ADI ADP1031三路隔离微功耗管理解决方案
电子工程师 来源:陈翠 2019-04-05 15:00 次阅读
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
ADI公司的ADP1031是具有七个数字隔离器的三路隔离微功耗管理(PMU)单元,包括隔离的反激DC/DC稳压器,反相的DC/DC稳压器和降压DC/DC稳压器。此外,还包括四个高速SPI隔离通路和三个通用的隔离器。输入电压从4.5V到60V,产生隔离VOUT1输出电压6V-28V(可调整版)或21V-24V(固定版),VOUT2为工厂可编程电压+5.15V,+5.0V或+3.3V,VOUT3为可调整输出电压-24V到-5V,主要用在工业自动化和过程控制,仪器和数据采集系统以及其数据和电源隔离。本文介绍了ADP1031主要特性, 简化框图, 应用电路图以及评估板ADP1031CP-EVALZ主要特性,电路图,材料清单和PCB设计图。
Three-Channel, Isolated Micropower Management Unit with Seven Digital IsolatorsThe ADP1031 is a high performance, isolated micropower management unit (PMU) that combines an isolated flyback dc-to-dc regulator, an inverting dc-to-dc regulator, and a buck dc-to-dc regulator, providing three isolated power rails. Additionally, the ADP1031 contains four, high speed, serial peripheral interface (SPI) isolation channels and three general- purpose isolators for channel to channel applications where low power dissipation and small solution size is required.
Operating over an input voltage range of +4.5 V to +60 V, the ADP1031 generates isolated output voltages of +6 V to +28 V (adjustable version) or+ 21 V and +24 V (fixed versions) for VOUT1, factory programmable voltages of +5.15 V, +5.0 V, or +3.3 V for VOUT2, and an adjustable output voltages of −24 V to −5 V for VOUT3. By default, the ADP1031 flyback regulator operates at a 250 kHz switching frequency and the buck and inverting regulators operate at 125 kHz. All three regulators are phase shifted relative to each other to reduce electromagnetic interference (EMI)。 The ADP1031 can be driven by an external oscillator in the range of 350 kHz to 750 kHz to ease noise filtering in sensitive applications. The digital isolators integrated in the ADP1031 use Analog Devices,Inc., iCoupler® chip scale transformer technology, optimized for low power and low radiated emissions. The ADP1031 is available in a 9 mm×7 mm, 41-lead LFCSP and is rated for a −40℃ to +125℃ operating junction temperature range.
ADP1031主要特性:
Wide input supply voltage range: 4.5 V to 60 V
Integrated flyback power switch
Generates isolated, independent bipolar outputs and factory programmable buck output
VOUT1: 21 V, 24 V or 6 V to 28 V
VOUT2: 5.15 V, 5.0 V, or 3.3 V
VOUT3: −24 V to −5 V
Uses a 1:1 ratio transformer for simplified transformer design
Peak current limiting and OVP for flyback, buck, and inverting regulators
Precision enable input and power-good output
Adjustable switching frequency via SYNC input Internal compensation and soft start control per regulator High speed, low propagation delay, SPI signal isolation channels
Three, 100 kbps general-purpose isolated data channels 9 mm × 7 mm LFCSP form factor enables small overall solution size
Conforms to CISPR11 Class B radiated emission limits
Safety and regulatory approvals (pending)
UL recognition: 2500 V rms for 1 minute per UL 1577
CSA Component Acceptance Notice 5A
300 V rms basic insulation between slave, master, and field power domains (IEC 61010-1, pending)
VDE certificate of conformity
DIN V VDE 0884-10 (VDE 0884-10):2006-12
VIORM = 565 VPEAK
ADP1031应用:
Industrial automation and process control
Instrumentation and data acquisition systems
Data and power isolation
图1.ADP1031简化框图
图2.采用AD5758的ADP1031应用电路图
评估板ADP1031CP-EVALZ
The ADP1031CP-EVALZ is a fully featured evaluation board that demonstrates the functionality of the ADP1031 dc-to-dc converters and the isolated data channels.
Users can evaluate ADP1031 device measurements, such as line regulation, load regulation, and efficiency with the evaluation board. The board also assists in evaluating the functionality of the isolated digital channels. Device features including oscillator synchronization, soft start, power good monitoring, sequencing, and slew rate control can be demonstrated on the evaluation board.
Each board model in the evaluation kit has a different output configuration. Only one board model is included in the kit but users can order from five different board models to fit their application needs.
Refer to the ADP1031 data sheet for more details about the dc-to-dc converters and isolated data channels.
