CC1352P主要特性以及pcb电路图
电子工程师 来源:陈翠 2019-04-05 16:15 次阅读
TI公司的CC1352P是集成了功率放大器(+20-dBm)的多频段(《1GHz和2.4GHz)多协议无线ARM MCUCPU工作频率48MHz,集成了灵活的非常低功耗的RF收发器,支持多个物理层和RF标准,专用的无线电控制器(Arm® Cortex®-M0)低级别RF协议指令,目标用在无线M总线,IEEE802.15.4g, IPv6使能智能对象(6LoWPAN),线程,Zigbee®, KNX RF, Wi-SUN®, Bluetooth® 5低功耗和专用系统。本文介绍了CC1352P主要特性,框图以及评估板LAUNCHXL-CC1352P1主要特性,电路图,材料清单和PCB设计图。
The CC1352P device is a multiprotocol Sub-1 and 2.4-GHz wireless MCU targeting Wireless M-Bus, IEEE802.15.4g, IPv6-enabled smart objects (6LoWPAN), Thread, Zigbee®, KNX RF, Wi-SUN®, Bluetooth® 5low energy, and proprietary systems. The device contains a +20-dBm integrated high-power amplifier withbest-in-class efficiency for long-range applications.
The CC1352P device is a member of the CC26xx and CC13xx family of cost-effective, ultra-low power,2.4-GHz and Sub-1 GHz RF devices. Very low active RF and microcontroller (MCU) current, in addition tosub-μA sleep current with up to 80KB of RAM retention, provide excellent battery lifetime and allowoperation on small coin-cell batteries and in energy-harvesting applications.
The CC1352P device combines a flexible, very low-power RF transceiver with a powerful 48-MHz Arm®Cortex®-M4F CPU in a platform supporting multiple physical layers and RF standards. A dedicated RadioController (Arm® Cortex®-M0) handles low-level RF protocol commands that are stored in ROM or RAM,thus ensuring ultra-low power and great flexibility. The low power consumption of the CC1352P devicedoes not come at the expense of RF performance; the CC1352P device has excellent sensitivity androbustness (selectivity and blocking) performance.
The CC1352P device is a highly integrated, true single-chip solution incorporating a complete RF systemand an on-chip DC/DC converter.
Sensors can be handled in a very low-power manner by a programmable, autonomous ultra-low powerSensor Controller CPU with 4KB of SRAM for program and data. The Sensor Controller, with its fastwake-up and ultra-low-power 2-MHz mode is designed for sampling, buffering, and processing bothanalog and digital sensor data; thus the MCU system can maximize sleep time and reduce active power.
The CC1352P device is part of the SimpleLink™ microcontroller (MCU) platform, which consists of Wi-Fi®,Bluetooth® low energy, Thread, Zigbee, Sub-1 GHz MCUs, and host MCUs, which all share a common,easy-to-use development environment with a single core software development kit (SDK) and rich tool set.
A one-time integration of the SimpleLink platform enables you to add any combination of the portfolio’sdevices into your design, allowing 100 percent code reuse when your design requirements change.
CC1352P主要特性:
• Microcontroller
– Powerful Arm® Cortex®-M4F Processor
– EEMBC CoreMark® Score: 148
– Clock Speed Up to 48 MHz
– 352KB of In-System Programmable Flash
– 256KB of ROM for Protocols and Firmware
– 8KB of Cache SRAM (Available as General-Purpose RAM)
– 80KB of Ultra-Low Leakage SRAM
– 2-Pin cJTAG and JTAG Debugging
– Supports Over-the-Air Upgrade (OTA)
• Ultra-Low Power Sensor Controller With 4KB ofSRAM
– Sample, Store, and Process Sensor Data
– Operation Independent From System CPU
– Fast Wake-Up for Low-Power Operation
• TI-RTOS, Drivers, Bootloader, Bluetooth® 5 lowenergy Controller, and IEEE 802.15.4 MAC inROM for Optimized Application Size
