使用LED驱动器评估板优化改造照明设计
电子设计 2019-01-16 01:06 1109次阅读
Lighting designers would do well to make judicious use of readily available evaluation boards or modules, both as a foundation for their lighting projects and to help accelerate the design cycle. In some cases, use of datasheets alone may not be sufficient to prepare you for the design challenges ahead, particularly, for example, if they lack all the data required to select the best LED driver solution for powering lighting systems such as LED retrofit bulbs and down-lighting applications.
Some of the trials lighting designers face include implementing dimming capabilities, achieving high efficiency, and choosing the right design tradeoffs, while simultaneously trying to squeeze all of the electronics into a small space. These reference design kits or evaluation boards focus on making it easier to solve some of these tasks so engineers can quickly implement LED driver ICs into their designs.
We will look at several evaluation boards for LED retrofit bulb projects, including A19, PAR30/38, PAR20, GU10, and candelabra-style bulbs. A range of reference design kits and evaluation boards is available on the Digi-Key website from companies such as Maxim Integrated, Power Integrations, and Texas Instruments.
"LED lighting designs are really a balancing act," said Andrew Smith, product marketing manager at Power Integrations. "There are multiple different features and requirements in different geographical regions. If this is your first time trying to manage all of these competing variables, it is extremely daunting."
The role of a design evaluation board or reference design kit is to provide a design that is 75 percent completed, added Smith. "It makes it a lot easier to establish what you really need. You might have to modify a reference design, but you won't have to design it from scratch."
Smith noted that Power Integrations' reference design boards or kits offer a working, production-ready board. The idea is to give a designer something that looks like a real solution, which can be modified. The company's reference design kits include the board, schematics, Gerber files, complete bill of materials, blank boards to build a modified version of the circuit, and extra ICs to evaluate other devices in the same series, which typically provide a little more or less power. The included engineering test report also explains why specific trade-offs were made in the design.
"One of the challenges for LED drivers is that no two applications seem to have the same voltage, current, or form factor," said Smith. He added that “the other thing about reference designs is that they have to fit into very weird spaces so we spend a lot of time optimizing the layout to fit into the space required while not violating any of the design rules for good layout practice."
One of the key requirements for power supply design is to lay out the board properly, according to Smith. "If you're not familiar with how to lay out a power supply, it's a very difficult task."
Once you have decided to take advantage of the benefits provided by a reference design, a remaining challenge is choosing the right reference design for your application without having to do too many modifications. "The first retrofit bulbs were all isolated designs, but now we're seeing the market transition to non-isolated because it's lower cost and higher efficiency," said Smith.
As an example, Power Integrations offers a reference design kit for a basic bulb design that is a low cost and low component count solution. The RDK-131 reference design (Figure 1) board is a 3 W non-isolated constant current LED driver, using Power Integration's LinkSwitch-TN series (e.g., LNK306) for a small GU10 bulb socket. It uses a non-isolated buck converter configuration that enables the use of standard inductors, which reduces the cost of the design.
Figure 1: The Power Integrations RDK-131 reference design board using the LinkSwitch-TN LNK306DN fits into a GU10 bulb socket. (Courtesy of Power Integrations.)
In another example, Texas Instruments Inc. also focuses on applications that require a small form factor with minimal external components, targeting high-power LED retrofit bulbs including A19, PAR30/38, and GU10. TI offers evaluation boards for its TPS92310 constant-current driver with primary side sensing and power factor correction. The evaluation boards are available for a 120 V flyback LED driver and 230 V flyback LED driver.
The TPS92310 module (Figure 2) PCB measures 22 (L) x 55 (W) x 19 (H) mm. The module can operate with an AC line input from 90 to 132 VRMS or 180 to 264 VRMS. It can supply 350 mA current into a single string of LEDs, with typically six to seven LEDs in series. The evaluation board is designed to comply with industrial EMC and safety requirements. The user guide, datasheet and application notes will help engineers design a board for their specific application.
Figure 2: The TPS92310 EVM-8W evaluation module, using Texas Instruments' TPS92310 controller IC in a flyback configuration, is designed for A19, PAR30/38, and GU10 applications. (Courtesy of Texas Instruments.)
