ST STM8AF5288 8位MCU汽车应用开发方案
电子工程师 来源:陈翠 2019-04-05 09:26 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
ST公司的STM8AF526x/8x/Ax和STM8AF6269/8x/Ax系列是汽车应用的8位MCU,提供32KB到128KB的非易失存储器和集成了真数据EEPROM.器件的CPU工作频率24MHz,20MIPS,有强劲的I/O,单独的看门狗(独立时钟源)和时钟安全系统,具有降低系统成本,提高性能和鲁棒性,缩短开发周期和延长产品寿命。本文介绍了STM8AF526x/8x/Ax和STM8AF6269/8x/Ax框图,主要特性,以及评估板STM8A-DISCOVERY包括STM8AF和STM8AL共板主要特性,STM8AF专用板主要特性,STM8AL专用板主要特性以及和硬件框图,电路图,材料清单和PCB设计图。
This datasheet refers to the STM8AF526x/8x/Ax and STM8AF6269/8x/Ax products with 32to 128 Kbyte of program memory.
The STM8AF526x/8x/Ax and STM8AF6269/8x/Ax automotive 8-bit microcontrollersdescribed in this datasheet offer from 32 Kbyte to 128 Kbyte of non volatile memory andintegrated true data EEPROM. They are referred to as high density STM8A devices inSTM8S series and STM8AF series 8-bit microcontrollers reference manual (RM0016)。The STM8AF52 series features a CAN interface.
All devices of the STM8A product line provide the following benefits: reduced system cost,performance and robustness, short development cycles, and product longevity.
The system cost is reduced thanks to an integrated true data EEPROM for up to 300 kwrite/erase cycles and a high system integration level with internal clock oscillators,wtachdog, and brown-out reset.
Device performance is ensured by 20 MIPS at 24 MHz CPU clock frequency and enhancedcharacteristics which include robust I/O, independent watchdogs (with a separate clocksource), and a clock security system.
Short development cycles are guaranteed due to application scalability across a commonfamily product architecture with compatible pinout, memory map, and modular peripherals.
Full documentation is offered with a wide choice of development tools.Product longevity is ensured in the STM8A family thanks to their advanced core which ismade in a state-of-the art technology for automotive applications with 3.3 V to 5.5 Voperating supply.
All STM8A and ST7 microcontrollers are supported by the same tools includingSTVD/STVP development environment, the STice emulator and a low-cost, third party incircuitdebugging tool.
STM8AF5288主要特性:
• AEC-Q10x qualified
• Core
– Max fCPU: 24 MHz
– Advanced STM8A core with Harvardarchitecture and 3-stage pipeline
– Average 1.6 cycles/instruction resulting in10 MIPS at 16 MHz fCPU for industry standard benchmark
• Memories
– Program memory: 32 to 128 Kbyte Flashprogram; data retention 20 years at 55℃
– Data memory: up to 2 Kbyte true dataEEPROM; endurance 300 kcycle
– RAM: 6 Kbyte
• Clock management
– Low-power crystal resonator oscillator withexternal clock input
– Internal, user-trimmable 16 MHz RC andlow-power 128 kHz RC oscillators
– Clock security system with clock monitor
• Reset and supply management
– Wait/auto-wakeup/Halt low-power modeswith user definable clock gating
– Low consumption power-on and powerdownreset
• Interrupt management
– Nested interrupt controller with 32 vectors
– Up to 37 external interrupts on 5 vectors
• Timers
– 2 general purpose 16-bit timers with up to 3CAPCOM channels each (IC, OC, PWM)
– Advanced control timer: 16-bit, 4 CAPCOMchannels, 3 complementary outputs, deadtimeinsertion and flexible synchronization
– 8-bit AR basic timer with 8-bit prescaler
– Auto-wakeup timer
– Window and independent watchdog timers
• I/Os
– Up to 68 user pins (11 high sink I/Os)
– Highly robust I/O design, immune againstcurrent injection
• Communication interfaces
– High speed 1 Mbit/s CAN 2.0B interface
– USART with clock output for synchronousoperation - LIN master mode
– LINUART LIN 2.2 compliant, master/slavemodes with automatic resynchronization
– SPI interface up to 10 Mbit/s or fMASTER/2
I2C interface up to 400 Kbit/s
Analog to digital converter (ADC
– 10-bit resolution, 2 LSB TUE, 1 LSBlinearity and up to 16 multiplexed channels
• Operating temperature up to 150 °C
• Qualification conforms to AEC-Q100 grade 0
图1.STM8AF526x/8x/Ax和STM8AF6269/8x/Ax框图
评估板STM8A-DISCOVERY
The STM8A-DISCOVERY helps you discover the STM8AF and STM8AL automotivemicrocontroller family features and develop your applications through two dedicatedapplication boards that can be connected together via a LIN network.
