TPS65987D应用电路以及200W USB-C PD参考设计
电子工程师 来源:网络整理 2019-04-05 22:19 次阅读
TI公司的TPS65987D是单独可用的集成了功率开关的USB Type-C供电(PD)控制器,和USB PD 3.0兼容,提供电缆插头和取向检测,根据电缆检测,采用USB PD协议和CC线进行通信,当电缆检测和USB PD协商完成, TPS65987D就能提供合适供电通路,配置交替模式来设定外部多路复用器。主要用在笔记本电脑,坞站系统,平板电脑和超级本电脑, DisplayPort与雷电接口系统。本文介绍了TPS65987D主要特性,功能框图,应用电路, 评估模块10-GEXPANSION-EVM主要特性,电路图,材料清单和PCB设计图以及200W USB-C PD参考设计TIDA-050012主要特性和指标,框图,材料清单和PCB设计图。
The TPS65987D is a stand-alone USB Type-C and Power Delivery (PD) controller providing cable plug and orientation detection for a single USB Type-C connector. Upon cable detection, the TPS65987D communicates on the CC wire using the USB PD protocol. When cable detection and USB PD negotiation are complete, the TPS65987D enables the appropriate power path and configures alternate mode settings for external multiplexers.
TPS65987D主要特性:
1• USB Power Delivery (PD) Controller
– USB PD 3.0 Compliant
– Fast Role Swap Support
– Physical Layer and Policy Engine
– Configurable at Boot and Host-Controlled
• USB Type-C Specification Compliant
– Cable Attach and Orientation Detection
– Default, 1.5 A, or 3 A Power Advertisement
– Up to 600-mA VConn Current
• Port Power Switch
– Two 5 V to 20 V, 5-A Bidirectional Switches to or from VBUS
– Up to 10-A Adjustable Current Limiting
– Ideal Diode Reverse Current Protection
– Undervoltage, and Overvoltage Protection
– Slew Rate Control
– 5-V, 600-mA VConn Source
• BC1.2 Support
– Advertisement as DCP and CDP
– Automatic DCP Modes Selection:
– Shorted Mode per BC1.2 and YD/T 1591-2009
– 2.7-V Divider 3 Mode
– 1.2-V Mode
– Data Contact Detect
– Primary and Secondary Detection
I2C Master Write Control for Alt Mode Muxes and Variable DCDCs
• Alternate Mode Support
– DisplayPort
– Thunderbolt™
• Power Management
– Power Supply from 3.3 V or VBUS Source
– 3.3-V LDO Output for Dead Battery Support
• 7-mm × 7-mm QFN Package
– 0.4-mm Pitch
– 56 Pin
TPS65987D应用:
• Notebook Computers
• Docking Systems
• Tablets and Ultrabooks
• DisplayPort, and Thunderbolt™ Systems
图1. TPS65987D功能框图
图2. TPS65987D简化电路图
图3.端口电源开关
图4.数字核框图
图5. TPS65987D应用案例电路图
图6. TPS65987D应用案例2电路图
图7. TPS65987D支持PD充电的USB和DisplayPort笔记本电路图
图8. TPS65987D支持PD充电的雷电数据线笔记本电路图
This is the user’s guide for the 10G-EXPANSION-EVM for use with the TPS65987EVM supporting the expansion board connector. The 10G-EXPANSION-EVM is not intended to be used alone and requires the TPS65987EVM for operation.
The 10G-EXPANSION-EVM adds to the capabilities of the TPS6598xEVM supporting the expansion board connector by allowing the user to evaluate the USB Type-C and power-delivery (PD) capabilities of the TPS6598x USB Type-C and PD devices from the power and data perspective.
The TPS6598x USB Type-C and PD controller provides cable plug and orientation detection at the USB Type-C connector. Upon cable detection, the TPS6598x device communicates on the CC wire using the USB PD protocol. When cable detection and USB PD negotiation are complete, the TPS6598x device enables the appropriate power path and configures alternate mode settings for internal and (optional) external multiplexers.
This user guide describes the TPS65987EVM and the capabilities of this EVM with the 10GEXPANSIONEVM.
