高压增益稳定精密运算放大器
电子工程师 来源:xx 2019-05-01 17:06 次阅读
ADI公司ADHV4702-1是高压(220V)一增益稳定精密运算放大器,具有高输入阻抗和低输入偏压电流,低输入失调电压,低漂移和低噪音,对称工作电压±110 V,不对称单源工作电压220V,开环增益(AOL)170dB,共模抑制比(CMRR)160dB,最大事端失调电压(VOS) 2 μV/℃,输入噪音8 nV/√Hz ,主要用在高边电流检测,自动测试设备,高压驱动器,压电传感器以及数模转换器DAC)输出缓冲器。本文介绍了ADHV4702-1主要特性,功能框图以及评估板EVAL-ADHV4702-1CPZ主要特性,电路图和材料清单。
The ADHV4702-1 is a high voltage (220 V), unity-gain stable precision operational amplifier. The ADHV4702-1 offers high input impedance with low input bias current, low input offset voltage, low drift, and low noise for precision demanding applications. The next generation of proprietary semiconductor processes and innovative architecture from Analog Devices, Inc., enable this precision operational amplifier to operate from symmetrical dual supplies of ±110 V, asymmetrical dual supplies, or a single supply of 220 V.
For precision performance, the ADHV4702-1 has a 170 dB typical open-loop gain (AOL) and a 160 dB typical common-mode rejection ratio (CMRR), as shown in Figure 2. The ADHV4702-1 also has a 2 μV/℃ maximum input offset voltage (VOS) drift and an 8 nV/√Hz input voltage noise.
The exceptional dc precision of the ADHV4702-1 is complemented by excellent dynamic performance with a small signal bandwidth of 10 MHz and a slew rate of 74 V/μs. The ADHV4702-1 has an output current of 20 mA typical.
The ADHV4702-1 offers high voltage input common-mode swing as well as high voltage output swing, enabling precision high voltage use cases such as high-side current sensing. The ADHV4702-1 is also ideally suited for forcing a voltage in precision bias and control applications.
The ADHV4702-1 is available in a 12-lead, 7 mm × 7 mm lead frame chip scale package (LFCSP) with an exposed pad (EPAD) compliant to international electrotechnical commission (IEC) 61010-1 creepage and clearance standards. The copper EPAD provides a low thermal resistance path to improve heat dissipation and features high voltage isolation, allowing it to be safely connected to a 0 V ground plane regardless of VCC or VEE voltages. The ADHV4702-1 operates over the −40℃ to +85℃ industrial temperature range.
ADHV4702-1主要特性:
Wide range of operating voltages
Dual-supply: ±12 V to ±110 V
Asymmetrical supply operation: 24 V to 220 V
Wide input common-mode voltage range: 3 V from rails
High common-mode rejection ratio: 160 dB typical
High AOL: 170 dB typical
High slew rate
74 V/μs typical
24 V/μs typical with external input clamping diodes
Low input bias current: 2 pA maximum
Low input offset voltage: 1 mV maximum
Low input offset voltage drift: 2 μV/℃ maximum
Low input voltage noise: 8 nV/√Hz typical at 10 kHz
Wide small signal bandwidth: 10 MHz typical
Resistor adjustable quiescent current: 0.6 mA to 3 mA (VS = ±110 V)
Unity-gain stable
Thermal monitoring
Small footprint: 12-lead, 7 mm × 7 mm LFCSP compliant with IEC 61010-1 spacing
Shutdown mode
ADHV4702-1应用:
High-side current sensing
Automated test equipment
High voltage drivers
Piezotransducers
Digital-to-analog converter (DAC) output buffers
Light detecting and ranging (LiDAR), avalanche photodiode (APD), single photon avalanche diode (SPAD) biasing
[原创] ADI ADHV4702-124V至220V精密运算放大器解决方案
图1.ADHV4702-1功能框图
This user guide describes the EVAL-ADHV4702-1CPZ evalua-tion board, which helps users evaluate the ADHV4702-1 offered in a 7 mm × 7 mm, 12-lead lead frame chip scale package (LFCSP) with an exposed pad at the bottom. The evaluation board provides a platform for quick and easy evaluation of the ADHV4702-1. Figure 1 shows the top side of the evaluation board. Figure 2 shows the bottom side of the board with the large exposed copper area for attaching a heat sink to provide additional thermal management.
The evaluation board is a 6-layer board designed to minimize leakage currents with its guard ring feature. It accepts Subminia-ture Version A (SMA) and Subminiature Version B (SMB) edge mounted connectors on the inputs for easy connection to test equipment or other circuitry.
The ADHV4702-1 data sheet covers the specifications and details of the device operation and application circuit configurations and guidance. Full specifications of the ADHV4702-1 can be found in the ADHV4702-1 data sheet, available from Analog Devices, Inc., and must be consulted in conjunction with this user guide, especially when powering up the evaluation board for the first time.
For safety, the EVAL-ADHV4702-1CPZ evaluation board is covered top and bottom with acrylic plastic guards to reduce the risk of inadvertent contact with high voltage. Do not operate the board without these guards in place. If the guards must be removed to adjust jumpers or change component values, discon-nect the board from the power supply before removing guards, and replace the guards before powering up again. For full precautions when using this high voltage evaluation board, see the High Voltage Evaluation Board section.