The STM8AF board can perform both CAN and LIN communications with the MCU poweredat 5 V and is ready to be connected into a network with its integrated transceiver.
The STM8AL board manages LIN slave communication through its transceiver and uses a4-digit alphanumeric LCD display with the MCU powered at 3.3 V, offering low energypowermodes.
Both STM8AF and STM8AL boards include push buttons, LEDs, external connectors andallow various configurations to take advantage of the numerous capabilities of themicrocontrollers.
图2.评估板STM8A-DISCOVERY(STM8F+STM8AL) 外形图
STM8AF和STM8AL共板主要特性:
● On-board ST-LINK/V2 included for debugging and programming
● Board power supply: through 5 V USB bus
● Internal dual ST662A step-up converter building the 12 Vdc when powered by USBport
● External application power supply VBAT (up to 14 Vdc)
● 16 MHz HSE XTAL crystal oscillator
● L99PM62GXP power management IC with LIN and high speed CAN with SPI controlinterface and high-side drivers
● Two push buttons (USER1 and USER2)
● Extension header for L99PM62GXP including relays, high-side outputs and wake-upCapabilities
STM8AF专用板主要特性:
● STM8AF5288T microcontroller featuring 64 Kbytes Flash, 2 Kbytes data EEPROM,LIN, CAN in an 48-pin package
● Seven LEDs:
– LD1 (red/green) for USB communication
– LD2 (red) for 5 V power ON
– Five user LEDs LD3 (red) and LD4 to LD7 (green)
● RV1 potentiometer connected to the ADC peripheral
● Extension headers for MCU connectivity (full Port B, free ports pins, RESET)
STM8AL专用板主要特性:
● STM8AL3L68T microcontroller featuring 32 Kbytes Flash, 1 Kbytes data EEPROM,LCD in an 48-pin package
● Four LEDs:
– LD2 (red) for 3.3 V power ON
– 2 user LEDs LD3 (red) and LD4 (green)
● 4-digit alphanumeric LCD display including 4 bars display
● Extension header for MCU connectivity (free ports pins, RESET)
图3.STM8F板硬件框图
图4.STM8AF板正面布局图
图5.STM8AF板背面布局图
图6.STM8AL板硬件框图
图7.STM8AL板正面布局图
图8.STM8AL板背面布局图
图9.STM8AF板电路图(1)
图10.STM8AF板电路图(2):ST-LINK/V2(仅仅SWIM)
图11.STM8AF板电路图(3):MCU
图12.STM8AF板电路图(4):CAN/LIN和12V
图13.STM8AL板电路图(1)
图14.STM8AL板电路图(2):ST-LINK/V2(仅仅SWIM)
图15.STM8AL板电路图(3):MCU
图16.STM8AL板电路图(3):LCD
图17.STM8AL板电路图(4):IDD测量
图17.STM8AL板电路图(4):LIN和12V
STM8AF板和STM8AL板材料清单见:
MB1036-BOM和MB1037-BOM
详情请见:
https://www.st.com/content/ccc/resource/technical/document/user_manual/a2/95/53/05/e2/aa/43/b1
/DM00064161.pdf/files/DM00064161.pdf/jcr:content/translations/en.DM00064161.pdf
stm8af5268.pdf
en.DM00064161.pdf
stm8a-discovery.pdf
en.stm8a-discovery_bom.zip
en.stm8a-discovery_sch.zip
  • mcu
    mcu
  • STM8AF5288
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    stm8AF5288休眠唤醒后,只有can通讯无法恢复,为什么?
    stm8AF5288休眠唤醒后,只有can通讯无法恢复(AD与TIM正常工作)。
    发表于 04-07 06:25
    STM8AF如何读取ADC的参考电压?
