PWD5F60高密度片上系统电源驱动解决方案
电子工程师 来源:陈翠 2019-04-05 11:16 次阅读
ST公司的PWD5F60是先进的电源片上系统,集成了栅极驱动器和双路半桥配置的四个N沟功率MOSFET,其RDS(ON)=1.38Ω,BVDSS=600V;驱动器工作电压10V-20V,负载电流高达1A,主要用在工业风扇和泵,烹饪罩和气体加热器,吹风机,工业驱动和工厂自动化以及电源单元。本文介绍了PWD5F60主要特性,框图和应用框图,以及评估板EVALPWD5F60主要特性和指标,电路图,材料清单和PCB设计图。
High density power driver - high voltage full bridge with integrated comparators
The PWD5F60 is an advanced power system-in package integrating gate drivers and four N-channel power MOSFETs in dual half-bridge configuration.
The PWD5F60 is an advanced power system-in-package integrating gate drivers and four N-channel power MOSFETs in a compact QFN package.
The integrated power MOSFETs have an RDS(ON) of 1.38 Ω and 600 V drain-source breakdown voltage. The embedded gate drivers feature two comparators that can be used for peak current control or overcurrent protection and integrate bootstrap diodes. This allows to effectively drive loads in a tiny space and to drastically reduce external components and bill of materials.
The EVALPWD5F60 demonstrates how to use the PWD5F60 to drive a single-phase load in full-bridge topology. This allows control of both the direction and the value of the current flowing into the load. Typical applications that can benefit from the high integration of the PWD5F60 are, for example, single-phase BLDC motors and fans.
The board has a very small footprint and an optimized layout thanks to the integrated features of the PWD5F60, and it can be simply run by applying the supply voltages and a direction signal.
The board allows easy selection and modification of the relevant external component values, enabling fast performance evaluation under different applicative conditions as well as fine tuning of final application components.
PWD5F60主要特性:
Power system-in-package integrating gate drivers and power MOSFETs featuring: RDS(ON) = 1.38 Ω
BVDSS = 600 V
2 embedded comparators
Very low area occupation, all active devices in SMT technology and no heatsink
Fast-decay or slow-decay on-board constant OFF-time peak current control
PWM voltage mode control with overcurrent protection possible via external logic signals
Driver supply voltage range: 10 V to 20 V
UVLO protection on low-side and high-side
3.3 V to 15 V compatible inputs with hysteresis and pull-down
Internal bootstrap diode
Bill of materials reduction
Very compact and simplified layout
Flexible, easy and fast design
RoHS compliant
Load current up to 1 A
PWD5F60应用:
• Industrial fans and pumps
• Cooking hoods and gas heaters
• Blowers
• Industrial drives and factory automation
• Power supply units
图1.PWD5F60框图
图2.PWD5F60通用应用框图
图3.PWD5F60电流模式马达控制框图
评估板EVALPWD5F60
The EVALPWD5F60 demonstrates how to usethe PWD5F60 to drive a single-phase load in fullbridgetopology. This allows control of both thedirection and the value of the current flowing intothe load. Typical applications that can benefitfrom the high integration of the PWD5F60 are, forexample, single-phase BLDC motors and fans.
The board has a very small footprint and anoptimized layout thanks to the integrated featuresof the PWD5F60, and it can be simply run byapplying the supply voltages and a directionsignal.
The board allows easy selection and modificationof the relevant external component values,enabling fast performance evaluation underdifferent applicative conditions as well as finetuning of final application components.
