Full feature evaluation board for the ADMV4420
On-board SDP-S connector for SPI control
5 V operation
ACE software interface for SPI control
图2. 评估板ADMV4420-EVALZ外形图
图3. 评估板ADMV4420-EVALZ电路图
评估板ADMV4420-EVALZ材料清单:
图4. 评估板ADMV4420-EVALZ配置图
图5. 评估板ADMV4420-EVALZ实验室连接图
图6. 评估板ADMV4420-EVALZ 18GHz RF信号,17GHz LO和50MHz板上晶振设定图
图7. 评估板ADMV4420-EVALZ 18GHz RF信号,20.2GHz LO和50MHz板上晶振设定图
图8. 评估板ADMV4420-EVALZ 顶视图
图9. 评估板ADMV4420-EVALZ 底视图
图10. 评估板ADMV4420-EVALZ PCB顶视图
图11. 评估板ADMV4420-EVALZ实验室工作台建立框图
图12. 评估板ADMV4420-EVALZ 布局图(顶视图1)
图12. 评估板ADMV4420-EVALZ 布局图(层2)
图13. 评估板ADMV4420-EVALZ 布局图(层3)
图14. 评估板ADMV4420-EVALZ 布局图层4(底面)
详情请见:
https://www.analog.com/media/en/technical-documentation/data-sheets/ADMV4420.pdf
https://www.analog.com/media/en/technical-documentation/user-guides/ADMV4420-EVALZ-UG-1404.pdf
ADMV4420.pdf
  • 变换器
  • RF
    RF
    贸泽开售Analog Devices用于卫星通信的 ADMV4540 K波段正交解调
    贸泽电子 (Mouser Electronics) 即日起备货Analog Devices ADMV4540 K波段正交解调ADMV45
    发表于 03-04 14:48 1537次阅读
    贸泽开售Analog Devices用于卫星通信的 <b class='flag-5'>ADMV</b>4540 <b class='flag-5'>K</b><b class='flag-5'>波段</b>正交解调<b class='flag-5'>器</b>
    U/F变换器和F/U变换器
      电压/频率变换电路简称为U/F变换电路或U/F变换器(UFC),频率/电压变换电路简称为F/U变换电路或F/U
    发表于 11-10 11:28
    DCM变换器建模与CCM有什么不同
    什么是状态平均?DCM变换器建模与CCM有什么不同?基于电流峰值控制的CCM变换器建模是什么?
    发表于 10-15 06:02
    DCDC变换器建模
    DCDC变换器建模一、开关电源建模基本概念二、CCM变换器建模1.状态平均的概念2.推导变换器的状态空间平均方程3.对变换器的状态空间平均
    发表于 10-29 08:57
    DC-DC变换器解决方案
    变压,可为公司的 SCALE-iDriver™系列门极驱动提供正确电压和功率。二者结合可提供简单稳定且具有成本效益的DC-DC变换器解决方案,无需进行额外电压调整,可降低系统成本并
    发表于 11-16 08:36
    波段阻抗变换器
    讨论了双波段阻抗变换器的设计方法,分析了四分之一波长阻抗变换器的兀形等效电路,得到了双波段阻抗变换器的设计公式。 利用该等效电路,能方便将单
    发表于 02-25 10:18 63次下载
    用DC/DC变换器的高效电源解决方案
    变换器,是将信源发出的信息按一定的目的进行变换。矩阵式变换器是一种新型的交-交电源变换器。和传统的变换器相比,它具有如下优点:不需要中间直流
    发表于 05-15 15:32 9次下载
    用DC/DC<b class='flag-5'>变换器</b>的高效电源<b class='flag-5'>解决方案</b>
    ADMV4420 具有集成小数 N 分频 PLL 和 VCO 的 K 波段下变频
    电子发烧友网为你提供ADI(ti)ADMV4420相关产品参数、数据手册,更有ADMV4420的引脚图、接线图、封装手册、中文资料、英文资料,ADMV4420真值表,ADMV4420
    发表于 02-22 15:07
    <b class='flag-5'>ADMV4420</b> 具有集成小数 N 分频 PLL 和 VCO 的 <b class='flag-5'>K</b> <b class='flag-5'>波段</b>下变频<b class='flag-5'>器</b>
    ADMV4420:集成小数N PLL和压控振荡数据表的K波段下变频
    发表于 04-29 15:09 5次下载
    <b class='flag-5'>ADMV4420</b>:集成小数N PLL和压控振荡<b class='flag-5'>器</b>数据表的<b class='flag-5'>K</b><b class='flag-5'>波段</b>下变频<b class='flag-5'>器</b>
    UG-1404:评估集成小数N锁相环和压控振荡ADMV4420K波段下变频
    发表于 04-29 15:58 5次下载
    UG-1404:评估集成小数N锁相环和压控振荡<b class='flag-5'>器</b>的<b class='flag-5'>ADMV4420</b>,<b class='flag-5'>K</b><b class='flag-5'>波段</b>下变频<b class='flag-5'>器</b>
    EVAL-ADMV4420 EVAL-ADMV4420评估板
    电子发烧友网为你提供ADI(ti)EVAL-ADMV4420相关产品参数、数据手册,更有EVAL-ADMV4420的引脚图、接线图、封装手册、中文资料、英文资料,EVAL-ADMV4420真值表,EVAL-
    发表于 07-14 13:00
    伊顿正加速数字化转型步伐 贸泽开售ADMV4540 K波段正交解调
    提供超丰富半导体和电子元器件™的业界知名新品引入 (NPI) 分销商贸泽电子 (Mouser Electronics) 即日起备货Analog Devices ADMV4540 K波段正交解调
    发表于 03-17 15:06 868次阅读
    德州仪器全新同步升压变换器TPS61288,无线音箱升压变换器的理想方案
    发表于 10-28 12:00 1次下载
    德州仪器全新同步升压<b class='flag-5'>变换器</b>TPS61288,无线音箱升压<b class='flag-5'>变换器</b>的理想<b class='flag-5'>方案</b>
    基于GD32F303的高频DC/DC变换器解决方案
    的头像 发表于 11-06 17:04 807次阅读
    基于GD32F303的高频DC/DC<b class='flag-5'>变换器</b><b class='flag-5'>解决方案</b>
    阻抗变换器的参数K1和K2是什么
    阻抗变换器是一种用于实现不同阻抗之间转换的电子设备,广泛应用于通信、广播、电视、雷达等领域。在阻抗变换器中,参数K1和K2是两个非常重要的参数,它们对阻抗
    的头像 发表于 08-28 14:39 696次阅读
