ST公司的ST8500是全可编动力线通信(PLC)调制解调器片上系统(SoC),采用标准ARM® 32-bit Cortex®-M4F全可编程核,可以运行任何的PLC协议如ITU G.9904(PRIME),ITU G.9903 (G3-PLC®),目标CENELEC EN50065, FCC和ARIB兼容的应用,集成了差分PLC模拟前端,包括具有自动增益控制和PGA和ADC,带发送预驱动器的DAC,数字发送电平控制,零交叉比较器和高达500kHz PLC信号带宽,最高工作频率高达200MHz,工作温度-40℃到+105℃,主要用在智能计量,智能电网和物联网(IoT),以及和CENELEC, FCC 与 ARIB兼容的应用设计。本文介绍了ST8500主要特性,框图和详细架构图以及评估板EVALKITST8500-1主要特性,框图,电路图,材料清单和PCB设计图。
The ST8500 is a fully programmable power line communication (PLC) modem System onChip (SoC), able to run any PLC protocol in the frequency band up to 500 kHz.
The device architecture has been designed to target CENELEC EN50065, FCC and ARIBcompliant applications supporting all major PLC protocol standards such as ITU G.9904(PRIME), ITU G.9903 (G3-PLC®) and many other possible PLC protocol specifications andevolutions.
ST8500主要特性:
Programmable power line communication(PLC) modem System on Chip
Integrated differential PLC analog front-end
– PGA with automatic gain control and ADC
– DAC with transmission pre-driver
– Digital transmission level control
– Zero crossing comparator
– Up to 500 kHz PLC signal bandwidth
High performance, fully programmable realtimeengine dedicated to PLC PHY and real -time MAC protocol management (400 MHzmax. frequency)
– Dedicated code and data SRAM memories
Standard ARM® 32-bit Cortex®-M4F fullyprogrammable core for protocol upper layersand peripherals management
– 200 MHz maximum frequency
– 256 kB of embedded SRAM for code anddata
– 96 kB of embedded SRAM for data
– 8 kB of embedded shared RAM
– Bootloader ROM memory
– One Time Programmable (OTP) memorywith dedicated areas available for securekeys and user information storage
– Serial wire and JTAG interfaces
– 24 multiplexed GPIOs
– 4 general purpose timers
– 1 flexible CRC calculation unit
– 2 USART, 1 UART, 3 SPI, 1 I2C
Cryptographic engine
– AES 128/192/256 engine
– True random number generator
– Pseudo random number generator
Clock management:
– 25 MHz external crystal for system clock
– Integrated 25 MHz oscillator (XOSC) withfrequency synthesizer (FS) andpre-scalerunits to generate internal clock signals
Power management
– 3.3 V external supply voltage for I/O andanalog
– 2.5 V internal linear regulator for analog
– 1.1 V external supply voltage for digital
– Normal, Slow, Doze and low power modes
Available in QFN56 package
-40℃ to +105℃ temperature range
ST8500应用:
Smart metering, smart grid and Internet ofThings applications
Suitable for application design compliant withCENELEC, FCC and ARIB regulations
图1.ST8500基本框图
The ST8500 architecture is composed of the following parts:
1. PLC front-end including digital front-end (DFE) and analog front-end (AFE)
2. Real-time engine: the digital core running the lower layers of the PLC protocol stackand implementing modulation, demodulation and advanced forward error corrections(FEC) algorithms
3. Protocol engine: the digital core running the upper layers of the PLC protocol stack andmanaging the interface with external microcontrollers.
4. Peripherals, crypto, debug section
5. Clock and reset section
6. Power management section
图1.ST8500详细架构图
评估板EVALKITST8500-1
The EVALKITST8500-1 is a platform which allows an easy way to evaluate the features andperformance of a power line communication (PLC) node based on the ST8500 modemsystem-on-chip and the STLD1 line driver.
This user manual explains the EVALKITST8500-1 hardware and software installation, anddetails the evaluation of the kits.
This user manual does not explain the functionalities of the various PLC protocols runningon the ST8500. Detailed information can be found in the protocol specific documentation,available within the software packages, separately delivered under the Software licenseagreement by contacting your local ST sales office.
图2.评估板EVALKITST8500-1-ST8500外形图
The box delivery contains
EVALKITST8500-1 platform, based on 3 hardware boards
– One ST8500 module (including the STLD1 line driver as a companion chip),supporting full PLC system based on ST8500 and STLD1
– One STM32 mother board, supporting host device and interfaces
– STEVAL-ISA175V1, wide-range input voltage, 9.4 W power supply board basedon VIPER26HD
USB cable to the evaluation kit to PC
AC power cord to connect the evaluation kit to AC mains supply
图3.评估板EVALKITST8500-1框图
图4.STM32控制板外形图
图5.STM32控制板概述图
图6.ST8500模块概述图
图7.STEVAL-ISA175V1外形图
图8.STEVAL-ISA175V1电路图(1)
图9.STEVAL-ISA175V1电路图(2)
图10.STEVAL-ISA175V1电路图(3)
图11.STEVAL-ISA175V1电路图(4)
图12.STEVAL-ISA175V1电路图(5)
STEVAL-ISA175V1材料清单:
图13.STEVAL-ISA175V1 PCB设计图(1)
图14.STEVAL-ISA175V1 PCB设计图(2)
图15.STEVAL-ISA175V1 PCB设计图(3)
图16.STEVAL-ISA175V1 PCB设计图(4)
详情请见:
https://www.st.com/content/st_com/en/products/interfaces-and-transceivers/power-line-transceivers/st8500.html?icmp=tt5812_gl_prom_oct2017
和https://www.st.com/content/ccc/resource/technical/document/user_manual/group0/
3a/dc/89/3e/4d/6d/46/d1/DM00467734/files/DM00467734.pdf/jcr:content/translations/en.DM00467734.pdf
st8500.pdf
驱动器
53文章
8311浏览量
147266 -
调制解调器
3文章
862浏览量
39054
通信和电信>xDSL 调制解调器/DSLAM
线缆调制解调器的原理是什么?
HART调制解调器DS8500资料推荐
调制解调器(MODEM)介绍
调制解调器(Modem),调制解调器(Modem)是什么意思
DS8500 HART调制解调器简介
![DS<b class='flag-5'>8500</b> HART<b class='flag-5'>调制解调器</b>简介](https://file.elecfans.com//web2/M00/95/F8/pYYBAGQC6DOAXNiiAAAU8g8A1Tw800.gif)
