Maxim MAX77640/MAX77641超低功耗PMIC解决方案
电子工程师 来源:陈翠 2019-04-05 07:55 次阅读
Maxim公司的MAX77640/MAX77641是具有3输出SIMO,150mA LDO和加电顺序器的超低功耗PMIC,集成了3输出单电感多输出(SIMO)降压-升压稳压器,150mA LDO和三路电流驱动器,工作电压2.7V-5.5V,输出电压0.8V -5.25V可调,主要用在蓝牙耳机和耳塞,可穿戴如健美,健康和活动监视器,照相机,可穿戴照相机和物联网IoT)小型电器。本文介绍了MAX77640/MAX77641主要优势和特性,详细框图和简化应用电路,以及评估板MAX77640/MAX77641 EVK优势和特性,框图,电路图,材料清单和PCB设计图。
The MAX77640/MAX77641 are a low-IQ power solutionfor applications where size and efficiency are critical. Thedevice integrates a 3-output single-inductor multiple-output (SIMO) buck-boost regulator, a 150mA LDO, and a3-channel current-sink driver.The SIMO operates on an input between 2.7V and 5.5V.
The outputs are independently programmable between0.8V and 5.25V depending on ordering option. Each outputis a buck-boost with glitchless transition between buckand boost operation. The SIMO can support 》300mAloads (1.8VOUT, 3.7VIN)。
The 150mA LDO provides ripple rejection for noise-sensitiveapplications. The current sinks can be programmedto blink LEDs in custom patterns. The device integratesa power sequencer to control power-up/down order ofeach output. Default output voltages and sequence orderare factory-programmable. An I2C serial interface furtherconfigures the device.
The MAX77640/MAX77641 are available in a 30-bumpwafer-level package (WLP)。 Total solution size is 16mm2.For a similar product with a battery charger, refer to theMAX77650.
MAX77640/MAX77641主要优势和特性:
● Compact, High-Efficiency Power Solution
• 3-Output Single-Inductor Multiple-Output (SIMO)Buck-Boost Regulator
• 150mA LDO
• 3-Channel Current-Sink Driver
• Flexible Power Sequencing
• GPIO and Reset Output
● 3-Output SIMO Extends Battery Life
• 2.7V to 5.5V Input Voltage Range from Single CellLi-Ion
• 0.8V to 5.25V Output Voltage Range
• Supports 》300mA loads (1.8VOUT, 3.7VIN)
• Improves Overall System Efficiency while ReducingSize
• Maintains Regulation without Dropout unlikeTraditional Bucks
• Glitchless Buck-Boost Operation
● Low Quiescent Current
• 300nA Shutdown Current
• 5.6μA Operating Current (3 SIMO Channels andLDO On)
● Small Size
• 2.75mm x 2.15mm (0.7mm max heigh) WLP
• 30-Bump, 0.4mm Pitch, 6 x 5 Array
• 16mm2 Total Solution Size
MAX77640/MAX77641应用:
● Hearables: Bluetooth Headphones and Earbuds
● Wearables: Fitness, Health, and Activity Monitors
● Action Cameras, Wearable/Body Cameras
● Internet of Things (IoT) Gadgets
图1.MAX77640/MAX77641简化应用电路
图2.SIMO详细框图
图3.MAX77640/MAX77641应用电路图
The MAX77640/MAX77641 evaluation kit (EV kit) is a fully assembled and tested printed circuit board (PCB) that demonstrates the MAX77640/MAX77641. The EV kit allows for easy evaluation of the MAX77640/MAX77641 resources, including the SIMO, LDO, GPIO, current sinks, and I2C interface.
Windows®-based software provides a user-friendly graph­ical interface (GUI) as well as a detailed register-based interface to exercise the features of the MAX77640/ MAX77641.
评估板MAX77640/MAX77641 EVK优势和特性:
Easy to Use GUI Drives I2C Interface
Red/Green/Blue LED
Fully Assembled and Tested
Emulates System Loading On-Board Electronic Load for LDO and SIMO Buck Boost Outputs
Electronic Load has Steady-State, Transient, and Random Modes
Evaluates Both Push-Button and Slider-Switch On-Key Options
图4.评估板MAX77640/MAX77641 EVK外形图
图5.评估板MAX77640/MAX77641 EVK正面图
图6.评估板MAX77640/MAX77641 EVK背面图
图7.评估板MAX77640/MAX77641 EVK框图
图8.评估板MAX77640/MAX77641 EVK电路图(1)
图9.评估板MAX77640/MAX77641 EVK电路图(2)
图10.评估板MAX77640/MAX77641 EVK电路图(3)
图11.评估板MAX77640/MAX77641 EVK电路图(4)
评估板MAX77640/MAX77641 EVK材料清单:
图12.评估板MAX77640/MAX77641 EVK PCB设计图(1):顶层丝印
图13.评估板MAX77640/MAX77641 EVK PCB设计图(2):底层丝印
图14.评估板MAX77640/MAX77641 EVK PCB设计图(3):制造笔记
图15.评估板MAX77640/MAX77641 EVK PCB设计图(4):顶层布局
图16.评估板MAX77640/MAX77641 EVK PCB设计图(5):内层2
图17.评估板MAX77640/MAX77641 EVK PCB设计图(6):内层3
图18.评估板MAX77640/MAX77641 EVK PCB设计图(7):底层
  • Maxim
  • PMIC
    Maxim 40G传输解决方案有效降低功耗、提高数据吞吐率
    MAX3948直流耦合激光驱动器和DS4830光电微控制器。     Maxim的40G芯片组为数据中心提供高性价比、高能效方案  数据中心和数据通信网络在显著提升数据密度的同时,仍需维持原有的
    发表于 12-12 16:36
    小尺寸、超低功耗的智能穿戴定位解决方案
    解决方案也是必不可少的。本篇SKYLAB君将以小尺寸、超低功耗GPS模块SKG08A/SKG09A为切入点,详细介绍体积小、功耗低的智能穿戴定位解决方案。智能穿戴定位
    发表于 09-28 16:13
    75Msps超低功耗模拟前端MAX19700资料推荐
    75Msps超低功耗模拟前端MAX19700资料下载内容包括:MAX19700引脚功能MAX19700功能和特性MAX19700应用范围
    发表于 04-01 06:22
    10位45Msps超低功耗模拟前端MAX19707资料推荐
    10位45Msps超低功耗模拟前端MAX19707资料下载内容主要介绍了:MAX19707引脚功能MAX19707功能和特性MAX19707
    发表于 04-02 06:03
    超低功耗高度集成的模拟前端MAX5865电子资料
    概述:MAX5865超低功耗、高度集成的模拟前端适用于便携式通信设备,如手机、PDA、WLAN以及3G无线终端。MAX5865集成了双路8位接收ADC和双路10位发送DAC,以极低的功耗
    发表于 04-20 07:48
    MAXIMMAX31865温度检测器解决方案有什么特点?