Another challenge is which of the four topologies – flyback, buck, tapped buck or buck-boost – does a designer select for the LED bulb? Said Smith: "The problem is which one do I pick for my application, and unfortunately the combination of input and output, power factor (PF) and total harmonic distortion (THD) all influence those choices. It's not straightforward."
Power Integrations' RDK-268 reference design kit (Figure 3), as an example, does a good job balancing power factor and THD. The 1.1 W power-factor-corrected LED driver (non-isolated) using the LinkSwitch-PL driver IC, for a non-dimming candelabra lamp replacement design, delivers high power factor (>0.85), low THD (<25%), and low-harmonic content.
Figure 3: The Power Integrations RDK-268 reference design for a 1.1 W power-factor-corrected LED power supply, using the LinkSwitch-PL LNK454DG, is designed to fit into a candelabra lamp base. (Courtesy of Power Integrations.)
"The other thing that is critical for retrofit bulbs in down lighting is the thorny subject of triac dimming, which is a very iterative process to fix because there are many different triacs, and many different dimming circuits," said Smith. "What we tend to do with our reference designs is to specify a list of triac dimmers that this particular circuit will work with."
For instance, the RDK-193 reference design kit from Power Integrations (Figure 4) is a design for a 7 W TRIAC dimmable PAR20 LED driver, using the LinkSwitch-PH LNK403EG. The isolated flyback design delivers high efficiency (greater or equal to 81 percent), and high power factor (>0.90). It is a low cost and low component-count design.
Figure 4: The Power Integrations RDK-193 reference design board for a 7 W PAR20 LED driver, using the LinkSwitch-PH LNK403EG, provides a range of protection features including auto-restart for open control loop and output short circuits, line overvoltage, output overvoltage, and hysteretic thermal shutdown. (Courtesy of Power Integrations)
For MR16 bulb applications, Maxim Integrated offers its MAX16820EVKIT+ evaluation kit for the MAX16840 LED driver with integrated MOSFET, which is compatible with most electronic transformers and cut-angle dimmers. The IC can be used in buck, boost, and buck-boost topologies.
Summary
LED lighting designers have a number of design tradeoffs to consider when selecting a LED driver for their retrofit bulb designs. Designers have to consider a number of specs including topology, temperature, THD, efficiency, power factor, input voltage range, surge ratings, type of heat sink, lifetime, and, of course, cost. All of these design criteria have an impact on the final design.
The good news is that many fundamental decisions are made right on the reference design or evaluation board, allowing the designer to concentrate on areas that are most important. A few examples include meeting a high thermal environment, or ensuring that the design will work over an extended voltage range.
    TPS92020 用于 LED 照明的谐振开关驱动器控制数据手册