评估板EVALPWD5F60主要特性:
 Power system-in-package integrating gatedrivers and power MOSFETs featuring:
– RDS(ON) = 1.38 Ω
– BVDSS = 600 V
– 2 embedded comparators
 Very low area occupation, all active devices inSMT technology and no heatsink
 Fast-decay or slow-decay on-board constantOFF-time peak current control
 PWM voltage mode control with overcurrentprotection possible via external logic signals
 Driver supply voltage range: 10 V to 20 V
 UVLO protection on low-side and high-side
 3.3 V to 15 V compatible inputs with hysteresisand pull-down
 Internal bootstrap diode
 Bill of materials reduction
 Very compact and simplified layout
 Flexible, easy and fast design
 RoHS compliant
 Load current up to 1 A
评估板EVALPWD5F60主要指标:
图4.评估板EVALPWD5F60外形图
图5.评估板EVALPWD5F60电路图
评估板EVALPWD5F60材料清单:
图6.评估板EVALPWD5F60 PCB布局图(顶层)
图7.评估板EVALPWD5F60 PCB布局图(底层)
图8.评估板EVALPWD5F60 PCB元件布局图
  • 电源驱动
    器件高密度BGA封装设计
    面积比,是比较理想的封装方案。在相同面积,典型的BGA 封装互联数量是四方扁平(QFP) 封装的两倍。而且,BGA焊球要比QFP 引线强度高的多,可靠的封装能够承受更强的冲击。Altera 为高密度
    发表于 09-12 10:47
    数据中心高密度MPO/MTP布线系统解决方案
    高可靠性高性价比的布线解决方案。4, 转接模块和间接扇出光缆模块化的系统可以快速应用于高密度数据中心的基础建设,并且在转移、添加和改变中提高故障诊断和中心配置的能力。MPO/MTP转接模块盒可以使用户将
    发表于 01-18 15:31
    探讨高密度小间距LED屏工艺
    。暗线、亮线问题是现在高密度显示屏不容忽视的、需要急待攻克的难题。部分公司通过贴3m胶带、箱体细微调整螺母进行调整,以达到最佳效果。  8、系统卡选择:高密度显示屏明暗线及均匀性、色差是LED器件差异
    发表于 01-25 10:55
    浅析FPGA的60W~72W高密度电源
    FPGA 的 60W~72W 高密度电源的电气性能、热性能及布局设计之深入分析
    发表于 06-14 17:13
    高压高密度程控直流电源有哪些特点
    1000V100A30KW高压高密度程控直流电源支持60电源级联操作,具有高功率因数、高转换效率、高精确度、高稳定度、高可靠度、低纹波、低噪音、小体积(
    发表于 12-29 08:23
    DC/DC转换器的高密度印刷电路板(PCB)布局
    设计。为推出占位面积更小的解决方案电源系统设计人员现在正集中研究功率密度(一个功率转换器电路每单位面积或体积的输出功率)的问题。 高密度
    发表于 11-18 06:23
    德州仪器面向负载点设计推出创新高密度电源解决方案
    德州仪器面向负载点设计推出创新高密度电源解决方案 -- 完全集成的 600mA 解决方案尺寸仅 6.7 mm2,而高性能 6A、14.5V 集成转换器则实现了 800 W/in3的密
    发表于 11-06 15:56 647次阅读
    应用于高密度电源设计的GaN半导体材料
    GaN产品应用于可靠和高密度电源的设计
    的头像 发表于 08-16 00:55 3110次阅读
    PWD13F60 STMicroelectronics PWD13F60栅极驱动
    电子发烧友网为你提供ST(ti)PWD13F60相关产品参数、数据手册,更有PWD13F60的引脚图、接线图、封装手册、中文资料、英文资料,PWD13F60真值表,PWD13F60管脚
    发表于 10-30 14:06
    PWD5F60TR STMicroelectronics PWD5F60高密度功率驱动
    电子发烧友网为你提供ST(ti)PWD5F60TR相关产品参数、数据手册,更有PWD5F60TR的引脚图、接线图、封装手册、中文资料、英文资料,PWD5F60TR真值表,PWD5F60
    发表于 11-09 12:07
    AN2784_使用高密度STM32F10xxxFSMC外设驱动外部存储器
    发表于 11-21 08:11 0次下载
    AN2784_使用<b class='flag-5'>高密度</b>STM32<b class='flag-5'>F</b>10xxxFSMC外设<b class='flag-5'>驱动</b>外部存储器
    用于高密度和高效率电源设计的意法半导体WBG解决方案
    电子发烧友网站提供《用于高密度和高效率电源设计的意法半导体WBG解决方案.pdf》资料免费下载
    发表于 08-01 16:54 0次下载
    用于<b class='flag-5'>高密度</b>和高效率<b class='flag-5'>电源</b>设计的意法半导体WBG<b class='flag-5'>解决方案</b>
    面向5G射频功放推出的高密度异构集成SiP解决方案即将在国内大规模量产
    JSCJ长晶长电科技面向5G射频功放推出的高密度异构集成SiP解决方案即将在国内大规模量产
    的头像 发表于 11-01 15:20 656次阅读
    一种高密度、易于设计的通道间隔离模拟输入模块完整解决方案
    电子发烧友网站提供《一种高密度、易于设计的通道间隔离模拟输入模块完整解决方案.pdf》资料免费下载
    发表于 11-23 10:34 0次下载
    一种<b class='flag-5'>高密度</b>、易于设计的通道间隔离模拟输入模块完整<b class='flag-5'>解决方案</b>
    高密度互连印刷电路板:如何实现高密度互连 HDI
    的头像 发表于 12-05 16:42 750次阅读
    <b class='flag-5'>高密度</b>互连印刷电路板:如何实现<b class='flag-5'>高密度</b>互连 HDI