图9. 评估模块10-GEXPANSION-EVM外形图
图10. 评估模块10-GEXPANSION-EVM源板和沉板框图
图11. 评估模块10-GEXPANSION-EVM沉板MUX电路图
图12. 评估模块10-GEXPANSION-EVM内PCB沉电路图
图13. 评估模块10-GEXPANSION-EVM源MUX电路图
图14. 评估模块10-GEXPANSION-EVM内PCB源电路图
评估模块10-GEXPANSION-EVM材料清单:
图15. 评估模块10-GEXPANSION-EVM PCB设计图:左:顶层综合;右:顶层焊接
图16. 评估模块10-GEXPANSION-EVM PCB设计图:左:顶层;右:GND面1
图17. 评估模块10-GEXPANSION-EVM PCB设计图:左:高速层;右:GND面2
图18. 评估模块10-GEXPANSION-EVM PCB设计图:左:电源层1;右:电源层2
图19. 评估模块10-GEXPANSION-EVM PCB设计图:左:GND面3;右:底层
图20. 评估模块10-GEXPANSION-EVM PCB设计图:左:底层焊接;右:底层综合
电源UDO源200W USB-C PD参考设计TIDA-050012
This USB Power Delivery (PD) reference design will allow users to implement system that require more than 100 W as a power source while also highlighting the industries lowest RDSon solution. The design can output all four of the standard USB Type-C PD source
voltages of 5 V, 9 V, 15 V, and 20 V. In standard Type-C PD operation, the design will output up to 20V/4A. When Texas Instruments Power DUO mode is enabled, the design will be able to output up to 20V/10A while simultaneously lowering the RDSon by a factor of two.
This Design highlights how to implement a high powered USB Type-C PD Source device. This design can be referenced for various different end equipments, from PC Docks, Notebook PC Charger, Industrial chargers, Wall outlets, and many others. Through the use of a Texas Instruments USB Power Duo Mode, the TPS65987D PD adapter will close both of it's load switches in parallel to double the current carrying capability and reduce the effective RDSon by a factor of two. The design also highlights a feature of the TPS65987D called App Config by allowing users to select their Type-C PD Output voltage through push button switches. Additionally, this design goes through steps on how to implement a high powered DC/DC converter to offer the standard Type-C PD source voltages. Finally, the design also contains a P-FET bypass power path to route the input supply directly to the PD controller allowing for very high efficiency in a 20 V contract. The design also supports BC1.2 charging modes through the D+/D- USB 2.0 signals.
参考设计TIDA-050012主要特性:
• High Power USB Type-C PD Source
• Barrel Jack to Type-C: 5-V, 9-V, 15-V, or 20-V Charging up to 4 A
• Up to 20-V at 10 A through Texas Instruments Power Duo Mode
• Integrated power paths in PD Controller
• User selectable output voltage
参考设计TIDA-050012应用:
• Notebooks and Laptops
• Personal Electronics
• Consumer AC/DC: USB Type-C AC/DC Notebook PC Power Adapters (60 W Minimum)
• Power Bank
• Notebook PC Power Adapters
图21. 参考设计TIDA-050012外形图
图22. 参考设计TIDA-050012框图
参考设计TIDA-050012主要指标:
参考设计TIDA-050012材料清单:
图23. 参考设计TIDA-050012 PCB设计图(1)
图24. 参考设计TIDA-050012 PCB设计图(2)
图25. 参考设计TIDA-050012 PCB设计图(3)
图26. 参考设计TIDA-050012 PCB设计图(4)
图27. 参考设计TIDA-050012 PCB设计图(5)
图28. 参考设计TIDA-050012 PCB设计图(6)
图29. 参考设计TIDA-050012 PCB设计图(7)
图30. 参考设计TIDA-050012 PCB设计图(8)
  • usb
    usb
    USB-C PD系统的保护挑战及集成解决方案
    USB Type-C(USB-C)电缆和连接器规范极大地简化了实现互连和为数码相机和超薄平板电脑等电子产品供电的方式(图1)。该规范支持高达15W
    发表于 08-31 09:55 808次阅读
    200W音频放大器电路--200W Audio Amplif
    200W音频放大器电路--200W Audio Amplifier
    发表于 12-26 12:59 1965次阅读
