NCP51705主要特性_内部框图以及应用电路
电子工程师 来源:陈翠 2019-05-11 10:20 次阅读
On Semi公司的NCP51705驱动器是设计用来驱动SiC MOSFET晶体管,为了得到尽可能低导通损耗,驱动器能驱动SiC MOSFET器件的最大可允许栅极电压,源电流和沉电流为6A,并提供重要的保护功能如基本电源的欠压锁住监视和基于驱动电路的结温的热关断,主要用在驱动SiC MOSFET晶体管,工业逆变器,马达驱动和PFC,AC疍C转换器DC/DC转换器.本文介绍了NCP51705主要特性,内部框图,低边开关配置图和应用电路,以及NCP51705 Mini 评估板和NCP51705 Mini SMD评估板主要特性,电路图,材料清单和PCB设计图.
The NCP51705 driver is designed to primarily drive SiC MOSFETtransistors. To achieve the lowest possible conduction losses, thedriver is capable to deliver the maximum allowable gate voltage to theSiC MOSFET device. By providing high peak current during turn−onand turn−off, switching losses are also minimized. For improvedreliability, dV/dt immunity and even faster turn−off, the NCP51705can utilize its on−board charge pump to generate a user selectablenegative voltage rail.
For full compatibility and to minimize the complexity of the biassolution in isolated gate drive applications the NCP51705 alsoprovides an externally accessible 5 V rail to power the secondary sideof digital or high speed opto isolators.
The NCP51705 offers important protection functions such asunder−voltage lockout monitoring for the bias power and thermalshutdown based on the junction temperature of the driver circuit.
NCP51705主要特性:
• High Peak Output Current with Split Output Stages to allowindependent Turn−ON/Turn−OFF Adjustment;
♦ Source Capability: 6 A
♦ Sink Capability: 6 A
• Extended Positive Voltage Rating for Efficient SiC MOSFETOperation during the Conduction Period
• User−adjustable Built−in Negative Charge Pump for Fast Turn−offand Robust dV/dt Immunity
• Accessible 5 V Reference/Bias Rail for Digital Oscillator Supply
• Adjustable Under−Voltage Lockout
• Desaturation Function
• Thermal Shutdown Function (TSD)
• Small & Low Parasitic Inductance QFN24 Package
NCP51705典型应用:
• Driving SiC MOSFET
• Industrial Inverters, Motor Drivers
• PFC, AC to DC and DC to DC Converters
图1.NCP51705内部框图
图2.NCP51705低边开关配置图
图3.NCP51705典型应用电路图
图4. NCP51705半桥栅极驱动电路图
NCP51705 Mini 评估板
This document describes the use and applications for theNCP51705 SiC driver mini EVB. The EVB is designed ona four layer PCB and includes the NCP51705 driver and all the necessary drive circuitry. The EVB also includes anon−board digital isolator and the ability to solder anyMOSFET or SiC MOSFET in a T0247 high voltagepackage. The EVB does not include a power stage and isgeneric from the point of view that it is not dedicated to anyparticular topology. It can be used in any low−side orhigh−side power switching application. For bridgeconfigurations two or more of these EVBs can be configuredin a totem pole type drive configuration. The EVB can beconsidered as an isolator+driver+T0247 discrete module.
图5.评估板NCP51705 EVB(35 mm x 15 mm x 5 mm)外形图
图6.评估板NCP51705 EVB电路图
评估板NCP51705 EVB材料清单:
图7.评估板NCP51705 EVB顶层装配图
图8.评估板NCP51705 EVB底层装配图
图9.评估板NCP51705 EVB顶层图
图10.评估板NCP51705 EVB层2图
图11.评估板NCP51705 EVB层3图
图12.评估板NCP51705 EVB底层图
This document describes the use and applications for the NCP51705SiC driver mini SMD EVB. The EVB is designed on a four layer PCBand includes the NCP51705 driver and all the necessary drivecircuitry. The EVB also includes an on−board digital isolator and the ability to solder any MOSFET or SiC MOSFET in a TO−247 highvoltage package. The EVB does not include a power stage and isgeneric from the point of view that it is not dedicated to any particulartopology. It can be used in any low−side or high−side power switchingapplication. For bridge configurations two or more of these EVBs canbe configured in a totem pole type drive configuration. The EVB canbe considered as an isolator+driver+TO−247 discrete module.