评估板EVAL-ADHV4702-1CPZ主要特性:
Full featured evaluation board for the ADHV4702-1
Single-supply or dual-supply operation
On-board power management circuit generates high voltage
Edge mounted SMA and SMB connector provisions
Easy connection to test equipment and other circuits
Robust thermal management
评估板EVAL-ADHV4702-1CPZ包括:
图2.评估板EVAL-ADHV4702-1CPZ外形图(正面)
图3.评估板EVAL-ADHV4702-1CPZ外形图(背面)
图4.评估板EVAL-ADHV4702-1CPZ电路图(1)
图5.评估板EVAL-ADHV4702-1CPZ电路图(2)
评估板EVAL-ADHV4702-1CPZ材料清单:
详情请见:
https://www.analog.com/media/en/technical-documentation/data-sheets/ADHV4702-1.pdf
和https://www.analog.com/media/en/technical-documentation/user-guides/EVAL-ADHV4702-1CPZ-UG-1444.pdf
ADHV4702-1.pdf
  • 运算放大器
  • 缓冲器
    运算放大器的类型
    目前,市面上有大量通用的和精密运算放大器可供选择。精密运算放大器稳定性高,偏移电压低,偏置电流小。可以查阅Datesheet选择需要的
    发表于 03-10 11:10 2823次阅读
    <b class='flag-5'>运算放大器</b>的类型
    高压与工艺的追赶,高速运算放大器
    运算放大器虽然类型有很多种,通用型集成运算放大器、高速型集成运算放大器高压型集成运算放大器、功率型集成
    的头像 发表于 03-04 07:35 4534次阅读
    转向特定应用的运算放大器
    %包括芯片上精密电阻,提供固定增益,误差低至+/-0.35%一种精密运算放大器具有低失调电压和低失调过温漂移。精度通过采用自动调零技术来实现,这种技术中,次级
    发表于 10-22 08:57
    环路增益运算放大器电路有什么影响?
    运算放大器电路的等效负反馈模型环路增益运算放大器电路闭环参数的影响环路增益运算放大器电路稳定
    发表于 04-12 06:47
    零漂移精密运算放大器的相关资料推荐
    零漂移精密运算放大器是专为由于差分电压小而要求高输出精度的应用设计的专用运算放大器。它们不仅具有低输入失调电压,还具有高共模抑制比(CMRR)、高电源抑制比(PSRR)、高开环增益和在
    发表于 12-31 07:29
    如何使用运算放大器构建精密整流电路?
    使用的是转换率低的果冻豆 LM358 运算放大器。只需放置一个具有更高压摆率的运算放大器,您就可以解决这个问题。但请记住,这也会发生在电路的较高频率范围内。改进的精密整流电路上图显示了
    发表于 08-16 08:00
    数控增益运算放大器
    数控增益运算放大器
    发表于 03-20 11:09 781次阅读
    数控<b class='flag-5'>增益</b><b class='flag-5'>运算放大器</b>
    可变增益运算放大器
    可变增益运算放大器
    发表于 09-28 14:58 923次阅读
    可变<b class='flag-5'>增益</b><b class='flag-5'>运算放大器</b>
    高压大功率型运算放大器是什么意思
    高压大功率型运算放大器是什么意思 高压大功率型运算放大器的定义运算放大器的输出电压主要受供电电源的限制。在普通的
    发表于 03-09 16:18 3380次阅读
    稳定性101:判断运算放大器是否稳定的环路增益参数介绍
    ADI公司的Matt Duff介绍确定运算放大器电路是否稳定的关键术语环路增益
    的头像 发表于 07-05 06:14 5352次阅读
    AD8067: 高增益带宽产品、精密Fast FET™运算放大器
    发表于 03-21 11:12 0次下载
    AD8067:  高<b class='flag-5'>增益</b>带宽产品、<b class='flag-5'>精密</b>Fast FET™<b class='flag-5'>运算放大器</b>
    OPA333宽带单位增益稳定FET输入运算放大器模块设计资料
    发表于 10-26 14:38 0次下载
    运算放大器增益稳定
    分析运算放大器增益稳定
    发表于 10-24 11:27 12次下载
    电压反馈型运算放大器增益和宽带
    本文考察标定运算放大器增益和宽带的常用方法。需要指出的是,适用于电压反馈(VFB)型运算放大器
    的头像 发表于 11-01 15:09 3317次阅读
    电压反馈型<b class='flag-5'>运算放大器</b>的<b class='flag-5'>增益</b>和宽带
    RS8661/2/4系列高压精密低噪声运算放大器简介
    继RS8651/2/4系列高压精密低噪声运算放大器成功推向市场,润石科技再次成功量产RS8661/2/4系列高压精密低噪声
    的头像 发表于 08-26 17:25 399次阅读
    RS8661/2/4系列<b class='flag-5'>高压</b><b class='flag-5'>精密</b>低噪声<b class='flag-5'>运算放大器</b>简介
