基于NEWTEC-NTBMS的高等级ASIL C汽车电池管理参考设计
电子工程师 来源:陈翠 2019-04-05 15:31 次阅读
nxp公司的NEWTEC-NTBMS是汽车功能安全完整性等级高达ASIL C的汽车电池管理参考设计,和ISO 26262标准ASIL C兼容,包括两块板:功能安全系统模块(Safety SoM)和电池管理系统(BMS)应用板.Safety SoM基于NXP公司的S32K144和KEA微控制器和FS4503C安全电源系统.BMS应用板基于NXP公司的电池控制器,能够永久测量电池电压,超温保护,过流/过压检测,欠压检测(短路),安全继电器控制(ASIL C),非故意的继电器闭合和断开,各种定义的安全状态以及LIN和CAN总线接口,可控制多达6个锂电池,连续载流能力200A,最大电流800A,主要用在汽车BMS,智能电网和其它电池管理系统(医疗,电动自行车,轻型交通和工业)。本文介绍了NewTec NTBMS主要特性,框图,技术数据以及安全特性高达ASIL C电池管理参考设计NEWTEC-NTBMS主要特性,框图,建力图和电路图。
NewTec NTBMS is an e-mobility reference design and complete safety support package for Battery Management Systems. It is constructed with a two boards approach a functional safety System-on-Module (Safety SoM) board and a Battery Management System (BMS) application board. The Safety SoM is based on NXP's S32K144 and KEA microcontrollers, and FS4503C safety power system. The BMS application board is based on NXP's MC33772B battery cell controller IC. The support package includes the necessary safety documentation and software for certification purposes. It is intended for device manufacturers with Lithium-ion batteries and suppliers of automotive or industrial applications with a high degree of reliability and safety in accordance with ISO 26262 targeting safety level up to ASIL C, or IEC61508 SIL2.
Typical use cases would be:
Automotive Battery Management System for 14V auxiliary battery
Monitoring of starter batteries
Extendable to 48V battery systems
Stationary Energy Storage systems; Smart Grid
NTBMS is a Battery Management System for manufacturer ofautomotive Battery Systems, used as Starter Battery or AuxiliaryBattery with Li-Ion cells.
The NTBMS platform is designed for systems with high demandon reliability and safety in compliance with ISO 26262 ASIL C.NTBMS is a generic safety reference design for BMS developedin cooperation with NXP. The Battery Management System of Li-Ion battery includes cell monitoring, current sensing, passive cellbalancing, battery breaker control, computation unit for Batteryparameter extraction (such as State of Charge, State of Health)and communication to other ECU through CAN.
Battery management systems (BMS) are responsible to steerand control high-voltage batteries of Electric and Hybrid ElectricVehicles. This control unit is essential since several battery cellsare unified to a cluster to enhance battery capacity. It is a charge
regulator which should guarantee a stringent power supply ofthe engine.
BMS are essential to monitor state of charge, load distribution,temperature of each battery cell as well as of the whole batterypackage and development of the charging capacity.
NewTec NTBMS主要特性:
Permanent measurement of cell voltages
Over-temperature protection
Overcurrent / overvoltage detection
Undervoltage detection (short circuit)
Safe relay (breaker) control (ASIL C)
Unintended relay close
Unintended relay open
Various definable Safe States
LIN and CAN bus interface
Crash detection
Overcurrent control fuse
Power supply with watchdog protection
Control of up to 6 Lithium-ion battery cells
Electrical current carrying capability: 200 A continuous current, 800 A maximum current
Operating Current 《 25 mA@RT
Intrusive diagnostics (performed by MCU
Memory storage (RAM& flash)
Power management (low power and normal mode)
All components AEC-Q qualified
Programmable in C
客户效益:
_ Accelerate time to market
_ Reduction in costs for development and certification
_ Safety Development Platform for BMS
_ Reference Design in compliance to ISO 26262 ASIL C
NEWTEC-NTBMS典型应用:
_ Automotive BMS for Starter Battery with Li-Ion battery
_ Automotive BMS for Auxiliary Battery
_ Smart Grids
_ Other Battery Management opportunities (medical, e-Bike,light transportation, industrial)
技术数据:
Power Supply
The device is designed for operation with 12V to 18V DC power
Supply. Operation with other supply voltages is not permitted.
The supply voltage is connected via the connection cable provided
for this purpose.