    <b class='flag-5'>200W</b>音频放大器<b class='flag-5'>电路</b>--<b class='flag-5'>200W</b> Audio Amplif
    200W功率的灯闪光电路,200W Lamp Flasher
    发表于 02-27 09:28 3209次阅读
    <b class='flag-5'>200W</b>功率的灯闪光<b class='flag-5'>电路</b>,<b class='flag-5'>200W</b> Lamp Flasher
    TPS65987D TPS65987D
    电子发烧友网为你提供TI(ti)TPS65987D相关产品参数、数据手册,更有TPS65987D的引脚图、接线图、封装手册、中文资料、英文资料,TPS65987D真值表,TPS65987D
    发表于 10-16 11:19
    <b class='flag-5'>TPS65987D</b> <b class='flag-5'>TPS65987D</b>
    TI TPS65987DUSB Type-CPD控制器解决方案
    TI公司的TPS65987D是单独使用的USB Type-CPD控制器,提供了电缆插头和定向检测,是全集成USB供电(
    发表于 04-17 16:43 5575次阅读
    TI <b class='flag-5'>TPS65987</b>DUSB Type-<b class='flag-5'>C</b>和<b class='flag-5'>PD</b>控制器解决方案
    开源硬件-TIDA-050014-Power DUO 灌电流 200W USB-C PD PCB layout 设计
    Power DUO 电流阱 200W USB-C PD 参考设计是一个完整的 USB PD 电流阱参考设计,支持用户选择自己的
    发表于 10-22 10:10 22次下载
    开源硬件-TIDA-050014-Power DUO 灌电流 <b class='flag-5'>200W</b> <b class='flag-5'>USB-C</b> <b class='flag-5'>PD</b>  PCB layout 设计
    适用于Thunderbolt 3器件且具有集成电源开关的USB Type-C® 和 USB PD控制器TPS65987DDJ数据表
    电子发烧友网站提供《适用于Thunderbolt 3器件且具有集成电源开关的USB Type-C® 和 USB PD控制器TPS65987D
    发表于 03-05 10:25 0次下载
    适用于Thunderbolt 3器件且具有集成电源开关的<b class='flag-5'>USB</b> Type-<b class='flag-5'>C</b>® 和 <b class='flag-5'>USB</b> <b class='flag-5'>PD</b>控制器<b class='flag-5'>TPS65987</b>DDJ数据表
    具有集成电源开关的USB Type-C® 和 USB PD控制器TPS65987DDK数据表
    电子发烧友网站提供《具有集成电源开关的USB Type-C® 和 USB PD控制器TPS65987DDK数据表.pdf》资料免费下载
    发表于 03-05 10:20 1次下载
    具有集成电源开关的<b class='flag-5'>USB</b> Type-<b class='flag-5'>C</b>® 和 <b class='flag-5'>USB</b> <b class='flag-5'>PD</b>控制器<b class='flag-5'>TPS65987</b>DDK数据表
    支持USB3和交替模式的USB Type-C® 和USB PD控制器TPS65987D数据表
    电子发烧友网站提供《支持USB3和交替模式的USB Type-C® 和USB PD控制器TPS65987
    发表于 03-05 10:37 0次下载
    支持<b class='flag-5'>USB</b>3和交替模式的<b class='flag-5'>USB</b> Type-<b class='flag-5'>C</b>® 和<b class='flag-5'>USB</b> <b class='flag-5'>PD</b>控制器<b class='flag-5'>TPS65987D</b>数据表
    TPS65987D GPIO事件
    电子发烧友网站提供《TPS65987D GPIO事件.pdf》资料免费下载
    发表于 09-23 11:09 0次下载
    <b class='flag-5'>TPS65987D</b> GPIO事件
    TPS65987DTPS55288的USB型电源
    电子发烧友网站提供《带TPS65987DTPS55288的USB型电源.pdf》资料免费下载
    发表于 09-25 11:01 0次下载
    带<b class='flag-5'>TPS65987D</b>和<b class='flag-5'>TPS</b>55288的<b class='flag-5'>USB</b>型电源
    使用TPS25810和PD1S514-1的24V容差USB-C端口
    电子发烧友网站提供《使用TPS25810和PD1S514-1的24V容差USB-C端口.pdf》资料免费下载
    发表于 09-25 09:56 0次下载
    使用<b class='flag-5'>TPS</b>25810和<b class='flag-5'>PD</b>1S514-1的24V容差<b class='flag-5'>USB-C</b>端口
    TPS65987DTPS65988 BC1.2实施指南
    电子发烧友网站提供《TPS65987DTPS65988 BC1.2实施指南.pdf》资料免费下载
    发表于 09-25 09:41 1次下载
    <b class='flag-5'>TPS65987D</b>和<b class='flag-5'>TPS</b>65988 BC1.2实施指南
    TPS65987DTPS65988用户交替模式
    电子发烧友网站提供《TPS65987DTPS65988用户交替模式.pdf》资料免费下载
    发表于 09-29 11:00 1次下载
    <b class='flag-5'>TPS65987D</b>和<b class='flag-5'>TPS</b>65988用户交替模式
    TPS65988和TPS65987D PD3.0快速角色互换
    电子发烧友网站提供《TPS65988和TPS65987D PD3.0快速角色互换.pdf》资料免费下载
    发表于 09-29 10:40 1次下载
    <b class='flag-5'>TPS</b>65988和<b class='flag-5'>TPS65987D</b> <b class='flag-5'>PD</b>3.0快速角色互换