    网上讲ADC有参考电压是1.2V,因为是内部参考没有引用,我查STM8AF5288最高0:9共10个通道,试了一下读10与11出来的值都不对比较大应该不对。不知道如何读出1.2V电压的ADC值用作参考电压。
    发表于 05-09 06:17
    STM8AF5288T不带ADC1吗?
    S208) || defined(STM8S207) || defined (STM8S007) || defined (STM8AF52Ax) || defined (STM8AF6
    发表于 05-10 08:30
    STM8AF5288 LIN相关问题
    本帖最后由 _近旁的一株木棉_ 于 2017-7-3 15:50 编辑 小弟初次使用STM8AF5288,串口硬件配置有1组USART和1组LINUART,但是我需要2组LIN。请问
    发表于 07-03 15:47
    使用STVD开发STM8AF5288调试失败
    我正在尝试使用STVD开发STM8AF5288,但调试尝试失败:错误:游泳编程错误[42004]:内存写入错误在STVP中,我无法选择STM8AF5288,但它选择了STM8AF52
    发表于 02-28 16:24
    基于STM8L15xxx设计的超低功耗8MCU开发方案
    发表于 05-17 11:56 4602次阅读
    基于STM<b class='flag-5'>8</b>L15xxx设计的超低功耗<b class='flag-5'>8</b><b class='flag-5'>位</b><b class='flag-5'>MCU</b><b class='flag-5'>开发</b><b class='flag-5'>方案</b>
    ST STM8AF5286汽车8微控制器的开发方案
    STM8AF526x/8x/Ax和STM8AF6269/8x/Ax汽车8
    发表于 04-27 05:11 5641次阅读
    <b class='flag-5'>ST</b> STM<b class='flag-5'>8AF</b>5286<b class='flag-5'>汽车</b><b class='flag-5'>8</b><b class='flag-5'>位</b>微控制器的<b class='flag-5'>开发</b><b class='flag-5'>方案</b>
    ST公司的STM8AF5286主要特性及框图
    ST公司的STM8AF5286是用于汽车8MCU,配置了多达128KB闪存,数据EEPROM
    发表于 05-03 09:49 6198次阅读
    <b class='flag-5'>ST</b>公司的STM<b class='flag-5'>8AF</b>5286主要特性及框图
    昂科烧录器支持ST意法半导体的汽车8微控制器STM8AF52A8T
    芯片烧录领导者昂科技术近期宣布了其烧录软件的最新迭代,并公布了一系列新增兼容芯片型号。在此次更新中,意法半导体(ST)推出的汽车8微控制器STM
    的头像 发表于 03-07 15:16 1322次阅读
    昂科烧录器支持<b class='flag-5'>ST</b>意法半导体的<b class='flag-5'>汽车</b>级<b class='flag-5'>8</b><b class='flag-5'>位</b>微控制器STM<b class='flag-5'>8AF52A8</b>T
    ST72260Gx/ST72262Gx/ST72264Gx:8MCU的卓越之选
    ST72260Gx/ST72262Gx/ST72264Gx:8MCU的卓越之选 在电子设计领域
    的头像 发表于 04-16 12:40 365次阅读
    ST72321Bxxx-Auto:汽车8MCU的全方位解析
    ST72321Bxxx-Auto:汽车8MCU的全方位解析 在汽车电子领域,微控制器(
    的头像 发表于 04-16 12:55 218次阅读
    深入剖析ST72321B系列8MCU:特性、应用与开发指南
    深入剖析ST72321B系列8MCU:特性、应用与开发指南 在电子工程师的日常工作中,选择合适的微控制器(
    的头像 发表于 04-16 12:55 257次阅读
    ST72324B-Auto:汽车8MCU的全方位解析
    ST72324B-Auto:汽车8MCU的全方位解析 在汽车电子领域,微控制器(
    的头像 发表于 04-16 13:00 185次阅读
    ST6252C、ST6262B、ST6262C 8MCU技术解析
    ST6252C、ST6262B、ST6262C 8MCU技术解析 在电子设计领域,微控制器(
    的头像 发表于 04-16 14:40 250次阅读
    ST7L34/35/38/39:汽车8MCU的卓越之选
    ST7L34/35/38/39:汽车8MCU的卓越之选 在汽车电子领域,对微控制器(
    的头像 发表于 04-16 15:40 224次阅读