    TPS92020 是一款高性能谐振开关 LED 驱动器控制。它专为更高功率的 LED 照明系统而设计。TPS92020 在 LLC 拓扑中
    的头像 发表于 03-28 11:33 131次阅读
    TPS92020 用于 <b class='flag-5'>LED</b> <b class='flag-5'>照明</b>的谐振开关<b class='flag-5'>驱动器</b>控制<b class='flag-5'>器</b>数据手册
    TPS92023 用于 LED 照明的谐振开关驱动器控制数据手册
    TPS92023 是一款高性能谐振开关 LED 驱动器控制。是的 设计用于更高功率的 LED 照明系统。TPS92023 在 LLC 拓扑
    的头像 发表于 03-26 11:11 128次阅读
    TPS92023 用于 <b class='flag-5'>LED</b> <b class='flag-5'>照明</b>的谐振开关<b class='flag-5'>驱动器</b>控制<b class='flag-5'>器</b>数据手册
    新品 | 频率和占空比可调的驱动电源用全桥变压驱动器评估
    新品频率和占空比可调的驱动电源用全桥变压驱动器评估设计工程师可使用该系列评估
    的头像 发表于 02-07 17:02 352次阅读
    新品 | 频率和占空比可调的<b class='flag-5'>驱动</b>电源用全桥变压<b class='flag-5'>器</b><b class='flag-5'>驱动器</b><b class='flag-5'>评估</b><b class='flag-5'>板</b>
    大电流降压LED驱动器评估模块
    电子发烧友网站提供《大电流降压LED驱动器评估模块.pdf》资料免费下载
    发表于 12-09 14:35 0次下载
    大电流降压<b class='flag-5'>LED</b><b class='flag-5'>驱动器</b><b class='flag-5'>评估</b>模块
    TPS54200EVM-818降压LED驱动器评估模块
    电子发烧友网站提供《TPS54200EVM-818降压LED驱动器评估模块.pdf》资料免费下载
    发表于 12-07 14:04 0次下载
    TPS54200EVM-818降压<b class='flag-5'>LED</b><b class='flag-5'>驱动器</b><b class='flag-5'>评估</b>模块
    TLC6984 48×16共阴极矩阵LED显示驱动器评估模块
    电子发烧友网站提供《TLC6984 48×16共阴极矩阵LED显示驱动器评估模块.pdf》资料免费下载
    发表于 12-03 15:27 0次下载
    TLC6984 48×16共阴极矩阵<b class='flag-5'>LED</b>显示<b class='flag-5'>驱动器</b><b class='flag-5'>评估</b>模块
    TPS92200EVM 30V、1.5A降压LED驱动器评估模块
    电子发烧友网站提供《TPS92200EVM 30V、1.5A降压LED驱动器评估模块.pdf》资料免费下载
    发表于 11-22 14:22 0次下载
    TPS92200EVM 30V、1.5A降压<b class='flag-5'>LED</b><b class='flag-5'>驱动器</b><b class='flag-5'>评估</b>模块
    LP5891 48x16共阴极矩阵LED显示驱动器评估模块
    电子发烧友网站提供《LP5891 48x16共阴极矩阵LED显示驱动器评估模块.pdf》资料免费下载
    发表于 11-15 15:49 1次下载
    LP5891 48x16共阴极矩阵<b class='flag-5'>LED</b>显示<b class='flag-5'>驱动器</b><b class='flag-5'>评估</b>模块
    LP5891-Q1 48×16共阴极矩阵LED显示驱动器评估模块
    电子发烧友网站提供《LP5891-Q1 48×16共阴极矩阵LED显示驱动器评估模块.pdf》资料免费下载
    发表于 11-13 14:29 1次下载
    LP5891-Q1 48×16共阴极矩阵<b class='flag-5'>LED</b>显示<b class='flag-5'>驱动器</b><b class='flag-5'>评估</b>模块
    LED驱动器常见故障解决
    LED驱动器LED照明系统中的关键组件,负责将电源电压转换为适合LED发光的电压和电流。LED
    的头像 发表于 10-14 17:39 4082次阅读
    采用初级侧调节的4.2W GU10 LED照明驱动器
    电子发烧友网站提供《采用初级侧调节的4.2W GU10 LED照明驱动器.pdf》资料免费下载
    发表于 10-10 11:01 0次下载
    采用初级侧调节的4.2W GU10 <b class='flag-5'>LED</b><b class='flag-5'>照明</b><b class='flag-5'>驱动器</b>
    如何选择RGB LED驱动器
    电子发烧友网站提供《如何选择RGB LED驱动器.pdf》资料免费下载
    发表于 09-25 14:29 1次下载
    如何选择RGB <b class='flag-5'>LED</b><b class='flag-5'>驱动器</b>
    ISL6745LEVAL2Z离线高亮度白光LED驱动器评估
    的SEPIC转换应用。它由驱动器LED 的独立组件组成,支持多达 21 个高亮度 LEDLED
    发表于 07-19 17:31 0次下载
    SPI控制的三桥半桥驱动器评估NCV7703CGEVB数据手册
    电子发烧友网站提供《SPI控制的三桥半桥驱动器评估NCV7703CGEVB数据手册.rar》资料免费下载
    发表于 04-18 16:44 0次下载
    SPI控制的三桥半桥<b class='flag-5'>驱动器</b><b class='flag-5'>评估</b><b class='flag-5'>板</b>NCV7703CGEVB数据手册
    8W智能LED驱动器NCL30186SMRTGEVB评估数据手册
    电子发烧友网站提供《8W智能LED驱动器NCL30186SMRTGEVB评估数据手册.rar》资料免费下载
    发表于 04-15 17:18 0次下载
    8W智能<b class='flag-5'>LED</b><b class='flag-5'>驱动器</b>NCL30186SMRTGEVB<b class='flag-5'>评估</b><b class='flag-5'>板</b>数据手册