Environmental Conditions
Temperature
The device is designed for storage and operations at the followingtemperature ranges:
_ Storage temperature: -15°C to +70°C
_ Operating temperature: 0°C to +40°C
Battery Characteristics
Electrical current carrying capability for shunt resistor
_ 250 A permanent;
_ 600 A for 40 s;
_ 1400 A for 1 s
Battery Management System current
_ operating current 《 25 mA@RT
Other Characteristics
_ Intrusive diagnostics (performed by MCU)
_ Memory storage (RAM& flash)
_ Power management (low power and normal mode)
_ LIN for starter batteries
_ CAN for the auxiliary batteries
NXPNEWTEC-NTBMS汽车电池管理参考设计
图1.NTBatteryManagementSystem(NTBMS)框图
NEWTEC-NTBMS:安全特性高达ASIL C电池管理参考设计
NEWTEC-NTBMS: The Battery Management Reference Design with Functional Safety Features up to ASIL C
The application is a Battery Management System (BMS) evaluation platform for a14V Li-Ion battery (including cell monitoring, current sensing, passive cell balancing, battery breaker control, computation unit for Battery parameter extraction and communication to other ECU through CAN.
The NT BMS consists of a general purpose Safety System on Module (NT SafeSOMmicro) which is an ASILC ready microcontroller platform, including two microcontrollers which are supervising each other and an ASIL D qualified System Basis Chip providing all necessary voltages, CAN PHY and Watchdog functionality.
Second part is the NT BMS Baseboard where all battery management specific components are located. The three main components are:
·Battery Cell Controller
·Current measurement shunt resistor
·Breaker control circuit
This product is a reference design platform for the development of safety-critical battery management systems and applications. In no case must it be installed or used in vehicles or medical equipment. Military use of this product is not permitted.
This product may only be used in workshops and laboratories by trained specialist personnel. It may only be connected to the following components:
 Battery Pack with up to 6 cells and 3 Temperature Sensors TBD Max Voltage, Max current
 Power Supply, 14V, with sufficient power for Battery Pack charging
 Battery Pack with 3 Temperature Sensors and up to 6 cells, max Voltage: 14V
 Fuse with fitting characteristic for Battery Pack
 Breaker Relay, recommended type: TE Connectivity V23130-C2021-A400 (max current 190A)
参考设计NEWTEC-NTBMS包括:
Evaluation Board
Schematic / Layout / Gerber Files
Quick-Start-Guide
Safety How-to-Guide for ASIL C
Application Software
Complete Safety Documentation Templates for Certification
图2.NEWTEC-NTBMS基板&NTSafeSOMmicro外形图
图3.NTBMS建立图
图4:参考设计NEWTEC-NTBMS电路图(1)
图5:参考设计NEWTEC-NTBMS电路图(2)
图6:参考设计NEWTEC-NTBMS电路图(3)
图7:参考设计NEWTEC-NTBMS电路图(4)
图8:参考设计NEWTEC-NTBMS电路图(5)
  • 汽车电池
  • 电池
    百兆网口高等级大浪涌方案
    `百兆网口高等级大浪涌方案描述:全球气候变暖,雷雨天气增多,导致网络设备遭受雷击损坏的概率增大,维护成本大幅度上升,其次随着行业发展高浪涌防护已成为行业的必然选择。解决方案内容:2 颗 UN
    发表于 06-22 10:41
    智原硅智财符合车辆安全完整性最高等级ASIL-D