评估板ADP1031CP-EVALZ主要特性:
Input voltage range: 4.5 V to 60 V
Output voltage VOUT1: 24 V or 21 V
Output voltage VOUT2: 5.15 V
Output voltage VOUT3: −15 V
Enable and disable controls
Slew rate controls
Access to SYNC pin for oscillator synchronization
Access to all seven data channels
图3.评估板ADP1031CP-EVALZ外形图
图4.评估板ADP1031CP-EVALZ概略图
图5.评估板ADP1031CP-EVALZ电路图(1)
图6.评估板ADP1031CP-EVALZ电路图(2):连接器和外设
评估板ADP1031CP-EVALZ材料清单:
图7.评估板ADP1031CP-EVALZ PCB设计图(1):顶层
图8.评估板ADP1031CP-EVALZ PCB设计图(2):底层
图9.评估板ADP1031CP-EVALZ PCB设计图(3):顶层丝印
详情请见:
https://www.analog.com/media/en/technical-documentation/data-sheets/ADP1031.pdf
和https://www.analog.com/media/en/technical-documentation/user-guides/ADP1031CP-EVALZ-UG-1226.pdf
ADP1031.pdf
  • ADI
    ADI
  • PMU
    PMU
加入交流群
微信小助手二维码
扫码添加小助手
加入工程师交流群
    热点推荐
    能够设计出适合过程控制的高精度、高密度和隔离模拟输出模块的系统级方法
    ADP1031采用了ADI获得专利的i Coupler®技术,在7 mm × 9 mm大小的封装内集成3个隔离电源轨,以及SPI和GPIO数据隔离
    发表于 03-16 10:28 1413次阅读
    ADI可穿戴设备电源管理解决方案
    解决方案呢?看看ADI亚太区医疗行业市场经理王胜怎么说吧! 迎合电源管理功耗、小体积及低成本要求“可穿戴设备本身是很宽泛的概念覆盖各类产品形态,包括传统便携设备(如手表),也包括在非
    发表于 09-17 10:43
    用于多路抽头输出隔离电源的简易解决方案
    作为系统硬件设计工程师的您,是否还在为选择高性价比的多路电源输出的隔离方案而苦恼呢?比如说+15V, -15V, +5V的三路隔离电源输出, 在大多数情况下,凡是用到运放(AMP),模
    发表于 09-27 21:26
    【限时下载】ADI 用于多路抽头输出隔离电源的简易解决方案
    发表于 10-12 17:00
    基于ADP1032的功耗电源管理解决方案
    ADI公司的ADP1032是高性能双隔离功耗管理
    发表于 06-10 11:15 2011次阅读
    基于<b class='flag-5'>ADP</b>1032的<b class='flag-5'>微</b><b class='flag-5'>功耗</b>电源<b class='flag-5'>管理解决方案</b>
    三路数字电源控制器ADP1053的性能特点及应用
    ADI公司的ADP1053是三路数字电源控制器,基于电压模式PWM架构,能对三路单独输出提供控制,监视和保护,其他两带反馈控制,另一
    的头像 发表于 03-11 16:16 3732次阅读
    <b class='flag-5'>三路</b>数字电源控制器<b class='flag-5'>ADP</b>1053的性能特点及应用
    ADP1828三路输出电压
    ADP1828三路输出电压
    发表于 04-23 15:09 9次下载
    <b class='flag-5'>ADP</b>1828<b class='flag-5'>三路</b>输出电压
    LTC1326/LTC1326-2.5:功耗精密三路电源监控数据表
    发表于 05-19 16:19 0次下载
    LTC1326/LTC1326-2.5:<b class='flag-5'>微</b><b class='flag-5'>功耗</b>精密<b class='flag-5'>三路</b>电源监控数据表
    ADP1031:带七个数字隔离器的通道隔离功率管理单元数据表
    发表于 05-22 13:39 7次下载
    <b class='flag-5'>ADP1031</b>:带七个数字<b class='flag-5'>隔离</b>器的<b class='flag-5'>三</b>通道<b class='flag-5'>隔离</b><b class='flag-5'>微</b>功率<b class='flag-5'>管理</b>单元数据表
    ADP1031CP-EVALZ ADP1031CP-EVALZ评估板
    电子发烧友网为你提供ADI(ti)ADP1031CP-EVALZ相关产品参数、数据手册,更有ADP1031CP-EVALZ的引脚图、接线图、封装手册、中文资料、英文资料,ADP1031
    发表于 07-14 10:00
    ADI高性能电源管理解决方案
    电子发烧友网站提供《ADI高性能电源管理解决方案.pdf》资料免费下载
    发表于 11-15 11:04 498次下载
    ADP1031具有七个数字隔离器的通道隔离式微功耗管理单元技术手册
    ADP1031 是一款高性能隔离式微功耗管理单元 (PMU),它将隔离式反激直流/直流稳压器、反相直流/直流稳压器和降压直流/直流稳压器结合
    的头像 发表于 05-30 10:46 1166次阅读
    <b class='flag-5'>ADP1031</b>具有七个数字<b class='flag-5'>隔离</b>器的<b class='flag-5'>三</b>通道<b class='flag-5'>隔离</b>式微<b class='flag-5'>功耗</b><b class='flag-5'>管理</b>单元技术手册
    ADP5320:适用于多电池类型的可穿戴电源管理解决方案
    ADP5320:适用于多电池类型的可穿戴电源管理解决方案 在可穿戴设备和物联网应用蓬勃发展的今天,高效、紧凑且功能丰富的电源管理解决方案显得尤为重要。ADP5320作为一款高度集成的电
    的头像 发表于 02-05 09:15 363次阅读
    ADP5037:高性能电源管理解决方案
    ADP5037:高性能电源管理解决方案 在电子设备的设计中,电源管理是至关重要的一环。它直接影响着设备的性能、稳定性和续航能力。今天,我们就来深入了解一款功能强大的电源管理芯片——
    的头像 发表于 03-10 14:00 202次阅读
    ADP5051/ADP5053评估板:高性能电源管理解决方案
    ADP5051/ADP5053评估板:高性能电源管理解决方案 在电子设计领域,电源管理是至关重要的一环。今天,我们来深入了解一下Analog Devices推出的
    的头像 发表于 03-31 11:10 243次阅读