    MAX31865的基本特性是什么MAXIMMAX31865温度检测器解决方案有什么特点?
    发表于 05-11 06:10
    MAX9972 四通道、超低功耗、300Mbps ATE驱动
    MAX9972 四通道、超低功耗、300Mbps ATE驱动器/比较器 概述 MAX9971/MAX9972为四通道、超低功耗、引脚电子
    发表于 12-19 12:20 1600次阅读
    <b class='flag-5'>MAX</b>9972 四通道、<b class='flag-5'>超低功耗</b>、300Mbps ATE驱动
    Maxim带EEPROM高度集成PMIC MAX17106
    Maxim带EEPROM高度集成PMIC MAX17106有效降低LCD成本 Maxim推出完全集成的PMIC (电源管理IC)
    发表于 01-16 23:02 1015次阅读
    MAX6006-MAX6009超低功耗SOT23电压基准
    MAX6006-MAX6009超低功耗并联基准是空间的关键和低功耗应用的理想选择。他们提供3引脚SOT23封装,保证最低工作电流
    发表于 11-02 09:57 4850次阅读
    <b class='flag-5'>MAX6006-MAX</b>6009<b class='flag-5'>超低功耗</b>SOT23电压基准
    Maxim超低功耗PMIC MAX77650/51加入贸泽分销阵营 同时提升可穿戴设备电池寿命与效率
    77650和MAX77651电源管理IC (PMIC)。此系列超低功耗超小型PMIC将稳压器、充电器与稳流器集成在一起,减少了设计小型锂离子电池供电产品时所需的外部元件数。
    发表于 08-21 11:26 1459次阅读
    超低功耗稳压器、监控器和PMIC
    超低功耗稳压器、监控器和PMIC
    发表于 05-25 13:32 9次下载
    <b class='flag-5'>超低功耗</b>稳压器、监控器和<b class='flag-5'>PMIC</b>
    使用超低功耗GPS解决方案延长电池寿命
    使用 Maxim超低功耗 GPS 解决方案,将您的车辆追踪器/资产追踪器/物联网设备的电池寿命延长 10 倍。
    的头像 发表于 12-30 09:40 2339次阅读
    使用<b class='flag-5'>超低功耗</b>GPS<b class='flag-5'>解决方案</b>延长电池寿命
    MAX77640AEWV+T - (Maxim Integrated) - PMIC - 电源管理 - 专用型
    电子发烧友网为你提供Maxim(Maxim)MAX77640AEWV+T相关产品参数、数据手册,更有MAX77640AEWV+T的引脚图、接线图、封装手册、中文资料、英文资料,
    发表于 09-01 18:35
    <b class='flag-5'>MAX77640</b>AEWV+T - (<b class='flag-5'>Maxim</b> Integrated) - <b class='flag-5'>PMIC</b> - 电源管理 - 专用型
    MAX77640AEWV+ - (Maxim Integrated) - PMIC - 电源管理 - 专用型
    电子发烧友网为你提供Maxim(Maxim)MAX77640AEWV+相关产品参数、数据手册,更有MAX77640AEWV+的引脚图、接线图、封装手册、中文资料、英文资料,
    发表于 09-05 19:01
    <b class='flag-5'>MAX77640</b>AEWV+ - (<b class='flag-5'>Maxim</b> Integrated) - <b class='flag-5'>PMIC</b> - 电源管理 - 专用型
    MAX77641AEWV+ - (Maxim Integrated) - PMIC - 电源管理 - 专用型
    电子发烧友网为你提供Maxim(Maxim)MAX77641AEWV+相关产品参数、数据手册,更有MAX77641AEWV+的引脚图、接线图、封装手册、中文资料、英文资料,
    发表于 09-05 19:01
    <b class='flag-5'>MAX77641</b>AEWV+ - (<b class='flag-5'>Maxim</b> Integrated) - <b class='flag-5'>PMIC</b> - 电源管理 - 专用型