图13.NCP51705 Mini SMD评估板外形图(1)
图14.NCP51705 Mini SMD评估板顶层和底层图
图15.NCP51705 Mini SMD评估板简化框图
图16.NCP51705 Mini SMD评估板电路图
NCP51705 Mini SMD评估板材料清单:
图17.NCP51705 Mini SMD评估板PCB顶/底层装配图
图18.NCP51705 Mini SMD评估板PCBINNER_1/INNER_2层布局图
图19.NCP51705 SiC EVB PCB打孔图
图20.NCP51705 SiC EVB未安装时PCB的测试配置图
  • 变换器
  • DC/DC变换器
    开关稳压器NCP3065资料推荐
    开关稳压器NCP3065资料下载内容包括:NCP3065功能和特性NCP3065引脚功能NCP3065
    发表于 03-23 06:00
    电源控制芯片NCP1239F相关资料下载
    电源控制芯片NCP1239F资料下载内容主要介绍了:NCP1239F特性NCP1239F引脚功能NCP
    发表于 03-29 06:24
    电源管理芯片NCP1294相关资料分享
    电源管理芯片NCP1294资料下载内容主要介绍了:NCP1294功能和特性NCP1294引脚功能NCP
    发表于 03-31 06:24
    LED驱动器NCP5602相关资料分享
    LED驱动器NCP5602资料下载内容主要介绍了:NCP5602功能和特性NCP5602引脚功能NCP
    发表于 03-31 07:42
    超小型RGBLED驱动电路NCP5623资料推荐
    超小型RGBLED驱动电路NCP5623资料下载内容主要介绍了:NCP5623引脚功能NCP5623内部
    发表于 04-02 07:07
    POEPD以太网供电用电设备控制器NCP1081资料推荐
    POEPD以太网供电用电设备控制器NCP1081资料下载内容主要介绍了:NCP1081引脚功能NCP1081
    发表于 04-02 06:00
    TA8316AS内部框图与应用电路
    TA8316内部框图与应用电路
    发表于 03-06 19:20 8750次阅读
    TA8316AS<b class='flag-5'>内部</b><b class='flag-5'>框图</b>与应<b class='flag-5'>用电路</b>图
    IK2110的内部框图以及基本电路
    IK2110的内部框图以及基本电路
    发表于 07-20 14:37 923次阅读
    IK2110的<b class='flag-5'>内部</b><b class='flag-5'>框图</b><b class='flag-5'>以及</b>基本<b class='flag-5'>电路</b>图
    AD8452主要特性_框图以及用电路
    本文介绍了AD8452主要特性,框图,应用电路,评估板AD8452-EVALZ主要特性,
    的头像 发表于 05-11 10:33 7720次阅读
    AD8452<b class='flag-5'>主要</b><b class='flag-5'>特性</b>_<b class='flag-5'>框图</b><b class='flag-5'>以及</b>应<b class='flag-5'>用电路</b>
    ISO224主要特性以及用电路
    本文介绍了ISO224主要特性框图,应用电路以及评估模块ISO224EVM主要
    的头像 发表于 04-05 17:41 1.1w次阅读
    ISO224<b class='flag-5'>主要</b><b class='flag-5'>特性</b><b class='flag-5'>以及</b>应<b class='flag-5'>用电路</b>
    MAX40056主要特性以及用电路
    本文介绍了MAX40056主要优势和特性框图,应用电路以及评估板MAX40056 EVK主要
    发表于 04-05 11:25 5727次阅读
    MAX40056<b class='flag-5'>主要</b><b class='flag-5'>特性</b><b class='flag-5'>以及</b>应<b class='flag-5'>用电路</b>
    MAX28200优势特性以及基本应用电路
    本文介绍了MAX28200优势和主要特性,应用框图和基本应用电路以及评估板MAX28200 EVK主要
    发表于 04-05 16:05 1640次阅读
    MAX28200优势<b class='flag-5'>特性</b><b class='flag-5'>以及</b>基本应<b class='flag-5'>用电路</b>
    MAX86150的优势特性以及典型应用电路
    本文介绍了MAX86150主要优势和特性,简化框图和功能框图,典型应用电路以及评估板MAX86
    发表于 04-05 22:11 5684次阅读
    MAX86150的优势<b class='flag-5'>特性</b><b class='flag-5'>以及</b>典型应<b class='flag-5'>用电路</b>图
    NCP51705 SiC MOSFET驱动器 低侧 单个6A高速
    电子发烧友网为你提供()NCP51705相关产品参数、数据手册,更有NCP51705的引脚图、接线图、封装手册、中文资料、英文资料,NCP51705真值表,NCP51705管脚等资料,
    发表于 04-18 21:45
    NCP1611控制器的主要特性及应用通用电路
    闭锁和过压保护,电压检测,软起动和过流限制,主要用在PC电源,需要PFC的所有离线电器电源。本文介绍了NCP1611主要特性,方框图,应用通
    的头像 发表于 03-11 15:57 5136次阅读
    <b class='flag-5'>NCP</b>1611控制器的<b class='flag-5'>主要</b><b class='flag-5'>特性</b>及应用通<b class='flag-5'>用电路</b>