• RoHS-Compliant Package
– 7-mm × 7-mm RGZ VQFN48 (26 GPIOs)
• Peripherals
– Digital Peripherals Can be Routed to Any GPIO
– 4× 32-Bit or 8× 16-Bit General-Purpose Timers
– 12-Bit ADC, 200 kSamples/s, 8 Channels
– 2× Comparators With Internal Reference DAC(1× Continuous Time, 1× Ultra-Low Power)
– Programmable Current Source
– 2× UART
– 2× SSI (SPI, MICROWIRE, TI)
I2C
– I2S
– Real-Time Clock (RTC)
– AES 128- and 256-bit Crypto Accelerator
– ECC and RSA Public Key Hardware Accelerator
– SHA2 Accelerator (Full Suite Up to SHA-512)
– True Random Number Generator (TRNG)
– Capacitive Sensing, Up to 8 Channels
– Integrated Temperature and Battery Monitor
• External System
– On-Chip Buck DC/DC Converter
• Low Power
– Wide Supply Voltage Range: 1.8 V to 3.8 V
– Active-Mode RX: 5.8 mA (868 MHz)
– Active-Mode TX at +20 dBm: 65 mA (868 MHz)
– Active-Mode MCU 48 MHz (CoreMark):2.82 mA (59 μA/MHz)
– Sensor Controller 16-Hz Flow Metering:1.7 μA
– Sensor Controller 100-Hz Comp A Reading:1.5 μA
– Sensor Controller, 1-Hz ADC Sampling:1 μA
– Standby: 0.83 μA (RTC on, 80KB RAM andCPU Retention)
– Shutdown: 125 nA (Wakeup on External Events)
• Radio Section
– Dual-Band Sub-1 GHz and 2.4-GHz RFTransceiver Compatible With Bluetooth 5 low
energy and IEEE 802.15.4 PHY and MAC
– Excellent Receiver Sensitivity:
–122 dBm for SimpleLink Long Range,
–110 dBm at 50 kbps, –103 dBm for Bluetooth 5low energy Coded
– Excellent Selectivity: 48 dB at 50 kbps
– Programmable Output Power Up to +20 dBm
– Suitable for Systems Targeting Compliance WithWorldwide Radio Frequency Regulations
– ETSI EN 300 220, EN 300 328, EN 303 131,EN 303 204 (Europe)
– EN 300 440 Class 2 (Europe)
– FCC CFR47 Part 15 (US)
– ARIB STD-T108 and STD-T66 (Japan)
– Wide Standard Support
• Development Tools and Software
– LAUNCHXL-CC1352P1, P1-2, and P1-4Development Kits
– SimpleLink CC13X2 Software Development Kit
– SmartRF™ Software Studio for Simple RadioConfiguration
– Sensor Controller Studio for Building Low-PowerSensing Applications
CC1352P应用:
• 433-, 470- to 510-, 868-, 902- to 928-, and2400- to 2480-MHz ISM and SRD Systems (1)With Down to 4 kHz of Receive Bandwidth
• Smart Grid and Automatic Meter Reading
– Water, Gas, and Electricity Meters
– Heat Cost Allocators
– Gateways
• Wireless Sensor Networks
– Long-Range Sensor Applications
• Industrial
– Asset Tracking and Management
– Factory Automation
– Remote Display
• Wireless Healthcare Applications
• Energy Harvesting Applications
• Electronic Shelf Label (ESL)
• Home and Building Automation
– Wireless Alarms and Security Systems
– Locks
– Lightning Control
– Motion Detectors
– Connected Appliances
– HVAC
– Garage Door Openers
图1.CC1352P框图
图2.评估板LAUNCHXL-CC1352P1外形图(1)
图3.评估板LAUNCHXL-CC1352P1外形图(2)
图4.评估板LAUNCHXL-CC1352P1电路图(1)
图5.评估板LAUNCHXL-CC1352P1电路图(2)
图6.评估板LAUNCHXL-CC1352P1电路图(3)
图7.评估板LAUNCHXL-CC1352P1电路图(4)
图8.评估板LAUNCHXL-CC1352P1电路图(5)
图9.评估板LAUNCHXL-CC1352P1电路图(6)
图10.评估板LAUNCHXL-CC1352P1电路图(7)
评估板LAUNCHXL-CC1352P1材料清单:
图11.评估板LAUNCHXL-CC1352P1 PCB设计图(1)
图12.评估板LAUNCHXL-CC1352P1 PCB设计图(2)
图13.评估板LAUNCHXL-CC1352P1 PCB设计图(3)
图14.评估板LAUNCHXL-CC1352P1 PCB设计图(4)
图15.评估板LAUNCHXL-CC1352P1 PCB设计图(5)
图16.评估板LAUNCHXL-CC1352P1 PCB设计图(6)
图17.评估板LAUNCHXL-CC1352P1 PCB设计图(7)