    (Memory Compiler),包含静态随机存取内存SRAM及只读存储器ROM,获得德国验证机构SGS-TÜV颁发ISO 26262车用安全最高等级 ASIL-D Ready证书,同步亦推出符合车用ISO
    的头像 发表于 01-24 16:15 1871次阅读
    华为智能电动MCU符合ISO 26262汽车安全完整性最高等级功能安全要求
    认证证书,意味着这款产品全生命周期均已符合ISO 26262汽车安全完整性最高等级ASIL D)的功能安全要求,同时也标志着国产自主自研MCU可达到国际功能安全最高等级要求。
    的头像 发表于 08-16 09:42 2290次阅读
    中兴微电子获得汽车功能安全最高等级认证
    近日,深圳市中兴微电子技术有限公司(以下简称“中兴微电子”)获得了由国际公认的测试、检验和认证机构SGS颁发的ISO 26262:2018汽车功能安全最高等级ASIL D功能安全流程认证证书,此举
    发表于 10-20 10:42 894次阅读
    美泰公司获得ISO 26262功能安全管理体系最高等级认证
    2023年1月6日,美泰公司获国际知名第三方检测、检验和认证机构德国莱茵TÜV功能安全管理体系最高等级ASIL D认证。 作为国内最早从事MEMS技术研发与产品制造的企业,近年来,美泰公司以雄厚
    的头像 发表于 01-11 17:43 2162次阅读
    汽车安全底线!德国莱茵为虹软颁发ISO 26262汽车功能安全管理体系ASIL D等级认证
    最新消息,虹软正式获得国际独立第三方检测、检验和认证机构德国莱茵TÜV颁发的ISO 26262汽车功能安全管理体系ASIL D等级认证证书。这表明,虹软已建立起符合功能安全最
    的头像 发表于 01-16 11:35 1752次阅读
    筑<b class='flag-5'>汽车</b>安全底线!德国莱茵为虹软颁发ISO 26262<b class='flag-5'>汽车</b>功能安全<b class='flag-5'>管理</b>体系<b class='flag-5'>ASIL</b> D<b class='flag-5'>等级</b>认证
    国民技术通过ISO 26262 ASIL-D汽车功能安全最高等级认证
    等级,这标志着国民技术的产品研发流程与管理体系已完全能够全面支撑汽车行业最为严苛的功能安全场景的开发需求。 ASIL (Automotive Safety Integration Le
    的头像 发表于 05-09 16:33 2297次阅读
    国民技术通过ISO 26262 <b class='flag-5'>ASIL</b>-D<b class='flag-5'>汽车</b>功能安全最<b class='flag-5'>高等级</b>认证
    权威认可・镭神智能获汽车功能安全流程ASIL D最高等级认证
    7月14日,镭神智能获得由TÜVNORD颁发的ISO26262:2018汽车功能安全流程认证证书,且获得ASILD最高等级认可!(ASIL有四个等级,分别为A、B、
    的头像 发表于 07-19 18:02 850次阅读
    权威认可・镭神智能获<b class='flag-5'>汽车</b>功能安全流程<b class='flag-5'>ASIL</b> D最<b class='flag-5'>高等级</b>认证
    兆易创新获ISO 26262:2018汽车功能安全最高等级ASIL D流程认证证书
    :2018汽车功能安全最高等级ASIL D流程认证证书,这标志着兆易创新已经建立起完善的、符合汽车功能安全最高等级要求的产品软硬件开发流程体
    的头像 发表于 08-29 14:09 1183次阅读
    航顺芯片获得ISO 26262最高等级ASIL D认证,汽车功能安全管理体系再升级
    近日,国际独立第三方检测、检验和认证机构SGS为深圳市航顺芯片技术研发有限公司(以下简称“航顺芯片”)颁发了ISO 26262:2018汽车功能安全最高等级ASIL D流程认证证书。 这标志着航顺
    的头像 发表于 10-08 10:15 859次阅读
    航顺芯片获得ISO 26262最<b class='flag-5'>高等级</b><b class='flag-5'>ASIL</b> D认证,<b class='flag-5'>汽车</b>功能安全<b class='flag-5'>管理</b>体系再升级
    航顺芯片获ISO 26262最高等级ASIL D认证证书
    【2023年10月17日,深圳】国际独立第三方检测、检验和认证机构SGS为深圳市航顺芯片技术研发有限公司(以下简称“航顺芯片”)正式颁发了ISO 26262:2018汽车功能安全最高等级ASIL D流程认证证书。
    的头像 发表于 10-18 11:19 1171次阅读
    航顺芯片获ISO 26262最<b class='flag-5'>高等级</b><b class='flag-5'>ASIL</b> D认证证书
    光庭信息获得ISO 26262汽车功能安全最高等级认证
    高等级ASIL D”级别的产品开发和管理流程体系,将深度赋能汽车智能化电动化技术安全性发展和技术革新。SGS中国功能安全中心产品线总监郑峥、光庭信息CTO项锋及双方代表共同出席了颁
    的头像 发表于 11-28 16:16 982次阅读
    艾为电子获得ISO 26262汽车功能安全最高等级认证
    要求,建立起完全符合汽车功能安全最高等级ASIL D级别的产品开发和管理流程体系,也意味着艾为电子在功能安全开发和管理能力上均达到了国际领先
    的头像 发表于 11-30 11:24 962次阅读
    欧冶半导体通过ISO 26262汽车功能安全最高等级ASIL-D流程认证
    获得此证书标志着欧冶半导体的功能安全开发流程已经按照ISO 26262:2018标准要求,建立起符合最高等级ASIL D”级别的功能安全产品开发和管理流程体系。
    的头像 发表于 01-05 10:56 1004次阅读
    欧冶半导体通过ISO 26262<b class='flag-5'>汽车</b>功能安全最<b class='flag-5'>高等级</b><b class='flag-5'>ASIL</b>-D流程认证
    芯驿电子获得ISO 26262汽车功能安全最高等级ASIL D认证
    ISO 26262:2018 版标准要求,建立起符合功能安全最高等级ASIL D”级别的产品开发和管理流程体系。
    的头像 发表于 03-19 10:20 640次阅读
    芯驿电子获得ISO 26262<b class='flag-5'>汽车</b>功能安全最<b class='flag-5'>高等级</b><b class='flag-5'>ASIL</b> D认证