图18.评估板LAUNCHXL-CC1352P1 PCB设计图(8)
图19.评估板LAUNCHXL-CC1352P1 PCB设计图(9)
图20.评估板LAUNCHXL-CC1352P1 PCB设计图(10)
  • 电路图
  • pcb
    pcb
    CC2530的主要功能特性以及应用电路图
    ,照明系统,工业控制和监视,低功耗无线传感器网络,消费类电子和卫生保健.本文介绍了CC2530的主要特性,方框图以及应用电路图和所用元件表。
    发表于 11-25 15:38 4.1w次阅读
    CC3220R主要特性介绍 单片无线ARM MCU解决方案
    本文介绍了CC3220R主要特性, 硬件和嵌入软件概述,功能框图,应用电路及其材料清单,以及S
    发表于 05-03 11:52 5996次阅读
    <b class='flag-5'>CC</b>3220R<b class='flag-5'>主要</b><b class='flag-5'>特性</b>介绍 单片无线ARM MCU解决方案
    一文详解IDP2303的主要特性/应用电路图PCB设计图
    本文介绍了IDP2303产品亮点和主要特性,典型应用电路图以及采用IDP2303的120 W 24 V 3.5 A 12 V 3 A SMPS演示板
    的头像 发表于 06-16 15:46 2.1w次阅读
    一文详解IDP2303的<b class='flag-5'>主要</b><b class='flag-5'>特性</b>/应用<b class='flag-5'>电路图</b>及<b class='flag-5'>PCB设计图</b>
    一文解析AK7736B主要特性_功能_电路图PCB元件布局
    本文介绍了AK7736B主要特性,框图和评估板AKD7736B-A功能,框图,布局框图以及电路图PCB元件布局
    的头像 发表于 06-07 09:16 7249次阅读
    一文解析AK7736B<b class='flag-5'>主要</b><b class='flag-5'>特性</b>_功能_<b class='flag-5'>电路图</b>及<b class='flag-5'>PCB</b>元件布局<b class='flag-5'>图</b>
    TI CC1352R多波段多协议无线MCU解决方案
    本文介绍了CC1352R主要特性,框图,物联网(IoT)网关参考设计TIDC-01002主要特性,硬件框图和15.4堆栈传感器-云参考设计软
    的头像 发表于 06-24 09:26 1w次阅读
    TI <b class='flag-5'>CC1352</b>R多波段多协议无线MCU解决方案
    AD8452主要特性_框图以及应用电路
    本文介绍了AD8452主要特性,框图,应用电路,评估板AD8452-EVALZ主要特性,框图,电路图
    的头像 发表于 05-11 10:33 7718次阅读
    AD8452<b class='flag-5'>主要</b><b class='flag-5'>特性</b>_框图<b class='flag-5'>以及</b>应用<b class='flag-5'>电路</b>
    ISO224主要特性以及应用电路
    本文介绍了ISO224主要特性,框图,应用电路以及评估模块ISO224EVM主要特性
    的头像 发表于 04-05 17:41 1.1w次阅读
    ISO224<b class='flag-5'>主要</b><b class='flag-5'>特性</b><b class='flag-5'>以及</b>应用<b class='flag-5'>电路</b>
    CC1352P高性能双频带无线MCU的数据手册免费下载
    CC1352P 器件是一款多协议低于 1GHz 和 2.4GHz 无线 MCU,面向无线 M-Bus、IEEE 802.15.4g、支持 IPv6 的智能对象 (6LoWPAN)、线程
    发表于 02-12 08:00 7次下载
    MAX40056主要特性以及应用电路
    本文介绍了MAX40056主要优势和特性,框图,应用电路以及评估板MAX40056 EVK主要特性
    发表于 04-05 11:25 5724次阅读
    MAX40056<b class='flag-5'>主要</b><b class='flag-5'>特性</b><b class='flag-5'>以及</b>应用<b class='flag-5'>电路</b>
    ATSAME70Q21的主要特性以及电路图
    本文介绍了ATSAME70Q21主要特性,SAM S70, SAM E70, V70和V71 144引脚框图,以及SAM E70 Xplained Ultra评估板DM320113主要
    的头像 发表于 04-05 18:45 1.6w次阅读
    ATSAME70Q21的<b class='flag-5'>主要</b><b class='flag-5'>特性</b><b class='flag-5'>以及</b><b class='flag-5'>电路图</b>
    MAX86150的优势特性以及典型应用电路图
    本文介绍了MAX86150主要优势和特性,简化框图和功能框图,典型应用电路图以及评估板MAX86150 EVS主要
    发表于 04-05 22:11 5680次阅读
    MAX86150的优势<b class='flag-5'>特性</b><b class='flag-5'>以及</b>典型应用<b class='flag-5'>电路图</b>
    如何正确的使用LAUNCHXL-CC1352P1和EnergyTrace功能
    CC1352P器件是 SimpleLink™ 微控制器(MCU)平台的一部分,该平台包括Wi-Fi®、低功耗Bluetooth®、低于1GHz 和主机MCU”选板时误以为CC1352P支持WI-FI、BLE和SUB-1G,后来细看资料才发现并
    发表于 04-30 14:18 2482次阅读
    CC1352P Sensorcontroller 控制光照传感器OPT3004及功耗实测
    Other Parts Discussed in Post: CC1352P, OPT3004, OPT3004EVM, LAUNCHXL-CC1352P, ENERGYTRACE作者:TI工程师
    的头像 发表于 01-19 16:08 3132次阅读
    <b class='flag-5'>CC1352P</b> Sensorcontroller 控制光照传感器OPT3004及功耗实测
    CC1352P Sensorcontroller控制光照传感器OPT3004及功耗实测
    发表于 10-31 08:23 1次下载
    <b class='flag-5'>CC1352P</b> Sensorcontroller控制光照传感器OPT3004及功耗实测
    优化Simplelink CC1352P以在10dBm输出功率下通过纽扣电池供电
    电子发烧友网站提供《优化Simplelink CC1352P以在10dBm输出功率下通过纽扣电池供电.pdf》资料免费下载
    发表于 09-21 10:19 0次下载
    优化Simplelink <b class='flag-5'>CC1352P</b>以在10dBm输出功率下通过纽扣电池供电
